root/radiance/ray/src/cv/mgflib/context.c
Revision: 1.10
Committed: Sat Jun 25 19:31:14 1994 UTC (31 years ago) by greg
Changes since 1.9: +16 -13 lines
fixed bugs made worse by last change
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Context handlers
9 */
10
11 #include <stdio.h>
12 #include <math.h>
13 #include <string.h>
14 #include "parser.h"
15 #include "lookup.h"
16
17 /* default context values */
18 static C_COLOR c_dfcolor = C_DEFCOLOR;
19 static C_MATERIAL c_dfmaterial = C_DEFMATERIAL;
20 static C_VERTEX c_dfvertex = C_DEFVERTEX;
21
22 /* the unnamed contexts */
23 static C_COLOR c_uncolor = C_DEFCOLOR;
24 static C_MATERIAL c_unmaterial = C_DEFMATERIAL;
25 static C_VERTEX c_unvertex = C_DEFVERTEX;
26
27 /* the current contexts */
28 C_COLOR *c_ccolor = &c_uncolor;
29 C_MATERIAL *c_cmaterial = &c_unmaterial;
30 C_VERTEX *c_cvertex = &c_unvertex;
31
32 static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */
33 static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */
34 static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */
35
36 /* CIE 1931 Standard Observer */
37 static C_COLOR cie_xf = C_CIEX;
38 static C_COLOR cie_yf = C_CIEY;
39 static C_COLOR cie_zf = C_CIEZ;
40
41 static int setspectrum();
42 static void mixcolors();
43
44
45 int
46 c_hcolor(ac, av) /* handle color entity */
47 int ac;
48 register char **av;
49 {
50 double w, wsum;
51 register int i;
52 char *nm;
53 register LUENT *lp;
54
55 switch (mg_entity(av[0])) {
56 case MG_E_COLOR: /* get/set color context */
57 if (ac > 4)
58 return(MG_EARGC);
59 if (ac == 1) { /* set unnamed color context */
60 c_uncolor = c_dfcolor;
61 c_ccolor = &c_uncolor;
62 return(MG_OK);
63 }
64 lp = lu_find(&clr_tab, av[1]); /* lookup context */
65 if (lp == NULL)
66 return(MG_EMEM);
67 c_ccolor = (C_COLOR *)lp->data;
68 if (ac == 2) { /* reestablish previous context */
69 if (c_ccolor == NULL)
70 return(MG_EUNDEF);
71 return(MG_OK);
72 }
73 if (av[2][0] != '=' || av[2][1])
74 return(MG_ETYPE);
75 if (c_ccolor == NULL) { /* create new color context */
76 lp->key = (char *)malloc(strlen(av[1])+1);
77 if (lp->key == NULL)
78 return(MG_EMEM);
79 strcpy(lp->key, av[1]);
80 lp->data = (char *)malloc(sizeof(C_COLOR));
81 if (lp->data == NULL)
82 return(MG_EMEM);
83 c_ccolor = (C_COLOR *)lp->data;
84 c_ccolor->clock = 0;
85 }
86 nm = lp->key;
87 i = c_ccolor->clock;
88 if (ac == 3) { /* use default template */
89 *c_ccolor = c_dfcolor;
90 c_ccolor->name = nm;
91 c_ccolor->clock = i + 1;
92 return(MG_OK);
93 }
94 lp = lu_find(&clr_tab, av[3]); /* lookup template */
95 if (lp == NULL)
96 return(MG_EMEM);
97 if (lp->data == NULL)
98 return(MG_EUNDEF);
99 *c_ccolor = *(C_COLOR *)lp->data;
100 c_ccolor->name = nm;
101 c_ccolor->clock = i + 1;
102 return(MG_OK);
103 case MG_E_CXY: /* assign CIE XY value */
104 if (ac != 3)
105 return(MG_EARGC);
106 if (!isflt(av[1]) || !isflt(av[2]))
107 return(MG_ETYPE);
108 c_ccolor->cx = atof(av[1]);
109 c_ccolor->cy = atof(av[2]);
110 c_ccolor->flags = C_CDXY|C_CSXY;
111 if (c_ccolor->cx < 0. | c_ccolor->cy < 0. |
112 c_ccolor->cx + c_ccolor->cy > 1.)
113 return(MG_EILL);
114 c_ccolor->clock++;
115 return(MG_OK);
116 case MG_E_CSPEC: /* assign spectral values */
117 if (ac < 5)
118 return(MG_EARGC);
119 if (!isint(av[1]) || !isint(av[2]))
120 return(MG_ETYPE);
121 return(setspectrum(c_ccolor, atoi(av[1]), atoi(av[2]),
122 ac-3, av+3));
123 case MG_E_CMIX: /* mix colors */
124 if (ac < 5 || (ac-1)%2)
125 return(MG_EARGC);
126 if (!isflt(av[1]))
127 return(MG_ETYPE);
128 wsum = atof(av[1]);
129 if (wsum < 0.)
130 return(MG_EILL);
131 if ((lp = lu_find(&clr_tab, av[2])) == NULL)
132 return(MG_EMEM);
133 if (lp->data == NULL)
134 return(MG_EUNDEF);
135 *c_ccolor = *(C_COLOR *)lp->data;
136 for (i = 3; i < ac; i += 2) {
137 if (!isflt(av[i]))
138 return(MG_ETYPE);
139 w = atof(av[i]);
140 if (w < 0.)
141 return(MG_EILL);
142 if ((lp = lu_find(&clr_tab, av[i+1])) == NULL)
143 return(MG_EMEM);
144 if (lp->data == NULL)
145 return(MG_EUNDEF);
146 mixcolors(c_ccolor, wsum, c_ccolor,
147 w, (C_COLOR *)lp->data);
148 wsum += w;
149 }
150 c_ccolor->clock++;
151 return(MG_OK);
152 }
153 return(MG_EUNK);
154 }
155
156
157 int
158 c_hmaterial(ac, av) /* handle material entity */
159 int ac;
160 register char **av;
161 {
162 int i;
163 char *nm;
164 register LUENT *lp;
165
166 switch (mg_entity(av[0])) {
167 case MG_E_MATERIAL: /* get/set material context */
168 if (ac > 4)
169 return(MG_EARGC);
170 if (ac == 1) { /* set unnamed material context */
171 c_unmaterial = c_dfmaterial;
172 c_cmaterial = &c_unmaterial;
173 return(MG_OK);
174 }
175 lp = lu_find(&mat_tab, av[1]); /* lookup context */
176 if (lp == NULL)
177 return(MG_EMEM);
178 c_cmaterial = (C_MATERIAL *)lp->data;
179 if (ac == 2) { /* reestablish previous context */
180 if (c_cmaterial == NULL)
181 return(MG_EUNDEF);
182 return(MG_OK);
183 }
184 if (av[2][0] != '=' || av[2][1])
185 return(MG_ETYPE);
186 if (c_cmaterial == NULL) { /* create new material */
187 lp->key = (char *)malloc(strlen(av[1])+1);
188 if (lp->key == NULL)
189 return(MG_EMEM);
190 strcpy(lp->key, av[1]);
191 lp->data = (char *)malloc(sizeof(C_MATERIAL));
192 if (lp->data == NULL)
193 return(MG_EMEM);
194 c_cmaterial = (C_MATERIAL *)lp->data;
195 c_cmaterial->clock = 0;
196 }
197 nm = lp->key;
198 i = c_cmaterial->clock;
199 if (ac == 3) { /* use default template */
200 *c_cmaterial = c_dfmaterial;
201 c_cmaterial->name = nm;
202 c_cmaterial->clock = i + 1;
203 return(MG_OK);
204 }
205 lp = lu_find(&mat_tab, av[3]); /* lookup template */
206 if (lp == NULL)
207 return(MG_EMEM);
208 if (lp->data == NULL)
209 return(MG_EUNDEF);
210 *c_cmaterial = *(C_MATERIAL *)lp->data;
211 c_cmaterial->name = nm;
212 c_cmaterial->clock = i + 1;
213 return(MG_OK);
214 case MG_E_RD: /* set diffuse reflectance */
215 if (ac != 2)
216 return(MG_EARGC);
217 if (!isflt(av[1]))
218 return(MG_ETYPE);
219 c_cmaterial->rd = atof(av[1]);
220 if (c_cmaterial->rd < 0. | c_cmaterial->rd > 1.)
221 return(MG_EILL);
222 c_cmaterial->rd_c = *c_ccolor;
223 c_cmaterial->clock++;
224 return(MG_OK);
225 case MG_E_ED: /* set diffuse emittance */
226 if (ac != 2)
227 return(MG_EARGC);
228 if (!isflt(av[1]))
229 return(MG_ETYPE);
230 c_cmaterial->ed = atof(av[1]);
231 if (c_cmaterial->ed < 0.)
232 return(MG_EILL);
233 c_cmaterial->ed_c = *c_ccolor;
234 c_cmaterial->clock++;
235 return(MG_OK);
236 case MG_E_TD: /* set diffuse transmittance */
237 if (ac != 2)
238 return(MG_EARGC);
239 if (!isflt(av[1]))
240 return(MG_ETYPE);
241 c_cmaterial->td = atof(av[1]);
242 if (c_cmaterial->td < 0. | c_cmaterial->td > 1.)
243 return(MG_EILL);
244 c_cmaterial->td_c = *c_ccolor;
245 c_cmaterial->clock++;
246 return(MG_OK);
247 case MG_E_RS: /* set specular reflectance */
248 if (ac != 3)
249 return(MG_EARGC);
250 if (!isflt(av[1]) || !isflt(av[2]))
251 return(MG_ETYPE);
252 c_cmaterial->rs = atof(av[1]);
253 c_cmaterial->rs_a = atof(av[2]);
254 if (c_cmaterial->rs < 0. | c_cmaterial->rs > 1. |
255 c_cmaterial->rs_a < 0.)
256 return(MG_EILL);
257 c_cmaterial->rs_c = *c_ccolor;
258 c_cmaterial->clock++;
259 return(MG_OK);
260 case MG_E_TS: /* set specular transmittance */
261 if (ac != 3)
262 return(MG_EARGC);
263 if (!isflt(av[1]) || !isflt(av[2]))
264 return(MG_ETYPE);
265 c_cmaterial->ts = atof(av[1]);
266 c_cmaterial->ts_a = atof(av[2]);
267 if (c_cmaterial->ts < 0. | c_cmaterial->ts > 1. |
268 c_cmaterial->ts_a < 0.)
269 return(MG_EILL);
270 c_cmaterial->ts_c = *c_ccolor;
271 c_cmaterial->clock++;
272 return(MG_OK);
273 }
274 return(MG_EUNK);
275 }
276
277
278 int
279 c_hvertex(ac, av) /* handle a vertex entity */
280 int ac;
281 register char **av;
282 {
283 int i;
284 char *nm;
285 register LUENT *lp;
286
287 switch (mg_entity(av[0])) {
288 case MG_E_VERTEX: /* get/set vertex context */
289 if (ac > 4)
290 return(MG_EARGC);
291 if (ac == 1) { /* set unnamed vertex context */
292 c_unvertex = c_dfvertex;
293 c_cvertex = &c_unvertex;
294 return(MG_OK);
295 }
296 lp = lu_find(&vtx_tab, av[1]); /* lookup context */
297 if (lp == NULL)
298 return(MG_EMEM);
299 c_cvertex = (C_VERTEX *)lp->data;
300 if (ac == 2) { /* reestablish previous context */
301 if (c_cvertex == NULL)
302 return(MG_EUNDEF);
303 return(MG_OK);
304 }
305 if (av[2][0] != '=' || av[2][1])
306 return(MG_ETYPE);
307 if (c_cvertex == NULL) { /* create new vertex context */
308 lp->key = (char *)malloc(strlen(av[1])+1);
309 if (lp->key == NULL)
310 return(MG_EMEM);
311 strcpy(lp->key, av[1]);
312 lp->data = (char *)malloc(sizeof(C_VERTEX));
313 if (lp->data == NULL)
314 return(MG_EMEM);
315 c_cvertex = (C_VERTEX *)lp->data;
316 }
317 nm = lp->key;
318 i = c_cvertex->clock;
319 if (ac == 3) { /* use default template */
320 *c_cvertex = c_dfvertex;
321 c_cvertex->name = nm;
322 c_cvertex->clock = i + 1;
323 return(MG_OK);
324 }
325 lp = lu_find(&vtx_tab, av[3]); /* lookup template */
326 if (lp == NULL)
327 return(MG_EMEM);
328 if (lp->data == NULL)
329 return(MG_EUNDEF);
330 *c_cvertex = *(C_VERTEX *)lp->data;
331 c_cvertex->name = nm;
332 c_cvertex->clock = i + 1;
333 return(MG_OK);
334 case MG_E_POINT: /* set point */
335 if (ac != 4)
336 return(MG_EARGC);
337 if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3]))
338 return(MG_ETYPE);
339 c_cvertex->p[0] = atof(av[1]);
340 c_cvertex->p[1] = atof(av[2]);
341 c_cvertex->p[2] = atof(av[3]);
342 c_cvertex->clock++;
343 return(MG_OK);
344 case MG_E_NORMAL: /* set normal */
345 if (ac != 4)
346 return(MG_EARGC);
347 if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3]))
348 return(MG_ETYPE);
349 c_cvertex->n[0] = atof(av[1]);
350 c_cvertex->n[1] = atof(av[2]);
351 c_cvertex->n[2] = atof(av[3]);
352 (void)normalize(c_cvertex->n);
353 c_cvertex->clock++;
354 return(MG_OK);
355 }
356 return(MG_EUNK);
357 }
358
359
360 void
361 c_clearall() /* empty context tables */
362 {
363 c_uncolor = c_dfcolor;
364 c_ccolor = &c_uncolor;
365 lu_done(&clr_tab);
366 c_unmaterial = c_dfmaterial;
367 c_cmaterial = &c_unmaterial;
368 lu_done(&mat_tab);
369 c_unvertex = c_dfvertex;
370 c_cvertex = &c_unvertex;
371 lu_done(&vtx_tab);
372 }
373
374
375 C_VERTEX *
376 c_getvert(name) /* get a named vertex */
377 char *name;
378 {
379 register LUENT *lp;
380
381 if ((lp = lu_find(&vtx_tab, name)) == NULL)
382 return(NULL);
383 return((C_VERTEX *)lp->data);
384 }
385
386
387 C_COLOR *
388 c_getcolor(name) /* get a named color */
389 char *name;
390 {
391 register LUENT *lp;
392
393 if ((lp = lu_find(&clr_tab, name)) == NULL)
394 return(NULL);
395 return((C_COLOR *)lp->data);
396 }
397
398
399 int
400 c_isgrey(clr) /* check if color is grey */
401 register C_COLOR *clr;
402 {
403 if (!(clr->flags & (C_CSXY|C_CSSPEC)))
404 return(1); /* no settings == grey */
405 c_ccvt(clr, C_CSXY);
406 return(clr->cx >= .323 && clr->cx <= .343 &&
407 clr->cy >= .323 && clr->cy <= .343);
408 }
409
410
411 void
412 c_ccvt(clr, fl) /* convert color representations */
413 register C_COLOR *clr;
414 int fl;
415 {
416 double x, y, z;
417 register int i;
418
419 if (clr->flags & fl) /* already done */
420 return;
421 if (!(clr->flags & (C_CSXY|C_CSSPEC))) /* nothing set! */
422 *clr = c_dfcolor;
423 else if (fl & C_CSXY) { /* cspec -> cxy */
424 x = y = z = 0.;
425 for (i = 0; i < C_CNSS; i++) {
426 x += cie_xf.ssamp[i] * clr->ssamp[i];
427 y += cie_yf.ssamp[i] * clr->ssamp[i];
428 z += cie_zf.ssamp[i] * clr->ssamp[i];
429 }
430 z += x + y;
431 clr->cx = x / z;
432 clr->cy = y / z;
433 clr->flags |= C_CSXY;
434 } else { /* cxy -> cspec */
435 z = (cie_xf.ssum + cie_yf.ssum + cie_zf.ssum) / 3.;
436 x = clr->cx * z / cie_xf.ssum;
437 y = clr->cy * z / cie_yf.ssum;
438 z = (1. - clr->cx - clr->cy) * z / cie_zf.ssum;
439 clr->ssum = 0;
440 for (i = 0; i < C_CNSS; i++)
441 clr->ssum += clr->ssamp[i] =
442 x * cie_xf.ssamp[i] +
443 y * cie_yf.ssamp[i] +
444 z * cie_zf.ssamp[i] ;
445 clr->flags |= C_CSSPEC;
446 }
447 }
448
449
450 static int
451 setspectrum(clr, wlmin, wlmax, ac, av) /* convert a spectrum */
452 register C_COLOR *clr;
453 int wlmin, wlmax;
454 int ac;
455 char **av;
456 {
457 double scale;
458 float *va;
459 register int i;
460 int wl, pos;
461 double wl0, wlstep;
462
463 if (wlmin < C_CMINWL || wlmin >= wlmax || wlmax > C_CMAXWL)
464 return(MG_EILL);
465 if ((va = (float *)malloc(ac*sizeof(float))) == NULL)
466 return(MG_EMEM);
467 scale = 0.; /* get values and maximum */
468 for (i = 0; i < ac; i++) {
469 if (!isflt(av[i]))
470 return(MG_ETYPE);
471 va[i] = atof(av[i]);
472 if (va[i] < 0.)
473 return(MG_EILL);
474 if (va[i] > scale)
475 scale = va[i];
476 }
477 if (scale == 0.)
478 return(MG_EILL);
479 scale = C_CMAXV / scale;
480 clr->ssum = 0; /* convert to our spacing */
481 wl0 = wlmin;
482 wlstep = (double)(wlmax - wlmin)/(ac-1);
483 pos = 0;
484 for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI)
485 if (wl < wlmin || wl > wlmax)
486 clr->ssamp[i] = 0;
487 else {
488 while (wl0 + wlstep < wl+FTINY) {
489 wl0 += wlstep;
490 pos++;
491 }
492 if (wl+FTINY >= wl0 && wl-FTINY <= wl0)
493 clr->ssamp[i] = scale*va[pos];
494 else /* interpolate if necessary */
495 clr->ssamp[i] = scale / wlstep *
496 ( va[pos]*(wl0+wlstep - wl) +
497 va[pos+1]*(wl - wl0) );
498 clr->ssum += clr->ssamp[i];
499 }
500 clr->flags = C_CDSPEC|C_CSSPEC;
501 clr->clock++;
502 free((MEM_PTR)va);
503 return(MG_OK);
504 }
505
506
507 static void
508 mixcolors(cres, w1, c1, w2, c2) /* mix two colors according to weights given */
509 register C_COLOR *cres, *c1, *c2;
510 double w1, w2;
511 {
512 double scale;
513 float cmix[C_CNSS];
514 register int i;
515
516 if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */
517 c_ccvt(c1, C_CSSPEC);
518 c_ccvt(c2, C_CSSPEC);
519 w1 /= (double)c1->ssum;
520 w2 /= (double)c2->ssum;
521 scale = 0.;
522 for (i = 0; i < C_CNSS; i++) {
523 cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i];
524 if (cmix[i] > scale)
525 scale = cmix[i];
526 }
527 scale = C_CMAXV / scale;
528 cres->ssum = 0;
529 for (i = 0; i < C_CNSS; i++)
530 cres->ssum += cres->ssamp[i] = scale*cmix[i] + .5;
531 cres->flags = C_CDSPEC|C_CSSPEC;
532 } else { /* CIE xy mixing */
533 c_ccvt(c1, C_CSXY);
534 c_ccvt(c2, C_CSXY);
535 scale = 1. / (w1/c1->cy + w2/c2->cy);
536 cres->cx = (c1->cx*w1/c1->cy + c2->cx*w2/c2->cy) * scale;
537 cres->cy = (w1 + w2) * scale;
538 cres->flags = C_CDXY|C_CSXY;
539 }
540 }
