root/Development/ray/src/cv/mgflib/Makefile
Revision 1.13
Tue Feb 22 15:58:41 2011 UTC (14 years, 9 months ago) by greg
FILE REMOVED
Finish of code reorg, moving MGF library into src/cv and src/common
Mon Jan 3 20:30:21 2011 UTC (14 years, 10 months ago) by greg
Changes since 1.11: +5 -2 lines
Diff to previous 1.11
Separated color manipulation routines
Fri Jun 6 19:40:34 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 1.10
Fri Feb 28 20:11:29 2003 UTC (22 years, 9 months ago) by greg
Changes since 1.9: +0 -1 lines
Diff to previous 1.9
Updates for 3.5 release
Thu Feb 8 11:08:30 1996 UTC (29 years, 9 months ago) by greg
Changes since 1.8: +8 -1 lines
Diff to previous 1.8
added make for 3ds2mgf
Mon Dec 4 12:03:15 1995 UTC (30 years ago) by greg
Diff to previous 1.7
removed cvrgb.o from library
Mon Dec 4 11:35:45 1995 UTC (30 years ago) by greg
Changes since 1.6: +8 -2 lines
Diff to previous 1.6
added mgf2inv and cvrgb.c
Thu Jun 29 20:56:49 1995 UTC (30 years, 5 months ago) by greg
Diff to previous 1.5
added to clean line
Fri May 12 17:20:01 1995 UTC (30 years, 6 months ago) by greg
Diff to previous 1.4
added comments about different compile flags
Thu May 11 21:48:44 1995 UTC (30 years, 6 months ago) by greg
Diff to previous 1.3
added version tracking
Tue Mar 7 14:53:28 1995 UTC (30 years, 8 months ago) by greg
Diff to previous 1.2
added cct entity
Thu Jun 23 10:27:36 1994 UTC (31 years, 5 months ago) by greg
minor change to clean entry
Tue Jun 21 14:45:49 1994 UTC (31 years, 5 months ago) by greg
