root/Development/ray/src/cv/mgflib/README
Revision: 1.6
Committed: Sat Nov 15 17:54:06 2003 UTC (22 years, 1 month ago) by schorsch
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6, HEAD
Changes since 1.5: +1 -6 lines
Error occurred while calculating annotation data.
1 MGF Parser Library Version 2.0
2 SCCSid "@(#)README 1.4 3/18/97 LBL"
3
4 Welcome to the second major release of the MGF language and parser library.
5 If you have not read it already, you should take a look at the documentation
6 in the troff file "mgfdoc.tr". This can be printed out using the -ms
7 macro package, or by sending the file "mgfdoc.ps" to a PostScript printer.
8 The figures for this document are contained in "figures.ps", which may
9 also be sent to a PostScript printer, or displayed with ghostview (if you
10 have it).
11
12 Most of the source files go directly into the parser library, with
13 the following exceptions:
14
15 face2tri.C - C++ converter from polygons to triangles
16 mgf2inv.c - MGF to Inventor converter, complete
17 mgf2rad.c - MGF to Radiance converter, missing some libraries
18 mgfilt.c - MGF to MGF filter, compiled in Makefile
19 rad2mgf.c - Radiance to MGF converter, missing some libraries
20 3ds2mgf.c - 3D-Studio to MGF converter, complete with below
21 optray.[ch] - Triangle smoothing code used by 3ds2mgf
22 vect.[ch] - Vector and matrix code used by 3ds2mgf
23
24 The Makefile creates three useful items:
25
26 mgfilt - a filter for MGF
27 libmgf.a - the MGF parser library
28 mgf2inv - a translator from MGF to Inventor (or VRML) format
29 3ds2mgf - a translator from 3D-Studio to MGF
30
31 Before you compile, you should probably check to make sure that the
32 compiler and flags you like are included.
33
