--- ray/src/cv/mgflib/context.c 1994/06/22 15:33:44 1.2 +++ ray/src/cv/mgflib/context.c 2011/02/03 19:36:10 1.30 @@ -1,21 +1,17 @@ -/* Copyright (c) 1994 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: context.c,v 1.30 2011/02/03 19:36:10 greg Exp $"; #endif - /* * Context handlers */ #include -#include +#include #include #include "parser.h" #include "lookup.h" /* default context values */ -static C_COLOR c_dfcolor = C_DEFCOLOR; static C_MATERIAL c_dfmaterial = C_DEFMATERIAL; static C_VERTEX c_dfvertex = C_DEFVERTEX; @@ -26,40 +22,53 @@ static C_VERTEX c_unvertex = C_DEFVERTEX; /* the current contexts */ C_COLOR *c_ccolor = &c_uncolor; +char *c_ccname = NULL; C_MATERIAL *c_cmaterial = &c_unmaterial; +char *c_cmname = NULL; C_VERTEX *c_cvertex = &c_unvertex; +char *c_cvname = NULL; -static LUTAB clr_tab; /* color lookup table */ -static LUTAB mat_tab; /* material lookup table */ -static LUTAB vtx_tab; /* vertex lookup table */ +static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */ +static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */ +static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */ +static int setspectrum(); + int c_hcolor(ac, av) /* handle color entity */ int ac; register char **av; { + double w, wsum; + register int i; register LUENT *lp; switch (mg_entity(av[0])) { case MG_E_COLOR: /* get/set color context */ + if (ac > 4) + return(MG_EARGC); if (ac == 1) { /* set unnamed color context */ c_uncolor = c_dfcolor; c_ccolor = &c_uncolor; + c_ccname = NULL; return(MG_OK); } + if (!isname(av[1])) + return(MG_EILL); lp = lu_find(&clr_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); + c_ccname = lp->key; + c_ccolor = (C_COLOR *)lp->data; if (ac == 2) { /* reestablish previous context */ - if (lp->data == NULL) + if (c_ccolor == NULL) return(MG_EUNDEF); - c_ccolor = (C_COLOR *)lp->data; return(MG_OK); } if (av[2][0] != '=' || av[2][1]) return(MG_ETYPE); - if (lp->key == NULL) { /* create new color context */ + if (c_ccolor == NULL) { /* create new color context */ lp->key = (char *)malloc(strlen(av[1])+1); if (lp->key == NULL) return(MG_EMEM); @@ -67,10 +76,15 @@ register char **av; lp->data = (char *)malloc(sizeof(C_COLOR)); if (lp->data == NULL) return(MG_EMEM); + c_ccname = lp->key; + c_ccolor = (C_COLOR *)lp->data; + c_ccolor->clock = 0; + c_ccolor->client_data = NULL; } - c_ccolor = (C_COLOR *)lp->data; + i = c_ccolor->clock; if (ac == 3) { /* use default template */ *c_ccolor = c_dfcolor; + c_ccolor->clock = i + 1; return(MG_OK); } lp = lu_find(&clr_tab, av[3]); /* lookup template */ @@ -79,20 +93,64 @@ register char **av; if (lp->data == NULL) return(MG_EUNDEF); *c_ccolor = *(C_COLOR *)lp->data; - if (ac > 4) - return(MG_EARGC); + c_ccolor->clock = i + 1; return(MG_OK); case MG_E_CXY: /* assign CIE XY value */ if (ac != 3) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2])) + if (!isflt(av[1]) | !isflt(av[2])) return(MG_ETYPE); c_ccolor->cx = atof(av[1]); c_ccolor->cy = atof(av[2]); - if (c_ccolor->cx < 0. | c_ccolor->cy < 0. | - c_ccolor->cx + c_ccolor->cy > 1.) + c_ccolor->flags = C_CDXY|C_CSXY; + if ((c_ccolor->cx < 0.) | (c_ccolor->cy < 0.) | + (c_ccolor->cx + c_ccolor->cy > 1.)) return(MG_EILL); + c_ccolor->clock++; return(MG_OK); + case MG_E_CSPEC: /* assign spectral values */ + if (ac < 5) + return(MG_EARGC); + if (!isflt(av[1]) | !isflt(av[2])) + return(MG_ETYPE); + return(setspectrum(c_ccolor, atof(av[1]), atof(av[2]), + ac-3, av+3)); + case MG_E_CCT: /* assign black body spectrum */ + if (ac != 2) + return(MG_EARGC); + if (!isflt(av[1])) + return(MG_ETYPE); + if (!c_bbtemp(c_ccolor, atof(av[1]))) + return(MG_EILL); + c_ccolor->clock++; + return(MG_OK); + case MG_E_CMIX: /* mix colors */ + if (ac < 5 || (ac-1)%2) + return(MG_EARGC); + if (!isflt(av[1])) + return(MG_ETYPE); + wsum = atof(av[1]); + if ((lp = lu_find(&clr_tab, av[2])) == NULL) + return(MG_EMEM); + if (lp->data == NULL) + return(MG_EUNDEF); + *c_ccolor = *(C_COLOR *)lp->data; + for (i = 3; i < ac; i += 2) { + if (!isflt(av[i])) + return(MG_ETYPE); + w = atof(av[i]); + if ((lp = lu_find(&clr_tab, av[i+1])) == NULL) + return(MG_EMEM); + if (lp->data == NULL) + return(MG_EUNDEF); + c_cmix(c_ccolor, wsum, c_ccolor, + w, (C_COLOR *)lp->data); + wsum += w; + } + if (wsum <= 0.) + return(MG_EILL); + c_ccolor->clock++; + return(MG_OK); } return(MG_EUNK); } @@ -103,27 +161,34 @@ c_hmaterial(ac, av) /* handle material entity */ int ac; register char **av; { + int i; register LUENT *lp; switch (mg_entity(av[0])) { case MG_E_MATERIAL: /* get/set material context */ + if (ac > 4) + return(MG_EARGC); if (ac == 1) { /* set unnamed material context */ c_unmaterial = c_dfmaterial; c_cmaterial = &c_unmaterial; + c_cmname = NULL; return(MG_OK); } + if (!isname(av[1])) + return(MG_EILL); lp = lu_find(&mat_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); + c_cmname = lp->key; + c_cmaterial = (C_MATERIAL *)lp->data; if (ac == 2) { /* reestablish previous context */ - if (lp->data == NULL) + if (c_cmaterial == NULL) return(MG_EUNDEF); - c_cmaterial = (C_MATERIAL *)lp->data; return(MG_OK); } if (av[2][0] != '=' || av[2][1]) return(MG_ETYPE); - if (lp->key == NULL) { /* create new material context */ + if (c_cmaterial == NULL) { /* create new material */ lp->key = (char *)malloc(strlen(av[1])+1); if (lp->key == NULL) return(MG_EMEM); @@ -131,11 +196,15 @@ register char **av; lp->data = (char *)malloc(sizeof(C_MATERIAL)); if (lp->data == NULL) return(MG_EMEM); + c_cmname = lp->key; + c_cmaterial = (C_MATERIAL *)lp->data; + c_cmaterial->clock = 0; + c_cmaterial->client_data = NULL; } - c_cmaterial = (C_MATERIAL *)lp->data; + i = c_cmaterial->clock; if (ac == 3) { /* use default template */ *c_cmaterial = c_dfmaterial; - c_cmaterial->name = lp->key; + c_cmaterial->clock = i + 1; return(MG_OK); } lp = lu_find(&mat_tab, av[3]); /* lookup template */ @@ -144,10 +213,18 @@ register char **av; if (lp->data == NULL) return(MG_EUNDEF); *c_cmaterial = *(C_MATERIAL *)lp->data; - c_cmaterial->name = lp->key; - c_cmaterial->clock = 1; - if (ac > 4) + c_cmaterial->clock = i + 1; + return(MG_OK); + case MG_E_IR: /* set index of refraction */ + if (ac != 3) return(MG_EARGC); + if (!isflt(av[1]) | !isflt(av[2])) + return(MG_ETYPE); + c_cmaterial->nr = atof(av[1]); + c_cmaterial->ni = atof(av[2]); + if (c_cmaterial->nr <= FTINY) + return(MG_EILL); + c_cmaterial->clock++; return(MG_OK); case MG_E_RD: /* set diffuse reflectance */ if (ac != 2) @@ -155,7 +232,7 @@ register char **av; if (!isflt(av[1])) return(MG_ETYPE); c_cmaterial->rd = atof(av[1]); - if (c_cmaterial->rd < 0. | c_cmaterial->rd > 1.) + if ((c_cmaterial->rd < 0.) | (c_cmaterial->rd > 1.)) return(MG_EILL); c_cmaterial->rd_c = *c_ccolor; c_cmaterial->clock++; @@ -177,19 +254,20 @@ register char **av; if (!isflt(av[1])) return(MG_ETYPE); c_cmaterial->td = atof(av[1]); - if (c_cmaterial->td < 0. | c_cmaterial->td > 1.) + if ((c_cmaterial->td < 0.) | (c_cmaterial->td > 1.)) return(MG_EILL); c_cmaterial->td_c = *c_ccolor; + c_cmaterial->clock++; return(MG_OK); case MG_E_RS: /* set specular reflectance */ if (ac != 3) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2])) + if (!isflt(av[1]) | !isflt(av[2])) return(MG_ETYPE); c_cmaterial->rs = atof(av[1]); c_cmaterial->rs_a = atof(av[2]); - if (c_cmaterial->rs < 0. | c_cmaterial->rs > 1. | - c_cmaterial->rs_a < 0.) + if ((c_cmaterial->rs < 0.) | (c_cmaterial->rs > 1.) | + (c_cmaterial->rs_a < 0.)) return(MG_EILL); c_cmaterial->rs_c = *c_ccolor; c_cmaterial->clock++; @@ -197,16 +275,30 @@ register char **av; case MG_E_TS: /* set specular transmittance */ if (ac != 3) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2])) + if (!isflt(av[1]) | !isflt(av[2])) return(MG_ETYPE); c_cmaterial->ts = atof(av[1]); c_cmaterial->ts_a = atof(av[2]); - if (c_cmaterial->ts < 0. | c_cmaterial->ts > 1. | - c_cmaterial->ts_a < 0.) + if ((c_cmaterial->ts < 0.) | (c_cmaterial->ts > 1.) | + (c_cmaterial->ts_a < 0.)) return(MG_EILL); c_cmaterial->ts_c = *c_ccolor; c_cmaterial->clock++; return(MG_OK); + case MG_E_SIDES: /* set number of sides */ + if (ac != 2) + return(MG_EARGC); + if (!isint(av[1])) + return(MG_ETYPE); + i = atoi(av[1]); + if (i == 1) + c_cmaterial->sided = 1; + else if (i == 2) + c_cmaterial->sided = 0; + else + return(MG_EILL); + c_cmaterial->clock++; + return(MG_OK); } return(MG_EUNK); } @@ -217,27 +309,34 @@ c_hvertex(ac, av) /* handle a vertex entity */ int ac; register char **av; { + int i; register LUENT *lp; switch (mg_entity(av[0])) { case MG_E_VERTEX: /* get/set vertex context */ + if (ac > 4) + return(MG_EARGC); if (ac == 1) { /* set unnamed vertex context */ c_unvertex = c_dfvertex; c_cvertex = &c_unvertex; + c_cvname = NULL; return(MG_OK); } + if (!isname(av[1])) + return(MG_EILL); lp = lu_find(&vtx_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); + c_cvname = lp->key; + c_cvertex = (C_VERTEX *)lp->data; if (ac == 2) { /* reestablish previous context */ - if (lp->data == NULL) + if (c_cvertex == NULL) return(MG_EUNDEF); - c_cvertex = (C_VERTEX *)lp->data; return(MG_OK); } if (av[2][0] != '=' || av[2][1]) return(MG_ETYPE); - if (lp->key == NULL) { /* create new vertex context */ + if (c_cvertex == NULL) { /* create new vertex context */ lp->key = (char *)malloc(strlen(av[1])+1); if (lp->key == NULL) return(MG_EMEM); @@ -245,10 +344,15 @@ register char **av; lp->data = (char *)malloc(sizeof(C_VERTEX)); if (lp->data == NULL) return(MG_EMEM); + c_cvname = lp->key; + c_cvertex = (C_VERTEX *)lp->data; + c_cvertex->clock = 0; + c_cvertex->client_data = NULL; } - c_cvertex = (C_VERTEX *)lp->data; + i = c_cvertex->clock; if (ac == 3) { /* use default template */ *c_cvertex = c_dfvertex; + c_cvertex->clock = i + 1; return(MG_OK); } lp = lu_find(&vtx_tab, av[3]); /* lookup template */ @@ -257,57 +361,64 @@ register char **av; if (lp->data == NULL) return(MG_EUNDEF); *c_cvertex = *(C_VERTEX *)lp->data; - if (ac > 4) - return(MG_EARGC); + c_cvertex->clock = i + 1; return(MG_OK); case MG_E_POINT: /* set point */ if (ac != 4) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3])) + if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3])) return(MG_ETYPE); c_cvertex->p[0] = atof(av[1]); c_cvertex->p[1] = atof(av[2]); c_cvertex->p[2] = atof(av[3]); + c_cvertex->clock++; return(MG_OK); case MG_E_NORMAL: /* set normal */ if (ac != 4) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3])) + if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3])) return(MG_ETYPE); c_cvertex->n[0] = atof(av[1]); c_cvertex->n[1] = atof(av[2]); c_cvertex->n[2] = atof(av[3]); (void)normalize(c_cvertex->n); + c_cvertex->clock++; return(MG_OK); } return(MG_EUNK); } -static void -freectx(lp) /* free a context table entry */ -register LUENT *lp; -{ - free((MEM_PTR)lp->key); - free((MEM_PTR)lp->data); -} - - void c_clearall() /* empty context tables */ { c_uncolor = c_dfcolor; c_ccolor = &c_uncolor; - lu_done(&clr_tab, freectx); + c_ccname = NULL; + lu_done(&clr_tab); c_unmaterial = c_dfmaterial; c_cmaterial = &c_unmaterial; - lu_done(&mat_tab, freectx); + c_cmname = NULL; + lu_done(&mat_tab); c_unvertex = c_dfvertex; c_cvertex = &c_unvertex; - lu_done(&vtx_tab, freectx); + c_cvname = NULL; + lu_done(&vtx_tab); } +C_MATERIAL * +c_getmaterial(name) /* get a named material */ +char *name; +{ + register LUENT *lp; + + if ((lp = lu_find(&mat_tab, name)) == NULL) + return(NULL); + return((C_MATERIAL *)lp->data); +} + + C_VERTEX * c_getvert(name) /* get a named vertex */ char *name; @@ -317,4 +428,97 @@ char *name; if ((lp = lu_find(&vtx_tab, name)) == NULL) return(NULL); return((C_VERTEX *)lp->data); +} + + +C_COLOR * +c_getcolor(name) /* get a named color */ +char *name; +{ + register LUENT *lp; + + if ((lp = lu_find(&clr_tab, name)) == NULL) + return(NULL); + return((C_COLOR *)lp->data); +} + + +static int +setspectrum(clr, wlmin, wlmax, ac, av) /* convert a spectrum */ +register C_COLOR *clr; +double wlmin, wlmax; +int ac; +char **av; +{ + double scale; + float va[C_CNSS]; + register int i, pos; + int n, imax; + int wl; + double wl0, wlstep; + double boxpos, boxstep; + /* check bounds */ + if ((wlmax <= C_CMINWL) | (wlmax <= wlmin) | (wlmin >= C_CMAXWL)) + return(MG_EILL); + wlstep = (wlmax - wlmin)/(ac-1); + while (wlmin < C_CMINWL) { + wlmin += wlstep; + ac--; av++; + } + while (wlmax > C_CMAXWL) { + wlmax -= wlstep; + ac--; + } + imax = ac; /* box filter if necessary */ + boxpos = 0; + boxstep = 1; + if (wlstep < C_CWLI) { + imax = (wlmax - wlmin)/C_CWLI + (1-FTINY); + boxpos = (wlmin - C_CMINWL)/C_CWLI; + boxstep = wlstep/C_CWLI; + wlstep = C_CWLI; + } + scale = 0.; /* get values and maximum */ + pos = 0; + for (i = 0; i < imax; i++) { + va[i] = 0.; n = 0; + while (boxpos < i+.5 && pos < ac) { + if (!isflt(av[pos])) + return(MG_ETYPE); + va[i] += atof(av[pos++]); + n++; + boxpos += boxstep; + } + if (n > 1) + va[i] /= (double)n; + if (va[i] > scale) + scale = va[i]; + else if (va[i] < -scale) + scale = -va[i]; + } + if (scale <= FTINY) + return(MG_EILL); + scale = C_CMAXV / scale; + clr->ssum = 0; /* convert to our spacing */ + wl0 = wlmin; + pos = 0; + for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI) + if ((wl < wlmin) | (wl > wlmax)) + clr->ssamp[i] = 0; + else { + while (wl0 + wlstep < wl+FTINY) { + wl0 += wlstep; + pos++; + } + if ((wl+FTINY >= wl0) & (wl-FTINY <= wl0)) + clr->ssamp[i] = scale*va[pos] + .5; + else /* interpolate if necessary */ + clr->ssamp[i] = .5 + scale / wlstep * + ( va[pos]*(wl0+wlstep - wl) + + va[pos+1]*(wl - wl0) ); + clr->ssum += clr->ssamp[i]; + } + clr->flags = C_CDSPEC|C_CSSPEC; + clr->clock++; + return(MG_OK); }
