--- ray/src/cv/mgflib/context.c 1994/06/25 16:33:14 1.9 +++ ray/src/cv/mgflib/context.c 1994/06/25 19:31:14 1.10 @@ -49,6 +49,7 @@ register char **av; { double w, wsum; register int i; + char *nm; register LUENT *lp; switch (mg_entity(av[0])) { @@ -82,10 +83,11 @@ register char **av; c_ccolor = (C_COLOR *)lp->data; c_ccolor->clock = 0; } + nm = lp->key; + i = c_ccolor->clock; if (ac == 3) { /* use default template */ - i = c_ccolor->clock; *c_ccolor = c_dfcolor; - c_ccolor->name = av[1]; + c_ccolor->name = nm; c_ccolor->clock = i + 1; return(MG_OK); } @@ -94,9 +96,8 @@ register char **av; return(MG_EMEM); if (lp->data == NULL) return(MG_EUNDEF); - i = c_ccolor->clock; *c_ccolor = *(C_COLOR *)lp->data; - c_ccolor->name = av[1]; + c_ccolor->name = nm; c_ccolor->clock = i + 1; return(MG_OK); case MG_E_CXY: /* assign CIE XY value */ @@ -146,6 +147,7 @@ register char **av; w, (C_COLOR *)lp->data); wsum += w; } + c_ccolor->clock++; return(MG_OK); } return(MG_EUNK); @@ -158,6 +160,7 @@ int ac; register char **av; { int i; + char *nm; register LUENT *lp; switch (mg_entity(av[0])) { @@ -191,10 +194,11 @@ register char **av; c_cmaterial = (C_MATERIAL *)lp->data; c_cmaterial->clock = 0; } + nm = lp->key; + i = c_cmaterial->clock; if (ac == 3) { /* use default template */ - i = c_cmaterial->clock; *c_cmaterial = c_dfmaterial; - c_cmaterial->name = av[1]; + c_cmaterial->name = nm; c_cmaterial->clock = i + 1; return(MG_OK); } @@ -203,9 +207,8 @@ register char **av; return(MG_EMEM); if (lp->data == NULL) return(MG_EUNDEF); - i = c_cmaterial->clock; *c_cmaterial = *(C_MATERIAL *)lp->data; - c_cmaterial->name = av[1]; + c_cmaterial->name = nm; c_cmaterial->clock = i + 1; return(MG_OK); case MG_E_RD: /* set diffuse reflectance */ @@ -278,6 +281,7 @@ int ac; register char **av; { int i; + char *nm; register LUENT *lp; switch (mg_entity(av[0])) { @@ -310,10 +314,11 @@ register char **av; return(MG_EMEM); c_cvertex = (C_VERTEX *)lp->data; } + nm = lp->key; + i = c_cvertex->clock; if (ac == 3) { /* use default template */ - i = c_cvertex->clock; *c_cvertex = c_dfvertex; - c_cvertex->name = av[1]; + c_cvertex->name = nm; c_cvertex->clock = i + 1; return(MG_OK); } @@ -322,9 +327,8 @@ register char **av; return(MG_EMEM); if (lp->data == NULL) return(MG_EUNDEF); - i = c_cvertex->clock; *c_cvertex = *(C_VERTEX *)lp->data; - c_cvertex->name = av[1]; + c_cvertex->name = nm; c_cvertex->clock = i + 1; return(MG_OK); case MG_E_POINT: /* set point */ @@ -533,5 +537,4 @@ double w1, w2; cres->cy = (w1 + w2) * scale; cres->flags = C_CDXY|C_CSXY; } - cres->clock++; /* record the change */ }
