--- ray/src/cv/mgflib/context.c 1994/06/22 15:33:44 1.2 +++ ray/src/cv/mgflib/context.c 1994/06/25 11:55:45 1.8 @@ -29,20 +29,32 @@ C_COLOR *c_ccolor = &c_uncolor; C_MATERIAL *c_cmaterial = &c_unmaterial; C_VERTEX *c_cvertex = &c_unvertex; -static LUTAB clr_tab; /* color lookup table */ -static LUTAB mat_tab; /* material lookup table */ -static LUTAB vtx_tab; /* vertex lookup table */ +static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */ +static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */ +static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */ + /* CIE 1931 Standard Observer */ +static C_COLOR cie_xf = C_CIEX; +static C_COLOR cie_yf = C_CIEY; +static C_COLOR cie_zf = C_CIEZ; +static int setspectrum(); +static void mixcolors(); + + int c_hcolor(ac, av) /* handle color entity */ int ac; register char **av; { + double w, wsum; + register int i; register LUENT *lp; switch (mg_entity(av[0])) { case MG_E_COLOR: /* get/set color context */ + if (ac > 4) + return(MG_EARGC); if (ac == 1) { /* set unnamed color context */ c_uncolor = c_dfcolor; c_ccolor = &c_uncolor; @@ -71,6 +83,7 @@ register char **av; c_ccolor = (C_COLOR *)lp->data; if (ac == 3) { /* use default template */ *c_ccolor = c_dfcolor; + c_ccolor->name = lp->key; return(MG_OK); } lp = lu_find(&clr_tab, av[3]); /* lookup template */ @@ -79,6 +92,8 @@ register char **av; if (lp->data == NULL) return(MG_EUNDEF); *c_ccolor = *(C_COLOR *)lp->data; + c_ccolor->name = lp->key; + c_ccolor->clock = 1; if (ac > 4) return(MG_EARGC); return(MG_OK); @@ -89,10 +104,47 @@ register char **av; return(MG_ETYPE); c_ccolor->cx = atof(av[1]); c_ccolor->cy = atof(av[2]); + c_ccolor->flags = C_CDXY|C_CSXY; if (c_ccolor->cx < 0. | c_ccolor->cy < 0. | c_ccolor->cx + c_ccolor->cy > 1.) return(MG_EILL); + c_ccolor->clock++; return(MG_OK); + case MG_E_CSPEC: /* assign spectral values */ + if (ac < 5) + return(MG_EARGC); + if (!isint(av[1]) || !isint(av[2])) + return(MG_ETYPE); + return(setspectrum(c_ccolor, atoi(av[1]), atoi(av[2]), + ac-3, av+3)); + case MG_E_CMIX: /* mix colors */ + if (ac < 5 || (ac-1)%2) + return(MG_EARGC); + if (!isflt(av[1])) + return(MG_ETYPE); + wsum = atof(av[1]); + if (wsum < 0.) + return(MG_EILL); + if ((lp = lu_find(&clr_tab, av[2])) == NULL) + return(MG_EMEM); + if (lp->data == NULL) + return(MG_EUNDEF); + *c_ccolor = *(C_COLOR *)lp->data; + for (i = 3; i < ac; i += 2) { + if (!isflt(av[i])) + return(MG_ETYPE); + w = atof(av[i]); + if (w < 0.) + return(MG_EILL); + if ((lp = lu_find(&clr_tab, av[i+1])) == NULL) + return(MG_EMEM); + if (lp->data == NULL) + return(MG_EUNDEF); + mixcolors(c_ccolor, wsum, c_ccolor, + w, (C_COLOR *)lp->data); + wsum += w; + } + return(MG_OK); } return(MG_EUNK); } @@ -107,6 +159,8 @@ register char **av; switch (mg_entity(av[0])) { case MG_E_MATERIAL: /* get/set material context */ + if (ac > 4) + return(MG_EARGC); if (ac == 1) { /* set unnamed material context */ c_unmaterial = c_dfmaterial; c_cmaterial = &c_unmaterial; @@ -180,6 +234,7 @@ register char **av; if (c_cmaterial->td < 0. | c_cmaterial->td > 1.) return(MG_EILL); c_cmaterial->td_c = *c_ccolor; + c_cmaterial->clock++; return(MG_OK); case MG_E_RS: /* set specular reflectance */ if (ac != 3) @@ -221,6 +276,8 @@ register char **av; switch (mg_entity(av[0])) { case MG_E_VERTEX: /* get/set vertex context */ + if (ac > 4) + return(MG_EARGC); if (ac == 1) { /* set unnamed vertex context */ c_unvertex = c_dfvertex; c_cvertex = &c_unvertex; @@ -249,6 +306,7 @@ register char **av; c_cvertex = (C_VERTEX *)lp->data; if (ac == 3) { /* use default template */ *c_cvertex = c_dfvertex; + c_cvertex->name = lp->key return(MG_OK); } lp = lu_find(&vtx_tab, av[3]); /* lookup template */ @@ -257,6 +315,8 @@ register char **av; if (lp->data == NULL) return(MG_EUNDEF); *c_cvertex = *(C_VERTEX *)lp->data; + c_cvertex->name = lp->key + c_cvertex->clock = 1; if (ac > 4) return(MG_EARGC); return(MG_OK); @@ -268,6 +328,7 @@ register char **av; c_cvertex->p[0] = atof(av[1]); c_cvertex->p[1] = atof(av[2]); c_cvertex->p[2] = atof(av[3]); + c_cvertex->clock++; return(MG_OK); case MG_E_NORMAL: /* set normal */ if (ac != 4) @@ -278,33 +339,25 @@ register char **av; c_cvertex->n[1] = atof(av[2]); c_cvertex->n[2] = atof(av[3]); (void)normalize(c_cvertex->n); + c_cvertex->clock++; return(MG_OK); } return(MG_EUNK); } -static void -freectx(lp) /* free a context table entry */ -register LUENT *lp; -{ - free((MEM_PTR)lp->key); - free((MEM_PTR)lp->data); -} - - void c_clearall() /* empty context tables */ { c_uncolor = c_dfcolor; c_ccolor = &c_uncolor; - lu_done(&clr_tab, freectx); + lu_done(&clr_tab); c_unmaterial = c_dfmaterial; c_cmaterial = &c_unmaterial; - lu_done(&mat_tab, freectx); + lu_done(&mat_tab); c_unvertex = c_dfvertex; c_cvertex = &c_unvertex; - lu_done(&vtx_tab, freectx); + lu_done(&vtx_tab); } @@ -317,4 +370,161 @@ char *name; if ((lp = lu_find(&vtx_tab, name)) == NULL) return(NULL); return((C_VERTEX *)lp->data); +} + + +C_COLOR * +c_getcolor(name) /* get a named color */ +char *name; +{ + register LUENT *lp; + + if ((lp = lu_find(&clr_tab, name)) == NULL) + return(NULL); + return((C_COLOR *)lp->data); +} + + +int +c_isgrey(clr) /* check if color is grey */ +register C_COLOR *clr; +{ + if (!(clr->flags & (C_CSXY|C_CSSPEC))) + return(1); /* no settings == grey */ + c_ccvt(clr, C_CSXY); + return(clr->cx >= .323 && clr->cx <= .343 && + clr->cy >= .323 && clr->cy <= .343); +} + + +void +c_ccvt(clr, fl) /* convert color representations */ +register C_COLOR *clr; +int fl; +{ + double x, y, z; + register int i; + + if (clr->flags & fl) /* already done */ + return; + if (!(clr->flags & (C_CSXY|C_CSSPEC))) /* nothing set! */ + *clr = c_dfcolor; + else if (fl & C_CSXY) { /* cspec -> cxy */ + x = y = z = 0.; + for (i = 0; i < C_CNSS; i++) { + x += cie_xf.ssamp[i] * clr->ssamp[i]; + y += cie_yf.ssamp[i] * clr->ssamp[i]; + z += cie_zf.ssamp[i] * clr->ssamp[i]; + } + z += x + y; + clr->cx = x / z; + clr->cy = y / z; + clr->flags |= C_CSXY; + } else { /* cxy -> cspec */ + z = (cie_xf.ssum + cie_yf.ssum + cie_zf.ssum) / 3.; + x = clr->cx * z / cie_xf.ssum; + y = clr->cy * z / cie_yf.ssum; + z = (1. - clr->cx - clr->cy) * z / cie_zf.ssum; + clr->ssum = 0; + for (i = 0; i < C_CNSS; i++) + clr->ssum += clr->ssamp[i] = + x * cie_xf.ssamp[i] + + y * cie_yf.ssamp[i] + + z * cie_zf.ssamp[i] ; + clr->flags |= C_CSSPEC; + } +} + + +static int +setspectrum(clr, wlmin, wlmax, ac, av) /* convert a spectrum */ +register C_COLOR *clr; +int wlmin, wlmax; +int ac; +char **av; +{ + double scale; + float *va; + register int i; + int wl, pos; + double wl0, wlstep; + + if (wlmin < C_CMINWL || wlmin >= wlmax || wlmax > C_CMAXWL) + return(MG_EILL); + if ((va = (float *)malloc(ac*sizeof(float))) == NULL) + return(MG_EMEM); + scale = 0.; /* get values and maximum */ + for (i = 0; i < ac; i++) { + if (!isflt(av[i])) + return(MG_ETYPE); + va[i] = atof(av[i]); + if (va[i] < 0.) + return(MG_EILL); + if (va[i] > scale) + scale = va[i]; + } + if (scale == 0.) + return(MG_EILL); + scale = C_CMAXV / scale; + clr->ssum = 0; /* convert to our spacing */ + wl0 = wlmin; + wlstep = (double)(wlmax - wlmin)/(ac-1); + pos = 0; + for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI) + if (wl < wlmin || wl > wlmax) + clr->ssamp[i] = 0; + else { + while (wl0 + wlstep < wl+FTINY) { + wl0 += wlstep; + pos++; + } + if (wl+FTINY >= wl0 && wl-FTINY <= wl0) + clr->ssamp[i] = scale*va[pos]; + else /* interpolate if necessary */ + clr->ssamp[i] = scale / wlstep * + ( va[pos]*(wl0+wlstep - wl) + + va[pos+1]*(wl - wl0) ); + clr->ssum += clr->ssamp[i]; + } + clr->flags = C_CDSPEC|C_CSSPEC; + clr->clock++; + free((MEM_PTR)va); + return(MG_OK); +} + + +static void +mixcolors(cres, w1, c1, w2, c2) /* mix two colors according to weights given */ +register C_COLOR *cres, *c1, *c2; +double w1, w2; +{ + double scale; + float cmix[C_CNSS]; + register int i; + + if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */ + c_ccvt(c1, C_CSSPEC); + c_ccvt(c2, C_CSSPEC); + w1 /= (double)c1->ssum; + w2 /= (double)c2->ssum; + scale = 0.; + for (i = 0; i < C_CNSS; i++) { + cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i]; + if (cmix[i] > scale) + scale = cmix[i]; + } + scale = C_CMAXV / scale; + cres->ssum = 0; + for (i = 0; i < C_CNSS; i++) + cres->ssum += cres->ssamp[i] = scale*cmix[i] + .5; + cres->flags = C_CDSPEC|C_CSSPEC; + } else { /* CIE xy mixing */ + c_ccvt(c1, C_CSXY); + c_ccvt(c2, C_CSXY); + scale = 1. / (w1/c1->cy + w2/c2->cy); + cres->cx = (c1->cx*w1/c1->cy + c2->cx*w2/c2->cy) * scale; + cres->cy = (w1 + w2) * scale; + cres->flags = C_CDXY|C_CSXY; + } + cres->clock++; /* record the change */ }
