--- ray/src/cv/mgflib/context.c 1994/06/30 11:07:36 1.11 +++ ray/src/cv/mgflib/context.c 1994/07/01 10:18:38 1.12 @@ -26,8 +26,11 @@ static C_VERTEX c_unvertex = C_DEFVERTEX; /* the current contexts */ C_COLOR *c_ccolor = &c_uncolor; +char *c_ccname = NULL; C_MATERIAL *c_cmaterial = &c_unmaterial; +char *c_cmname = NULL; C_VERTEX *c_cvertex = &c_unvertex; +char *c_cvname = NULL; static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */ static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */ @@ -49,7 +52,6 @@ register char **av; { double w, wsum; register int i; - char *nm; register LUENT *lp; switch (mg_entity(av[0])) { @@ -59,6 +61,7 @@ register char **av; if (ac == 1) { /* set unnamed color context */ c_uncolor = c_dfcolor; c_ccolor = &c_uncolor; + c_ccname = NULL; return(MG_OK); } lp = lu_find(&clr_tab, av[1]); /* lookup context */ @@ -83,11 +86,10 @@ register char **av; c_ccolor = (C_COLOR *)lp->data; c_ccolor->clock = 0; } - nm = lp->key; + c_ccname = lp->key; i = c_ccolor->clock; if (ac == 3) { /* use default template */ *c_ccolor = c_dfcolor; - c_ccolor->name = nm; c_ccolor->clock = i + 1; return(MG_OK); } @@ -97,7 +99,6 @@ register char **av; if (lp->data == NULL) return(MG_EUNDEF); *c_ccolor = *(C_COLOR *)lp->data; - c_ccolor->name = nm; c_ccolor->clock = i + 1; return(MG_OK); case MG_E_CXY: /* assign CIE XY value */ @@ -160,7 +161,6 @@ int ac; register char **av; { int i; - char *nm; register LUENT *lp; switch (mg_entity(av[0])) { @@ -170,6 +170,7 @@ register char **av; if (ac == 1) { /* set unnamed material context */ c_unmaterial = c_dfmaterial; c_cmaterial = &c_unmaterial; + c_cmname = NULL; return(MG_OK); } lp = lu_find(&mat_tab, av[1]); /* lookup context */ @@ -194,11 +195,10 @@ register char **av; c_cmaterial = (C_MATERIAL *)lp->data; c_cmaterial->clock = 0; } - nm = lp->key; + c_cmname = lp->key; i = c_cmaterial->clock; if (ac == 3) { /* use default template */ *c_cmaterial = c_dfmaterial; - c_cmaterial->name = nm; c_cmaterial->clock = i + 1; return(MG_OK); } @@ -208,7 +208,6 @@ register char **av; if (lp->data == NULL) return(MG_EUNDEF); *c_cmaterial = *(C_MATERIAL *)lp->data; - c_cmaterial->name = nm; c_cmaterial->clock = i + 1; return(MG_OK); case MG_E_RD: /* set diffuse reflectance */ @@ -281,7 +280,6 @@ int ac; register char **av; { int i; - char *nm; register LUENT *lp; switch (mg_entity(av[0])) { @@ -291,6 +289,7 @@ register char **av; if (ac == 1) { /* set unnamed vertex context */ c_unvertex = c_dfvertex; c_cvertex = &c_unvertex; + c_cvname = NULL; return(MG_OK); } lp = lu_find(&vtx_tab, av[1]); /* lookup context */ @@ -314,11 +313,10 @@ register char **av; return(MG_EMEM); c_cvertex = (C_VERTEX *)lp->data; } - nm = lp->key; + c_cvname = lp->key; i = c_cvertex->clock; if (ac == 3) { /* use default template */ *c_cvertex = c_dfvertex; - c_cvertex->name = nm; c_cvertex->clock = i + 1; return(MG_OK); } @@ -328,7 +326,6 @@ register char **av; if (lp->data == NULL) return(MG_EUNDEF); *c_cvertex = *(C_VERTEX *)lp->data; - c_cvertex->name = nm; c_cvertex->clock = i + 1; return(MG_OK); case MG_E_POINT: /* set point */
