root/radiance/ray/src/cv/mgflib/context.c
Revision: 1.13
Committed: Fri Jul 1 18:06:56 1994 UTC (30 years, 11 months ago) by greg
Changes since 1.12: +14 -0 lines
added "sides" entity for one- vs. two-sided surfaces
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Context handlers
9 */
10
11 #include <stdio.h>
12 #include <math.h>
13 #include <string.h>
14 #include "parser.h"
15 #include "lookup.h"
16
17 /* default context values */
18 static C_COLOR c_dfcolor = C_DEFCOLOR;
19 static C_MATERIAL c_dfmaterial = C_DEFMATERIAL;
20 static C_VERTEX c_dfvertex = C_DEFVERTEX;
21
22 /* the unnamed contexts */
23 static C_COLOR c_uncolor = C_DEFCOLOR;
24 static C_MATERIAL c_unmaterial = C_DEFMATERIAL;
25 static C_VERTEX c_unvertex = C_DEFVERTEX;
26
27 /* the current contexts */
28 C_COLOR *c_ccolor = &c_uncolor;
29 char *c_ccname = NULL;
30 C_MATERIAL *c_cmaterial = &c_unmaterial;
31 char *c_cmname = NULL;
32 C_VERTEX *c_cvertex = &c_unvertex;
33 char *c_cvname = NULL;
34
35 static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */
36 static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */
37 static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */
38
39 /* CIE 1931 Standard Observer */
40 static C_COLOR cie_xf = C_CIEX;
41 static C_COLOR cie_yf = C_CIEY;
42 static C_COLOR cie_zf = C_CIEZ;
43
44 static int setspectrum();
45 static void mixcolors();
46
47
48 int
49 c_hcolor(ac, av) /* handle color entity */
50 int ac;
51 register char **av;
52 {
53 double w, wsum;
54 register int i;
55 register LUENT *lp;
56
57 switch (mg_entity(av[0])) {
58 case MG_E_COLOR: /* get/set color context */
59 if (ac > 4)
60 return(MG_EARGC);
61 if (ac == 1) { /* set unnamed color context */
62 c_uncolor = c_dfcolor;
63 c_ccolor = &c_uncolor;
64 c_ccname = NULL;
65 return(MG_OK);
66 }
67 lp = lu_find(&clr_tab, av[1]); /* lookup context */
68 if (lp == NULL)
69 return(MG_EMEM);
70 c_ccolor = (C_COLOR *)lp->data;
71 if (ac == 2) { /* reestablish previous context */
72 if (c_ccolor == NULL)
73 return(MG_EUNDEF);
74 return(MG_OK);
75 }
76 if (av[2][0] != '=' || av[2][1])
77 return(MG_ETYPE);
78 if (c_ccolor == NULL) { /* create new color context */
79 lp->key = (char *)malloc(strlen(av[1])+1);
80 if (lp->key == NULL)
81 return(MG_EMEM);
82 strcpy(lp->key, av[1]);
83 lp->data = (char *)malloc(sizeof(C_COLOR));
84 if (lp->data == NULL)
85 return(MG_EMEM);
86 c_ccolor = (C_COLOR *)lp->data;
87 c_ccolor->clock = 0;
88 }
89 c_ccname = lp->key;
90 i = c_ccolor->clock;
91 if (ac == 3) { /* use default template */
92 *c_ccolor = c_dfcolor;
93 c_ccolor->clock = i + 1;
94 return(MG_OK);
95 }
96 lp = lu_find(&clr_tab, av[3]); /* lookup template */
97 if (lp == NULL)
98 return(MG_EMEM);
99 if (lp->data == NULL)
100 return(MG_EUNDEF);
101 *c_ccolor = *(C_COLOR *)lp->data;
102 c_ccolor->clock = i + 1;
103 return(MG_OK);
104 case MG_E_CXY: /* assign CIE XY value */
105 if (ac != 3)
106 return(MG_EARGC);
107 if (!isflt(av[1]) || !isflt(av[2]))
108 return(MG_ETYPE);
109 c_ccolor->cx = atof(av[1]);
110 c_ccolor->cy = atof(av[2]);
111 c_ccolor->flags = C_CDXY|C_CSXY;
112 if (c_ccolor->cx < 0. | c_ccolor->cy < 0. |
113 c_ccolor->cx + c_ccolor->cy > 1.)
114 return(MG_EILL);
115 c_ccolor->clock++;
116 return(MG_OK);
117 case MG_E_CSPEC: /* assign spectral values */
118 if (ac < 5)
119 return(MG_EARGC);
120 if (!isint(av[1]) || !isint(av[2]))
121 return(MG_ETYPE);
122 return(setspectrum(c_ccolor, atoi(av[1]), atoi(av[2]),
123 ac-3, av+3));
124 case MG_E_CMIX: /* mix colors */
125 if (ac < 5 || (ac-1)%2)
126 return(MG_EARGC);
127 if (!isflt(av[1]))
128 return(MG_ETYPE);
129 wsum = atof(av[1]);
130 if (wsum < 0.)
131 return(MG_EILL);
132 if ((lp = lu_find(&clr_tab, av[2])) == NULL)
133 return(MG_EMEM);
134 if (lp->data == NULL)
135 return(MG_EUNDEF);
136 *c_ccolor = *(C_COLOR *)lp->data;
137 for (i = 3; i < ac; i += 2) {
138 if (!isflt(av[i]))
139 return(MG_ETYPE);
140 w = atof(av[i]);
141 if (w < 0.)
142 return(MG_EILL);
143 if ((lp = lu_find(&clr_tab, av[i+1])) == NULL)
144 return(MG_EMEM);
145 if (lp->data == NULL)
146 return(MG_EUNDEF);
147 mixcolors(c_ccolor, wsum, c_ccolor,
148 w, (C_COLOR *)lp->data);
149 wsum += w;
150 }
151 c_ccolor->clock++;
152 return(MG_OK);
153 }
154 return(MG_EUNK);
155 }
156
157
158 int
159 c_hmaterial(ac, av) /* handle material entity */
160 int ac;
161 register char **av;
162 {
163 int i;
164 register LUENT *lp;
165
166 switch (mg_entity(av[0])) {
167 case MG_E_MATERIAL: /* get/set material context */
168 if (ac > 4)
169 return(MG_EARGC);
170 if (ac == 1) { /* set unnamed material context */
171 c_unmaterial = c_dfmaterial;
172 c_cmaterial = &c_unmaterial;
173 c_cmname = NULL;
174 return(MG_OK);
175 }
176 lp = lu_find(&mat_tab, av[1]); /* lookup context */
177 if (lp == NULL)
178 return(MG_EMEM);
179 c_cmaterial = (C_MATERIAL *)lp->data;
180 if (ac == 2) { /* reestablish previous context */
181 if (c_cmaterial == NULL)
182 return(MG_EUNDEF);
183 return(MG_OK);
184 }
185 if (av[2][0] != '=' || av[2][1])
186 return(MG_ETYPE);
187 if (c_cmaterial == NULL) { /* create new material */
188 lp->key = (char *)malloc(strlen(av[1])+1);
189 if (lp->key == NULL)
190 return(MG_EMEM);
191 strcpy(lp->key, av[1]);
192 lp->data = (char *)malloc(sizeof(C_MATERIAL));
193 if (lp->data == NULL)
194 return(MG_EMEM);
195 c_cmaterial = (C_MATERIAL *)lp->data;
196 c_cmaterial->clock = 0;
197 }
198 c_cmname = lp->key;
199 i = c_cmaterial->clock;
200 if (ac == 3) { /* use default template */
201 *c_cmaterial = c_dfmaterial;
202 c_cmaterial->clock = i + 1;
203 return(MG_OK);
204 }
205 lp = lu_find(&mat_tab, av[3]); /* lookup template */
206 if (lp == NULL)
207 return(MG_EMEM);
208 if (lp->data == NULL)
209 return(MG_EUNDEF);
210 *c_cmaterial = *(C_MATERIAL *)lp->data;
211 c_cmaterial->clock = i + 1;
212 return(MG_OK);
213 case MG_E_RD: /* set diffuse reflectance */
214 if (ac != 2)
215 return(MG_EARGC);
216 if (!isflt(av[1]))
217 return(MG_ETYPE);
218 c_cmaterial->rd = atof(av[1]);
219 if (c_cmaterial->rd < 0. | c_cmaterial->rd > 1.)
220 return(MG_EILL);
221 c_cmaterial->rd_c = *c_ccolor;
222 c_cmaterial->clock++;
223 return(MG_OK);
224 case MG_E_ED: /* set diffuse emittance */
225 if (ac != 2)
226 return(MG_EARGC);
227 if (!isflt(av[1]))
228 return(MG_ETYPE);
229 c_cmaterial->ed = atof(av[1]);
230 if (c_cmaterial->ed < 0.)
231 return(MG_EILL);
232 c_cmaterial->ed_c = *c_ccolor;
233 c_cmaterial->clock++;
234 return(MG_OK);
235 case MG_E_TD: /* set diffuse transmittance */
236 if (ac != 2)
237 return(MG_EARGC);
238 if (!isflt(av[1]))
239 return(MG_ETYPE);
240 c_cmaterial->td = atof(av[1]);
241 if (c_cmaterial->td < 0. | c_cmaterial->td > 1.)
242 return(MG_EILL);
243 c_cmaterial->td_c = *c_ccolor;
244 c_cmaterial->clock++;
245 return(MG_OK);
246 case MG_E_RS: /* set specular reflectance */
247 if (ac != 3)
248 return(MG_EARGC);
249 if (!isflt(av[1]) || !isflt(av[2]))
250 return(MG_ETYPE);
251 c_cmaterial->rs = atof(av[1]);
252 c_cmaterial->rs_a = atof(av[2]);
253 if (c_cmaterial->rs < 0. | c_cmaterial->rs > 1. |
254 c_cmaterial->rs_a < 0.)
255 return(MG_EILL);
256 c_cmaterial->rs_c = *c_ccolor;
257 c_cmaterial->clock++;
258 return(MG_OK);
259 case MG_E_TS: /* set specular transmittance */
260 if (ac != 3)
261 return(MG_EARGC);
262 if (!isflt(av[1]) || !isflt(av[2]))
263 return(MG_ETYPE);
264 c_cmaterial->ts = atof(av[1]);
265 c_cmaterial->ts_a = atof(av[2]);
266 if (c_cmaterial->ts < 0. | c_cmaterial->ts > 1. |
267 c_cmaterial->ts_a < 0.)
268 return(MG_EILL);
269 c_cmaterial->ts_c = *c_ccolor;
270 c_cmaterial->clock++;
271 return(MG_OK);
272 case MG_E_SIDES: /* set number of sides */
273 if (ac != 2)
274 return(MG_EARGC);
275 if (!isint(av[1]))
276 return(MG_ETYPE);
277 i = atoi(av[1]);
278 if (i == 1)
279 c_cmaterial->sided = 1;
280 else if (i == 2)
281 c_cmaterial->sided = 0;
282 else
283 return(MG_EILL);
284 c_cmaterial->clock++;
285 return(MG_OK);
286 }
287 return(MG_EUNK);
288 }
289
290
291 int
292 c_hvertex(ac, av) /* handle a vertex entity */
293 int ac;
294 register char **av;
295 {
296 int i;
297 register LUENT *lp;
298
299 switch (mg_entity(av[0])) {
300 case MG_E_VERTEX: /* get/set vertex context */
301 if (ac > 4)
302 return(MG_EARGC);
303 if (ac == 1) { /* set unnamed vertex context */
304 c_unvertex = c_dfvertex;
305 c_cvertex = &c_unvertex;
306 c_cvname = NULL;
307 return(MG_OK);
308 }
309 lp = lu_find(&vtx_tab, av[1]); /* lookup context */
310 if (lp == NULL)
311 return(MG_EMEM);
312 c_cvertex = (C_VERTEX *)lp->data;
313 if (ac == 2) { /* reestablish previous context */
314 if (c_cvertex == NULL)
315 return(MG_EUNDEF);
316 return(MG_OK);
317 }
318 if (av[2][0] != '=' || av[2][1])
319 return(MG_ETYPE);
320 if (c_cvertex == NULL) { /* create new vertex context */
321 lp->key = (char *)malloc(strlen(av[1])+1);
322 if (lp->key == NULL)
323 return(MG_EMEM);
324 strcpy(lp->key, av[1]);
325 lp->data = (char *)malloc(sizeof(C_VERTEX));
326 if (lp->data == NULL)
327 return(MG_EMEM);
328 c_cvertex = (C_VERTEX *)lp->data;
329 }
330 c_cvname = lp->key;
331 i = c_cvertex->clock;
332 if (ac == 3) { /* use default template */
333 *c_cvertex = c_dfvertex;
334 c_cvertex->clock = i + 1;
335 return(MG_OK);
336 }
337 lp = lu_find(&vtx_tab, av[3]); /* lookup template */
338 if (lp == NULL)
339 return(MG_EMEM);
340 if (lp->data == NULL)
341 return(MG_EUNDEF);
342 *c_cvertex = *(C_VERTEX *)lp->data;
343 c_cvertex->clock = i + 1;
344 return(MG_OK);
345 case MG_E_POINT: /* set point */
346 if (ac != 4)
347 return(MG_EARGC);
348 if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3]))
349 return(MG_ETYPE);
350 c_cvertex->p[0] = atof(av[1]);
351 c_cvertex->p[1] = atof(av[2]);
352 c_cvertex->p[2] = atof(av[3]);
353 c_cvertex->clock++;
354 return(MG_OK);
355 case MG_E_NORMAL: /* set normal */
356 if (ac != 4)
357 return(MG_EARGC);
358 if (!isflt(av[1]) || !isflt(av[2]) || !isflt(av[3]))
359 return(MG_ETYPE);
360 c_cvertex->n[0] = atof(av[1]);
361 c_cvertex->n[1] = atof(av[2]);
362 c_cvertex->n[2] = atof(av[3]);
363 (void)normalize(c_cvertex->n);
364 c_cvertex->clock++;
365 return(MG_OK);
366 }
367 return(MG_EUNK);
368 }
369
370
371 void
372 c_clearall() /* empty context tables */
373 {
374 c_uncolor = c_dfcolor;
375 c_ccolor = &c_uncolor;
376 lu_done(&clr_tab);
377 c_unmaterial = c_dfmaterial;
378 c_cmaterial = &c_unmaterial;
379 lu_done(&mat_tab);
380 c_unvertex = c_dfvertex;
381 c_cvertex = &c_unvertex;
382 lu_done(&vtx_tab);
383 }
384
385
386 C_MATERIAL *
387 c_getmaterial(name) /* get a named material */
388 char *name;
389 {
390 register LUENT *lp;
391
392 if ((lp = lu_find(&mat_tab, name)) == NULL)
393 return(NULL);
394 return((C_MATERIAL *)lp->data);
395 }
396
397
398 C_VERTEX *
399 c_getvert(name) /* get a named vertex */
400 char *name;
401 {
402 register LUENT *lp;
403
404 if ((lp = lu_find(&vtx_tab, name)) == NULL)
405 return(NULL);
406 return((C_VERTEX *)lp->data);
407 }
408
409
410 C_COLOR *
411 c_getcolor(name) /* get a named color */
412 char *name;
413 {
414 register LUENT *lp;
415
416 if ((lp = lu_find(&clr_tab, name)) == NULL)
417 return(NULL);
418 return((C_COLOR *)lp->data);
419 }
420
421
422 int
423 c_isgrey(clr) /* check if color is grey */
424 register C_COLOR *clr;
425 {
426 if (!(clr->flags & (C_CSXY|C_CSSPEC)))
427 return(1); /* no settings == grey */
428 c_ccvt(clr, C_CSXY);
429 return(clr->cx >= .323 && clr->cx <= .343 &&
430 clr->cy >= .323 && clr->cy <= .343);
431 }
432
433
434 void
435 c_ccvt(clr, fl) /* convert color representations */
436 register C_COLOR *clr;
437 int fl;
438 {
439 double x, y, z;
440 register int i;
441
442 if (clr->flags & fl) /* already done */
443 return;
444 if (!(clr->flags & (C_CSXY|C_CSSPEC))) /* nothing set! */
445 *clr = c_dfcolor;
446 else if (fl & C_CSXY) { /* cspec -> cxy */
447 x = y = z = 0.;
448 for (i = 0; i < C_CNSS; i++) {
449 x += cie_xf.ssamp[i] * clr->ssamp[i];
450 y += cie_yf.ssamp[i] * clr->ssamp[i];
451 z += cie_zf.ssamp[i] * clr->ssamp[i];
452 }
453 z += x + y;
454 clr->cx = x / z;
455 clr->cy = y / z;
456 clr->flags |= C_CSXY;
457 } else { /* cxy -> cspec */
458 z = (cie_xf.ssum + cie_yf.ssum + cie_zf.ssum) / 3.;
459 x = clr->cx * z / cie_xf.ssum;
460 y = clr->cy * z / cie_yf.ssum;
461 z = (1. - clr->cx - clr->cy) * z / cie_zf.ssum;
462 clr->ssum = 0;
463 for (i = 0; i < C_CNSS; i++)
464 clr->ssum += clr->ssamp[i] =
465 x * cie_xf.ssamp[i] +
466 y * cie_yf.ssamp[i] +
467 z * cie_zf.ssamp[i] ;
468 clr->flags |= C_CSSPEC;
469 }
470 }
471
472
473 static int
474 setspectrum(clr, wlmin, wlmax, ac, av) /* convert a spectrum */
475 register C_COLOR *clr;
476 int wlmin, wlmax;
477 int ac;
478 char **av;
479 {
480 double scale;
481 float *va;
482 register int i;
483 int wl, pos;
484 double wl0, wlstep;
485
486 if (wlmin < C_CMINWL || wlmin >= wlmax || wlmax > C_CMAXWL)
487 return(MG_EILL);
488 if ((va = (float *)malloc(ac*sizeof(float))) == NULL)
489 return(MG_EMEM);
490 scale = 0.; /* get values and maximum */
491 for (i = 0; i < ac; i++) {
492 if (!isflt(av[i]))
493 return(MG_ETYPE);
494 va[i] = atof(av[i]);
495 if (va[i] < 0.)
496 return(MG_EILL);
497 if (va[i] > scale)
498 scale = va[i];
499 }
500 if (scale == 0.)
501 return(MG_EILL);
502 scale = C_CMAXV / scale;
503 clr->ssum = 0; /* convert to our spacing */
504 wl0 = wlmin;
505 wlstep = (double)(wlmax - wlmin)/(ac-1);
506 pos = 0;
507 for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI)
508 if (wl < wlmin || wl > wlmax)
509 clr->ssamp[i] = 0;
510 else {
511 while (wl0 + wlstep < wl+FTINY) {
512 wl0 += wlstep;
513 pos++;
514 }
515 if (wl+FTINY >= wl0 && wl-FTINY <= wl0)
516 clr->ssamp[i] = scale*va[pos];
517 else /* interpolate if necessary */
518 clr->ssamp[i] = scale / wlstep *
519 ( va[pos]*(wl0+wlstep - wl) +
520 va[pos+1]*(wl - wl0) );
521 clr->ssum += clr->ssamp[i];
522 }
523 clr->flags = C_CDSPEC|C_CSSPEC;
524 clr->clock++;
525 free((MEM_PTR)va);
526 return(MG_OK);
527 }
528
529
530 static void
531 mixcolors(cres, w1, c1, w2, c2) /* mix two colors according to weights given */
532 register C_COLOR *cres, *c1, *c2;
533 double w1, w2;
534 {
535 double scale;
536 float cmix[C_CNSS];
537 register int i;
538
539 if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */
540 c_ccvt(c1, C_CSSPEC);
541 c_ccvt(c2, C_CSSPEC);
542 w1 /= (double)c1->ssum;
543 w2 /= (double)c2->ssum;
544 scale = 0.;
545 for (i = 0; i < C_CNSS; i++) {
546 cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i];
547 if (cmix[i] > scale)
548 scale = cmix[i];
549 }
550 scale = C_CMAXV / scale;
551 cres->ssum = 0;
552 for (i = 0; i < C_CNSS; i++)
553 cres->ssum += cres->ssamp[i] = scale*cmix[i] + .5;
554 cres->flags = C_CDSPEC|C_CSSPEC;
555 } else { /* CIE xy mixing */
556 c_ccvt(c1, C_CSXY);
557 c_ccvt(c2, C_CSXY);
558 scale = 1. / (w1/c1->cy + w2/c2->cy);
559 cres->cx = (c1->cx*w1/c1->cy + c2->cx*w2/c2->cy) * scale;
560 cres->cy = (w1 + w2) * scale;
561 cres->flags = C_CDXY|C_CSXY;
562 }
563 }
