root/Development/ray/src/cv/mgflib/ccolor.c
Revision: 1.4
Committed: Tue Feb 22 15:58:41 2011 UTC (14 years, 10 months ago) by greg
State: FILE REMOVED
Finish of code reorg, moving MGF library into src/cv and src/common
2 static const char RCSid[] = "$Id: ccolor.c,v 1.3 2011/02/04 06:31:41 greg Exp $";
5 * Spectral color handling routines
6 */
7
8 #include <stdio.h>
9 #include <math.h>
10 #include "ccolor.h"
11
12
13 C_COLOR c_dfcolor = C_DEFCOLOR;
14
15 /* CIE 1931 Standard Observer curves */
16 static C_COLOR cie_xf = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,
17 {14,42,143,435,1344,2839,3483,3362,2908,1954,956,
18 320,49,93,633,1655,2904,4334,5945,7621,9163,10263,
19 10622,10026,8544,6424,4479,2835,1649,874,468,227,
20 114,58,29,14,7,3,2,1,0}, 106836L, .467, .368, 362.230
21 };
22 static C_COLOR cie_yf = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,
23 {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,
24 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,
25 5030,3810,2650,1750,1070,610,320,170,82,41,21,10,
26 5,2,1,1,0,0}, 106856L, .398, .542, 493.525
27 };
28 static C_COLOR cie_zf = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,
29 {65,201,679,2074,6456,13856,17471,17721,16692,
30 12876,8130,4652,2720,1582,782,422,203,87,39,21,17,
31 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
32 106770L, .147, .077, 54.363
33 };
34 /* Derived CIE 1931 Primaries (imaginary) */
35 static C_COLOR cie_xp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY,
36 {-174,-198,-195,-197,-202,-213,-235,-272,-333,
37 -444,-688,-1232,-2393,-4497,-6876,-6758,-5256,
38 -3100,-815,1320,3200,4782,5998,6861,7408,7754,
39 7980,8120,8199,8240,8271,8292,8309,8283,8469,
40 8336,8336,8336,8336,8336,8336},
41 127424L, 1., .0,
42 };
43 static C_COLOR cie_yp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY,
44 {-451,-431,-431,-430,-427,-417,-399,-366,-312,
45 -204,57,691,2142,4990,8810,9871,9122,7321,5145,
46 3023,1123,-473,-1704,-2572,-3127,-3474,-3704,
47 -3846,-3927,-3968,-3999,-4021,-4038,-4012,-4201,
48 -4066,-4066,-4066,-4066,-4066,-4066},
49 -23035L, .0, 1.,
50 };
51 static C_COLOR cie_zp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY,
52 {4051,4054,4052,4053,4054,4056,4059,4064,4071,
53 4074,4056,3967,3677,2933,1492,313,-440,-795,
54 -904,-918,-898,-884,-869,-863,-855,-855,-851,
55 -848,-847,-846,-846,-846,-845,-846,-843,-845,
56 -845,-845,-845,-845,-845},
57 36057L, .0, .0,
58 };
59
60 /* check if color is grey */
61 int
62 c_isgrey(C_COLOR *clr)
63 {
64 if (!(clr->flags & (C_CSXY|C_CSSPEC)))
65 return(1); /* no settings == grey */
66
67 c_ccvt(clr, C_CSXY);
68
69 return(clr->cx >= .323 && clr->cx <= .343 &&
70 clr->cy >= .323 && clr->cy <= .343);
71 }
72
73 /* convert color representations */
74 void
75 c_ccvt(C_COLOR *clr, int fl)
76 {
77 double x, y, z;
78 int i;
79
80 fl &= ~clr->flags; /* ignore what's done */
81 if (!fl) /* everything's done! */
82 return;
83 if (!(clr->flags & (C_CSXY|C_CSSPEC))) {
84 *clr = c_dfcolor; /* nothing was set! */
85 return;
86 }
87 if (fl & C_CSXY) { /* cspec -> cxy */
88 x = y = z = 0.;
89 for (i = 0; i < C_CNSS; i++) {
90 x += cie_xf.ssamp[i] * clr->ssamp[i];
91 y += cie_yf.ssamp[i] * clr->ssamp[i];
92 z += cie_zf.ssamp[i] * clr->ssamp[i];
93 }
94 x /= (double)cie_xf.ssum;
95 y /= (double)cie_yf.ssum;
96 z /= (double)cie_zf.ssum;
97 z += x + y;
98 clr->cx = x / z;
99 clr->cy = y / z;
100 clr->flags |= C_CSXY;
101 } else if (fl & C_CSSPEC) { /* cxy -> cspec */
102 x = clr->cx;
103 y = clr->cy;
104 z = 1. - x - y;
105 clr->ssum = 0;
106 for (i = 0; i < C_CNSS; i++) {
107 clr->ssamp[i] = x*cie_xp.ssamp[i] + y*cie_yp.ssamp[i]
108 + z*cie_zp.ssamp[i] + .5;
109 if (clr->ssamp[i] < 0) /* out of gamut! */
110 clr->ssamp[i] = 0;
111 else
112 clr->ssum += clr->ssamp[i];
113 }
114 clr->flags |= C_CSSPEC;
115 }
116 if (fl & C_CSEFF) { /* compute efficacy */
117 if (clr->flags & C_CSSPEC) { /* from spectrum */
118 y = 0.;
119 for (i = 0; i < C_CNSS; i++)
120 y += cie_yf.ssamp[i] * clr->ssamp[i];
121 clr->eff = C_CLPWM * y / clr->ssum;
122 } else /* clr->flags & C_CSXY */ { /* from (x,y) */
123 clr->eff = clr->cx*cie_xf.eff + clr->cy*cie_yf.eff +
124 (1. - clr->cx - clr->cy)*cie_zf.eff;
125 }
126 clr->flags |= C_CSEFF;
127 }
128 }
129
130 /* mix two colors according to weights given -- cres can be c1 or c2 */
131 void
132 c_cmix(C_COLOR *cres, double w1, C_COLOR *c1, double w2, C_COLOR *c2)
133 {
134 double scale;
135 float cmix[C_CNSS];
136 int i;
137
138 if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */
139 c_ccvt(c1, C_CSSPEC|C_CSEFF);
140 c_ccvt(c2, C_CSSPEC|C_CSEFF);
141 w1 /= c1->eff*c1->ssum;
142 w2 /= c2->eff*c2->ssum;
143 scale = 0.;
144 for (i = 0; i < C_CNSS; i++) {
145 cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i];
146 if (cmix[i] > scale)
147 scale = cmix[i];
148 }
149 scale = C_CMAXV / scale;
150 cres->ssum = 0;
151 for (i = 0; i < C_CNSS; i++)
152 cres->ssum += cres->ssamp[i] = scale*cmix[i] + .5;
153 cres->flags = C_CDSPEC|C_CSSPEC;
154 } else { /* CIE xy mixing */
155 c_ccvt(c1, C_CSXY);
156 c_ccvt(c2, C_CSXY);
157 w1 *= c2->cy;
158 w2 *= c1->cy;
159 scale = w1 + w2;
160 if (scale == 0.) {
161 *cres = c_dfcolor;
162 return;
163 }
164 scale = 1. / scale;
165 cres->cx = (w1*c1->cx + w2*c2->cx) * scale;
166 cres->cy = (w1*c1->cy + w2*c2->cy) * scale;
167 cres->flags = C_CDXY|C_CSXY;
168 }
169 }
170
171 #define C1 3.741832e-16 /* W-m^2 */
172 #define C2 1.4388e-2 /* m-K */
173
174 #define bbsp(l,t) (C1/((l)*(l)*(l)*(l)*(l)*(exp(C2/((t)*(l)))-1.)))
175 #define bblm(t) (C2/5./(t))
176
177 /* set black body spectrum */
178 int
179 c_bbtemp(C_COLOR *clr, double tk)
180 {
181 double sf, wl;
182 int i;
183
184 if (tk < 1000)
185 return(0);
186 wl = bblm(tk); /* scalefactor based on peak */
187 if (wl < C_CMINWL*1e-9)
188 wl = C_CMINWL*1e-9;
189 else if (wl > C_CMAXWL*1e-9)
190 wl = C_CMAXWL*1e-9;
191 sf = C_CMAXV/bbsp(wl,tk);
192 clr->ssum = 0;
193 for (i = 0; i < C_CNSS; i++) {
194 wl = (C_CMINWL + i*C_CWLI)*1e-9;
195 clr->ssum += clr->ssamp[i] = sf*bbsp(wl,tk) + .5;
196 }
197 clr->flags = C_CDSPEC|C_CSSPEC;
198 return(1);
199 }
200
201 #undef C1
202 #undef C2
203 #undef bbsp
204 #undef bblm
