root/radiance/ray/src/cv/mgflib/context.c
Revision: 1.28
Committed: Sun Jul 27 22:12:02 2003 UTC (20 years, 9 months ago) by schorsch
CVS Tags: rad3R7P1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad3R7P2
Changes since 1.27: +12 -12 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 1.28 static const char RCSid[] = "$Id: context.c,v 1.27 2003/02/28 20:11:29 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Context handlers
6     */
7
8     #include <stdio.h>
9 greg 1.2 #include <math.h>
10 gregl 1.26 #include <stdlib.h>
11 greg 1.1 #include <string.h>
12     #include "parser.h"
13     #include "lookup.h"
14
15     /* default context values */
16     static C_COLOR c_dfcolor = C_DEFCOLOR;
17     static C_MATERIAL c_dfmaterial = C_DEFMATERIAL;
18     static C_VERTEX c_dfvertex = C_DEFVERTEX;
19
20     /* the unnamed contexts */
21     static C_COLOR c_uncolor = C_DEFCOLOR;
22     static C_MATERIAL c_unmaterial = C_DEFMATERIAL;
23     static C_VERTEX c_unvertex = C_DEFVERTEX;
24
25     /* the current contexts */
26     C_COLOR *c_ccolor = &c_uncolor;
27 greg 1.12 char *c_ccname = NULL;
28 greg 1.1 C_MATERIAL *c_cmaterial = &c_unmaterial;
29 greg 1.12 char *c_cmname = NULL;
30 greg 1.1 C_VERTEX *c_cvertex = &c_unvertex;
31 greg 1.12 char *c_cvname = NULL;
32 greg 1.1
33 greg 1.3 static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */
34     static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */
35     static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */
36 greg 1.1
37 greg 1.19 /* CIE 1931 Standard Observer curves */
38 gregl 1.25 static C_COLOR cie_xf = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,
39 greg 1.19 {14,42,143,435,1344,2839,3483,3362,2908,1954,956,
40     320,49,93,633,1655,2904,4334,5945,7621,9163,10263,
41     10622,10026,8544,6424,4479,2835,1649,874,468,227,
42     114,58,29,14,7,3,2,1,0}, 106836L, .467, .368, 362.230
43     };
44 gregl 1.25 static C_COLOR cie_yf = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,
45 greg 1.19 {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,
46     5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,
47     5030,3810,2650,1750,1070,610,320,170,82,41,21,10,
48     5,2,1,1,0,0}, 106856L, .398, .542, 493.525
49     };
50 gregl 1.25 static C_COLOR cie_zf = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,
51 greg 1.19 {65,201,679,2074,6456,13856,17471,17721,16692,
52     12876,8130,4652,2720,1582,782,422,203,87,39,21,17,
53     11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
54     106770L, .147, .077, 54.363
55     };
56     /* Derived CIE 1931 Primaries (imaginary) */
57 gregl 1.25 static C_COLOR cie_xp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY,
58 greg 1.19 {-174,-198,-195,-197,-202,-213,-235,-272,-333,
59     -444,-688,-1232,-2393,-4497,-6876,-6758,-5256,
60     -3100,-815,1320,3200,4782,5998,6861,7408,7754,
61     7980,8120,8199,8240,8271,8292,8309,8283,8469,
62     8336,8336,8336,8336,8336,8336},
63     127424L, 1., .0,
64     };
65 gregl 1.25 static C_COLOR cie_yp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY,
66 greg 1.19 {-451,-431,-431,-430,-427,-417,-399,-366,-312,
67     -204,57,691,2142,4990,8810,9871,9122,7321,5145,
68     3023,1123,-473,-1704,-2572,-3127,-3474,-3704,
69     -3846,-3927,-3968,-3999,-4021,-4038,-4012,-4201,
70     -4066,-4066,-4066,-4066,-4066,-4066},
71     -23035L, .0, 1.,
72     };
73 gregl 1.25 static C_COLOR cie_zp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY,
74 greg 1.19 {4051,4054,4052,4053,4054,4056,4059,4064,4071,
75     4074,4056,3967,3677,2933,1492,313,-440,-795,
76     -904,-918,-898,-884,-869,-863,-855,-855,-851,
77     -848,-847,-846,-846,-846,-845,-846,-843,-845,
78     -845,-845,-845,-845,-845},
79     36057L, .0, .0,
80     };
81 greg 1.1
82 greg 1.5 static int setspectrum();
83 greg 1.18 static int setbbtemp();
84 greg 1.5 static void mixcolors();
85
86
87 greg 1.1 int
88     c_hcolor(ac, av) /* handle color entity */
89     int ac;
90     register char **av;
91     {
92 greg 1.5 double w, wsum;
93     register int i;
94 greg 1.1 register LUENT *lp;
95
96     switch (mg_entity(av[0])) {
97     case MG_E_COLOR: /* get/set color context */
98 greg 1.4 if (ac > 4)
99     return(MG_EARGC);
100 greg 1.1 if (ac == 1) { /* set unnamed color context */
101     c_uncolor = c_dfcolor;
102     c_ccolor = &c_uncolor;
103 greg 1.12 c_ccname = NULL;
104 greg 1.1 return(MG_OK);
105     }
106 greg 1.22 if (!isname(av[1]))
107     return(MG_EILL);
108 greg 1.1 lp = lu_find(&clr_tab, av[1]); /* lookup context */
109     if (lp == NULL)
110     return(MG_EMEM);
111 greg 1.14 c_ccname = lp->key;
112 greg 1.9 c_ccolor = (C_COLOR *)lp->data;
113 greg 1.1 if (ac == 2) { /* reestablish previous context */
114 greg 1.9 if (c_ccolor == NULL)
115 greg 1.1 return(MG_EUNDEF);
116     return(MG_OK);
117     }
118     if (av[2][0] != '=' || av[2][1])
119     return(MG_ETYPE);
120 greg 1.9 if (c_ccolor == NULL) { /* create new color context */
121 greg 1.1 lp->key = (char *)malloc(strlen(av[1])+1);
122     if (lp->key == NULL)
123     return(MG_EMEM);
124     strcpy(lp->key, av[1]);
125     lp->data = (char *)malloc(sizeof(C_COLOR));
126     if (lp->data == NULL)
127     return(MG_EMEM);
128 greg 1.14 c_ccname = lp->key;
129 greg 1.9 c_ccolor = (C_COLOR *)lp->data;
130     c_ccolor->clock = 0;
131 gregl 1.25 c_ccolor->client_data = NULL;
132 greg 1.1 }
133 greg 1.10 i = c_ccolor->clock;
134 greg 1.1 if (ac == 3) { /* use default template */
135     *c_ccolor = c_dfcolor;
136 greg 1.9 c_ccolor->clock = i + 1;
137 greg 1.1 return(MG_OK);
138     }
139     lp = lu_find(&clr_tab, av[3]); /* lookup template */
140     if (lp == NULL)
141     return(MG_EMEM);
142     if (lp->data == NULL)
143     return(MG_EUNDEF);
144     *c_ccolor = *(C_COLOR *)lp->data;
145 greg 1.9 c_ccolor->clock = i + 1;
146 greg 1.1 return(MG_OK);
147     case MG_E_CXY: /* assign CIE XY value */
148     if (ac != 3)
149     return(MG_EARGC);
150 greg 1.18 if (!isflt(av[1]) | !isflt(av[2]))
151 greg 1.1 return(MG_ETYPE);
152     c_ccolor->cx = atof(av[1]);
153     c_ccolor->cy = atof(av[2]);
154 greg 1.5 c_ccolor->flags = C_CDXY|C_CSXY;
155 schorsch 1.28 if ((c_ccolor->cx < 0.) | (c_ccolor->cy < 0.) |
156     (c_ccolor->cx + c_ccolor->cy > 1.))
157 greg 1.1 return(MG_EILL);
158 greg 1.8 c_ccolor->clock++;
159 greg 1.1 return(MG_OK);
160 greg 1.5 case MG_E_CSPEC: /* assign spectral values */
161     if (ac < 5)
162     return(MG_EARGC);
163 greg 1.18 if (!isflt(av[1]) | !isflt(av[2]))
164 greg 1.5 return(MG_ETYPE);
165 greg 1.17 return(setspectrum(c_ccolor, atof(av[1]), atof(av[2]),
166 greg 1.5 ac-3, av+3));
167 greg 1.18 case MG_E_CCT: /* assign black body spectrum */
168     if (ac != 2)
169     return(MG_EARGC);
170     if (!isflt(av[1]))
171     return(MG_ETYPE);
172     return(setbbtemp(c_ccolor, atof(av[1])));
173 greg 1.5 case MG_E_CMIX: /* mix colors */
174     if (ac < 5 || (ac-1)%2)
175     return(MG_EARGC);
176     if (!isflt(av[1]))
177     return(MG_ETYPE);
178     wsum = atof(av[1]);
179     if ((lp = lu_find(&clr_tab, av[2])) == NULL)
180     return(MG_EMEM);
181     if (lp->data == NULL)
182     return(MG_EUNDEF);
183     *c_ccolor = *(C_COLOR *)lp->data;
184     for (i = 3; i < ac; i += 2) {
185     if (!isflt(av[i]))
186     return(MG_ETYPE);
187     w = atof(av[i]);
188     if ((lp = lu_find(&clr_tab, av[i+1])) == NULL)
189     return(MG_EMEM);
190     if (lp->data == NULL)
191     return(MG_EUNDEF);
192     mixcolors(c_ccolor, wsum, c_ccolor,
193     w, (C_COLOR *)lp->data);
194     wsum += w;
195     }
196 greg 1.24 if (wsum <= 0.)
197     return(MG_EILL);
198 greg 1.10 c_ccolor->clock++;
199 greg 1.5 return(MG_OK);
200 greg 1.1 }
201     return(MG_EUNK);
202     }
203
204
205     int
206     c_hmaterial(ac, av) /* handle material entity */
207     int ac;
208     register char **av;
209     {
210 greg 1.9 int i;
211 greg 1.1 register LUENT *lp;
212
213     switch (mg_entity(av[0])) {
214     case MG_E_MATERIAL: /* get/set material context */
215 greg 1.4 if (ac > 4)
216     return(MG_EARGC);
217 greg 1.1 if (ac == 1) { /* set unnamed material context */
218     c_unmaterial = c_dfmaterial;
219     c_cmaterial = &c_unmaterial;
220 greg 1.12 c_cmname = NULL;
221 greg 1.1 return(MG_OK);
222     }
223 greg 1.22 if (!isname(av[1]))
224     return(MG_EILL);
225 greg 1.1 lp = lu_find(&mat_tab, av[1]); /* lookup context */
226     if (lp == NULL)
227     return(MG_EMEM);
228 greg 1.14 c_cmname = lp->key;
229 greg 1.9 c_cmaterial = (C_MATERIAL *)lp->data;
230 greg 1.1 if (ac == 2) { /* reestablish previous context */
231 greg 1.9 if (c_cmaterial == NULL)
232 greg 1.1 return(MG_EUNDEF);
233     return(MG_OK);
234     }
235     if (av[2][0] != '=' || av[2][1])
236     return(MG_ETYPE);
237 greg 1.9 if (c_cmaterial == NULL) { /* create new material */
238 greg 1.1 lp->key = (char *)malloc(strlen(av[1])+1);
239     if (lp->key == NULL)
240     return(MG_EMEM);
241     strcpy(lp->key, av[1]);
242     lp->data = (char *)malloc(sizeof(C_MATERIAL));
243     if (lp->data == NULL)
244     return(MG_EMEM);
245 greg 1.14 c_cmname = lp->key;
246 greg 1.9 c_cmaterial = (C_MATERIAL *)lp->data;
247     c_cmaterial->clock = 0;
248 gregl 1.25 c_cmaterial->client_data = NULL;
249 greg 1.1 }
250 greg 1.10 i = c_cmaterial->clock;
251 greg 1.1 if (ac == 3) { /* use default template */
252     *c_cmaterial = c_dfmaterial;
253 greg 1.9 c_cmaterial->clock = i + 1;
254 greg 1.1 return(MG_OK);
255     }
256     lp = lu_find(&mat_tab, av[3]); /* lookup template */
257     if (lp == NULL)
258     return(MG_EMEM);
259     if (lp->data == NULL)
260     return(MG_EUNDEF);
261     *c_cmaterial = *(C_MATERIAL *)lp->data;
262 greg 1.9 c_cmaterial->clock = i + 1;
263 greg 1.1 return(MG_OK);
264 greg 1.21 case MG_E_IR: /* set index of refraction */
265     if (ac != 3)
266     return(MG_EARGC);
267     if (!isflt(av[1]) | !isflt(av[2]))
268     return(MG_ETYPE);
269     c_cmaterial->nr = atof(av[1]);
270     c_cmaterial->ni = atof(av[2]);
271     if (c_cmaterial->nr <= FTINY)
272     return(MG_EILL);
273     c_cmaterial->clock++;
274     return(MG_OK);
275 greg 1.1 case MG_E_RD: /* set diffuse reflectance */
276     if (ac != 2)
277     return(MG_EARGC);
278     if (!isflt(av[1]))
279     return(MG_ETYPE);
280     c_cmaterial->rd = atof(av[1]);
281 schorsch 1.28 if ((c_cmaterial->rd < 0.) | (c_cmaterial->rd > 1.))
282 greg 1.1 return(MG_EILL);
283     c_cmaterial->rd_c = *c_ccolor;
284 greg 1.2 c_cmaterial->clock++;
285 greg 1.1 return(MG_OK);
286     case MG_E_ED: /* set diffuse emittance */
287     if (ac != 2)
288     return(MG_EARGC);
289     if (!isflt(av[1]))
290     return(MG_ETYPE);
291     c_cmaterial->ed = atof(av[1]);
292     if (c_cmaterial->ed < 0.)
293     return(MG_EILL);
294     c_cmaterial->ed_c = *c_ccolor;
295 greg 1.2 c_cmaterial->clock++;
296 greg 1.1 return(MG_OK);
297     case MG_E_TD: /* set diffuse transmittance */
298     if (ac != 2)
299     return(MG_EARGC);
300     if (!isflt(av[1]))
301     return(MG_ETYPE);
302     c_cmaterial->td = atof(av[1]);
303 schorsch 1.28 if ((c_cmaterial->td < 0.) | (c_cmaterial->td > 1.))
304 greg 1.1 return(MG_EILL);
305     c_cmaterial->td_c = *c_ccolor;
306 greg 1.8 c_cmaterial->clock++;
307 greg 1.1 return(MG_OK);
308     case MG_E_RS: /* set specular reflectance */
309     if (ac != 3)
310     return(MG_EARGC);
311 greg 1.18 if (!isflt(av[1]) | !isflt(av[2]))
312 greg 1.1 return(MG_ETYPE);
313     c_cmaterial->rs = atof(av[1]);
314     c_cmaterial->rs_a = atof(av[2]);
315 schorsch 1.28 if ((c_cmaterial->rs < 0.) | (c_cmaterial->rs > 1.) |
316     (c_cmaterial->rs_a < 0.))
317 greg 1.1 return(MG_EILL);
318     c_cmaterial->rs_c = *c_ccolor;
319 greg 1.2 c_cmaterial->clock++;
320 greg 1.1 return(MG_OK);
321     case MG_E_TS: /* set specular transmittance */
322     if (ac != 3)
323     return(MG_EARGC);
324 greg 1.18 if (!isflt(av[1]) | !isflt(av[2]))
325 greg 1.1 return(MG_ETYPE);
326     c_cmaterial->ts = atof(av[1]);
327     c_cmaterial->ts_a = atof(av[2]);
328 schorsch 1.28 if ((c_cmaterial->ts < 0.) | (c_cmaterial->ts > 1.) |
329     (c_cmaterial->ts_a < 0.))
330 greg 1.1 return(MG_EILL);
331     c_cmaterial->ts_c = *c_ccolor;
332 greg 1.2 c_cmaterial->clock++;
333 greg 1.1 return(MG_OK);
334 greg 1.13 case MG_E_SIDES: /* set number of sides */
335     if (ac != 2)
336     return(MG_EARGC);
337     if (!isint(av[1]))
338     return(MG_ETYPE);
339     i = atoi(av[1]);
340     if (i == 1)
341     c_cmaterial->sided = 1;
342     else if (i == 2)
343     c_cmaterial->sided = 0;
344     else
345     return(MG_EILL);
346     c_cmaterial->clock++;
347     return(MG_OK);
348 greg 1.1 }
349     return(MG_EUNK);
350     }
351
352
353     int
354     c_hvertex(ac, av) /* handle a vertex entity */
355     int ac;
356     register char **av;
357     {
358 greg 1.9 int i;
359 greg 1.1 register LUENT *lp;
360
361     switch (mg_entity(av[0])) {
362     case MG_E_VERTEX: /* get/set vertex context */
363 greg 1.4 if (ac > 4)
364     return(MG_EARGC);
365 greg 1.1 if (ac == 1) { /* set unnamed vertex context */
366     c_unvertex = c_dfvertex;
367     c_cvertex = &c_unvertex;
368 greg 1.12 c_cvname = NULL;
369 greg 1.1 return(MG_OK);
370     }
371 greg 1.22 if (!isname(av[1]))
372     return(MG_EILL);
373 greg 1.1 lp = lu_find(&vtx_tab, av[1]); /* lookup context */
374     if (lp == NULL)
375     return(MG_EMEM);
376 greg 1.14 c_cvname = lp->key;
377 greg 1.9 c_cvertex = (C_VERTEX *)lp->data;
378 greg 1.1 if (ac == 2) { /* reestablish previous context */
379 greg 1.9 if (c_cvertex == NULL)
380 greg 1.1 return(MG_EUNDEF);
381     return(MG_OK);
382     }
383     if (av[2][0] != '=' || av[2][1])
384     return(MG_ETYPE);
385 greg 1.9 if (c_cvertex == NULL) { /* create new vertex context */
386 greg 1.1 lp->key = (char *)malloc(strlen(av[1])+1);
387     if (lp->key == NULL)
388     return(MG_EMEM);
389     strcpy(lp->key, av[1]);
390     lp->data = (char *)malloc(sizeof(C_VERTEX));
391     if (lp->data == NULL)
392     return(MG_EMEM);
393 greg 1.14 c_cvname = lp->key;
394 greg 1.9 c_cvertex = (C_VERTEX *)lp->data;
395 gregl 1.25 c_cvertex->clock = 0;
396     c_cvertex->client_data = NULL;
397 greg 1.1 }
398 greg 1.10 i = c_cvertex->clock;
399 greg 1.1 if (ac == 3) { /* use default template */
400     *c_cvertex = c_dfvertex;
401 greg 1.9 c_cvertex->clock = i + 1;
402 greg 1.1 return(MG_OK);
403     }
404     lp = lu_find(&vtx_tab, av[3]); /* lookup template */
405     if (lp == NULL)
406     return(MG_EMEM);
407     if (lp->data == NULL)
408     return(MG_EUNDEF);
409     *c_cvertex = *(C_VERTEX *)lp->data;
410 greg 1.9 c_cvertex->clock = i + 1;
411 greg 1.1 return(MG_OK);
412     case MG_E_POINT: /* set point */
413     if (ac != 4)
414     return(MG_EARGC);
415 greg 1.18 if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3]))
416 greg 1.1 return(MG_ETYPE);
417     c_cvertex->p[0] = atof(av[1]);
418     c_cvertex->p[1] = atof(av[2]);
419     c_cvertex->p[2] = atof(av[3]);
420 greg 1.8 c_cvertex->clock++;
421 greg 1.1 return(MG_OK);
422     case MG_E_NORMAL: /* set normal */
423     if (ac != 4)
424     return(MG_EARGC);
425 greg 1.18 if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3]))
426 greg 1.1 return(MG_ETYPE);
427     c_cvertex->n[0] = atof(av[1]);
428     c_cvertex->n[1] = atof(av[2]);
429     c_cvertex->n[2] = atof(av[3]);
430     (void)normalize(c_cvertex->n);
431 greg 1.8 c_cvertex->clock++;
432 greg 1.1 return(MG_OK);
433     }
434     return(MG_EUNK);
435     }
436
437
438     void
439     c_clearall() /* empty context tables */
440     {
441     c_uncolor = c_dfcolor;
442     c_ccolor = &c_uncolor;
443 greg 1.15 c_ccname = NULL;
444 greg 1.3 lu_done(&clr_tab);
445 greg 1.1 c_unmaterial = c_dfmaterial;
446     c_cmaterial = &c_unmaterial;
447 greg 1.15 c_cmname = NULL;
448 greg 1.3 lu_done(&mat_tab);
449 greg 1.1 c_unvertex = c_dfvertex;
450     c_cvertex = &c_unvertex;
451 greg 1.15 c_cvname = NULL;
452 greg 1.3 lu_done(&vtx_tab);
453 greg 1.1 }
454
455
456 greg 1.11 C_MATERIAL *
457     c_getmaterial(name) /* get a named material */
458     char *name;
459     {
460     register LUENT *lp;
461
462     if ((lp = lu_find(&mat_tab, name)) == NULL)
463     return(NULL);
464     return((C_MATERIAL *)lp->data);
465     }
466
467
468 greg 1.1 C_VERTEX *
469     c_getvert(name) /* get a named vertex */
470     char *name;
471     {
472     register LUENT *lp;
473
474     if ((lp = lu_find(&vtx_tab, name)) == NULL)
475     return(NULL);
476     return((C_VERTEX *)lp->data);
477 greg 1.5 }
478
479
480 greg 1.7 C_COLOR *
481     c_getcolor(name) /* get a named color */
482     char *name;
483     {
484     register LUENT *lp;
485
486     if ((lp = lu_find(&clr_tab, name)) == NULL)
487     return(NULL);
488     return((C_COLOR *)lp->data);
489     }
490
491
492 greg 1.5 int
493     c_isgrey(clr) /* check if color is grey */
494     register C_COLOR *clr;
495     {
496 greg 1.8 if (!(clr->flags & (C_CSXY|C_CSSPEC)))
497 greg 1.5 return(1); /* no settings == grey */
498     c_ccvt(clr, C_CSXY);
499     return(clr->cx >= .323 && clr->cx <= .343 &&
500     clr->cy >= .323 && clr->cy <= .343);
501     }
502
503
504     void
505     c_ccvt(clr, fl) /* convert color representations */
506     register C_COLOR *clr;
507     int fl;
508     {
509     double x, y, z;
510     register int i;
511
512 greg 1.16 fl &= ~clr->flags; /* ignore what's done */
513     if (!fl) /* everything's done! */
514 greg 1.5 return;
515 greg 1.8 if (!(clr->flags & (C_CSXY|C_CSSPEC))) /* nothing set! */
516 greg 1.5 *clr = c_dfcolor;
517 greg 1.16 if (fl & C_CSXY) { /* cspec -> cxy */
518 greg 1.5 x = y = z = 0.;
519     for (i = 0; i < C_CNSS; i++) {
520     x += cie_xf.ssamp[i] * clr->ssamp[i];
521     y += cie_yf.ssamp[i] * clr->ssamp[i];
522     z += cie_zf.ssamp[i] * clr->ssamp[i];
523     }
524 greg 1.17 x /= (double)cie_xf.ssum;
525     y /= (double)cie_yf.ssum;
526     z /= (double)cie_zf.ssum;
527 greg 1.5 z += x + y;
528     clr->cx = x / z;
529     clr->cy = y / z;
530     clr->flags |= C_CSXY;
531 greg 1.16 } else if (fl & C_CSSPEC) { /* cxy -> cspec */
532 greg 1.19 x = clr->cx;
533     y = clr->cy;
534     z = 1. - x - y;
535 greg 1.5 clr->ssum = 0;
536 greg 1.19 for (i = 0; i < C_CNSS; i++) {
537     clr->ssamp[i] = x*cie_xp.ssamp[i] + y*cie_yp.ssamp[i]
538     + z*cie_zp.ssamp[i] + .5;
539     if (clr->ssamp[i] < 0) /* out of gamut! */
540     clr->ssamp[i] = 0;
541     else
542     clr->ssum += clr->ssamp[i];
543     }
544 greg 1.5 clr->flags |= C_CSSPEC;
545     }
546 greg 1.16 if (fl & C_CSEFF) { /* compute efficacy */
547 greg 1.19 if (clr->flags & C_CSSPEC) { /* from spectrum */
548 greg 1.16 y = 0.;
549     for (i = 0; i < C_CNSS; i++)
550     y += cie_yf.ssamp[i] * clr->ssamp[i];
551     clr->eff = C_CLPWM * y / clr->ssum;
552 greg 1.19 } else /* clr->flags & C_CSXY */ { /* from (x,y) */
553 greg 1.16 clr->eff = clr->cx*cie_xf.eff + clr->cy*cie_yf.eff +
554     (1. - clr->cx - clr->cy)*cie_zf.eff;
555     }
556     clr->flags |= C_CSEFF;
557     }
558 greg 1.5 }
559
560
561     static int
562     setspectrum(clr, wlmin, wlmax, ac, av) /* convert a spectrum */
563     register C_COLOR *clr;
564 greg 1.17 double wlmin, wlmax;
565 greg 1.5 int ac;
566     char **av;
567     {
568     double scale;
569 greg 1.17 float va[C_CNSS];
570     register int i, pos;
571     int n, imax;
572     int wl;
573 greg 1.5 double wl0, wlstep;
574 greg 1.20 double boxpos, boxstep;
575 greg 1.17 /* check bounds */
576 schorsch 1.28 if ((wlmax <= C_CMINWL) | (wlmax <= wlmin) | (wlmin >= C_CMAXWL))
577 greg 1.5 return(MG_EILL);
578 greg 1.17 wlstep = (wlmax - wlmin)/(ac-1);
579     while (wlmin < C_CMINWL) {
580     wlmin += wlstep;
581     ac--; av++;
582     }
583     while (wlmax > C_CMAXWL) {
584     wlmax -= wlstep;
585     ac--;
586     }
587     imax = ac; /* box filter if necessary */
588 greg 1.20 boxpos = 0;
589     boxstep = 1;
590 greg 1.17 if (wlstep < C_CWLI) {
591 greg 1.20 imax = (wlmax - wlmin)/C_CWLI + (1-FTINY);
592     boxpos = (wlmin - C_CMINWL)/C_CWLI;
593     boxstep = wlstep/C_CWLI;
594 greg 1.17 wlstep = C_CWLI;
595     }
596 greg 1.5 scale = 0.; /* get values and maximum */
597 greg 1.17 pos = 0;
598     for (i = 0; i < imax; i++) {
599     va[i] = 0.; n = 0;
600 greg 1.20 while (boxpos < i+.5 && pos < ac) {
601 greg 1.17 if (!isflt(av[pos]))
602     return(MG_ETYPE);
603     va[i] += atof(av[pos++]);
604     n++;
605 greg 1.20 boxpos += boxstep;
606 greg 1.17 }
607     if (n > 1)
608     va[i] /= (double)n;
609 greg 1.5 if (va[i] > scale)
610     scale = va[i];
611 greg 1.23 else if (va[i] < -scale)
612     scale = -va[i];
613 greg 1.5 }
614 greg 1.20 if (scale <= FTINY)
615 greg 1.5 return(MG_EILL);
616     scale = C_CMAXV / scale;
617     clr->ssum = 0; /* convert to our spacing */
618     wl0 = wlmin;
619     pos = 0;
620     for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI)
621 schorsch 1.28 if ((wl < wlmin) | (wl > wlmax))
622 greg 1.5 clr->ssamp[i] = 0;
623     else {
624     while (wl0 + wlstep < wl+FTINY) {
625     wl0 += wlstep;
626     pos++;
627     }
628 schorsch 1.28 if ((wl+FTINY >= wl0) & (wl-FTINY <= wl0))
629 greg 1.18 clr->ssamp[i] = scale*va[pos] + .5;
630 greg 1.5 else /* interpolate if necessary */
631 greg 1.18 clr->ssamp[i] = .5 + scale / wlstep *
632 greg 1.5 ( va[pos]*(wl0+wlstep - wl) +
633     va[pos+1]*(wl - wl0) );
634     clr->ssum += clr->ssamp[i];
635     }
636     clr->flags = C_CDSPEC|C_CSSPEC;
637 greg 1.8 clr->clock++;
638 greg 1.5 return(MG_OK);
639     }
640
641
642     static void
643     mixcolors(cres, w1, c1, w2, c2) /* mix two colors according to weights given */
644     register C_COLOR *cres, *c1, *c2;
645     double w1, w2;
646     {
647     double scale;
648     float cmix[C_CNSS];
649     register int i;
650
651     if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */
652 greg 1.16 c_ccvt(c1, C_CSSPEC|C_CSEFF);
653     c_ccvt(c2, C_CSSPEC|C_CSEFF);
654     w1 /= c1->eff*c1->ssum;
655 greg 1.17 w2 /= c2->eff*c2->ssum;
656 greg 1.5 scale = 0.;
657     for (i = 0; i < C_CNSS; i++) {
658     cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i];
659     if (cmix[i] > scale)
660     scale = cmix[i];
661     }
662     scale = C_CMAXV / scale;
663     cres->ssum = 0;
664     for (i = 0; i < C_CNSS; i++)
665     cres->ssum += cres->ssamp[i] = scale*cmix[i] + .5;
666     cres->flags = C_CDSPEC|C_CSSPEC;
667     } else { /* CIE xy mixing */
668     c_ccvt(c1, C_CSXY);
669     c_ccvt(c2, C_CSXY);
670 greg 1.24 scale = w1/c1->cy + w2/c2->cy;
671     if (scale == 0.)
672     return;
673     scale = 1. / scale;
674 greg 1.5 cres->cx = (c1->cx*w1/c1->cy + c2->cx*w2/c2->cy) * scale;
675     cres->cy = (w1 + w2) * scale;
676     cres->flags = C_CDXY|C_CSXY;
677     }
678 greg 1.1 }
679 greg 1.18
680
681     #define C1 3.741832e-16 /* W-m^2 */
682     #define C2 1.4388e-2 /* m-K */
683
684     #define bbsp(l,t) (C1/((l)*(l)*(l)*(l)*(l)*(exp(C2/((t)*(l)))-1.)))
685     #define bblm(t) (C2/5./(t))
686
687     static int
688     setbbtemp(clr, tk) /* set black body spectrum */
689     register C_COLOR *clr;
690     double tk;
691     {
692     double sf, wl;
693     register int i;
694
695     if (tk < 1000)
696     return(MG_EILL);
697     wl = bblm(tk); /* scalefactor based on peak */
698     if (wl < C_CMINWL*1e-9)
699     wl = C_CMINWL*1e-9;
700     else if (wl > C_CMAXWL*1e-9)
701     wl = C_CMAXWL*1e-9;
702     sf = C_CMAXV/bbsp(wl,tk);
703     clr->ssum = 0;
704     for (i = 0; i < C_CNSS; i++) {
705     wl = (C_CMINWL + i*C_CWLI)*1e-9;
706     clr->ssum += clr->ssamp[i] = sf*bbsp(wl,tk) + .5;
707     }
708     clr->flags = C_CDSPEC|C_CSSPEC;
709     clr->clock++;
710     return(MG_OK);
711     }
712
713     #undef C1
714     #undef C2
715     #undef bbsp
716     #undef bblm
