| 1 |
MGF Parser Library Version 1.0
| 2 |
SCCSid "$SunId$ LBL"
| 3 |
| 4 |
Welcome to the initial release of the MGF language and parser library.
| 5 |
If you have not read it already, you should take a look at the documentation
| 6 |
in the troff file "mgfdoc.tr". This can be printed out using the -ms
| 7 |
macro package, or by sending the file "mgfdoc.ps" to a PostScript printer.
| 8 |
The figures for this document are contained in "figures.ps", which may
| 9 |
also be sent to a PostScript printer, or displayed with ghostview (if you
| 10 |
have it).
| 11 |
| 12 |
Most of the source files go directly into the parser library, with
| 13 |
the following exceptions:
| 14 |
| 15 |
face2tri.C - C++ converter from polygons to triangles
| 16 |
mgf2rad.c - MGF to Radiance converter, missing some libraries
| 17 |
mgfilt.c - MGF to MGF filter, compiled in Makefile
| 18 |
rad2mgf.c - Radiance to MGF converter, missing some libraries
| 19 |
| 20 |
The Makefile creates two useful items:
| 21 |
| 22 |
mgfilt - a filter for MGF
| 23 |
libmgf.a - the MGF parser library
| 24 |
| 25 |
Before you compile, you should probably check to make sure that the
| 26 |
compiler and flags you like are included. If you're like me and lack
| 27 |
an ANSII-compatible C compiler on your machine, use the -DNOPROTO flag
| 28 |
to take out function prototypes and get back K&R compatibility.
