--- ray/src/cv/mgflib/context.c 1994/06/25 16:33:14 1.9 +++ ray/src/cv/mgflib/context.c 1995/02/24 16:50:08 1.17 @@ -26,8 +26,11 @@ static C_VERTEX c_unvertex = C_DEFVERTEX; /* the current contexts */ C_COLOR *c_ccolor = &c_uncolor; +char *c_ccname = NULL; C_MATERIAL *c_cmaterial = &c_unmaterial; +char *c_cmname = NULL; C_VERTEX *c_cvertex = &c_unvertex; +char *c_cvname = NULL; static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */ static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */ @@ -58,11 +61,13 @@ register char **av; if (ac == 1) { /* set unnamed color context */ c_uncolor = c_dfcolor; c_ccolor = &c_uncolor; + c_ccname = NULL; return(MG_OK); } lp = lu_find(&clr_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); + c_ccname = lp->key; c_ccolor = (C_COLOR *)lp->data; if (ac == 2) { /* reestablish previous context */ if (c_ccolor == NULL) @@ -79,13 +84,13 @@ register char **av; lp->data = (char *)malloc(sizeof(C_COLOR)); if (lp->data == NULL) return(MG_EMEM); + c_ccname = lp->key; c_ccolor = (C_COLOR *)lp->data; c_ccolor->clock = 0; } + i = c_ccolor->clock; if (ac == 3) { /* use default template */ - i = c_ccolor->clock; *c_ccolor = c_dfcolor; - c_ccolor->name = av[1]; c_ccolor->clock = i + 1; return(MG_OK); } @@ -94,9 +99,7 @@ register char **av; return(MG_EMEM); if (lp->data == NULL) return(MG_EUNDEF); - i = c_ccolor->clock; *c_ccolor = *(C_COLOR *)lp->data; - c_ccolor->name = av[1]; c_ccolor->clock = i + 1; return(MG_OK); case MG_E_CXY: /* assign CIE XY value */ @@ -115,9 +118,9 @@ register char **av; case MG_E_CSPEC: /* assign spectral values */ if (ac < 5) return(MG_EARGC); - if (!isint(av[1]) || !isint(av[2])) + if (!isflt(av[1]) || !isflt(av[2])) return(MG_ETYPE); - return(setspectrum(c_ccolor, atoi(av[1]), atoi(av[2]), + return(setspectrum(c_ccolor, atof(av[1]), atof(av[2]), ac-3, av+3)); case MG_E_CMIX: /* mix colors */ if (ac < 5 || (ac-1)%2) @@ -146,6 +149,7 @@ register char **av; w, (C_COLOR *)lp->data); wsum += w; } + c_ccolor->clock++; return(MG_OK); } return(MG_EUNK); @@ -167,11 +171,13 @@ register char **av; if (ac == 1) { /* set unnamed material context */ c_unmaterial = c_dfmaterial; c_cmaterial = &c_unmaterial; + c_cmname = NULL; return(MG_OK); } lp = lu_find(&mat_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); + c_cmname = lp->key; c_cmaterial = (C_MATERIAL *)lp->data; if (ac == 2) { /* reestablish previous context */ if (c_cmaterial == NULL) @@ -188,13 +194,13 @@ register char **av; lp->data = (char *)malloc(sizeof(C_MATERIAL)); if (lp->data == NULL) return(MG_EMEM); + c_cmname = lp->key; c_cmaterial = (C_MATERIAL *)lp->data; c_cmaterial->clock = 0; } + i = c_cmaterial->clock; if (ac == 3) { /* use default template */ - i = c_cmaterial->clock; *c_cmaterial = c_dfmaterial; - c_cmaterial->name = av[1]; c_cmaterial->clock = i + 1; return(MG_OK); } @@ -203,9 +209,7 @@ register char **av; return(MG_EMEM); if (lp->data == NULL) return(MG_EUNDEF); - i = c_cmaterial->clock; *c_cmaterial = *(C_MATERIAL *)lp->data; - c_cmaterial->name = av[1]; c_cmaterial->clock = i + 1; return(MG_OK); case MG_E_RD: /* set diffuse reflectance */ @@ -267,6 +271,20 @@ register char **av; c_cmaterial->ts_c = *c_ccolor; c_cmaterial->clock++; return(MG_OK); + case MG_E_SIDES: /* set number of sides */ + if (ac != 2) + return(MG_EARGC); + if (!isint(av[1])) + return(MG_ETYPE); + i = atoi(av[1]); + if (i == 1) + c_cmaterial->sided = 1; + else if (i == 2) + c_cmaterial->sided = 0; + else + return(MG_EILL); + c_cmaterial->clock++; + return(MG_OK); } return(MG_EUNK); } @@ -287,11 +305,13 @@ register char **av; if (ac == 1) { /* set unnamed vertex context */ c_unvertex = c_dfvertex; c_cvertex = &c_unvertex; + c_cvname = NULL; return(MG_OK); } lp = lu_find(&vtx_tab, av[1]); /* lookup context */ if (lp == NULL) return(MG_EMEM); + c_cvname = lp->key; c_cvertex = (C_VERTEX *)lp->data; if (ac == 2) { /* reestablish previous context */ if (c_cvertex == NULL) @@ -308,12 +328,12 @@ register char **av; lp->data = (char *)malloc(sizeof(C_VERTEX)); if (lp->data == NULL) return(MG_EMEM); + c_cvname = lp->key; c_cvertex = (C_VERTEX *)lp->data; } + i = c_cvertex->clock; if (ac == 3) { /* use default template */ - i = c_cvertex->clock; *c_cvertex = c_dfvertex; - c_cvertex->name = av[1]; c_cvertex->clock = i + 1; return(MG_OK); } @@ -322,9 +342,7 @@ register char **av; return(MG_EMEM); if (lp->data == NULL) return(MG_EUNDEF); - i = c_cvertex->clock; *c_cvertex = *(C_VERTEX *)lp->data; - c_cvertex->name = av[1]; c_cvertex->clock = i + 1; return(MG_OK); case MG_E_POINT: /* set point */ @@ -358,16 +376,31 @@ c_clearall() /* empty context tables */ { c_uncolor = c_dfcolor; c_ccolor = &c_uncolor; + c_ccname = NULL; lu_done(&clr_tab); c_unmaterial = c_dfmaterial; c_cmaterial = &c_unmaterial; + c_cmname = NULL; lu_done(&mat_tab); c_unvertex = c_dfvertex; c_cvertex = &c_unvertex; + c_cvname = NULL; lu_done(&vtx_tab); } +C_MATERIAL * +c_getmaterial(name) /* get a named material */ +char *name; +{ + register LUENT *lp; + + if ((lp = lu_find(&mat_tab, name)) == NULL) + return(NULL); + return((C_MATERIAL *)lp->data); +} + + C_VERTEX * c_getvert(name) /* get a named vertex */ char *name; @@ -412,22 +445,26 @@ int fl; double x, y, z; register int i; - if (clr->flags & fl) /* already done */ + fl &= ~clr->flags; /* ignore what's done */ + if (!fl) /* everything's done! */ return; if (!(clr->flags & (C_CSXY|C_CSSPEC))) /* nothing set! */ *clr = c_dfcolor; - else if (fl & C_CSXY) { /* cspec -> cxy */ + if (fl & C_CSXY) { /* cspec -> cxy */ x = y = z = 0.; for (i = 0; i < C_CNSS; i++) { x += cie_xf.ssamp[i] * clr->ssamp[i]; y += cie_yf.ssamp[i] * clr->ssamp[i]; z += cie_zf.ssamp[i] * clr->ssamp[i]; } + x /= (double)cie_xf.ssum; + y /= (double)cie_yf.ssum; + z /= (double)cie_zf.ssum; z += x + y; clr->cx = x / z; clr->cy = y / z; clr->flags |= C_CSXY; - } else { /* cxy -> cspec */ + } else if (fl & C_CSSPEC) { /* cxy -> cspec */ z = (cie_xf.ssum + cie_yf.ssum + cie_zf.ssum) / 3.; x = clr->cx * z / cie_xf.ssum; y = clr->cy * z / cie_yf.ssum; @@ -440,31 +477,65 @@ int fl; z * cie_zf.ssamp[i] ; clr->flags |= C_CSSPEC; } + if (fl & C_CSEFF) { /* compute efficacy */ + if (clr->flags & C_CDSPEC) { /* from spectrum */ + y = 0.; + for (i = 0; i < C_CNSS; i++) + y += cie_yf.ssamp[i] * clr->ssamp[i]; + clr->eff = C_CLPWM * y / clr->ssum; + } else /* clr->flags & C_CDXY */ { /* from (x,y) */ + clr->eff = clr->cx*cie_xf.eff + clr->cy*cie_yf.eff + + (1. - clr->cx - clr->cy)*cie_zf.eff; + } + clr->flags |= C_CSEFF; + } } static int setspectrum(clr, wlmin, wlmax, ac, av) /* convert a spectrum */ register C_COLOR *clr; -int wlmin, wlmax; +double wlmin, wlmax; int ac; char **av; { double scale; - float *va; - register int i; - int wl, pos; + float va[C_CNSS]; + register int i, pos; + int n, imax; + int wl; double wl0, wlstep; - - if (wlmin < C_CMINWL || wlmin >= wlmax || wlmax > C_CMAXWL) + /* check bounds */ + if (wlmax <= C_CMINWL | wlmax <= wlmin | wlmin >= C_CMAXWL) return(MG_EILL); - if ((va = (float *)malloc(ac*sizeof(float))) == NULL) - return(MG_EMEM); + wlstep = (wlmax - wlmin)/(ac-1); + while (wlmin < C_CMINWL) { + wlmin += wlstep; + ac--; av++; + } + while (wlmax > C_CMAXWL) { + wlmax -= wlstep; + ac--; + } + if (ac < 2) + return(MG_EILL); + imax = ac; /* box filter if necessary */ + if (wlstep < C_CWLI) { + wlstep = C_CWLI; + imax = (wlmax - wlmin)/wlstep; + } scale = 0.; /* get values and maximum */ - for (i = 0; i < ac; i++) { - if (!isflt(av[i])) - return(MG_ETYPE); - va[i] = atof(av[i]); + pos = 0; + for (i = 0; i < imax; i++) { + va[i] = 0.; n = 0; + while (pos < (i+.5)*ac/imax) { + if (!isflt(av[pos])) + return(MG_ETYPE); + va[i] += atof(av[pos++]); + n++; + } + if (n > 1) + va[i] /= (double)n; if (va[i] < 0.) return(MG_EILL); if (va[i] > scale) @@ -475,17 +546,16 @@ char **av; scale = C_CMAXV / scale; clr->ssum = 0; /* convert to our spacing */ wl0 = wlmin; - wlstep = (double)(wlmax - wlmin)/(ac-1); pos = 0; for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI) - if (wl < wlmin || wl > wlmax) + if (wl < wlmin | wl > wlmax) clr->ssamp[i] = 0; else { while (wl0 + wlstep < wl+FTINY) { wl0 += wlstep; pos++; } - if (wl+FTINY >= wl0 && wl-FTINY <= wl0) + if (wl+FTINY >= wl0 & wl-FTINY <= wl0) clr->ssamp[i] = scale*va[pos]; else /* interpolate if necessary */ clr->ssamp[i] = scale / wlstep * @@ -495,7 +565,6 @@ char **av; } clr->flags = C_CDSPEC|C_CSSPEC; clr->clock++; - free((MEM_PTR)va); return(MG_OK); } @@ -510,10 +579,10 @@ double w1, w2; register int i; if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */ - c_ccvt(c1, C_CSSPEC); - c_ccvt(c2, C_CSSPEC); - w1 /= (double)c1->ssum; - w2 /= (double)c2->ssum; + c_ccvt(c1, C_CSSPEC|C_CSEFF); + c_ccvt(c2, C_CSSPEC|C_CSEFF); + w1 /= c1->eff*c1->ssum; + w2 /= c2->eff*c2->ssum; scale = 0.; for (i = 0; i < C_CNSS; i++) { cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i]; @@ -533,5 +602,4 @@ double w1, w2; cres->cy = (w1 + w2) * scale; cres->flags = C_CDXY|C_CSXY; } - cres->clock++; /* record the change */ }
