root/radiance/ray/src/cv/mgflib/context.c
Revision: 1.5
Committed: Fri Jun 24 16:28:15 1994 UTC (29 years, 11 months ago) by greg
Changes since 1.4: +189 -0 lines
added cspec and cmix entities
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Context handlers
9 */
10
11 #include <stdio.h>
12 #include <math.h>
13 #include <string.h>
14 #include "parser.h"
15 #include "lookup.h"
16
17 /* default context values */
18 static C_COLOR c_dfcolor = C_DEFCOLOR;
19 static C_MATERIAL c_dfmaterial = C_DEFMATERIAL;
20 static C_VERTEX c_dfvertex = C_DEFVERTEX;
21
22 /* the unnamed contexts */
23 static C_COLOR c_uncolor = C_DEFCOLOR;
24 static C_MATERIAL c_unmaterial = C_DEFMATERIAL;
25 static C_VERTEX c_unvertex = C_DEFVERTEX;
26
27 /* the current contexts */
28 C_COLOR *c_ccolor = &c_uncolor;
29 C_MATERIAL *c_cmaterial = &c_unmaterial;
30 C_VERTEX *c_cvertex = &c_unvertex;
31
32 static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */
33 static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */
34 static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */
35
36 /* CIE 1931 Standard Observer */
37 static C_COLOR cie_xf = C_CIEX;
38 static C_COLOR cie_yf = C_CIEY;
39 static C_COLOR cie_zf = C_CIEZ;
40
41 static int setspectrum();
42 static void mixcolors();
43
44
45 int
46 c_hcolor(ac, av) /* handle color entity */
47 int ac;
48 register char **av;
49 {
50 double w, wsum;
51 register int i;
52 register LUENT *lp;
53
54 switch (mg_entity(av[0])) {
55 case MG_E_COLOR: /* get/set color context */
56 if (ac > 4)
57 return(MG_EARGC);
58 if (ac == 1) { /* set unnamed color context */
59 c_uncolor = c_dfcolor;
60 c_ccolor = &c_uncolor;
61 return(MG_OK);
62 }
63 lp = lu_find(&clr_tab, av[1]); /* lookup context */
64 if (lp == NULL)
65 return(MG_EMEM);
66 if (ac == 2) { /* reestablish previous context */
67 if (lp->data == NULL)
68 return(MG_EUNDEF);
69 c_ccolor = (C_COLOR *)lp->data;
70 return(MG_OK);
71 }
72 if (av[2][0] != '=' || av[2][1])
73 return(MG_ETYPE);
74 if (lp->key == NULL) { /* create new color context */
75 lp->key = (char *)malloc(strlen(av[1])+1);
76 if (lp->key == NULL)
77 return(MG_EMEM);
78 strcpy(lp->key, av[1]);
79 lp->data = (char *)malloc(sizeof(C_COLOR));
80 if (lp->data == NULL)
81 return(MG_EMEM);
82 }
83 c_ccolor = (C_COLOR *)lp->data;
84 if (ac == 3) { /* use default template */
85 *c_ccolor = c_dfcolor;
86 return(MG_OK);
87 }
88 lp = lu_find(&clr_tab, av[3]); /* lookup template */
89 if (lp == NULL)
90 return(MG_EMEM);
91 if (lp->data == NULL)
92 return(MG_EUNDEF);
93 *c_ccolor = *(C_COLOR *)lp->data;
94 if (ac > 4)
95 return(MG_EARGC);
96 return(MG_OK);
97 case MG_E_CXY: /* assign CIE XY value */
98 if (ac != 3)
99 return(MG_EARGC);
100 if (!isflt(av[1]) || !isflt(av[2]))
101 return(MG_ETYPE);
102 c_ccolor->cx = atof(av[1]);
103 c_ccolor->cy = atof(av[2]);
104 c_ccolor->flags = C_CDXY|C_CSXY;
105 if (c_ccolor->cx < 0. | c_ccolor->cy < 0. |
106 c_ccolor->cx + c_ccolor->cy > 1.)
107 return(MG_EILL);
108 return(MG_OK);
109 case MG_E_CSPEC: /* assign spectral values */
110 if (ac < 5)
111 return(MG_EARGC);
112 if (!isint(av[1]) || !isint(av[2]))
113 return(MG_ETYPE);
114 return(setspectrum(c_ccolor, atoi(av[1]), atoi(av[2]),
115 ac-3, av+3));
116 case MG_E_CMIX: /* mix colors */
117 if (ac < 5 || (ac-1)%2)
118 return(MG_EARGC);
119 if (!isflt(av[1]))
120 return(MG_ETYPE);
121 wsum = atof(av[1]);
122 if (wsum < 0.)
123 return(MG_EILL);
124 if ((lp = lu_find(&clr_tab, av[2])) == NULL)
125 return(MG_EMEM);
126 if (lp->data == NULL)
127 return(MG_EUNDEF);
128 *c_ccolor = *(C_COLOR *)lp->data;
129 for (i = 3; i < ac; i += 2) {
130 if (!isflt(av[i]))
131 return(MG_ETYPE);
132 w = atof(av[i]);
133 if (w < 0.)
134 return(MG_EILL);
135 if ((lp = lu_find(&clr_tab, av[i+1])) == NULL)
136 return(MG_EMEM);
137 if (lp->data == NULL)
138 return(MG_EUNDEF);
139 mixcolors(c_ccolor, wsum, c_ccolor,
140 w, (C_COLOR *)lp->data);
141 wsum += w;
142 }
143 return(MG_OK);
144 }
145 return(MG_EUNK);
146 }
147
148
149 int
150 c_hmaterial(ac, av) /* handle material entity */
151 int ac;
152 register char **av;
153 {
154 register LUENT *lp;
155
156 switch (mg_entity(av[0])) {
157 case MG_E_MATERIAL: /* get/set material context */
158 if (ac > 4)
159 return(MG_EARGC);
160 if (ac == 1) { /* set unnamed material context */
161 c_unmaterial = c_dfmaterial;
162 c_cmaterial = &c_unmaterial;
163 return(MG_OK);
164 }
165 lp = lu_find(&mat_tab, av[1]); /* lookup context */
166 if (lp == NULL)
167 return(MG_EMEM);
168 if (ac == 2) { /* reestablish previous context */
169 if (lp->data == NULL)
170 return(MG_EUNDEF);
171 c_cmaterial = (C_MATERIAL *)lp->data;
172 return(MG_OK);
173 }
174 if (av[2][0] != '=' || av[2][1])
175 return(MG_ETYPE);
176 if (lp->key == NULL) { /* create new material context */
177 lp->key = (char *)malloc(strlen(av[1])+1);
178 if (lp->key == NULL)
179 return(MG_EMEM);
180 strcpy(lp->key, av[1]);
181 lp->data = (char *)malloc(sizeof(C_MATERIAL));
182 if (lp->data == NULL)
183 return(MG_EMEM);
184 }
185 c_cmaterial = (C_MATERIAL *)lp->data;
186 if (ac == 3) { /* use default template */
187 *c_cmaterial = c_dfmaterial;
188 c_cmaterial->name = lp->key;
189 return(MG_OK);
190 }
191 lp = lu_find(&mat_tab, av[3]); /* lookup template */
192 if (lp == NULL)
193 return(MG_EMEM);
194 if (lp->data == NULL)
195 return(MG_EUNDEF);
196 *c_cmaterial = *(C_MATERIAL *)lp->data;
197 c_cmaterial->name = lp->key;
198 c_cmaterial->clock = 1;
199 if (ac > 4)
200 return(MG_EARGC);
201 return(MG_OK);
202 case MG_E_RD: /* set diffuse reflectance */
203 if (ac != 2)
204 return(MG_EARGC);
205 if (!isflt(av[1]))
206 return(MG_ETYPE);
207 c_cmaterial->rd = atof(av[1]);
208 if (c_cmaterial->rd < 0. | c_cmaterial->rd > 1.)
209 return(MG_EILL);
210 c_cmaterial->rd_c = *c_ccolor;
211 c_cmaterial->clock++;
212 return(MG_OK);
213 case MG_E_ED: /* set diffuse emittance */
214 if (ac != 2)
215 return(MG_EARGC);
216 if (!isflt(av[1]))
217 return(MG_ETYPE);
218 c_cmaterial->ed = atof(av[1]);
219 if (c_cmaterial->ed < 0.)
220 return(MG_EILL);
221 c_cmaterial->ed_c = *c_ccolor;
222 c_cmaterial->clock++;
223 return(MG_OK);
224 case MG_E_TD: /* set diffuse transmittance */
225 if (ac != 2)
226 return(MG_EARGC);
227 if (!isflt(av[1]))
228 return(MG_ETYPE);
229 c_cmaterial->td = atof(av[1]);
230 if (c_cmaterial->td < 0. | c_cmaterial->td > 1.)
231 return(MG_EILL);
232 c_cmaterial->td_c = *c_ccolor;
233 return(MG_OK);
234 case MG_E_RS: /* set specular reflectance */
235 if (ac != 3)
236 return(MG_EARGC);
237 if (!isflt(av[1]) || !isflt(av[2]))
238 return(MG_ETYPE);
239 c_cmaterial->rs = atof(av[1]);
240 c_cmaterial->rs_a = atof(av[2]);
241 if (c_cmaterial->rs < 0. | c_cmaterial->rs > 1. |
242 c_cmaterial->rs_a < 0.)
243 return(MG_EILL);
244 c_cmaterial->rs_c = *c_ccolor;
245 c_cmaterial->clock++;
246 return(MG_OK);
247 case MG_E_TS: /* set specular transmittance */
248 if (ac != 3)
249 return(MG_EARGC);
250 if (!isflt(av[1]) || !isflt(av[2]))
251 return(MG_ETYPE);
252 c_cmaterial->ts = atof(av[1]);
253 c_cmaterial->ts_a = atof(av[2]);
254 if (c_cmaterial->ts < 0. | c_cmaterial->ts > 1. |
255 c_cmaterial->ts_a < 0.)
256 return(MG_EILL);
257 c_cmaterial->ts_c = *c_ccolor;
258 c_cmaterial->clock++;
259 return(MG_OK);
260 }
261 return(MG_EUNK);
262 }
263
264
265 int
266 c_hvertex(ac, av) /* handle a vertex entity */
267 int ac;
268 register char **av;
269 {
270 register LUENT *lp;
271
272 switch (mg_entity(av[0])) {
273 case MG_E_VERTEX: /* get/set vertex context */
274 if (ac > 4)
275 return(MG_EARGC);
276 if (ac == 1) { /* set unnamed vertex context */
277 c_unvertex = c_dfvertex;
278 c_cvertex = &c_unvertex;
279 return(MG_OK);
280 }
281 lp = lu_find(&vtx_tab, av[1]); /* lookup context */
282 if (lp == NULL)
283 return(MG_EMEM);
284 if (ac == 2) { /* reestablish previous context */
285 if (lp->data == NULL)
286 return(MG_EUNDEF);
287 c_cvertex = (C_VERTEX *)lp->data;
288 return(MG_OK);
289 }
290 if (av[2][0] != '=' || av[2][1])
291 return(MG_ETYPE);
292 if (lp->key == NULL) { /* create new vertex context */
293 lp->key = (char *)malloc(strlen(av[1])+1);
294 if (lp->key == NULL)
295 return(MG_EMEM);
296 strcpy(lp->key, av[1]);
297 lp->data = (char *)malloc(sizeof(C_VERTEX));
298 if (lp->data == NULL)
299 return(MG_EMEM);
300 }
301 c_cvertex = (C_VERTEX *)lp->data;
302 if (ac == 3) { /* use default template */
303 *c_cvertex = c_dfvertex;
304 return(MG_OK);
305 }
306 lp = lu_find(&vtx_tab, av[3]); /* lookup template */
307 if (lp == NULL)
308 return(MG_EMEM);
309 if (lp->data == NULL)
310 return(MG_EUNDEF);
311 *c_cvertex = *(C_VERTEX *)lp->data;
312 if (ac > 4)
313 return(MG_EARGC);
314 return(MG_OK);
315 case MG_E_POINT: /* set point */
316 if (ac != 4)
317 return(MG_EARGC);
318 if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3]))
319 return(MG_ETYPE);
320 c_cvertex->p[0] = atof(av[1]);
321 c_cvertex->p[1] = atof(av[2]);
322 c_cvertex->p[2] = atof(av[3]);
323 return(MG_OK);
324 case MG_E_NORMAL: /* set normal */
325 if (ac != 4)
326 return(MG_EARGC);
327 if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3]))
328 return(MG_ETYPE);
329 c_cvertex->n[0] = atof(av[1]);
330 c_cvertex->n[1] = atof(av[2]);
331 c_cvertex->n[2] = atof(av[3]);
332 (void)normalize(c_cvertex->n);
333 return(MG_OK);
334 }
335 return(MG_EUNK);
336 }
337
338
339 void
340 c_clearall() /* empty context tables */
341 {
342 c_uncolor = c_dfcolor;
343 c_ccolor = &c_uncolor;
344 lu_done(&clr_tab);
345 c_unmaterial = c_dfmaterial;
346 c_cmaterial = &c_unmaterial;
347 lu_done(&mat_tab);
348 c_unvertex = c_dfvertex;
349 c_cvertex = &c_unvertex;
350 lu_done(&vtx_tab);
351 }
352
353
354 C_VERTEX *
355 c_getvert(name) /* get a named vertex */
356 char *name;
357 {
358 register LUENT *lp;
359
360 if ((lp = lu_find(&vtx_tab, name)) == NULL)
361 return(NULL);
362 return((C_VERTEX *)lp->data);
363 }
364
365
366 int
367 c_isgrey(clr) /* check if color is grey */
368 register C_COLOR *clr;
369 {
370 if (!clr->flags)
371 return(1); /* no settings == grey */
372 c_ccvt(clr, C_CSXY);
373 return(clr->cx >= .323 && clr->cx <= .343 &&
374 clr->cy >= .323 && clr->cy <= .343);
375 }
376
377
378 void
379 c_ccvt(clr, fl) /* convert color representations */
380 register C_COLOR *clr;
381 int fl;
382 {
383 double x, y, z;
384 register int i;
385
386 if (clr->flags & fl) /* already done */
387 return;
388 if (!(clr->flags & (C_SXY|C_SSPEC)) /* nothing set */
389 *clr = c_dfcolor;
390 else if (fl & C_CSXY) { /* cspec -> cxy */
391 x = y = z = 0.;
392 for (i = 0; i < C_CNSS; i++) {
393 x += cie_xf.ssamp[i] * clr->ssamp[i];
394 y += cie_yf.ssamp[i] * clr->ssamp[i];
395 z += cie_zf.ssamp[i] * clr->ssamp[i];
396 }
397 z += x + y;
398 clr->cx = x / z;
399 clr->cy = y / z;
400 clr->flags |= C_CSXY;
401 } else { /* cxy -> cspec */
402 z = (cie_xf.ssum + cie_yf.ssum + cie_zf.ssum) / 3.;
403 x = clr->cx * z / cie_xf.ssum;
404 y = clr->cy * z / cie_yf.ssum;
405 z = (1. - clr->cx - clr->cy) * z / cie_zf.ssum;
406 clr->ssum = 0;
407 for (i = 0; i < C_CNSS; i++)
408 clr->ssum += clr->ssamp[i] =
409 x * cie_xf.ssamp[i] +
410 y * cie_yf.ssamp[i] +
411 z * cie_zf.ssamp[i] ;
412 clr->flags |= C_CSSPEC;
413 }
414 }
415
416
417 static int
418 setspectrum(clr, wlmin, wlmax, ac, av) /* convert a spectrum */
419 register C_COLOR *clr;
420 int wlmin, wlmax;
421 int ac;
422 char **av;
423 {
424 double scale;
425 float *va;
426 register int i;
427 int wl, pos;
428 double wl0, wlstep;
429
430 if (wlmin < C_CMINWL || wlmin >= wlmax || wlmax > C_CMAXWL)
431 return(MG_EILL);
432 if ((va = (float *)malloc(ac*sizeof(float))) == NULL)
433 return(MG_EMEM);
434 scale = 0.; /* get values and maximum */
435 for (i = 0; i < ac; i++) {
436 if (!isflt(av[i]))
437 return(MG_ETYPE);
438 va[i] = atof(av[i]);
439 if (va[i] < 0.)
440 return(MG_EILL);
441 if (va[i] > scale)
442 scale = va[i];
443 }
444 if (scale == 0.)
445 return(MG_EILL);
446 scale = C_CMAXV / scale;
447 clr->ssum = 0; /* convert to our spacing */
448 wl0 = wlmin;
449 wlstep = (double)(wlmax - wlmin)/(ac-1);
450 pos = 0;
451 for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI)
452 if (wl < wlmin || wl > wlmax)
453 clr->ssamp[i] = 0;
454 else {
455 while (wl0 + wlstep < wl+FTINY) {
456 wl0 += wlstep;
457 pos++;
458 }
459 if (wl+FTINY >= wl0 && wl-FTINY <= wl0)
460 clr->ssamp[i] = scale*va[pos];
461 else /* interpolate if necessary */
462 clr->ssamp[i] = scale / wlstep *
463 ( va[pos]*(wl0+wlstep - wl) +
464 va[pos+1]*(wl - wl0) );
465 clr->ssum += clr->ssamp[i];
466 }
467 clr->flags = C_CDSPEC|C_CSSPEC;
468 free((MEM_PTR)va);
469 return(MG_OK);
470 }
471
472
473 static void
474 mixcolors(cres, w1, c1, w2, c2) /* mix two colors according to weights given */
475 register C_COLOR *cres, *c1, *c2;
476 double w1, w2;
477 {
478 double scale;
479 float cmix[C_CNSS];
480 register int i;
481
482 if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */
483 c_ccvt(c1, C_CSSPEC);
484 c_ccvt(c2, C_CSSPEC);
485 w1 /= (double)c1->ssum;
486 w2 /= (double)c2->ssum;
487 scale = 0.;
488 for (i = 0; i < C_CNSS; i++) {
489 cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i];
490 if (cmix[i] > scale)
491 scale = cmix[i];
492 }
493 scale = C_CMAXV / scale;
494 cres->ssum = 0;
495 for (i = 0; i < C_CNSS; i++)
496 cres->ssum += cres->ssamp[i] = scale*cmix[i] + .5;
497 cres->flags = C_CDSPEC|C_CSSPEC;
498 } else { /* CIE xy mixing */
499 c_ccvt(c1, C_CSXY);
500 c_ccvt(c2, C_CSXY);
501 scale = 1. / (w1/c1->cy + w2/c2->cy);
502 cres->cx = (c1->cx*w1/c1->cy + c2->cx*w2/c2->cy) * scale;
503 cres->cy = (w1 + w2) * scale;
504 cres->flags = C_CDXY|C_CSXY;
505 }
506 }
