root/radiance/ray/src/cv/mgflib/Makefile
Fri Jun 6 19:40:34 2003 UTC (20 years, 11 months ago) by greg
Diff to previous 1.10 , to selected 1.9
Fri Feb 28 20:11:29 2003 UTC (21 years, 2 months ago) by greg
Changes since 1.9: +0 -1 lines
Diff to previous 1.9
Updates for 3.5 release
Revision 1.9 - (view) (download) (annotate) - [selected]
Thu Feb 8 11:08:30 1996 UTC (28 years, 3 months ago) by greg
Changes since 1.8: +8 -1 lines
Diff to previous 1.8
added make for 3ds2mgf
Mon Dec 4 12:03:15 1995 UTC (28 years, 5 months ago) by greg
Diff to previous 1.7 , to selected 1.9
removed cvrgb.o from library
Mon Dec 4 11:35:45 1995 UTC (28 years, 5 months ago) by greg
Changes since 1.6: +8 -2 lines
Diff to previous 1.6 , to selected 1.9
added mgf2inv and cvrgb.c
Thu Jun 29 20:56:49 1995 UTC (28 years, 10 months ago) by greg
Diff to previous 1.5 , to selected 1.9
added to clean line
Fri May 12 17:20:01 1995 UTC (29 years ago) by greg
Diff to previous 1.4 , to selected 1.9
added comments about different compile flags
Thu May 11 21:48:44 1995 UTC (29 years ago) by greg
Diff to previous 1.3 , to selected 1.9
added version tracking
Tue Mar 7 14:53:28 1995 UTC (29 years, 2 months ago) by greg
Diff to previous 1.2 , to selected 1.9
added cct entity
Thu Jun 23 10:27:36 1994 UTC (29 years, 10 months ago) by greg
Diff to previous 1.1 , to selected 1.9
minor change to clean entry
Tue Jun 21 14:45:49 1994 UTC (29 years, 10 months ago) by greg
Diff to selected 1.9
