--- ray/src/cv/mgflib/context.c 1994/06/25 11:55:45 1.8 +++ ray/src/cv/mgflib/context.c 1994/06/25 16:33:14 1.9 @@ -63,15 +63,15 @@ register char **av; lp = lu_find(&clr_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); + c_ccolor = (C_COLOR *)lp->data; if (ac == 2) { /* reestablish previous context */ - if (lp->data == NULL) + if (c_ccolor == NULL) return(MG_EUNDEF); - c_ccolor = (C_COLOR *)lp->data; return(MG_OK); } if (av[2][0] != '=' || av[2][1]) return(MG_ETYPE); - if (lp->key == NULL) { /* create new color context */ + if (c_ccolor == NULL) { /* create new color context */ lp->key = (char *)malloc(strlen(av[1])+1); if (lp->key == NULL) return(MG_EMEM); @@ -79,11 +79,14 @@ register char **av; lp->data = (char *)malloc(sizeof(C_COLOR)); if (lp->data == NULL) return(MG_EMEM); + c_ccolor = (C_COLOR *)lp->data; + c_ccolor->clock = 0; } - c_ccolor = (C_COLOR *)lp->data; if (ac == 3) { /* use default template */ + i = c_ccolor->clock; *c_ccolor = c_dfcolor; - c_ccolor->name = lp->key; + c_ccolor->name = av[1]; + c_ccolor->clock = i + 1; return(MG_OK); } lp = lu_find(&clr_tab, av[3]); /* lookup template */ @@ -91,11 +94,10 @@ register char **av; return(MG_EMEM); if (lp->data == NULL) return(MG_EUNDEF); + i = c_ccolor->clock; *c_ccolor = *(C_COLOR *)lp->data; - c_ccolor->name = lp->key; - c_ccolor->clock = 1; - if (ac > 4) - return(MG_EARGC); + c_ccolor->name = av[1]; + c_ccolor->clock = i + 1; return(MG_OK); case MG_E_CXY: /* assign CIE XY value */ if (ac != 3) @@ -155,6 +157,7 @@ c_hmaterial(ac, av) /* handle material entity */ int ac; register char **av; { + int i; register LUENT *lp; switch (mg_entity(av[0])) { @@ -169,15 +172,15 @@ register char **av; lp = lu_find(&mat_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); + c_cmaterial = (C_MATERIAL *)lp->data; if (ac == 2) { /* reestablish previous context */ - if (lp->data == NULL) + if (c_cmaterial == NULL) return(MG_EUNDEF); - c_cmaterial = (C_MATERIAL *)lp->data; return(MG_OK); } if (av[2][0] != '=' || av[2][1]) return(MG_ETYPE); - if (lp->key == NULL) { /* create new material context */ + if (c_cmaterial == NULL) { /* create new material */ lp->key = (char *)malloc(strlen(av[1])+1); if (lp->key == NULL) return(MG_EMEM); @@ -185,11 +188,14 @@ register char **av; lp->data = (char *)malloc(sizeof(C_MATERIAL)); if (lp->data == NULL) return(MG_EMEM); + c_cmaterial = (C_MATERIAL *)lp->data; + c_cmaterial->clock = 0; } - c_cmaterial = (C_MATERIAL *)lp->data; if (ac == 3) { /* use default template */ + i = c_cmaterial->clock; *c_cmaterial = c_dfmaterial; - c_cmaterial->name = lp->key; + c_cmaterial->name = av[1]; + c_cmaterial->clock = i + 1; return(MG_OK); } lp = lu_find(&mat_tab, av[3]); /* lookup template */ @@ -197,11 +203,10 @@ register char **av; return(MG_EMEM); if (lp->data == NULL) return(MG_EUNDEF); + i = c_cmaterial->clock; *c_cmaterial = *(C_MATERIAL *)lp->data; - c_cmaterial->name = lp->key; - c_cmaterial->clock = 1; - if (ac > 4) - return(MG_EARGC); + c_cmaterial->name = av[1]; + c_cmaterial->clock = i + 1; return(MG_OK); case MG_E_RD: /* set diffuse reflectance */ if (ac != 2) @@ -272,6 +277,7 @@ c_hvertex(ac, av) /* handle a vertex entity */ int ac; register char **av; { + int i; register LUENT *lp; switch (mg_entity(av[0])) { @@ -286,15 +292,15 @@ register char **av; lp = lu_find(&vtx_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); + c_cvertex = (C_VERTEX *)lp->data; if (ac == 2) { /* reestablish previous context */ - if (lp->data == NULL) + if (c_cvertex == NULL) return(MG_EUNDEF); - c_cvertex = (C_VERTEX *)lp->data; return(MG_OK); } if (av[2][0] != '=' || av[2][1]) return(MG_ETYPE); - if (lp->key == NULL) { /* create new vertex context */ + if (c_cvertex == NULL) { /* create new vertex context */ lp->key = (char *)malloc(strlen(av[1])+1); if (lp->key == NULL) return(MG_EMEM); @@ -302,11 +308,13 @@ register char **av; lp->data = (char *)malloc(sizeof(C_VERTEX)); if (lp->data == NULL) return(MG_EMEM); + c_cvertex = (C_VERTEX *)lp->data; } - c_cvertex = (C_VERTEX *)lp->data; if (ac == 3) { /* use default template */ + i = c_cvertex->clock; *c_cvertex = c_dfvertex; - c_cvertex->name = lp->key + c_cvertex->name = av[1]; + c_cvertex->clock = i + 1; return(MG_OK); } lp = lu_find(&vtx_tab, av[3]); /* lookup template */ @@ -314,11 +322,10 @@ register char **av; return(MG_EMEM); if (lp->data == NULL) return(MG_EUNDEF); + i = c_cvertex->clock; *c_cvertex = *(C_VERTEX *)lp->data; - c_cvertex->name = lp->key - c_cvertex->clock = 1; - if (ac > 4) - return(MG_EARGC); + c_cvertex->name = av[1]; + c_cvertex->clock = i + 1; return(MG_OK); case MG_E_POINT: /* set point */ if (ac != 4)
