root/radiance/ray/src/cv/mgflib/context.c
Revision: 1.3
Committed: Thu Jun 23 07:48:39 1994 UTC (31 years, 1 month ago) by greg
Changes since 1.2: +6 -15 lines
improved table lookup routines with new delete function
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Context handlers
9 */
10
11 #include <stdio.h>
12 #include <math.h>
13 #include <string.h>
14 #include "parser.h"
15 #include "lookup.h"
16
17 /* default context values */
18 static C_COLOR c_dfcolor = C_DEFCOLOR;
19 static C_MATERIAL c_dfmaterial = C_DEFMATERIAL;
20 static C_VERTEX c_dfvertex = C_DEFVERTEX;
21
22 /* the unnamed contexts */
23 static C_COLOR c_uncolor = C_DEFCOLOR;
24 static C_MATERIAL c_unmaterial = C_DEFMATERIAL;
25 static C_VERTEX c_unvertex = C_DEFVERTEX;
26
27 /* the current contexts */
28 C_COLOR *c_ccolor = &c_uncolor;
29 C_MATERIAL *c_cmaterial = &c_unmaterial;
30 C_VERTEX *c_cvertex = &c_unvertex;
31
32 static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */
33 static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */
34 static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */
35
36
37 int
38 c_hcolor(ac, av) /* handle color entity */
39 int ac;
40 register char **av;
41 {
42 register LUENT *lp;
43
44 switch (mg_entity(av[0])) {
45 case MG_E_COLOR: /* get/set color context */
46 if (ac == 1) { /* set unnamed color context */
47 c_uncolor = c_dfcolor;
48 c_ccolor = &c_uncolor;
49 return(MG_OK);
50 }
51 lp = lu_find(&clr_tab, av[1]); /* lookup context */
52 if (lp == NULL)
53 return(MG_EMEM);
54 if (ac == 2) { /* reestablish previous context */
55 if (lp->data == NULL)
56 return(MG_EUNDEF);
57 c_ccolor = (C_COLOR *)lp->data;
58 return(MG_OK);
59 }
60 if (av[2][0] != '=' || av[2][1])
61 return(MG_ETYPE);
62 if (lp->key == NULL) { /* create new color context */
63 lp->key = (char *)malloc(strlen(av[1])+1);
64 if (lp->key == NULL)
65 return(MG_EMEM);
66 strcpy(lp->key, av[1]);
67 lp->data = (char *)malloc(sizeof(C_COLOR));
68 if (lp->data == NULL)
69 return(MG_EMEM);
70 }
71 c_ccolor = (C_COLOR *)lp->data;
72 if (ac == 3) { /* use default template */
73 *c_ccolor = c_dfcolor;
74 return(MG_OK);
75 }
76 lp = lu_find(&clr_tab, av[3]); /* lookup template */
77 if (lp == NULL)
78 return(MG_EMEM);
79 if (lp->data == NULL)
80 return(MG_EUNDEF);
81 *c_ccolor = *(C_COLOR *)lp->data;
82 if (ac > 4)
83 return(MG_EARGC);
84 return(MG_OK);
85 case MG_E_CXY: /* assign CIE XY value */
86 if (ac != 3)
87 return(MG_EARGC);
88 if (!isflt(av[1]) || !isflt(av[2]))
89 return(MG_ETYPE);
90 c_ccolor->cx = atof(av[1]);
91 c_ccolor->cy = atof(av[2]);
92 if (c_ccolor->cx < 0. | c_ccolor->cy < 0. |
93 c_ccolor->cx + c_ccolor->cy > 1.)
94 return(MG_EILL);
95 return(MG_OK);
96 }
97 return(MG_EUNK);
98 }
99
100
101 int
102 c_hmaterial(ac, av) /* handle material entity */
103 int ac;
104 register char **av;
105 {
106 register LUENT *lp;
107
108 switch (mg_entity(av[0])) {
109 case MG_E_MATERIAL: /* get/set material context */
110 if (ac == 1) { /* set unnamed material context */
111 c_unmaterial = c_dfmaterial;
112 c_cmaterial = &c_unmaterial;
113 return(MG_OK);
114 }
115 lp = lu_find(&mat_tab, av[1]); /* lookup context */
116 if (lp == NULL)
117 return(MG_EMEM);
118 if (ac == 2) { /* reestablish previous context */
119 if (lp->data == NULL)
120 return(MG_EUNDEF);
121 c_cmaterial = (C_MATERIAL *)lp->data;
122 return(MG_OK);
123 }
124 if (av[2][0] != '=' || av[2][1])
125 return(MG_ETYPE);
126 if (lp->key == NULL) { /* create new material context */
127 lp->key = (char *)malloc(strlen(av[1])+1);
128 if (lp->key == NULL)
129 return(MG_EMEM);
130 strcpy(lp->key, av[1]);
131 lp->data = (char *)malloc(sizeof(C_MATERIAL));
132 if (lp->data == NULL)
133 return(MG_EMEM);
134 }
135 c_cmaterial = (C_MATERIAL *)lp->data;
136 if (ac == 3) { /* use default template */
137 *c_cmaterial = c_dfmaterial;
138 c_cmaterial->name = lp->key;
139 return(MG_OK);
140 }
141 lp = lu_find(&mat_tab, av[3]); /* lookup template */
142 if (lp == NULL)
143 return(MG_EMEM);
144 if (lp->data == NULL)
145 return(MG_EUNDEF);
146 *c_cmaterial = *(C_MATERIAL *)lp->data;
147 c_cmaterial->name = lp->key;
148 c_cmaterial->clock = 1;
149 if (ac > 4)
150 return(MG_EARGC);
151 return(MG_OK);
152 case MG_E_RD: /* set diffuse reflectance */
153 if (ac != 2)
154 return(MG_EARGC);
155 if (!isflt(av[1]))
156 return(MG_ETYPE);
157 c_cmaterial->rd = atof(av[1]);
158 if (c_cmaterial->rd < 0. | c_cmaterial->rd > 1.)
159 return(MG_EILL);
160 c_cmaterial->rd_c = *c_ccolor;
161 c_cmaterial->clock++;
162 return(MG_OK);
163 case MG_E_ED: /* set diffuse emittance */
164 if (ac != 2)
165 return(MG_EARGC);
166 if (!isflt(av[1]))
167 return(MG_ETYPE);
168 c_cmaterial->ed = atof(av[1]);
169 if (c_cmaterial->ed < 0.)
170 return(MG_EILL);
171 c_cmaterial->ed_c = *c_ccolor;
172 c_cmaterial->clock++;
173 return(MG_OK);
174 case MG_E_TD: /* set diffuse transmittance */
175 if (ac != 2)
176 return(MG_EARGC);
177 if (!isflt(av[1]))
178 return(MG_ETYPE);
179 c_cmaterial->td = atof(av[1]);
180 if (c_cmaterial->td < 0. | c_cmaterial->td > 1.)
181 return(MG_EILL);
182 c_cmaterial->td_c = *c_ccolor;
183 return(MG_OK);
184 case MG_E_RS: /* set specular reflectance */
185 if (ac != 3)
186 return(MG_EARGC);
187 if (!isflt(av[1]) || !isflt(av[2]))
188 return(MG_ETYPE);
189 c_cmaterial->rs = atof(av[1]);
190 c_cmaterial->rs_a = atof(av[2]);
191 if (c_cmaterial->rs < 0. | c_cmaterial->rs > 1. |
192 c_cmaterial->rs_a < 0.)
193 return(MG_EILL);
194 c_cmaterial->rs_c = *c_ccolor;
195 c_cmaterial->clock++;
196 return(MG_OK);
197 case MG_E_TS: /* set specular transmittance */
198 if (ac != 3)
199 return(MG_EARGC);
200 if (!isflt(av[1]) || !isflt(av[2]))
201 return(MG_ETYPE);
202 c_cmaterial->ts = atof(av[1]);
203 c_cmaterial->ts_a = atof(av[2]);
204 if (c_cmaterial->ts < 0. | c_cmaterial->ts > 1. |
205 c_cmaterial->ts_a < 0.)
206 return(MG_EILL);
207 c_cmaterial->ts_c = *c_ccolor;
208 c_cmaterial->clock++;
209 return(MG_OK);
210 }
211 return(MG_EUNK);
212 }
213
214
215 int
216 c_hvertex(ac, av) /* handle a vertex entity */
217 int ac;
218 register char **av;
219 {
220 register LUENT *lp;
221
222 switch (mg_entity(av[0])) {
223 case MG_E_VERTEX: /* get/set vertex context */
224 if (ac == 1) { /* set unnamed vertex context */
225 c_unvertex = c_dfvertex;
226 c_cvertex = &c_unvertex;
227 return(MG_OK);
228 }
229 lp = lu_find(&vtx_tab, av[1]); /* lookup context */
230 if (lp == NULL)
231 return(MG_EMEM);
232 if (ac == 2) { /* reestablish previous context */
233 if (lp->data == NULL)
234 return(MG_EUNDEF);
235 c_cvertex = (C_VERTEX *)lp->data;
236 return(MG_OK);
237 }
238 if (av[2][0] != '=' || av[2][1])
239 return(MG_ETYPE);
240 if (lp->key == NULL) { /* create new vertex context */
241 lp->key = (char *)malloc(strlen(av[1])+1);
242 if (lp->key == NULL)
243 return(MG_EMEM);
244 strcpy(lp->key, av[1]);
245 lp->data = (char *)malloc(sizeof(C_VERTEX));
246 if (lp->data == NULL)
247 return(MG_EMEM);
248 }
249 c_cvertex = (C_VERTEX *)lp->data;
250 if (ac == 3) { /* use default template */
251 *c_cvertex = c_dfvertex;
252 return(MG_OK);
253 }
254 lp = lu_find(&vtx_tab, av[3]); /* lookup template */
255 if (lp == NULL)
256 return(MG_EMEM);
257 if (lp->data == NULL)
258 return(MG_EUNDEF);
259 *c_cvertex = *(C_VERTEX *)lp->data;
260 if (ac > 4)
261 return(MG_EARGC);
262 return(MG_OK);
263 case MG_E_POINT: /* set point */
264 if (ac != 4)
265 return(MG_EARGC);
266 if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3]))
267 return(MG_ETYPE);
268 c_cvertex->p[0] = atof(av[1]);
269 c_cvertex->p[1] = atof(av[2]);
270 c_cvertex->p[2] = atof(av[3]);
271 return(MG_OK);
272 case MG_E_NORMAL: /* set normal */
273 if (ac != 4)
274 return(MG_EARGC);
275 if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3]))
276 return(MG_ETYPE);
277 c_cvertex->n[0] = atof(av[1]);
278 c_cvertex->n[1] = atof(av[2]);
279 c_cvertex->n[2] = atof(av[3]);
280 (void)normalize(c_cvertex->n);
281 return(MG_OK);
282 }
283 return(MG_EUNK);
284 }
285
286
287 void
288 c_clearall() /* empty context tables */
289 {
290 c_uncolor = c_dfcolor;
291 c_ccolor = &c_uncolor;
292 lu_done(&clr_tab);
293 c_unmaterial = c_dfmaterial;
294 c_cmaterial = &c_unmaterial;
295 lu_done(&mat_tab);
296 c_unvertex = c_dfvertex;
297 c_cvertex = &c_unvertex;
298 lu_done(&vtx_tab);
299 }
300
301
302 C_VERTEX *
303 c_getvert(name) /* get a named vertex */
304 char *name;
305 {
306 register LUENT *lp;
307
308 if ((lp = lu_find(&vtx_tab, name)) == NULL)
309 return(NULL);
310 return((C_VERTEX *)lp->data);
311 }
