--- ray/src/cv/mgflib/context.c 1995/03/07 14:53:20 1.18 +++ ray/src/cv/mgflib/context.c 1997/10/10 16:45:51 1.25 @@ -1,4 +1,4 @@ -/* Copyright (c) 1994 Regents of the University of California */ +/* Copyright (c) 1997 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -36,10 +36,50 @@ static LUTAB clr_tab = LU_SINIT(free,free); /* color l static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */ static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */ - /* CIE 1931 Standard Observer */ -static C_COLOR cie_xf = C_CIEX; -static C_COLOR cie_yf = C_CIEY; -static C_COLOR cie_zf = C_CIEZ; + /* CIE 1931 Standard Observer curves */ +static C_COLOR cie_xf = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF, + {14,42,143,435,1344,2839,3483,3362,2908,1954,956, + 320,49,93,633,1655,2904,4334,5945,7621,9163,10263, + 10622,10026,8544,6424,4479,2835,1649,874,468,227, + 114,58,29,14,7,3,2,1,0}, 106836L, .467, .368, 362.230 + }; +static C_COLOR cie_yf = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF, + {0,1,4,12,40,116,230,380,600,910,1390,2080,3230, + 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310, + 5030,3810,2650,1750,1070,610,320,170,82,41,21,10, + 5,2,1,1,0,0}, 106856L, .398, .542, 493.525 + }; +static C_COLOR cie_zf = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF, + {65,201,679,2074,6456,13856,17471,17721,16692, + 12876,8130,4652,2720,1582,782,422,203,87,39,21,17, + 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, + 106770L, .147, .077, 54.363 + }; + /* Derived CIE 1931 Primaries (imaginary) */ +static C_COLOR cie_xp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY, + {-174,-198,-195,-197,-202,-213,-235,-272,-333, + -444,-688,-1232,-2393,-4497,-6876,-6758,-5256, + -3100,-815,1320,3200,4782,5998,6861,7408,7754, + 7980,8120,8199,8240,8271,8292,8309,8283,8469, + 8336,8336,8336,8336,8336,8336}, + 127424L, 1., .0, + }; +static C_COLOR cie_yp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY, + {-451,-431,-431,-430,-427,-417,-399,-366,-312, + -204,57,691,2142,4990,8810,9871,9122,7321,5145, + 3023,1123,-473,-1704,-2572,-3127,-3474,-3704, + -3846,-3927,-3968,-3999,-4021,-4038,-4012,-4201, + -4066,-4066,-4066,-4066,-4066,-4066}, + -23035L, .0, 1., + }; +static C_COLOR cie_zp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY, + {4051,4054,4052,4053,4054,4056,4059,4064,4071, + 4074,4056,3967,3677,2933,1492,313,-440,-795, + -904,-918,-898,-884,-869,-863,-855,-855,-851, + -848,-847,-846,-846,-846,-845,-846,-843,-845, + -845,-845,-845,-845,-845}, + 36057L, .0, .0, + }; static int setspectrum(); static int setbbtemp(); @@ -65,6 +105,8 @@ register char **av; c_ccname = NULL; return(MG_OK); } + if (!isname(av[1])) + return(MG_EILL); lp = lu_find(&clr_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); @@ -88,6 +130,7 @@ register char **av; c_ccname = lp->key; c_ccolor = (C_COLOR *)lp->data; c_ccolor->clock = 0; + c_ccolor->client_data = NULL; } i = c_ccolor->clock; if (ac == 3) { /* use default template */ @@ -135,8 +178,6 @@ register char **av; if (!isflt(av[1])) return(MG_ETYPE); wsum = atof(av[1]); - if (wsum < 0.) - return(MG_EILL); if ((lp = lu_find(&clr_tab, av[2])) == NULL) return(MG_EMEM); if (lp->data == NULL) @@ -146,8 +187,6 @@ register char **av; if (!isflt(av[i])) return(MG_ETYPE); w = atof(av[i]); - if (w < 0.) - return(MG_EILL); if ((lp = lu_find(&clr_tab, av[i+1])) == NULL) return(MG_EMEM); if (lp->data == NULL) @@ -156,6 +195,8 @@ register char **av; w, (C_COLOR *)lp->data); wsum += w; } + if (wsum <= 0.) + return(MG_EILL); c_ccolor->clock++; return(MG_OK); } @@ -181,6 +222,8 @@ register char **av; c_cmname = NULL; return(MG_OK); } + if (!isname(av[1])) + return(MG_EILL); lp = lu_find(&mat_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); @@ -204,6 +247,7 @@ register char **av; c_cmname = lp->key; c_cmaterial = (C_MATERIAL *)lp->data; c_cmaterial->clock = 0; + c_cmaterial->client_data = NULL; } i = c_cmaterial->clock; if (ac == 3) { /* use default template */ @@ -219,6 +263,17 @@ register char **av; *c_cmaterial = *(C_MATERIAL *)lp->data; c_cmaterial->clock = i + 1; return(MG_OK); + case MG_E_IR: /* set index of refraction */ + if (ac != 3) + return(MG_EARGC); + if (!isflt(av[1]) | !isflt(av[2])) + return(MG_ETYPE); + c_cmaterial->nr = atof(av[1]); + c_cmaterial->ni = atof(av[2]); + if (c_cmaterial->nr <= FTINY) + return(MG_EILL); + c_cmaterial->clock++; + return(MG_OK); case MG_E_RD: /* set diffuse reflectance */ if (ac != 2) return(MG_EARGC); @@ -315,6 +370,8 @@ register char **av; c_cvname = NULL; return(MG_OK); } + if (!isname(av[1])) + return(MG_EILL); lp = lu_find(&vtx_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); @@ -337,6 +394,8 @@ register char **av; return(MG_EMEM); c_cvname = lp->key; c_cvertex = (C_VERTEX *)lp->data; + c_cvertex->clock = 0; + c_cvertex->client_data = NULL; } i = c_cvertex->clock; if (ac == 3) { /* use default template */ @@ -472,25 +531,27 @@ int fl; clr->cy = y / z; clr->flags |= C_CSXY; } else if (fl & C_CSSPEC) { /* cxy -> cspec */ - z = (cie_xf.ssum + cie_yf.ssum + cie_zf.ssum) / 3.; - x = clr->cx * z / cie_xf.ssum; - y = clr->cy * z / cie_yf.ssum; - z = (1. - clr->cx - clr->cy) * z / cie_zf.ssum; + x = clr->cx; + y = clr->cy; + z = 1. - x - y; clr->ssum = 0; - for (i = 0; i < C_CNSS; i++) - clr->ssum += clr->ssamp[i] = - x * cie_xf.ssamp[i] + - y * cie_yf.ssamp[i] + - z * cie_zf.ssamp[i] + .5; + for (i = 0; i < C_CNSS; i++) { + clr->ssamp[i] = x*cie_xp.ssamp[i] + y*cie_yp.ssamp[i] + + z*cie_zp.ssamp[i] + .5; + if (clr->ssamp[i] < 0) /* out of gamut! */ + clr->ssamp[i] = 0; + else + clr->ssum += clr->ssamp[i]; + } clr->flags |= C_CSSPEC; } if (fl & C_CSEFF) { /* compute efficacy */ - if (clr->flags & C_CDSPEC) { /* from spectrum */ + if (clr->flags & C_CSSPEC) { /* from spectrum */ y = 0.; for (i = 0; i < C_CNSS; i++) y += cie_yf.ssamp[i] * clr->ssamp[i]; clr->eff = C_CLPWM * y / clr->ssum; - } else /* clr->flags & C_CDXY */ { /* from (x,y) */ + } else /* clr->flags & C_CSXY */ { /* from (x,y) */ clr->eff = clr->cx*cie_xf.eff + clr->cy*cie_yf.eff + (1. - clr->cx - clr->cy)*cie_zf.eff; } @@ -512,6 +573,7 @@ char **av; int n, imax; int wl; double wl0, wlstep; + double boxpos, boxstep; /* check bounds */ if (wlmax <= C_CMINWL | wlmax <= wlmin | wlmin >= C_CMAXWL) return(MG_EILL); @@ -524,31 +586,34 @@ char **av; wlmax -= wlstep; ac--; } - if (ac < 2) - return(MG_EILL); imax = ac; /* box filter if necessary */ + boxpos = 0; + boxstep = 1; if (wlstep < C_CWLI) { + imax = (wlmax - wlmin)/C_CWLI + (1-FTINY); + boxpos = (wlmin - C_CMINWL)/C_CWLI; + boxstep = wlstep/C_CWLI; wlstep = C_CWLI; - imax = (wlmax - wlmin)/wlstep; } scale = 0.; /* get values and maximum */ pos = 0; for (i = 0; i < imax; i++) { va[i] = 0.; n = 0; - while (pos < (i+.5)*ac/imax) { + while (boxpos < i+.5 && pos < ac) { if (!isflt(av[pos])) return(MG_ETYPE); va[i] += atof(av[pos++]); n++; + boxpos += boxstep; } if (n > 1) va[i] /= (double)n; - if (va[i] < 0.) - return(MG_EILL); if (va[i] > scale) scale = va[i]; + else if (va[i] < -scale) + scale = -va[i]; } - if (scale == 0.) + if (scale <= FTINY) return(MG_EILL); scale = C_CMAXV / scale; clr->ssum = 0; /* convert to our spacing */ @@ -604,7 +669,10 @@ double w1, w2; } else { /* CIE xy mixing */ c_ccvt(c1, C_CSXY); c_ccvt(c2, C_CSXY); - scale = 1. / (w1/c1->cy + w2/c2->cy); + scale = w1/c1->cy + w2/c2->cy; + if (scale == 0.) + return; + scale = 1. / scale; cres->cx = (c1->cx*w1/c1->cy + c2->cx*w2/c2->cy) * scale; cres->cy = (w1 + w2) * scale; cres->flags = C_CDXY|C_CSXY;
