root/Development/ray/src/cv/mgflib/README
Revision: 1.2
Committed: Fri Dec 1 16:26:57 1995 UTC (30 years ago) by greg
added mgf2inv program
1 MGF Parser Library Version 1.0
2 SCCSid "$SunId$ LBL"
3
4 Welcome to the initial release of the MGF language and parser library.
5 If you have not read it already, you should take a look at the documentation
6 in the troff file "mgfdoc.tr". This can be printed out using the -ms
7 macro package, or by sending the file "mgfdoc.ps" to a PostScript printer.
8 The figures for this document are contained in "figures.ps", which may
9 also be sent to a PostScript printer, or displayed with ghostview (if you
10 have it).
11
12 Most of the source files go directly into the parser library, with
13 the following exceptions:
14
15 face2tri.C - C++ converter from polygons to triangles
16 mgf2inv.c - MGF to Inventor converter, complete
17 mgf2rad.c - MGF to Radiance converter, missing some libraries
18 mgfilt.c - MGF to MGF filter, compiled in Makefile
19 rad2mgf.c - Radiance to MGF converter, missing some libraries
20
21 The Makefile creates three useful items:
22
23 mgfilt - a filter for MGF
24 libmgf.a - the MGF parser library
25 mgf2inv - a translator from MGF to Inventor (or VRML) format
26
27 Before you compile, you should probably check to make sure that the
28 compiler and flags you like are included. If you're like me and lack
29 an ANSII-compatible C compiler on your machine, use the -DNOPROTO flag
30 to take out function prototypes and get back K&R compatibility.
