root/radiance/ray/src/cv/mgflib/examp1.ies
Revision: 1.1
Committed: Fri Jul 22 10:35:24 1994 UTC (30 years, 10 months ago) by greg
1 IESNA94
2 SCCSid "$SunId$ LBL"
3 [TEST] 38705 ITL
4 [MANUFAC] LEDALITE ARCHITECTURAL PRODUCTS, LTD.
5 [LUMCAT] APEX TYPE #2
6 [LUMINAIRE] EXTRUDED ALUMINUM BODY, FABRICATED SPECULAR REFLECTOR WITH
7 [MORE] PARABOLIC CROSS LOUVERS, OPEN TOP.
8 [MORE] SUSPENDED/DIRECT/INDIRECT
9 [LAMP] TWO F032T8/41K, EACH RATED 2900 LUMENS.
10 [BALLAST] VALMONT 8G4126W
11 [OTHER] DATE: 11-14-1991
12 [MORE] TOTAL INPUT WATTS= 80.0 AT 120.0 VOLTS
13 [MORE] LUMEN TO CANDELA RATIO USED= 9.17
14 [MORE] THE 0 DEGREE PLANE IS PARALLEL WITH THE LAMPS.
15 GEOM=examp1.mgf
16 TILT=NONE
17 2 2900 1 73 5 1 1 0.85 4.1 0.3
18 1 1 80
19 0 2.5 5 7.5 10 12.5 15 17.5 20 22.5 25 27.5 30 32.5 35 37.5 40 42.5 45 47.5
20 50
21 52.5 55 57.5 60 62.5 65 67.5 70 72.5 75 77.5 80 82.5 85 87.5 90 92.5 95
22 97.5
23 100 102.5 105 107.5 110 112.5 115 117.5 120 122.5 125 127.5 130 132.5 135
24 137.5 140 142.5 145 147.5 150 152.5 155 157.5 160 162.5 165 167.5 170
25 172.5
26 175 177.5 180
27 0 22.5 45 67.5 90
28 829 833 830 826 817 806 791 777 755 732 710 684 658 628 585 530 452 364 277
29 191
30 115 65 30 11 5 4 4 4 4 2 1 2 2 2 2 2 2 11 28 50 74 100 129 154 184 219 251
31 283
32 315 349 380 410 442 471 501 521 547 572 596 619 640 660 678 691 706 716
33 728
34 734 739 744 746 748 741
35 829 831 833 836 838 837 834 831 824 817 811 803 792 772 739 690 617 536 437
36 320
37 230 139 75 32 9 4 4 4 3 2 1 3 2 2 2 2 9 71 166 223 260 286 308 321 339 363
38 388
39 412 438 463 488 513 536 561 582 600 621 638 659 673 689 701 713 721 731
40 736
41 741 742 746 746 744 746 741
42 829 835 847 863 879 897 916 930 944 959 972 975 969 944 896 826 736 639 533
43 411
44 297 199 120 65 24 9 6 5 4 2 2 3 3 2 2 2 12 72 165 302 428 483 522 539 559
45 579
46 598 610 616 621 632 644 655 666 678 688 702 716 731 744 755 763 769 770
47 771
48 770 766 763 759 754 747 744 741
49 829 832 849 877 906 940 973 1000 1027 1051 1069 1084 1083 1037 953 845 731
50 616
51 503 387 259 149 76 31 14 10 9 6 5 3 2 3 3 2 2 2 16 88 176 295 449 585 660
52 694
53 719 730 740 750 762 771 775 771 769 771 773 775 776 777 781 788 795 801
54 805
55 802 800 794 786 778 768 758 746 741 741
56 829 837 862 889 924 962 1003 1029 1059 1082 1108 1133 1111 1046 946 821 685
57 572
58 465 318 196 103 38 15 12 9 8 7 6 3 3 4 3 3 2 2 18 84 170 280 427 582 691
59 736
60 775 785 794 801 813 823 830 830 821 817 816 813 810 807 807 807 810 814
61 818
62 815 810 803 792 782 769 758 746 738 741
