root/Development/ray/src/cv/mgflib/README
Revision: 1.3
Committed: Thu Feb 8 11:14:07 1996 UTC (29 years, 9 months ago) by greg
Changes since 1.2: +9 -1 lines
added 3ds2mgf
1 MGF Parser Library Version 1.1
2 SCCSid "$SunId$ LBL"
3
4 Welcome to the initial release of the MGF language and parser library.
5 If you have not read it already, you should take a look at the documentation
6 in the troff file "mgfdoc.tr". This can be printed out using the -ms
7 macro package, or by sending the file "mgfdoc.ps" to a PostScript printer.
8 The figures for this document are contained in "figures.ps", which may
9 also be sent to a PostScript printer, or displayed with ghostview (if you
10 have it).
11
12 Most of the source files go directly into the parser library, with
13 the following exceptions:
14
15 face2tri.C - C++ converter from polygons to triangles
16 mgf2inv.c - MGF to Inventor converter, complete
17 mgf2rad.c - MGF to Radiance converter, missing some libraries
18 mgfilt.c - MGF to MGF filter, compiled in Makefile
19 rad2mgf.c - Radiance to MGF converter, missing some libraries
20 3ds2mgf.c - 3D-Studio to MGF converter, complete with below
21 optray.[ch] - Triangle smoothing code used by 3ds2mgf
22 vect.[ch] - Vector and matrix code used by 3ds2mgf
23
24 The Makefile creates three useful items:
25
26 mgfilt - a filter for MGF
27 libmgf.a - the MGF parser library
28 mgf2inv - a translator from MGF to Inventor (or VRML) format
29 3ds2mgf - a translator from 3D-Studio to MGF
30
31 Before you compile, you should probably check to make sure that the
32 compiler and flags you like are included. If you're like me and lack
33 an ANSII-compatible C compiler on your machine, use the -DNOPROTO flag
34 to take out function prototypes and get back K&R compatibility.
35
36 The exception to this is 3ds2mgf, which requires an ANSI-C compiler with
37 prototypes. Because of this requirement, the program must be built
38 explicitly with "make 3ds2mgf".
