| 1 |
MGF Parser Library Version 1.1
| 2 |
SCCSid "$SunId$ LBL"
| 3 |
| 4 |
Welcome to the initial release of the MGF language and parser library.
| 5 |
If you have not read it already, you should take a look at the documentation
| 6 |
in the troff file "mgfdoc.tr". This can be printed out using the -ms
| 7 |
macro package, or by sending the file "mgfdoc.ps" to a PostScript printer.
| 8 |
The figures for this document are contained in "figures.ps", which may
| 9 |
also be sent to a PostScript printer, or displayed with ghostview (if you
| 10 |
have it).
| 11 |
| 12 |
Most of the source files go directly into the parser library, with
| 13 |
the following exceptions:
| 14 |
| 15 |
face2tri.C - C++ converter from polygons to triangles
| 16 |
mgf2inv.c - MGF to Inventor converter, complete
| 17 |
mgf2rad.c - MGF to Radiance converter, missing some libraries
| 18 |
mgfilt.c - MGF to MGF filter, compiled in Makefile
| 19 |
rad2mgf.c - Radiance to MGF converter, missing some libraries
| 20 |
3ds2mgf.c - 3D-Studio to MGF converter, complete with below
| 21 |
optray.[ch] - Triangle smoothing code used by 3ds2mgf
| 22 |
vect.[ch] - Vector and matrix code used by 3ds2mgf
| 23 |
| 24 |
The Makefile creates three useful items:
| 25 |
| 26 |
mgfilt - a filter for MGF
| 27 |
libmgf.a - the MGF parser library
| 28 |
mgf2inv - a translator from MGF to Inventor (or VRML) format
| 29 |
3ds2mgf - a translator from 3D-Studio to MGF
| 30 |
| 31 |
Before you compile, you should probably check to make sure that the
| 32 |
compiler and flags you like are included. If you're like me and lack
| 33 |
an ANSII-compatible C compiler on your machine, use the -DNOPROTO flag
| 34 |
to take out function prototypes and get back K&R compatibility.
| 35 |
| 36 |
The exception to this is 3ds2mgf, which requires an ANSI-C compiler with
| 37 |
prototypes. Because of this requirement, the program must be built
| 38 |
explicitly with "make 3ds2mgf".
