root/radiance/ray/src/cv/mgflib/context.c
Revision: 1.17
Committed: Fri Feb 24 16:50:08 1995 UTC (29 years, 3 months ago) by greg
Changes since 1.16: +42 -19 lines
fixed context handlers for spectral power distribution data
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Context handlers
9 */
10
11 #include <stdio.h>
12 #include <math.h>
13 #include <string.h>
14 #include "parser.h"
15 #include "lookup.h"
16
17 /* default context values */
18 static C_COLOR c_dfcolor = C_DEFCOLOR;
19 static C_MATERIAL c_dfmaterial = C_DEFMATERIAL;
20 static C_VERTEX c_dfvertex = C_DEFVERTEX;
21
22 /* the unnamed contexts */
23 static C_COLOR c_uncolor = C_DEFCOLOR;
24 static C_MATERIAL c_unmaterial = C_DEFMATERIAL;
25 static C_VERTEX c_unvertex = C_DEFVERTEX;
26
27 /* the current contexts */
28 C_COLOR *c_ccolor = &c_uncolor;
29 char *c_ccname = NULL;
30 C_MATERIAL *c_cmaterial = &c_unmaterial;
31 char *c_cmname = NULL;
32 C_VERTEX *c_cvertex = &c_unvertex;
33 char *c_cvname = NULL;
34
35 static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */
36 static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */
37 static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */
38
39 /* CIE 1931 Standard Observer */
40 static C_COLOR cie_xf = C_CIEX;
41 static C_COLOR cie_yf = C_CIEY;
42 static C_COLOR cie_zf = C_CIEZ;
43
44 static int setspectrum();
45 static void mixcolors();
46
47
48 int
49 c_hcolor(ac, av) /* handle color entity */
50 int ac;
51 register char **av;
52 {
53 double w, wsum;
54 register int i;
55 register LUENT *lp;
56
57 switch (mg_entity(av[0])) {
58 case MG_E_COLOR: /* get/set color context */
59 if (ac > 4)
60 return(MG_EARGC);
61 if (ac == 1) { /* set unnamed color context */
62 c_uncolor = c_dfcolor;
63 c_ccolor = &c_uncolor;
64 c_ccname = NULL;
65 return(MG_OK);
66 }
67 lp = lu_find(&clr_tab, av[1]); /* lookup context */
68 if (lp == NULL)
69 return(MG_EMEM);
70 c_ccname = lp->key;
71 c_ccolor = (C_COLOR *)lp->data;
72 if (ac == 2) { /* reestablish previous context */
73 if (c_ccolor == NULL)
74 return(MG_EUNDEF);
75 return(MG_OK);
76 }
77 if (av[2][0] != '=' || av[2][1])
78 return(MG_ETYPE);
79 if (c_ccolor == NULL) { /* create new color context */
80 lp->key = (char *)malloc(strlen(av[1])+1);
81 if (lp->key == NULL)
82 return(MG_EMEM);
83 strcpy(lp->key, av[1]);
84 lp->data = (char *)malloc(sizeof(C_COLOR));
85 if (lp->data == NULL)
86 return(MG_EMEM);
87 c_ccname = lp->key;
88 c_ccolor = (C_COLOR *)lp->data;
89 c_ccolor->clock = 0;
90 }
91 i = c_ccolor->clock;
92 if (ac == 3) { /* use default template */
93 *c_ccolor = c_dfcolor;
94 c_ccolor->clock = i + 1;
95 return(MG_OK);
96 }
97 lp = lu_find(&clr_tab, av[3]); /* lookup template */
98 if (lp == NULL)
99 return(MG_EMEM);
100 if (lp->data == NULL)
101 return(MG_EUNDEF);
102 *c_ccolor = *(C_COLOR *)lp->data;
103 c_ccolor->clock = i + 1;
104 return(MG_OK);
105 case MG_E_CXY: /* assign CIE XY value */
106 if (ac != 3)
107 return(MG_EARGC);
108 if (!isflt(av[1]) || !isflt(av[2]))
109 return(MG_ETYPE);
110 c_ccolor->cx = atof(av[1]);
111 c_ccolor->cy = atof(av[2]);
112 c_ccolor->flags = C_CDXY|C_CSXY;
113 if (c_ccolor->cx < 0. | c_ccolor->cy < 0. |
114 c_ccolor->cx + c_ccolor->cy > 1.)
115 return(MG_EILL);
116 c_ccolor->clock++;
117 return(MG_OK);
118 case MG_E_CSPEC: /* assign spectral values */
119 if (ac < 5)
120 return(MG_EARGC);
121 if (!isflt(av[1]) || !isflt(av[2]))
122 return(MG_ETYPE);
123 return(setspectrum(c_ccolor, atof(av[1]), atof(av[2]),
124 ac-3, av+3));
125 case MG_E_CMIX: /* mix colors */
126 if (ac < 5 || (ac-1)%2)
127 return(MG_EARGC);
128 if (!isflt(av[1]))
129 return(MG_ETYPE);
130 wsum = atof(av[1]);
131 if (wsum < 0.)
132 return(MG_EILL);
133 if ((lp = lu_find(&clr_tab, av[2])) == NULL)
134 return(MG_EMEM);
135 if (lp->data == NULL)
136 return(MG_EUNDEF);
137 *c_ccolor = *(C_COLOR *)lp->data;
138 for (i = 3; i < ac; i += 2) {
139 if (!isflt(av[i]))
140 return(MG_ETYPE);
141 w = atof(av[i]);
142 if (w < 0.)
143 return(MG_EILL);
144 if ((lp = lu_find(&clr_tab, av[i+1])) == NULL)
145 return(MG_EMEM);
146 if (lp->data == NULL)
147 return(MG_EUNDEF);
148 mixcolors(c_ccolor, wsum, c_ccolor,
149 w, (C_COLOR *)lp->data);
150 wsum += w;
151 }
152 c_ccolor->clock++;
153 return(MG_OK);
154 }
155 return(MG_EUNK);
156 }
157
158
159 int
160 c_hmaterial(ac, av) /* handle material entity */
161 int ac;
162 register char **av;
163 {
164 int i;
165 register LUENT *lp;
166
167 switch (mg_entity(av[0])) {
168 case MG_E_MATERIAL: /* get/set material context */
169 if (ac > 4)
170 return(MG_EARGC);
171 if (ac == 1) { /* set unnamed material context */
172 c_unmaterial = c_dfmaterial;
173 c_cmaterial = &c_unmaterial;
174 c_cmname = NULL;
175 return(MG_OK);
176 }
177 lp = lu_find(&mat_tab, av[1]); /* lookup context */
178 if (lp == NULL)
179 return(MG_EMEM);
180 c_cmname = lp->key;
181 c_cmaterial = (C_MATERIAL *)lp->data;
182 if (ac == 2) { /* reestablish previous context */
183 if (c_cmaterial == NULL)
184 return(MG_EUNDEF);
185 return(MG_OK);
186 }
187 if (av[2][0] != '=' || av[2][1])
188 return(MG_ETYPE);
189 if (c_cmaterial == NULL) { /* create new material */
190 lp->key = (char *)malloc(strlen(av[1])+1);
191 if (lp->key == NULL)
192 return(MG_EMEM);
193 strcpy(lp->key, av[1]);
194 lp->data = (char *)malloc(sizeof(C_MATERIAL));
195 if (lp->data == NULL)
196 return(MG_EMEM);
197 c_cmname = lp->key;
198 c_cmaterial = (C_MATERIAL *)lp->data;
199 c_cmaterial->clock = 0;
200 }
201 i = c_cmaterial->clock;
202 if (ac == 3) { /* use default template */
203 *c_cmaterial = c_dfmaterial;
204 c_cmaterial->clock = i + 1;
205 return(MG_OK);
206 }
207 lp = lu_find(&mat_tab, av[3]); /* lookup template */
208 if (lp == NULL)
209 return(MG_EMEM);
210 if (lp->data == NULL)
211 return(MG_EUNDEF);
212 *c_cmaterial = *(C_MATERIAL *)lp->data;
213 c_cmaterial->clock = i + 1;
214 return(MG_OK);
215 case MG_E_RD: /* set diffuse reflectance */
216 if (ac != 2)
217 return(MG_EARGC);
218 if (!isflt(av[1]))
219 return(MG_ETYPE);
220 c_cmaterial->rd = atof(av[1]);
221 if (c_cmaterial->rd < 0. | c_cmaterial->rd > 1.)
222 return(MG_EILL);
223 c_cmaterial->rd_c = *c_ccolor;
224 c_cmaterial->clock++;
225 return(MG_OK);
226 case MG_E_ED: /* set diffuse emittance */
227 if (ac != 2)
228 return(MG_EARGC);
229 if (!isflt(av[1]))
230 return(MG_ETYPE);
231 c_cmaterial->ed = atof(av[1]);
232 if (c_cmaterial->ed < 0.)
233 return(MG_EILL);
234 c_cmaterial->ed_c = *c_ccolor;
235 c_cmaterial->clock++;
236 return(MG_OK);
237 case MG_E_TD: /* set diffuse transmittance */
238 if (ac != 2)
239 return(MG_EARGC);
240 if (!isflt(av[1]))
241 return(MG_ETYPE);
242 c_cmaterial->td = atof(av[1]);
243 if (c_cmaterial->td < 0. | c_cmaterial->td > 1.)
244 return(MG_EILL);
245 c_cmaterial->td_c = *c_ccolor;
246 c_cmaterial->clock++;
247 return(MG_OK);
248 case MG_E_RS: /* set specular reflectance */
249 if (ac != 3)
250 return(MG_EARGC);
251 if (!isflt(av[1]) || !isflt(av[2]))
252 return(MG_ETYPE);
253 c_cmaterial->rs = atof(av[1]);
254 c_cmaterial->rs_a = atof(av[2]);
255 if (c_cmaterial->rs < 0. | c_cmaterial->rs > 1. |
256 c_cmaterial->rs_a < 0.)
257 return(MG_EILL);
258 c_cmaterial->rs_c = *c_ccolor;
259 c_cmaterial->clock++;
260 return(MG_OK);
261 case MG_E_TS: /* set specular transmittance */
262 if (ac != 3)
263 return(MG_EARGC);
264 if (!isflt(av[1]) || !isflt(av[2]))
265 return(MG_ETYPE);
266 c_cmaterial->ts = atof(av[1]);
267 c_cmaterial->ts_a = atof(av[2]);
268 if (c_cmaterial->ts < 0. | c_cmaterial->ts > 1. |
269 c_cmaterial->ts_a < 0.)
270 return(MG_EILL);
271 c_cmaterial->ts_c = *c_ccolor;
272 c_cmaterial->clock++;
273 return(MG_OK);
274 case MG_E_SIDES: /* set number of sides */
275 if (ac != 2)
276 return(MG_EARGC);
277 if (!isint(av[1]))
278 return(MG_ETYPE);
279 i = atoi(av[1]);
280 if (i == 1)
281 c_cmaterial->sided = 1;
282 else if (i == 2)
283 c_cmaterial->sided = 0;
284 else
285 return(MG_EILL);
286 c_cmaterial->clock++;
287 return(MG_OK);
288 }
289 return(MG_EUNK);
290 }
291
292
293 int
294 c_hvertex(ac, av) /* handle a vertex entity */
295 int ac;
296 register char **av;
297 {
298 int i;
299 register LUENT *lp;
300
301 switch (mg_entity(av[0])) {
302 case MG_E_VERTEX: /* get/set vertex context */
303 if (ac > 4)
304 return(MG_EARGC);
305 if (ac == 1) { /* set unnamed vertex context */
306 c_unvertex = c_dfvertex;
307 c_cvertex = &c_unvertex;
308 c_cvname = NULL;
309 return(MG_OK);
310 }
311 lp = lu_find(&vtx_tab, av[1]); /* lookup context */
312 if (lp == NULL)
313 return(MG_EMEM);
314 c_cvname = lp->key;
315 c_cvertex = (C_VERTEX *)lp->data;
316 if (ac == 2) { /* reestablish previous context */
317 if (c_cvertex == NULL)
318 return(MG_EUNDEF);
319 return(MG_OK);
320 }
321 if (av[2][0] != '=' || av[2][1])
322 return(MG_ETYPE);
323 if (c_cvertex == NULL) { /* create new vertex context */
324 lp->key = (char *)malloc(strlen(av[1])+1);
325 if (lp->key == NULL)
326 return(MG_EMEM);
327 strcpy(lp->key, av[1]);
328 lp->data = (char *)malloc(sizeof(C_VERTEX));
329 if (lp->data == NULL)
330 return(MG_EMEM);
331 c_cvname = lp->key;
332 c_cvertex = (C_VERTEX *)lp->data;
333 }
334 i = c_cvertex->clock;
335 if (ac == 3) { /* use default template */
336 *c_cvertex = c_dfvertex;
337 c_cvertex->clock = i + 1;
338 return(MG_OK);
339 }
340 lp = lu_find(&vtx_tab, av[3]); /* lookup template */
341 if (lp == NULL)
342 return(MG_EMEM);
343 if (lp->data == NULL)
344 return(MG_EUNDEF);
345 *c_cvertex = *(C_VERTEX *)lp->data;
346 c_cvertex->clock = i + 1;
347 return(MG_OK);
348 case MG_E_POINT: /* set point */
349 if (ac != 4)
350 return(MG_EARGC);
351 if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3]))
352 return(MG_ETYPE);
353 c_cvertex->p[0] = atof(av[1]);
354 c_cvertex->p[1] = atof(av[2]);
355 c_cvertex->p[2] = atof(av[3]);
356 c_cvertex->clock++;
357 return(MG_OK);
358 case MG_E_NORMAL: /* set normal */
359 if (ac != 4)
360 return(MG_EARGC);
361 if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3]))
362 return(MG_ETYPE);
363 c_cvertex->n[0] = atof(av[1]);
364 c_cvertex->n[1] = atof(av[2]);
365 c_cvertex->n[2] = atof(av[3]);
366 (void)normalize(c_cvertex->n);
367 c_cvertex->clock++;
368 return(MG_OK);
369 }
370 return(MG_EUNK);
371 }
372
373
374 void
375 c_clearall() /* empty context tables */
376 {
377 c_uncolor = c_dfcolor;
378 c_ccolor = &c_uncolor;
379 c_ccname = NULL;
380 lu_done(&clr_tab);
381 c_unmaterial = c_dfmaterial;
382 c_cmaterial = &c_unmaterial;
383 c_cmname = NULL;
384 lu_done(&mat_tab);
385 c_unvertex = c_dfvertex;
386 c_cvertex = &c_unvertex;
387 c_cvname = NULL;
388 lu_done(&vtx_tab);
389 }
390
391
392 C_MATERIAL *
393 c_getmaterial(name) /* get a named material */
394 char *name;
395 {
396 register LUENT *lp;
397
398 if ((lp = lu_find(&mat_tab, name)) == NULL)
399 return(NULL);
400 return((C_MATERIAL *)lp->data);
401 }
402
403
404 C_VERTEX *
405 c_getvert(name) /* get a named vertex */
406 char *name;
407 {
408 register LUENT *lp;
409
410 if ((lp = lu_find(&vtx_tab, name)) == NULL)
411 return(NULL);
412 return((C_VERTEX *)lp->data);
413 }
414
415
416 C_COLOR *
417 c_getcolor(name) /* get a named color */
418 char *name;
419 {
420 register LUENT *lp;
421
422 if ((lp = lu_find(&clr_tab, name)) == NULL)
423 return(NULL);
424 return((C_COLOR *)lp->data);
425 }
426
427
428 int
429 c_isgrey(clr) /* check if color is grey */
430 register C_COLOR *clr;
431 {
432 if (!(clr->flags & (C_CSXY|C_CSSPEC)))
433 return(1); /* no settings == grey */
434 c_ccvt(clr, C_CSXY);
435 return(clr->cx >= .323 && clr->cx <= .343 &&
436 clr->cy >= .323 && clr->cy <= .343);
437 }
438
439
440 void
441 c_ccvt(clr, fl) /* convert color representations */
442 register C_COLOR *clr;
443 int fl;
444 {
445 double x, y, z;
446 register int i;
447
448 fl &= ~clr->flags; /* ignore what's done */
449 if (!fl) /* everything's done! */
450 return;
451 if (!(clr->flags & (C_CSXY|C_CSSPEC))) /* nothing set! */
452 *clr = c_dfcolor;
453 if (fl & C_CSXY) { /* cspec -> cxy */
454 x = y = z = 0.;
455 for (i = 0; i < C_CNSS; i++) {
456 x += cie_xf.ssamp[i] * clr->ssamp[i];
457 y += cie_yf.ssamp[i] * clr->ssamp[i];
458 z += cie_zf.ssamp[i] * clr->ssamp[i];
459 }
460 x /= (double)cie_xf.ssum;
461 y /= (double)cie_yf.ssum;
462 z /= (double)cie_zf.ssum;
463 z += x + y;
464 clr->cx = x / z;
465 clr->cy = y / z;
466 clr->flags |= C_CSXY;
467 } else if (fl & C_CSSPEC) { /* cxy -> cspec */
468 z = (cie_xf.ssum + cie_yf.ssum + cie_zf.ssum) / 3.;
469 x = clr->cx * z / cie_xf.ssum;
470 y = clr->cy * z / cie_yf.ssum;
471 z = (1. - clr->cx - clr->cy) * z / cie_zf.ssum;
472 clr->ssum = 0;
473 for (i = 0; i < C_CNSS; i++)
474 clr->ssum += clr->ssamp[i] =
475 x * cie_xf.ssamp[i] +
476 y * cie_yf.ssamp[i] +
477 z * cie_zf.ssamp[i] ;
478 clr->flags |= C_CSSPEC;
479 }
480 if (fl & C_CSEFF) { /* compute efficacy */
481 if (clr->flags & C_CDSPEC) { /* from spectrum */
482 y = 0.;
483 for (i = 0; i < C_CNSS; i++)
484 y += cie_yf.ssamp[i] * clr->ssamp[i];
485 clr->eff = C_CLPWM * y / clr->ssum;
486 } else /* clr->flags & C_CDXY */ { /* from (x,y) */
487 clr->eff = clr->cx*cie_xf.eff + clr->cy*cie_yf.eff +
488 (1. - clr->cx - clr->cy)*cie_zf.eff;
489 }
490 clr->flags |= C_CSEFF;
491 }
492 }
493
494
495 static int
496 setspectrum(clr, wlmin, wlmax, ac, av) /* convert a spectrum */
497 register C_COLOR *clr;
498 double wlmin, wlmax;
499 int ac;
500 char **av;
501 {
502 double scale;
503 float va[C_CNSS];
504 register int i, pos;
505 int n, imax;
506 int wl;
507 double wl0, wlstep;
508 /* check bounds */
509 if (wlmax <= C_CMINWL | wlmax <= wlmin | wlmin >= C_CMAXWL)
510 return(MG_EILL);
511 wlstep = (wlmax - wlmin)/(ac-1);
512 while (wlmin < C_CMINWL) {
513 wlmin += wlstep;
514 ac--; av++;
515 }
516 while (wlmax > C_CMAXWL) {
517 wlmax -= wlstep;
518 ac--;
519 }
520 if (ac < 2)
521 return(MG_EILL);
522 imax = ac; /* box filter if necessary */
523 if (wlstep < C_CWLI) {
524 wlstep = C_CWLI;
525 imax = (wlmax - wlmin)/wlstep;
526 }
527 scale = 0.; /* get values and maximum */
528 pos = 0;
529 for (i = 0; i < imax; i++) {
530 va[i] = 0.; n = 0;
531 while (pos < (i+.5)*ac/imax) {
532 if (!isflt(av[pos]))
533 return(MG_ETYPE);
534 va[i] += atof(av[pos++]);
535 n++;
536 }
537 if (n > 1)
538 va[i] /= (double)n;
539 if (va[i] < 0.)
540 return(MG_EILL);
541 if (va[i] > scale)
542 scale = va[i];
543 }
544 if (scale == 0.)
545 return(MG_EILL);
546 scale = C_CMAXV / scale;
547 clr->ssum = 0; /* convert to our spacing */
548 wl0 = wlmin;
549 pos = 0;
550 for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI)
551 if (wl < wlmin | wl > wlmax)
552 clr->ssamp[i] = 0;
553 else {
554 while (wl0 + wlstep < wl+FTINY) {
555 wl0 += wlstep;
556 pos++;
557 }
558 if (wl+FTINY >= wl0 & wl-FTINY <= wl0)
559 clr->ssamp[i] = scale*va[pos];
560 else /* interpolate if necessary */
561 clr->ssamp[i] = scale / wlstep *
562 ( va[pos]*(wl0+wlstep - wl) +
563 va[pos+1]*(wl - wl0) );
564 clr->ssum += clr->ssamp[i];
565 }
566 clr->flags = C_CDSPEC|C_CSSPEC;
567 clr->clock++;
568 return(MG_OK);
569 }
570
571
572 static void
573 mixcolors(cres, w1, c1, w2, c2) /* mix two colors according to weights given */
574 register C_COLOR *cres, *c1, *c2;
575 double w1, w2;
576 {
577 double scale;
578 float cmix[C_CNSS];
579 register int i;
580
581 if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */
582 c_ccvt(c1, C_CSSPEC|C_CSEFF);
583 c_ccvt(c2, C_CSSPEC|C_CSEFF);
584 w1 /= c1->eff*c1->ssum;
585 w2 /= c2->eff*c2->ssum;
586 scale = 0.;
587 for (i = 0; i < C_CNSS; i++) {
588 cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i];
589 if (cmix[i] > scale)
590 scale = cmix[i];
591 }
592 scale = C_CMAXV / scale;
593 cres->ssum = 0;
594 for (i = 0; i < C_CNSS; i++)
595 cres->ssum += cres->ssamp[i] = scale*cmix[i] + .5;
596 cres->flags = C_CDSPEC|C_CSSPEC;
597 } else { /* CIE xy mixing */
598 c_ccvt(c1, C_CSXY);
599 c_ccvt(c2, C_CSXY);
600 scale = 1. / (w1/c1->cy + w2/c2->cy);
601 cres->cx = (c1->cx*w1/c1->cy + c2->cx*w2/c2->cy) * scale;
602 cres->cy = (w1 + w2) * scale;
603 cres->flags = C_CDXY|C_CSXY;
604 }
605 }
