--- ray/src/cv/mgflib/context.c 1994/06/22 15:33:44 1.2 +++ ray/src/cv/mgflib/context.c 1997/02/12 11:38:52 1.24 @@ -1,4 +1,4 @@ -/* Copyright (c) 1994 Regents of the University of California */ +/* Copyright (c) 1997 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -26,40 +26,100 @@ static C_VERTEX c_unvertex = C_DEFVERTEX; /* the current contexts */ C_COLOR *c_ccolor = &c_uncolor; +char *c_ccname = NULL; C_MATERIAL *c_cmaterial = &c_unmaterial; +char *c_cmname = NULL; C_VERTEX *c_cvertex = &c_unvertex; +char *c_cvname = NULL; -static LUTAB clr_tab; /* color lookup table */ -static LUTAB mat_tab; /* material lookup table */ -static LUTAB vtx_tab; /* vertex lookup table */ +static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */ +static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */ +static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */ + /* CIE 1931 Standard Observer curves */ +static C_COLOR cie_xf = { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF, + {14,42,143,435,1344,2839,3483,3362,2908,1954,956, + 320,49,93,633,1655,2904,4334,5945,7621,9163,10263, + 10622,10026,8544,6424,4479,2835,1649,874,468,227, + 114,58,29,14,7,3,2,1,0}, 106836L, .467, .368, 362.230 + }; +static C_COLOR cie_yf = { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF, + {0,1,4,12,40,116,230,380,600,910,1390,2080,3230, + 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310, + 5030,3810,2650,1750,1070,610,320,170,82,41,21,10, + 5,2,1,1,0,0}, 106856L, .398, .542, 493.525 + }; +static C_COLOR cie_zf = { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF, + {65,201,679,2074,6456,13856,17471,17721,16692, + 12876,8130,4652,2720,1582,782,422,203,87,39,21,17, + 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, + 106770L, .147, .077, 54.363 + }; + /* Derived CIE 1931 Primaries (imaginary) */ +static C_COLOR cie_xp = { 1, C_CDSPEC|C_CSSPEC|C_CSXY, + {-174,-198,-195,-197,-202,-213,-235,-272,-333, + -444,-688,-1232,-2393,-4497,-6876,-6758,-5256, + -3100,-815,1320,3200,4782,5998,6861,7408,7754, + 7980,8120,8199,8240,8271,8292,8309,8283,8469, + 8336,8336,8336,8336,8336,8336}, + 127424L, 1., .0, + }; +static C_COLOR cie_yp = { 1, C_CDSPEC|C_CSSPEC|C_CSXY, + {-451,-431,-431,-430,-427,-417,-399,-366,-312, + -204,57,691,2142,4990,8810,9871,9122,7321,5145, + 3023,1123,-473,-1704,-2572,-3127,-3474,-3704, + -3846,-3927,-3968,-3999,-4021,-4038,-4012,-4201, + -4066,-4066,-4066,-4066,-4066,-4066}, + -23035L, .0, 1., + }; +static C_COLOR cie_zp = { 1, C_CDSPEC|C_CSSPEC|C_CSXY, + {4051,4054,4052,4053,4054,4056,4059,4064,4071, + 4074,4056,3967,3677,2933,1492,313,-440,-795, + -904,-918,-898,-884,-869,-863,-855,-855,-851, + -848,-847,-846,-846,-846,-845,-846,-843,-845, + -845,-845,-845,-845,-845}, + 36057L, .0, .0, + }; +static int setspectrum(); +static int setbbtemp(); +static void mixcolors(); + + int c_hcolor(ac, av) /* handle color entity */ int ac; register char **av; { + double w, wsum; + register int i; register LUENT *lp; switch (mg_entity(av[0])) { case MG_E_COLOR: /* get/set color context */ + if (ac > 4) + return(MG_EARGC); if (ac == 1) { /* set unnamed color context */ c_uncolor = c_dfcolor; c_ccolor = &c_uncolor; + c_ccname = NULL; return(MG_OK); } + if (!isname(av[1])) + return(MG_EILL); lp = lu_find(&clr_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); + c_ccname = lp->key; + c_ccolor = (C_COLOR *)lp->data; if (ac == 2) { /* reestablish previous context */ - if (lp->data == NULL) + if (c_ccolor == NULL) return(MG_EUNDEF); - c_ccolor = (C_COLOR *)lp->data; return(MG_OK); } if (av[2][0] != '=' || av[2][1]) return(MG_ETYPE); - if (lp->key == NULL) { /* create new color context */ + if (c_ccolor == NULL) { /* create new color context */ lp->key = (char *)malloc(strlen(av[1])+1); if (lp->key == NULL) return(MG_EMEM); @@ -67,10 +127,14 @@ register char **av; lp->data = (char *)malloc(sizeof(C_COLOR)); if (lp->data == NULL) return(MG_EMEM); + c_ccname = lp->key; + c_ccolor = (C_COLOR *)lp->data; + c_ccolor->clock = 0; } - c_ccolor = (C_COLOR *)lp->data; + i = c_ccolor->clock; if (ac == 3) { /* use default template */ *c_ccolor = c_dfcolor; + c_ccolor->clock = i + 1; return(MG_OK); } lp = lu_find(&clr_tab, av[3]); /* lookup template */ @@ -79,20 +143,61 @@ register char **av; if (lp->data == NULL) return(MG_EUNDEF); *c_ccolor = *(C_COLOR *)lp->data; - if (ac > 4) - return(MG_EARGC); + c_ccolor->clock = i + 1; return(MG_OK); case MG_E_CXY: /* assign CIE XY value */ if (ac != 3) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2])) + if (!isflt(av[1]) | !isflt(av[2])) return(MG_ETYPE); c_ccolor->cx = atof(av[1]); c_ccolor->cy = atof(av[2]); + c_ccolor->flags = C_CDXY|C_CSXY; if (c_ccolor->cx < 0. | c_ccolor->cy < 0. | c_ccolor->cx + c_ccolor->cy > 1.) return(MG_EILL); + c_ccolor->clock++; return(MG_OK); + case MG_E_CSPEC: /* assign spectral values */ + if (ac < 5) + return(MG_EARGC); + if (!isflt(av[1]) | !isflt(av[2])) + return(MG_ETYPE); + return(setspectrum(c_ccolor, atof(av[1]), atof(av[2]), + ac-3, av+3)); + case MG_E_CCT: /* assign black body spectrum */ + if (ac != 2) + return(MG_EARGC); + if (!isflt(av[1])) + return(MG_ETYPE); + return(setbbtemp(c_ccolor, atof(av[1]))); + case MG_E_CMIX: /* mix colors */ + if (ac < 5 || (ac-1)%2) + return(MG_EARGC); + if (!isflt(av[1])) + return(MG_ETYPE); + wsum = atof(av[1]); + if ((lp = lu_find(&clr_tab, av[2])) == NULL) + return(MG_EMEM); + if (lp->data == NULL) + return(MG_EUNDEF); + *c_ccolor = *(C_COLOR *)lp->data; + for (i = 3; i < ac; i += 2) { + if (!isflt(av[i])) + return(MG_ETYPE); + w = atof(av[i]); + if ((lp = lu_find(&clr_tab, av[i+1])) == NULL) + return(MG_EMEM); + if (lp->data == NULL) + return(MG_EUNDEF); + mixcolors(c_ccolor, wsum, c_ccolor, + w, (C_COLOR *)lp->data); + wsum += w; + } + if (wsum <= 0.) + return(MG_EILL); + c_ccolor->clock++; + return(MG_OK); } return(MG_EUNK); } @@ -103,27 +208,34 @@ c_hmaterial(ac, av) /* handle material entity */ int ac; register char **av; { + int i; register LUENT *lp; switch (mg_entity(av[0])) { case MG_E_MATERIAL: /* get/set material context */ + if (ac > 4) + return(MG_EARGC); if (ac == 1) { /* set unnamed material context */ c_unmaterial = c_dfmaterial; c_cmaterial = &c_unmaterial; + c_cmname = NULL; return(MG_OK); } + if (!isname(av[1])) + return(MG_EILL); lp = lu_find(&mat_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); + c_cmname = lp->key; + c_cmaterial = (C_MATERIAL *)lp->data; if (ac == 2) { /* reestablish previous context */ - if (lp->data == NULL) + if (c_cmaterial == NULL) return(MG_EUNDEF); - c_cmaterial = (C_MATERIAL *)lp->data; return(MG_OK); } if (av[2][0] != '=' || av[2][1]) return(MG_ETYPE); - if (lp->key == NULL) { /* create new material context */ + if (c_cmaterial == NULL) { /* create new material */ lp->key = (char *)malloc(strlen(av[1])+1); if (lp->key == NULL) return(MG_EMEM); @@ -131,11 +243,14 @@ register char **av; lp->data = (char *)malloc(sizeof(C_MATERIAL)); if (lp->data == NULL) return(MG_EMEM); + c_cmname = lp->key; + c_cmaterial = (C_MATERIAL *)lp->data; + c_cmaterial->clock = 0; } - c_cmaterial = (C_MATERIAL *)lp->data; + i = c_cmaterial->clock; if (ac == 3) { /* use default template */ *c_cmaterial = c_dfmaterial; - c_cmaterial->name = lp->key; + c_cmaterial->clock = i + 1; return(MG_OK); } lp = lu_find(&mat_tab, av[3]); /* lookup template */ @@ -144,10 +259,18 @@ register char **av; if (lp->data == NULL) return(MG_EUNDEF); *c_cmaterial = *(C_MATERIAL *)lp->data; - c_cmaterial->name = lp->key; - c_cmaterial->clock = 1; - if (ac > 4) + c_cmaterial->clock = i + 1; + return(MG_OK); + case MG_E_IR: /* set index of refraction */ + if (ac != 3) return(MG_EARGC); + if (!isflt(av[1]) | !isflt(av[2])) + return(MG_ETYPE); + c_cmaterial->nr = atof(av[1]); + c_cmaterial->ni = atof(av[2]); + if (c_cmaterial->nr <= FTINY) + return(MG_EILL); + c_cmaterial->clock++; return(MG_OK); case MG_E_RD: /* set diffuse reflectance */ if (ac != 2) @@ -180,11 +303,12 @@ register char **av; if (c_cmaterial->td < 0. | c_cmaterial->td > 1.) return(MG_EILL); c_cmaterial->td_c = *c_ccolor; + c_cmaterial->clock++; return(MG_OK); case MG_E_RS: /* set specular reflectance */ if (ac != 3) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2])) + if (!isflt(av[1]) | !isflt(av[2])) return(MG_ETYPE); c_cmaterial->rs = atof(av[1]); c_cmaterial->rs_a = atof(av[2]); @@ -197,7 +321,7 @@ register char **av; case MG_E_TS: /* set specular transmittance */ if (ac != 3) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2])) + if (!isflt(av[1]) | !isflt(av[2])) return(MG_ETYPE); c_cmaterial->ts = atof(av[1]); c_cmaterial->ts_a = atof(av[2]); @@ -207,6 +331,20 @@ register char **av; c_cmaterial->ts_c = *c_ccolor; c_cmaterial->clock++; return(MG_OK); + case MG_E_SIDES: /* set number of sides */ + if (ac != 2) + return(MG_EARGC); + if (!isint(av[1])) + return(MG_ETYPE); + i = atoi(av[1]); + if (i == 1) + c_cmaterial->sided = 1; + else if (i == 2) + c_cmaterial->sided = 0; + else + return(MG_EILL); + c_cmaterial->clock++; + return(MG_OK); } return(MG_EUNK); } @@ -217,27 +355,34 @@ c_hvertex(ac, av) /* handle a vertex entity */ int ac; register char **av; { + int i; register LUENT *lp; switch (mg_entity(av[0])) { case MG_E_VERTEX: /* get/set vertex context */ + if (ac > 4) + return(MG_EARGC); if (ac == 1) { /* set unnamed vertex context */ c_unvertex = c_dfvertex; c_cvertex = &c_unvertex; + c_cvname = NULL; return(MG_OK); } + if (!isname(av[1])) + return(MG_EILL); lp = lu_find(&vtx_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); + c_cvname = lp->key; + c_cvertex = (C_VERTEX *)lp->data; if (ac == 2) { /* reestablish previous context */ - if (lp->data == NULL) + if (c_cvertex == NULL) return(MG_EUNDEF); - c_cvertex = (C_VERTEX *)lp->data; return(MG_OK); } if (av[2][0] != '=' || av[2][1]) return(MG_ETYPE); - if (lp->key == NULL) { /* create new vertex context */ + if (c_cvertex == NULL) { /* create new vertex context */ lp->key = (char *)malloc(strlen(av[1])+1); if (lp->key == NULL) return(MG_EMEM); @@ -245,10 +390,13 @@ register char **av; lp->data = (char *)malloc(sizeof(C_VERTEX)); if (lp->data == NULL) return(MG_EMEM); + c_cvname = lp->key; + c_cvertex = (C_VERTEX *)lp->data; } - c_cvertex = (C_VERTEX *)lp->data; + i = c_cvertex->clock; if (ac == 3) { /* use default template */ *c_cvertex = c_dfvertex; + c_cvertex->clock = i + 1; return(MG_OK); } lp = lu_find(&vtx_tab, av[3]); /* lookup template */ @@ -257,57 +405,64 @@ register char **av; if (lp->data == NULL) return(MG_EUNDEF); *c_cvertex = *(C_VERTEX *)lp->data; - if (ac > 4) - return(MG_EARGC); + c_cvertex->clock = i + 1; return(MG_OK); case MG_E_POINT: /* set point */ if (ac != 4) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3])) + if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3])) return(MG_ETYPE); c_cvertex->p[0] = atof(av[1]); c_cvertex->p[1] = atof(av[2]); c_cvertex->p[2] = atof(av[3]); + c_cvertex->clock++; return(MG_OK); case MG_E_NORMAL: /* set normal */ if (ac != 4) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3])) + if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3])) return(MG_ETYPE); c_cvertex->n[0] = atof(av[1]); c_cvertex->n[1] = atof(av[2]); c_cvertex->n[2] = atof(av[3]); (void)normalize(c_cvertex->n); + c_cvertex->clock++; return(MG_OK); } return(MG_EUNK); } -static void -freectx(lp) /* free a context table entry */ -register LUENT *lp; -{ - free((MEM_PTR)lp->key); - free((MEM_PTR)lp->data); -} - - void c_clearall() /* empty context tables */ { c_uncolor = c_dfcolor; c_ccolor = &c_uncolor; - lu_done(&clr_tab, freectx); + c_ccname = NULL; + lu_done(&clr_tab); c_unmaterial = c_dfmaterial; c_cmaterial = &c_unmaterial; - lu_done(&mat_tab, freectx); + c_cmname = NULL; + lu_done(&mat_tab); c_unvertex = c_dfvertex; c_cvertex = &c_unvertex; - lu_done(&vtx_tab, freectx); + c_cvname = NULL; + lu_done(&vtx_tab); } +C_MATERIAL * +c_getmaterial(name) /* get a named material */ +char *name; +{ + register LUENT *lp; + + if ((lp = lu_find(&mat_tab, name)) == NULL) + return(NULL); + return((C_MATERIAL *)lp->data); +} + + C_VERTEX * c_getvert(name) /* get a named vertex */ char *name; @@ -318,3 +473,242 @@ char *name; return(NULL); return((C_VERTEX *)lp->data); } + + +C_COLOR * +c_getcolor(name) /* get a named color */ +char *name; +{ + register LUENT *lp; + + if ((lp = lu_find(&clr_tab, name)) == NULL) + return(NULL); + return((C_COLOR *)lp->data); +} + + +int +c_isgrey(clr) /* check if color is grey */ +register C_COLOR *clr; +{ + if (!(clr->flags & (C_CSXY|C_CSSPEC))) + return(1); /* no settings == grey */ + c_ccvt(clr, C_CSXY); + return(clr->cx >= .323 && clr->cx <= .343 && + clr->cy >= .323 && clr->cy <= .343); +} + + +void +c_ccvt(clr, fl) /* convert color representations */ +register C_COLOR *clr; +int fl; +{ + double x, y, z; + register int i; + + fl &= ~clr->flags; /* ignore what's done */ + if (!fl) /* everything's done! */ + return; + if (!(clr->flags & (C_CSXY|C_CSSPEC))) /* nothing set! */ + *clr = c_dfcolor; + if (fl & C_CSXY) { /* cspec -> cxy */ + x = y = z = 0.; + for (i = 0; i < C_CNSS; i++) { + x += cie_xf.ssamp[i] * clr->ssamp[i]; + y += cie_yf.ssamp[i] * clr->ssamp[i]; + z += cie_zf.ssamp[i] * clr->ssamp[i]; + } + x /= (double)cie_xf.ssum; + y /= (double)cie_yf.ssum; + z /= (double)cie_zf.ssum; + z += x + y; + clr->cx = x / z; + clr->cy = y / z; + clr->flags |= C_CSXY; + } else if (fl & C_CSSPEC) { /* cxy -> cspec */ + x = clr->cx; + y = clr->cy; + z = 1. - x - y; + clr->ssum = 0; + for (i = 0; i < C_CNSS; i++) { + clr->ssamp[i] = x*cie_xp.ssamp[i] + y*cie_yp.ssamp[i] + + z*cie_zp.ssamp[i] + .5; + if (clr->ssamp[i] < 0) /* out of gamut! */ + clr->ssamp[i] = 0; + else + clr->ssum += clr->ssamp[i]; + } + clr->flags |= C_CSSPEC; + } + if (fl & C_CSEFF) { /* compute efficacy */ + if (clr->flags & C_CSSPEC) { /* from spectrum */ + y = 0.; + for (i = 0; i < C_CNSS; i++) + y += cie_yf.ssamp[i] * clr->ssamp[i]; + clr->eff = C_CLPWM * y / clr->ssum; + } else /* clr->flags & C_CSXY */ { /* from (x,y) */ + clr->eff = clr->cx*cie_xf.eff + clr->cy*cie_yf.eff + + (1. - clr->cx - clr->cy)*cie_zf.eff; + } + clr->flags |= C_CSEFF; + } +} + + +static int +setspectrum(clr, wlmin, wlmax, ac, av) /* convert a spectrum */ +register C_COLOR *clr; +double wlmin, wlmax; +int ac; +char **av; +{ + double scale; + float va[C_CNSS]; + register int i, pos; + int n, imax; + int wl; + double wl0, wlstep; + double boxpos, boxstep; + /* check bounds */ + if (wlmax <= C_CMINWL | wlmax <= wlmin | wlmin >= C_CMAXWL) + return(MG_EILL); + wlstep = (wlmax - wlmin)/(ac-1); + while (wlmin < C_CMINWL) { + wlmin += wlstep; + ac--; av++; + } + while (wlmax > C_CMAXWL) { + wlmax -= wlstep; + ac--; + } + imax = ac; /* box filter if necessary */ + boxpos = 0; + boxstep = 1; + if (wlstep < C_CWLI) { + imax = (wlmax - wlmin)/C_CWLI + (1-FTINY); + boxpos = (wlmin - C_CMINWL)/C_CWLI; + boxstep = wlstep/C_CWLI; + wlstep = C_CWLI; + } + scale = 0.; /* get values and maximum */ + pos = 0; + for (i = 0; i < imax; i++) { + va[i] = 0.; n = 0; + while (boxpos < i+.5 && pos < ac) { + if (!isflt(av[pos])) + return(MG_ETYPE); + va[i] += atof(av[pos++]); + n++; + boxpos += boxstep; + } + if (n > 1) + va[i] /= (double)n; + if (va[i] > scale) + scale = va[i]; + else if (va[i] < -scale) + scale = -va[i]; + } + if (scale <= FTINY) + return(MG_EILL); + scale = C_CMAXV / scale; + clr->ssum = 0; /* convert to our spacing */ + wl0 = wlmin; + pos = 0; + for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI) + if (wl < wlmin | wl > wlmax) + clr->ssamp[i] = 0; + else { + while (wl0 + wlstep < wl+FTINY) { + wl0 += wlstep; + pos++; + } + if (wl+FTINY >= wl0 & wl-FTINY <= wl0) + clr->ssamp[i] = scale*va[pos] + .5; + else /* interpolate if necessary */ + clr->ssamp[i] = .5 + scale / wlstep * + ( va[pos]*(wl0+wlstep - wl) + + va[pos+1]*(wl - wl0) ); + clr->ssum += clr->ssamp[i]; + } + clr->flags = C_CDSPEC|C_CSSPEC; + clr->clock++; + return(MG_OK); +} + + +static void +mixcolors(cres, w1, c1, w2, c2) /* mix two colors according to weights given */ +register C_COLOR *cres, *c1, *c2; +double w1, w2; +{ + double scale; + float cmix[C_CNSS]; + register int i; + + if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */ + c_ccvt(c1, C_CSSPEC|C_CSEFF); + c_ccvt(c2, C_CSSPEC|C_CSEFF); + w1 /= c1->eff*c1->ssum; + w2 /= c2->eff*c2->ssum; + scale = 0.; + for (i = 0; i < C_CNSS; i++) { + cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i]; + if (cmix[i] > scale) + scale = cmix[i]; + } + scale = C_CMAXV / scale; + cres->ssum = 0; + for (i = 0; i < C_CNSS; i++) + cres->ssum += cres->ssamp[i] = scale*cmix[i] + .5; + cres->flags = C_CDSPEC|C_CSSPEC; + } else { /* CIE xy mixing */ + c_ccvt(c1, C_CSXY); + c_ccvt(c2, C_CSXY); + scale = w1/c1->cy + w2/c2->cy; + if (scale == 0.) + return; + scale = 1. / scale; + cres->cx = (c1->cx*w1/c1->cy + c2->cx*w2/c2->cy) * scale; + cres->cy = (w1 + w2) * scale; + cres->flags = C_CDXY|C_CSXY; + } +} + + +#define C1 3.741832e-16 /* W-m^2 */ +#define C2 1.4388e-2 /* m-K */ + +#define bbsp(l,t) (C1/((l)*(l)*(l)*(l)*(l)*(exp(C2/((t)*(l)))-1.))) +#define bblm(t) (C2/5./(t)) + +static int +setbbtemp(clr, tk) /* set black body spectrum */ +register C_COLOR *clr; +double tk; +{ + double sf, wl; + register int i; + + if (tk < 1000) + return(MG_EILL); + wl = bblm(tk); /* scalefactor based on peak */ + if (wl < C_CMINWL*1e-9) + wl = C_CMINWL*1e-9; + else if (wl > C_CMAXWL*1e-9) + wl = C_CMAXWL*1e-9; + sf = C_CMAXV/bbsp(wl,tk); + clr->ssum = 0; + for (i = 0; i < C_CNSS; i++) { + wl = (C_CMINWL + i*C_CWLI)*1e-9; + clr->ssum += clr->ssamp[i] = sf*bbsp(wl,tk) + .5; + } + clr->flags = C_CDSPEC|C_CSSPEC; + clr->clock++; + return(MG_OK); +} + +#undef C1 +#undef C2 +#undef bbsp +#undef bblm
