root/radiance/ray/src/cv/mgflib/3ds2mgf.c
Wed Sep 5 02:41:19 2007 UTC (16 years, 9 months ago) by greg
Changes since 1.8: +2 -5 lines
Diff to previous 1.8
More copyright fixes
Revision 1.8 - (view) (download) (annotate) - [selected]
Wed Sep 5 01:36:37 2007 UTC (16 years, 9 months ago) by greg
Diff to previous 1.7
Copyright fixes
Sat Nov 15 17:54:06 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 1.6: +4 -2 lines
Diff to previous 1.6 , to selected 1.8
Fri Feb 28 20:11:29 2003 UTC (21 years, 3 months ago) by greg
Changes since 1.5: +3 -4 lines
Diff to previous 1.5 , to selected 1.8
Updates for 3.5 release
Fri Jan 16 10:47:27 1998 UTC (26 years, 5 months ago) by gregl
Diff to previous 1.4 , to selected 1.8
changed M_PI definition to ward off long double problems
Thu May 30 11:56:43 1996 UTC (28 years ago) by greg
Changes since 1.3: +6 -2 lines
Diff to previous 1.3 , to selected 1.8
added test for premature EOF
Fri Feb 9 11:02:29 1996 UTC (28 years, 4 months ago) by greg
Changes since 1.2: +4 -4 lines
Diff to previous 1.2 , to selected 1.8
changed help message and default format
Thu Feb 8 13:29:33 1996 UTC (28 years, 4 months ago) by greg
Changes since 1.1: +47 -3 lines
Diff to previous 1.1 , to selected 1.8
added better MGF output for smoothing turned off
Thu Feb 8 11:08:03 1996 UTC (28 years, 4 months ago) by greg
Diff to selected 1.8
