--- ray/src/cv/mgflib/context.c 1994/07/07 17:27:58 1.14 +++ ray/src/cv/mgflib/context.c 1995/03/07 14:53:20 1.18 @@ -42,6 +42,7 @@ static C_COLOR cie_yf = C_CIEY; static C_COLOR cie_zf = C_CIEZ; static int setspectrum(); +static int setbbtemp(); static void mixcolors(); @@ -105,7 +106,7 @@ register char **av; case MG_E_CXY: /* assign CIE XY value */ if (ac != 3) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2])) + if (!isflt(av[1]) | !isflt(av[2])) return(MG_ETYPE); c_ccolor->cx = atof(av[1]); c_ccolor->cy = atof(av[2]); @@ -118,10 +119,16 @@ register char **av; case MG_E_CSPEC: /* assign spectral values */ if (ac < 5) return(MG_EARGC); - if (!isint(av[1]) || !isint(av[2])) + if (!isflt(av[1]) | !isflt(av[2])) return(MG_ETYPE); - return(setspectrum(c_ccolor, atoi(av[1]), atoi(av[2]), + return(setspectrum(c_ccolor, atof(av[1]), atof(av[2]), ac-3, av+3)); + case MG_E_CCT: /* assign black body spectrum */ + if (ac != 2) + return(MG_EARGC); + if (!isflt(av[1])) + return(MG_ETYPE); + return(setbbtemp(c_ccolor, atof(av[1]))); case MG_E_CMIX: /* mix colors */ if (ac < 5 || (ac-1)%2) return(MG_EARGC); @@ -248,7 +255,7 @@ register char **av; case MG_E_RS: /* set specular reflectance */ if (ac != 3) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2])) + if (!isflt(av[1]) | !isflt(av[2])) return(MG_ETYPE); c_cmaterial->rs = atof(av[1]); c_cmaterial->rs_a = atof(av[2]); @@ -261,7 +268,7 @@ register char **av; case MG_E_TS: /* set specular transmittance */ if (ac != 3) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2])) + if (!isflt(av[1]) | !isflt(av[2])) return(MG_ETYPE); c_cmaterial->ts = atof(av[1]); c_cmaterial->ts_a = atof(av[2]); @@ -348,7 +355,7 @@ register char **av; case MG_E_POINT: /* set point */ if (ac != 4) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3])) + if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3])) return(MG_ETYPE); c_cvertex->p[0] = atof(av[1]); c_cvertex->p[1] = atof(av[2]); @@ -358,7 +365,7 @@ register char **av; case MG_E_NORMAL: /* set normal */ if (ac != 4) return(MG_EARGC); - if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3])) + if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3])) return(MG_ETYPE); c_cvertex->n[0] = atof(av[1]); c_cvertex->n[1] = atof(av[2]); @@ -376,12 +383,15 @@ c_clearall() /* empty context tables */ { c_uncolor = c_dfcolor; c_ccolor = &c_uncolor; + c_ccname = NULL; lu_done(&clr_tab); c_unmaterial = c_dfmaterial; c_cmaterial = &c_unmaterial; + c_cmname = NULL; lu_done(&mat_tab); c_unvertex = c_dfvertex; c_cvertex = &c_unvertex; + c_cvname = NULL; lu_done(&vtx_tab); } @@ -442,22 +452,26 @@ int fl; double x, y, z; register int i; - if (clr->flags & fl) /* already done */ + fl &= ~clr->flags; /* ignore what's done */ + if (!fl) /* everything's done! */ return; if (!(clr->flags & (C_CSXY|C_CSSPEC))) /* nothing set! */ *clr = c_dfcolor; - else if (fl & C_CSXY) { /* cspec -> cxy */ + if (fl & C_CSXY) { /* cspec -> cxy */ x = y = z = 0.; for (i = 0; i < C_CNSS; i++) { x += cie_xf.ssamp[i] * clr->ssamp[i]; y += cie_yf.ssamp[i] * clr->ssamp[i]; z += cie_zf.ssamp[i] * clr->ssamp[i]; } + x /= (double)cie_xf.ssum; + y /= (double)cie_yf.ssum; + z /= (double)cie_zf.ssum; z += x + y; clr->cx = x / z; clr->cy = y / z; clr->flags |= C_CSXY; - } else { /* cxy -> cspec */ + } else if (fl & C_CSSPEC) { /* cxy -> cspec */ z = (cie_xf.ssum + cie_yf.ssum + cie_zf.ssum) / 3.; x = clr->cx * z / cie_xf.ssum; y = clr->cy * z / cie_yf.ssum; @@ -467,34 +481,68 @@ int fl; clr->ssum += clr->ssamp[i] = x * cie_xf.ssamp[i] + y * cie_yf.ssamp[i] + - z * cie_zf.ssamp[i] ; + z * cie_zf.ssamp[i] + .5; clr->flags |= C_CSSPEC; } + if (fl & C_CSEFF) { /* compute efficacy */ + if (clr->flags & C_CDSPEC) { /* from spectrum */ + y = 0.; + for (i = 0; i < C_CNSS; i++) + y += cie_yf.ssamp[i] * clr->ssamp[i]; + clr->eff = C_CLPWM * y / clr->ssum; + } else /* clr->flags & C_CDXY */ { /* from (x,y) */ + clr->eff = clr->cx*cie_xf.eff + clr->cy*cie_yf.eff + + (1. - clr->cx - clr->cy)*cie_zf.eff; + } + clr->flags |= C_CSEFF; + } } static int setspectrum(clr, wlmin, wlmax, ac, av) /* convert a spectrum */ register C_COLOR *clr; -int wlmin, wlmax; +double wlmin, wlmax; int ac; char **av; { double scale; - float *va; - register int i; - int wl, pos; + float va[C_CNSS]; + register int i, pos; + int n, imax; + int wl; double wl0, wlstep; - - if (wlmin < C_CMINWL || wlmin >= wlmax || wlmax > C_CMAXWL) + /* check bounds */ + if (wlmax <= C_CMINWL | wlmax <= wlmin | wlmin >= C_CMAXWL) return(MG_EILL); - if ((va = (float *)malloc(ac*sizeof(float))) == NULL) - return(MG_EMEM); + wlstep = (wlmax - wlmin)/(ac-1); + while (wlmin < C_CMINWL) { + wlmin += wlstep; + ac--; av++; + } + while (wlmax > C_CMAXWL) { + wlmax -= wlstep; + ac--; + } + if (ac < 2) + return(MG_EILL); + imax = ac; /* box filter if necessary */ + if (wlstep < C_CWLI) { + wlstep = C_CWLI; + imax = (wlmax - wlmin)/wlstep; + } scale = 0.; /* get values and maximum */ - for (i = 0; i < ac; i++) { - if (!isflt(av[i])) - return(MG_ETYPE); - va[i] = atof(av[i]); + pos = 0; + for (i = 0; i < imax; i++) { + va[i] = 0.; n = 0; + while (pos < (i+.5)*ac/imax) { + if (!isflt(av[pos])) + return(MG_ETYPE); + va[i] += atof(av[pos++]); + n++; + } + if (n > 1) + va[i] /= (double)n; if (va[i] < 0.) return(MG_EILL); if (va[i] > scale) @@ -505,27 +553,25 @@ char **av; scale = C_CMAXV / scale; clr->ssum = 0; /* convert to our spacing */ wl0 = wlmin; - wlstep = (double)(wlmax - wlmin)/(ac-1); pos = 0; for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI) - if (wl < wlmin || wl > wlmax) + if (wl < wlmin | wl > wlmax) clr->ssamp[i] = 0; else { while (wl0 + wlstep < wl+FTINY) { wl0 += wlstep; pos++; } - if (wl+FTINY >= wl0 && wl-FTINY <= wl0) - clr->ssamp[i] = scale*va[pos]; + if (wl+FTINY >= wl0 & wl-FTINY <= wl0) + clr->ssamp[i] = scale*va[pos] + .5; else /* interpolate if necessary */ - clr->ssamp[i] = scale / wlstep * + clr->ssamp[i] = .5 + scale / wlstep * ( va[pos]*(wl0+wlstep - wl) + va[pos+1]*(wl - wl0) ); clr->ssum += clr->ssamp[i]; } clr->flags = C_CDSPEC|C_CSSPEC; clr->clock++; - free((MEM_PTR)va); return(MG_OK); } @@ -540,10 +586,10 @@ double w1, w2; register int i; if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */ - c_ccvt(c1, C_CSSPEC); - c_ccvt(c2, C_CSSPEC); - w1 /= (double)c1->ssum; - w2 /= (double)c2->ssum; + c_ccvt(c1, C_CSSPEC|C_CSEFF); + c_ccvt(c2, C_CSSPEC|C_CSEFF); + w1 /= c1->eff*c1->ssum; + w2 /= c2->eff*c2->ssum; scale = 0.; for (i = 0; i < C_CNSS; i++) { cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i]; @@ -564,3 +610,41 @@ double w1, w2; cres->flags = C_CDXY|C_CSXY; } } + + +#define C1 3.741832e-16 /* W-m^2 */ +#define C2 1.4388e-2 /* m-K */ + +#define bbsp(l,t) (C1/((l)*(l)*(l)*(l)*(l)*(exp(C2/((t)*(l)))-1.))) +#define bblm(t) (C2/5./(t)) + +static int +setbbtemp(clr, tk) /* set black body spectrum */ +register C_COLOR *clr; +double tk; +{ + double sf, wl; + register int i; + + if (tk < 1000) + return(MG_EILL); + wl = bblm(tk); /* scalefactor based on peak */ + if (wl < C_CMINWL*1e-9) + wl = C_CMINWL*1e-9; + else if (wl > C_CMAXWL*1e-9) + wl = C_CMAXWL*1e-9; + sf = C_CMAXV/bbsp(wl,tk); + clr->ssum = 0; + for (i = 0; i < C_CNSS; i++) { + wl = (C_CMINWL + i*C_CWLI)*1e-9; + clr->ssum += clr->ssamp[i] = sf*bbsp(wl,tk) + .5; + } + clr->flags = C_CDSPEC|C_CSSPEC; + clr->clock++; + return(MG_OK); +} + +#undef C1 +#undef C2 +#undef bbsp +#undef bblm
