1 |
/* Copyright (c) 1997 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Context handlers |
9 |
10 |
11 |
#include <stdio.h> |
12 |
#include <math.h> |
13 |
#include <string.h> |
14 |
#include "parser.h" |
15 |
#include "lookup.h" |
16 |
17 |
/* default context values */ |
18 |
static C_COLOR c_dfcolor = C_DEFCOLOR; |
19 |
static C_MATERIAL c_dfmaterial = C_DEFMATERIAL; |
20 |
static C_VERTEX c_dfvertex = C_DEFVERTEX; |
21 |
22 |
/* the unnamed contexts */ |
23 |
static C_COLOR c_uncolor = C_DEFCOLOR; |
24 |
static C_MATERIAL c_unmaterial = C_DEFMATERIAL; |
25 |
static C_VERTEX c_unvertex = C_DEFVERTEX; |
26 |
27 |
/* the current contexts */ |
28 |
C_COLOR *c_ccolor = &c_uncolor; |
29 |
char *c_ccname = NULL; |
30 |
C_MATERIAL *c_cmaterial = &c_unmaterial; |
31 |
char *c_cmname = NULL; |
32 |
C_VERTEX *c_cvertex = &c_unvertex; |
33 |
char *c_cvname = NULL; |
34 |
35 |
static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */ |
36 |
static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */ |
37 |
static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */ |
38 |
39 |
/* CIE 1931 Standard Observer curves */ |
40 |
static C_COLOR cie_xf = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF, |
41 |
{14,42,143,435,1344,2839,3483,3362,2908,1954,956, |
42 |
320,49,93,633,1655,2904,4334,5945,7621,9163,10263, |
43 |
10622,10026,8544,6424,4479,2835,1649,874,468,227, |
44 |
114,58,29,14,7,3,2,1,0}, 106836L, .467, .368, 362.230 |
45 |
46 |
static C_COLOR cie_yf = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF, |
47 |
{0,1,4,12,40,116,230,380,600,910,1390,2080,3230, |
48 |
5030,7100,8620,9540,9950,9950,9520,8700,7570,6310, |
49 |
5030,3810,2650,1750,1070,610,320,170,82,41,21,10, |
50 |
5,2,1,1,0,0}, 106856L, .398, .542, 493.525 |
51 |
52 |
static C_COLOR cie_zf = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF, |
53 |
{65,201,679,2074,6456,13856,17471,17721,16692, |
54 |
12876,8130,4652,2720,1582,782,422,203,87,39,21,17, |
55 |
11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, |
56 |
106770L, .147, .077, 54.363 |
57 |
58 |
/* Derived CIE 1931 Primaries (imaginary) */ |
59 |
static C_COLOR cie_xp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY, |
60 |
{-174,-198,-195,-197,-202,-213,-235,-272,-333, |
61 |
-444,-688,-1232,-2393,-4497,-6876,-6758,-5256, |
62 |
-3100,-815,1320,3200,4782,5998,6861,7408,7754, |
63 |
7980,8120,8199,8240,8271,8292,8309,8283,8469, |
64 |
8336,8336,8336,8336,8336,8336}, |
65 |
127424L, 1., .0, |
66 |
67 |
static C_COLOR cie_yp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY, |
68 |
{-451,-431,-431,-430,-427,-417,-399,-366,-312, |
69 |
-204,57,691,2142,4990,8810,9871,9122,7321,5145, |
70 |
3023,1123,-473,-1704,-2572,-3127,-3474,-3704, |
71 |
-3846,-3927,-3968,-3999,-4021,-4038,-4012,-4201, |
72 |
-4066,-4066,-4066,-4066,-4066,-4066}, |
73 |
-23035L, .0, 1., |
74 |
75 |
static C_COLOR cie_zp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY, |
76 |
{4051,4054,4052,4053,4054,4056,4059,4064,4071, |
77 |
4074,4056,3967,3677,2933,1492,313,-440,-795, |
78 |
-904,-918,-898,-884,-869,-863,-855,-855,-851, |
79 |
-848,-847,-846,-846,-846,-845,-846,-843,-845, |
80 |
-845,-845,-845,-845,-845}, |
81 |
36057L, .0, .0, |
82 |
83 |
84 |
static int setspectrum(); |
85 |
static int setbbtemp(); |
86 |
static void mixcolors(); |
87 |
88 |
89 |
int |
90 |
c_hcolor(ac, av) /* handle color entity */ |
91 |
int ac; |
92 |
register char **av; |
93 |
94 |
double w, wsum; |
95 |
register int i; |
96 |
register LUENT *lp; |
97 |
98 |
switch (mg_entity(av[0])) { |
99 |
case MG_E_COLOR: /* get/set color context */ |
100 |
if (ac > 4) |
101 |
return(MG_EARGC); |
102 |
if (ac == 1) { /* set unnamed color context */ |
103 |
c_uncolor = c_dfcolor; |
104 |
105 |
c_ccname = NULL; |
106 |
return(MG_OK); |
107 |
108 |
if (!isname(av[1])) |
109 |
return(MG_EILL); |
110 |
lp = lu_find(&clr_tab, av[1]); /* lookup context */ |
111 |
if (lp == NULL) |
112 |
return(MG_EMEM); |
113 |
c_ccname = lp->key; |
114 |
c_ccolor = (C_COLOR *)lp->data; |
115 |
if (ac == 2) { /* reestablish previous context */ |
116 |
if (c_ccolor == NULL) |
117 |
return(MG_EUNDEF); |
118 |
return(MG_OK); |
119 |
120 |
if (av[2][0] != '=' || av[2][1]) |
121 |
return(MG_ETYPE); |
122 |
if (c_ccolor == NULL) { /* create new color context */ |
123 |
lp->key = (char *)malloc(strlen(av[1])+1); |
124 |
if (lp->key == NULL) |
125 |
return(MG_EMEM); |
126 |
strcpy(lp->key, av[1]); |
127 |
lp->data = (char *)malloc(sizeof(C_COLOR)); |
128 |
if (lp->data == NULL) |
129 |
return(MG_EMEM); |
130 |
131 |
132 |
c_ccolor->clock = 0; |
133 |
c_ccolor->client_data = NULL; |
134 |
135 |
i = c_ccolor->clock; |
136 |
if (ac == 3) { /* use default template */ |
137 |
*c_ccolor = c_dfcolor; |
138 |
c_ccolor->clock = i + 1; |
139 |
return(MG_OK); |
140 |
141 |
lp = lu_find(&clr_tab, av[3]); /* lookup template */ |
142 |
if (lp == NULL) |
143 |
return(MG_EMEM); |
144 |
145 |
146 |
*c_ccolor = *(C_COLOR *)lp->data; |
147 |
148 |
return(MG_OK); |
149 |
case MG_E_CXY: /* assign CIE XY value */ |
150 |
if (ac != 3) |
151 |
return(MG_EARGC); |
152 |
if (!isflt(av[1]) | !isflt(av[2])) |
153 |
return(MG_ETYPE); |
154 |
c_ccolor->cx = atof(av[1]); |
155 |
c_ccolor->cy = atof(av[2]); |
156 |
c_ccolor->flags = C_CDXY|C_CSXY; |
157 |
if (c_ccolor->cx < 0. | c_ccolor->cy < 0. | |
158 |
c_ccolor->cx + c_ccolor->cy > 1.) |
159 |
return(MG_EILL); |
160 |
c_ccolor->clock++; |
161 |
return(MG_OK); |
162 |
case MG_E_CSPEC: /* assign spectral values */ |
163 |
if (ac < 5) |
164 |
return(MG_EARGC); |
165 |
166 |
return(MG_ETYPE); |
167 |
return(setspectrum(c_ccolor, atof(av[1]), atof(av[2]), |
168 |
ac-3, av+3)); |
169 |
case MG_E_CCT: /* assign black body spectrum */ |
170 |
if (ac != 2) |
171 |
return(MG_EARGC); |
172 |
if (!isflt(av[1])) |
173 |
return(MG_ETYPE); |
174 |
return(setbbtemp(c_ccolor, atof(av[1]))); |
175 |
case MG_E_CMIX: /* mix colors */ |
176 |
if (ac < 5 || (ac-1)%2) |
177 |
return(MG_EARGC); |
178 |
179 |
return(MG_ETYPE); |
180 |
wsum = atof(av[1]); |
181 |
if ((lp = lu_find(&clr_tab, av[2])) == NULL) |
182 |
return(MG_EMEM); |
183 |
184 |
185 |
186 |
for (i = 3; i < ac; i += 2) { |
187 |
if (!isflt(av[i])) |
188 |
return(MG_ETYPE); |
189 |
w = atof(av[i]); |
190 |
if ((lp = lu_find(&clr_tab, av[i+1])) == NULL) |
191 |
return(MG_EMEM); |
192 |
193 |
194 |
mixcolors(c_ccolor, wsum, c_ccolor, |
195 |
w, (C_COLOR *)lp->data); |
196 |
wsum += w; |
197 |
198 |
if (wsum <= 0.) |
199 |
return(MG_EILL); |
200 |
201 |
return(MG_OK); |
202 |
203 |
return(MG_EUNK); |
204 |
205 |
206 |
207 |
int |
208 |
c_hmaterial(ac, av) /* handle material entity */ |
209 |
int ac; |
210 |
211 |
212 |
int i; |
213 |
214 |
215 |
216 |
case MG_E_MATERIAL: /* get/set material context */ |
217 |
if (ac > 4) |
218 |
return(MG_EARGC); |
219 |
if (ac == 1) { /* set unnamed material context */ |
220 |
c_unmaterial = c_dfmaterial; |
221 |
222 |
c_cmname = NULL; |
223 |
return(MG_OK); |
224 |
225 |
226 |
return(MG_EILL); |
227 |
lp = lu_find(&mat_tab, av[1]); /* lookup context */ |
228 |
if (lp == NULL) |
229 |
return(MG_EMEM); |
230 |
c_cmname = lp->key; |
231 |
c_cmaterial = (C_MATERIAL *)lp->data; |
232 |
233 |
if (c_cmaterial == NULL) |
234 |
235 |
return(MG_OK); |
236 |
237 |
238 |
return(MG_ETYPE); |
239 |
if (c_cmaterial == NULL) { /* create new material */ |
240 |
241 |
242 |
return(MG_EMEM); |
243 |
244 |
lp->data = (char *)malloc(sizeof(C_MATERIAL)); |
245 |
246 |
return(MG_EMEM); |
247 |
248 |
249 |
c_cmaterial->clock = 0; |
250 |
c_cmaterial->client_data = NULL; |
251 |
252 |
i = c_cmaterial->clock; |
253 |
254 |
*c_cmaterial = c_dfmaterial; |
255 |
c_cmaterial->clock = i + 1; |
256 |
return(MG_OK); |
257 |
258 |
lp = lu_find(&mat_tab, av[3]); /* lookup template */ |
259 |
if (lp == NULL) |
260 |
return(MG_EMEM); |
261 |
262 |
263 |
*c_cmaterial = *(C_MATERIAL *)lp->data; |
264 |
265 |
return(MG_OK); |
266 |
case MG_E_IR: /* set index of refraction */ |
267 |
if (ac != 3) |
268 |
return(MG_EARGC); |
269 |
270 |
return(MG_ETYPE); |
271 |
c_cmaterial->nr = atof(av[1]); |
272 |
c_cmaterial->ni = atof(av[2]); |
273 |
if (c_cmaterial->nr <= FTINY) |
274 |
return(MG_EILL); |
275 |
c_cmaterial->clock++; |
276 |
return(MG_OK); |
277 |
case MG_E_RD: /* set diffuse reflectance */ |
278 |
if (ac != 2) |
279 |
return(MG_EARGC); |
280 |
281 |
return(MG_ETYPE); |
282 |
c_cmaterial->rd = atof(av[1]); |
283 |
if (c_cmaterial->rd < 0. | c_cmaterial->rd > 1.) |
284 |
return(MG_EILL); |
285 |
c_cmaterial->rd_c = *c_ccolor; |
286 |
287 |
return(MG_OK); |
288 |
case MG_E_ED: /* set diffuse emittance */ |
289 |
if (ac != 2) |
290 |
return(MG_EARGC); |
291 |
292 |
return(MG_ETYPE); |
293 |
c_cmaterial->ed = atof(av[1]); |
294 |
if (c_cmaterial->ed < 0.) |
295 |
return(MG_EILL); |
296 |
c_cmaterial->ed_c = *c_ccolor; |
297 |
298 |
return(MG_OK); |
299 |
case MG_E_TD: /* set diffuse transmittance */ |
300 |
if (ac != 2) |
301 |
return(MG_EARGC); |
302 |
303 |
return(MG_ETYPE); |
304 |
c_cmaterial->td = atof(av[1]); |
305 |
if (c_cmaterial->td < 0. | c_cmaterial->td > 1.) |
306 |
return(MG_EILL); |
307 |
c_cmaterial->td_c = *c_ccolor; |
308 |
309 |
return(MG_OK); |
310 |
case MG_E_RS: /* set specular reflectance */ |
311 |
if (ac != 3) |
312 |
return(MG_EARGC); |
313 |
314 |
return(MG_ETYPE); |
315 |
c_cmaterial->rs = atof(av[1]); |
316 |
c_cmaterial->rs_a = atof(av[2]); |
317 |
if (c_cmaterial->rs < 0. | c_cmaterial->rs > 1. | |
318 |
c_cmaterial->rs_a < 0.) |
319 |
return(MG_EILL); |
320 |
c_cmaterial->rs_c = *c_ccolor; |
321 |
322 |
return(MG_OK); |
323 |
case MG_E_TS: /* set specular transmittance */ |
324 |
if (ac != 3) |
325 |
return(MG_EARGC); |
326 |
327 |
return(MG_ETYPE); |
328 |
c_cmaterial->ts = atof(av[1]); |
329 |
c_cmaterial->ts_a = atof(av[2]); |
330 |
if (c_cmaterial->ts < 0. | c_cmaterial->ts > 1. | |
331 |
c_cmaterial->ts_a < 0.) |
332 |
return(MG_EILL); |
333 |
c_cmaterial->ts_c = *c_ccolor; |
334 |
335 |
return(MG_OK); |
336 |
case MG_E_SIDES: /* set number of sides */ |
337 |
if (ac != 2) |
338 |
return(MG_EARGC); |
339 |
if (!isint(av[1])) |
340 |
return(MG_ETYPE); |
341 |
i = atoi(av[1]); |
342 |
if (i == 1) |
343 |
c_cmaterial->sided = 1; |
344 |
else if (i == 2) |
345 |
c_cmaterial->sided = 0; |
346 |
else |
347 |
return(MG_EILL); |
348 |
349 |
return(MG_OK); |
350 |
351 |
return(MG_EUNK); |
352 |
353 |
354 |
355 |
int |
356 |
c_hvertex(ac, av) /* handle a vertex entity */ |
357 |
int ac; |
358 |
359 |
360 |
int i; |
361 |
362 |
363 |
364 |
case MG_E_VERTEX: /* get/set vertex context */ |
365 |
if (ac > 4) |
366 |
return(MG_EARGC); |
367 |
if (ac == 1) { /* set unnamed vertex context */ |
368 |
c_unvertex = c_dfvertex; |
369 |
370 |
c_cvname = NULL; |
371 |
return(MG_OK); |
372 |
373 |
374 |
return(MG_EILL); |
375 |
lp = lu_find(&vtx_tab, av[1]); /* lookup context */ |
376 |
if (lp == NULL) |
377 |
return(MG_EMEM); |
378 |
c_cvname = lp->key; |
379 |
c_cvertex = (C_VERTEX *)lp->data; |
380 |
381 |
if (c_cvertex == NULL) |
382 |
383 |
return(MG_OK); |
384 |
385 |
386 |
return(MG_ETYPE); |
387 |
if (c_cvertex == NULL) { /* create new vertex context */ |
388 |
389 |
390 |
return(MG_EMEM); |
391 |
392 |
lp->data = (char *)malloc(sizeof(C_VERTEX)); |
393 |
394 |
return(MG_EMEM); |
395 |
396 |
397 |
c_cvertex->clock = 0; |
398 |
c_cvertex->client_data = NULL; |
399 |
400 |
i = c_cvertex->clock; |
401 |
402 |
*c_cvertex = c_dfvertex; |
403 |
c_cvertex->clock = i + 1; |
404 |
return(MG_OK); |
405 |
406 |
lp = lu_find(&vtx_tab, av[3]); /* lookup template */ |
407 |
if (lp == NULL) |
408 |
return(MG_EMEM); |
409 |
410 |
411 |
*c_cvertex = *(C_VERTEX *)lp->data; |
412 |
413 |
return(MG_OK); |
414 |
case MG_E_POINT: /* set point */ |
415 |
if (ac != 4) |
416 |
return(MG_EARGC); |
417 |
if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3])) |
418 |
return(MG_ETYPE); |
419 |
c_cvertex->p[0] = atof(av[1]); |
420 |
c_cvertex->p[1] = atof(av[2]); |
421 |
c_cvertex->p[2] = atof(av[3]); |
422 |
c_cvertex->clock++; |
423 |
return(MG_OK); |
424 |
case MG_E_NORMAL: /* set normal */ |
425 |
if (ac != 4) |
426 |
return(MG_EARGC); |
427 |
428 |
return(MG_ETYPE); |
429 |
c_cvertex->n[0] = atof(av[1]); |
430 |
c_cvertex->n[1] = atof(av[2]); |
431 |
c_cvertex->n[2] = atof(av[3]); |
432 |
(void)normalize(c_cvertex->n); |
433 |
434 |
return(MG_OK); |
435 |
436 |
return(MG_EUNK); |
437 |
438 |
439 |
440 |
void |
441 |
c_clearall() /* empty context tables */ |
442 |
443 |
444 |
445 |
c_ccname = NULL; |
446 |
lu_done(&clr_tab); |
447 |
448 |
449 |
c_cmname = NULL; |
450 |
lu_done(&mat_tab); |
451 |
452 |
453 |
c_cvname = NULL; |
454 |
lu_done(&vtx_tab); |
455 |
456 |
457 |
458 |
C_MATERIAL * |
459 |
c_getmaterial(name) /* get a named material */ |
460 |
char *name; |
461 |
462 |
463 |
464 |
if ((lp = lu_find(&mat_tab, name)) == NULL) |
465 |
return(NULL); |
466 |
return((C_MATERIAL *)lp->data); |
467 |
468 |
469 |
470 |
C_VERTEX * |
471 |
c_getvert(name) /* get a named vertex */ |
472 |
char *name; |
473 |
474 |
475 |
476 |
if ((lp = lu_find(&vtx_tab, name)) == NULL) |
477 |
return(NULL); |
478 |
return((C_VERTEX *)lp->data); |
479 |
480 |
481 |
482 |
C_COLOR * |
483 |
c_getcolor(name) /* get a named color */ |
484 |
char *name; |
485 |
486 |
487 |
488 |
if ((lp = lu_find(&clr_tab, name)) == NULL) |
489 |
return(NULL); |
490 |
return((C_COLOR *)lp->data); |
491 |
492 |
493 |
494 |
int |
495 |
c_isgrey(clr) /* check if color is grey */ |
496 |
register C_COLOR *clr; |
497 |
498 |
if (!(clr->flags & (C_CSXY|C_CSSPEC))) |
499 |
return(1); /* no settings == grey */ |
500 |
c_ccvt(clr, C_CSXY); |
501 |
return(clr->cx >= .323 && clr->cx <= .343 && |
502 |
clr->cy >= .323 && clr->cy <= .343); |
503 |
504 |
505 |
506 |
void |
507 |
c_ccvt(clr, fl) /* convert color representations */ |
508 |
509 |
int fl; |
510 |
511 |
double x, y, z; |
512 |
register int i; |
513 |
514 |
fl &= ~clr->flags; /* ignore what's done */ |
515 |
if (!fl) /* everything's done! */ |
516 |
return; |
517 |
if (!(clr->flags & (C_CSXY|C_CSSPEC))) /* nothing set! */ |
518 |
*clr = c_dfcolor; |
519 |
if (fl & C_CSXY) { /* cspec -> cxy */ |
520 |
x = y = z = 0.; |
521 |
for (i = 0; i < C_CNSS; i++) { |
522 |
x += cie_xf.ssamp[i] * clr->ssamp[i]; |
523 |
y += cie_yf.ssamp[i] * clr->ssamp[i]; |
524 |
z += cie_zf.ssamp[i] * clr->ssamp[i]; |
525 |
526 |
x /= (double)cie_xf.ssum; |
527 |
y /= (double)cie_yf.ssum; |
528 |
z /= (double)cie_zf.ssum; |
529 |
z += x + y; |
530 |
clr->cx = x / z; |
531 |
clr->cy = y / z; |
532 |
clr->flags |= C_CSXY; |
533 |
} else if (fl & C_CSSPEC) { /* cxy -> cspec */ |
534 |
x = clr->cx; |
535 |
y = clr->cy; |
536 |
z = 1. - x - y; |
537 |
clr->ssum = 0; |
538 |
539 |
clr->ssamp[i] = x*cie_xp.ssamp[i] + y*cie_yp.ssamp[i] |
540 |
+ z*cie_zp.ssamp[i] + .5; |
541 |
if (clr->ssamp[i] < 0) /* out of gamut! */ |
542 |
clr->ssamp[i] = 0; |
543 |
else |
544 |
clr->ssum += clr->ssamp[i]; |
545 |
546 |
clr->flags |= C_CSSPEC; |
547 |
548 |
if (fl & C_CSEFF) { /* compute efficacy */ |
549 |
if (clr->flags & C_CSSPEC) { /* from spectrum */ |
550 |
y = 0.; |
551 |
for (i = 0; i < C_CNSS; i++) |
552 |
553 |
clr->eff = C_CLPWM * y / clr->ssum; |
554 |
} else /* clr->flags & C_CSXY */ { /* from (x,y) */ |
555 |
clr->eff = clr->cx*cie_xf.eff + clr->cy*cie_yf.eff + |
556 |
(1. - clr->cx - clr->cy)*cie_zf.eff; |
557 |
558 |
clr->flags |= C_CSEFF; |
559 |
560 |
561 |
562 |
563 |
static int |
564 |
setspectrum(clr, wlmin, wlmax, ac, av) /* convert a spectrum */ |
565 |
566 |
double wlmin, wlmax; |
567 |
int ac; |
568 |
char **av; |
569 |
570 |
double scale; |
571 |
float va[C_CNSS]; |
572 |
register int i, pos; |
573 |
int n, imax; |
574 |
int wl; |
575 |
double wl0, wlstep; |
576 |
double boxpos, boxstep; |
577 |
/* check bounds */ |
578 |
if (wlmax <= C_CMINWL | wlmax <= wlmin | wlmin >= C_CMAXWL) |
579 |
return(MG_EILL); |
580 |
wlstep = (wlmax - wlmin)/(ac-1); |
581 |
while (wlmin < C_CMINWL) { |
582 |
wlmin += wlstep; |
583 |
ac--; av++; |
584 |
585 |
while (wlmax > C_CMAXWL) { |
586 |
wlmax -= wlstep; |
587 |
ac--; |
588 |
589 |
imax = ac; /* box filter if necessary */ |
590 |
boxpos = 0; |
591 |
boxstep = 1; |
592 |
if (wlstep < C_CWLI) { |
593 |
imax = (wlmax - wlmin)/C_CWLI + (1-FTINY); |
594 |
boxpos = (wlmin - C_CMINWL)/C_CWLI; |
595 |
boxstep = wlstep/C_CWLI; |
596 |
wlstep = C_CWLI; |
597 |
598 |
scale = 0.; /* get values and maximum */ |
599 |
pos = 0; |
600 |
for (i = 0; i < imax; i++) { |
601 |
va[i] = 0.; n = 0; |
602 |
while (boxpos < i+.5 && pos < ac) { |
603 |
if (!isflt(av[pos])) |
604 |
return(MG_ETYPE); |
605 |
va[i] += atof(av[pos++]); |
606 |
n++; |
607 |
boxpos += boxstep; |
608 |
609 |
if (n > 1) |
610 |
va[i] /= (double)n; |
611 |
if (va[i] > scale) |
612 |
scale = va[i]; |
613 |
else if (va[i] < -scale) |
614 |
scale = -va[i]; |
615 |
616 |
if (scale <= FTINY) |
617 |
return(MG_EILL); |
618 |
scale = C_CMAXV / scale; |
619 |
clr->ssum = 0; /* convert to our spacing */ |
620 |
wl0 = wlmin; |
621 |
pos = 0; |
622 |
for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI) |
623 |
if (wl < wlmin | wl > wlmax) |
624 |
625 |
else { |
626 |
while (wl0 + wlstep < wl+FTINY) { |
627 |
wl0 += wlstep; |
628 |
pos++; |
629 |
630 |
if (wl+FTINY >= wl0 & wl-FTINY <= wl0) |
631 |
clr->ssamp[i] = scale*va[pos] + .5; |
632 |
else /* interpolate if necessary */ |
633 |
clr->ssamp[i] = .5 + scale / wlstep * |
634 |
( va[pos]*(wl0+wlstep - wl) + |
635 |
va[pos+1]*(wl - wl0) ); |
636 |
637 |
638 |
clr->flags = C_CDSPEC|C_CSSPEC; |
639 |
clr->clock++; |
640 |
return(MG_OK); |
641 |
642 |
643 |
644 |
static void |
645 |
mixcolors(cres, w1, c1, w2, c2) /* mix two colors according to weights given */ |
646 |
register C_COLOR *cres, *c1, *c2; |
647 |
double w1, w2; |
648 |
649 |
double scale; |
650 |
float cmix[C_CNSS]; |
651 |
register int i; |
652 |
653 |
if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */ |
654 |
c_ccvt(c1, C_CSSPEC|C_CSEFF); |
655 |
c_ccvt(c2, C_CSSPEC|C_CSEFF); |
656 |
w1 /= c1->eff*c1->ssum; |
657 |
w2 /= c2->eff*c2->ssum; |
658 |
scale = 0.; |
659 |
660 |
cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i]; |
661 |
if (cmix[i] > scale) |
662 |
scale = cmix[i]; |
663 |
664 |
665 |
cres->ssum = 0; |
666 |
667 |
cres->ssum += cres->ssamp[i] = scale*cmix[i] + .5; |
668 |
cres->flags = C_CDSPEC|C_CSSPEC; |
669 |
} else { /* CIE xy mixing */ |
670 |
c_ccvt(c1, C_CSXY); |
671 |
c_ccvt(c2, C_CSXY); |
672 |
scale = w1/c1->cy + w2/c2->cy; |
673 |
if (scale == 0.) |
674 |
return; |
675 |
scale = 1. / scale; |
676 |
cres->cx = (c1->cx*w1/c1->cy + c2->cx*w2/c2->cy) * scale; |
677 |
cres->cy = (w1 + w2) * scale; |
678 |
cres->flags = C_CDXY|C_CSXY; |
679 |
680 |
681 |
682 |
683 |
#define C1 3.741832e-16 /* W-m^2 */ |
684 |
#define C2 1.4388e-2 /* m-K */ |
685 |
686 |
#define bbsp(l,t) (C1/((l)*(l)*(l)*(l)*(l)*(exp(C2/((t)*(l)))-1.))) |
687 |
#define bblm(t) (C2/5./(t)) |
688 |
689 |
static int |
690 |
setbbtemp(clr, tk) /* set black body spectrum */ |
691 |
692 |
double tk; |
693 |
694 |
double sf, wl; |
695 |
register int i; |
696 |
697 |
if (tk < 1000) |
698 |
return(MG_EILL); |
699 |
wl = bblm(tk); /* scalefactor based on peak */ |
700 |
if (wl < C_CMINWL*1e-9) |
701 |
wl = C_CMINWL*1e-9; |
702 |
else if (wl > C_CMAXWL*1e-9) |
703 |
wl = C_CMAXWL*1e-9; |
704 |
sf = C_CMAXV/bbsp(wl,tk); |
705 |
clr->ssum = 0; |
706 |
707 |
wl = (C_CMINWL + i*C_CWLI)*1e-9; |
708 |
clr->ssum += clr->ssamp[i] = sf*bbsp(wl,tk) + .5; |
709 |
710 |
711 |
clr->clock++; |
712 |
return(MG_OK); |
713 |
714 |
715 |
#undef C1 |
716 |
#undef C2 |
717 |
#undef bbsp |
718 |
#undef bblm |
