root/radiance/ray/src/cv/mgflib/context.c
Sun Jul 27 22:12:02 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 1.27: +12 -12 lines
Diff to previous 1.27 , to selected 1.24
Fri Feb 28 20:11:29 2003 UTC (21 years, 2 months ago) by greg
Changes since 1.26: +1 -4 lines
Diff to previous 1.26 , to selected 1.24
Updates for 3.5 release
Mon Dec 15 09:41:37 1997 UTC (26 years, 4 months ago) by gregl
Changes since 1.25: +1 -0 lines
Diff to previous 1.25 , to selected 1.24
added stdlib.h for better reliability on some systems
Fri Oct 10 16:45:51 1997 UTC (26 years, 6 months ago) by gregl
Changes since 1.24: +10 -6 lines
Diff to previous 1.24
Added client data pointers to context structures (vertex, color, material).
Revision 1.24 - (view) (download) (annotate) - [selected]
Wed Feb 12 11:38:52 1997 UTC (27 years, 2 months ago) by greg
Changes since 1.23: +7 -6 lines
Diff to previous 1.23
allow negative weights in cmix entity
Mon Aug 28 16:44:12 1995 UTC (28 years, 8 months ago) by greg
Diff to previous 1.22 , to selected 1.24
allow negative values for spectral components
Wed May 10 17:46:09 1995 UTC (28 years, 11 months ago) by greg
Changes since 1.21: +6 -0 lines
Diff to previous 1.21 , to selected 1.24
added check for illegal names and identifiers
Thu Apr 13 12:11:26 1995 UTC (29 years ago) by greg
Changes since 1.20: +11 -0 lines
Diff to previous 1.20 , to selected 1.24
added material index of refraction
Wed Apr 12 17:16:33 1995 UTC (29 years ago) by greg
Changes since 1.19: +9 -5 lines
Diff to previous 1.19 , to selected 1.24
improved box filtering of detailed spectra in setspectrum()
Mon Mar 13 13:00:34 1995 UTC (29 years, 1 month ago) by greg
Changes since 1.18: +57 -15 lines
Diff to previous 1.18 , to selected 1.24
added conversion from (x,y) chromaticities to spectral color
Tue Mar 7 14:53:20 1995 UTC (29 years, 2 months ago) by greg
Changes since 1.17: +54 -9 lines
Diff to previous 1.17 , to selected 1.24
added cct entity
Fri Feb 24 16:50:08 1995 UTC (29 years, 2 months ago) by greg
Changes since 1.16: +42 -19 lines
Diff to previous 1.16 , to selected 1.24
fixed context handlers for spectral power distribution data
Fri Sep 2 16:04:19 1994 UTC (29 years, 8 months ago) by greg
Changes since 1.15: +20 -7 lines
Diff to previous 1.15 , to selected 1.24
corrected problems with cmix function (I think -- needs checking!)
Fri Jul 22 12:50:24 1994 UTC (29 years, 9 months ago) by greg
Diff to previous 1.14 , to selected 1.24
added clearing of current names to c_clearall()
Thu Jul 7 17:27:58 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.13: +6 -3 lines
Diff to previous 1.13 , to selected 1.24
bug fix in setting of current names
Fri Jul 1 18:06:56 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.12: +14 -0 lines
Diff to previous 1.12 , to selected 1.24
added "sides" entity for one- vs. two-sided surfaces
Fri Jul 1 10:18:38 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.11: +9 -12 lines
Diff to previous 1.11 , to selected 1.24
changed context names from struct members to extern variables
Thu Jun 30 11:07:36 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.10: +12 -0 lines
Diff to previous 1.10 , to selected 1.24
added c_getmaterial() call
Sat Jun 25 19:31:14 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.9: +16 -13 lines
Diff to previous 1.9 , to selected 1.24
fixed bugs made worse by last change
Sat Jun 25 16:33:14 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.8: +34 -27 lines
Diff to previous 1.8 , to selected 1.24
bug fixes and enhancements
Sat Jun 25 11:55:45 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.7: +14 -2 lines
Diff to previous 1.7 , to selected 1.24
added name and clock members to C_COLOR and C_VERTEX structures
Sat Jun 25 09:48:01 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.6: +12 -0 lines
Diff to previous 1.6 , to selected 1.24
minor fixes and enhancements
Fri Jun 24 17:15:47 1994 UTC (29 years, 10 months ago) by greg
Diff to previous 1.5 , to selected 1.24
minor bug fix
Fri Jun 24 16:28:15 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.4: +189 -0 lines
Diff to previous 1.4 , to selected 1.24
added cspec and cmix entities
Fri Jun 24 09:32:49 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.3: +6 -0 lines
Diff to previous 1.3 , to selected 1.24
added prism entity and minor changes
Thu Jun 23 07:48:39 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.2: +6 -15 lines
Diff to previous 1.2 , to selected 1.24
improved table lookup routines with new delete function
Wed Jun 22 15:33:44 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.1: +8 -0 lines
Diff to previous 1.1 , to selected 1.24
various enhancements and fixes
Tue Jun 21 14:45:43 1994 UTC (29 years, 10 months ago) by greg
Diff to selected 1.24
