root/radiance/ray/src/cv/mgflib/3ds2mgf.c
Sat Nov 15 17:54:06 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 1.6: +4 -2 lines
Fri Feb 28 20:11:29 2003 UTC (22 years, 3 months ago) by greg
Changes since 1.5: +3 -4 lines
Updates for 3.5 release
Fri Jan 16 10:47:27 1998 UTC (27 years, 4 months ago) by gregl
changed M_PI definition to ward off long double problems
Thu May 30 11:56:43 1996 UTC (29 years ago) by greg
Changes since 1.3: +6 -2 lines
added test for premature EOF
Fri Feb 9 11:02:29 1996 UTC (29 years, 4 months ago) by greg
Changes since 1.2: +4 -4 lines
Diff to previous 1.2
changed help message and default format
Thu Feb 8 13:29:33 1996 UTC (29 years, 4 months ago) by greg
Changes since 1.1: +47 -3 lines
Diff to previous 1.1
added better MGF output for smoothing turned off
Thu Feb 8 11:08:03 1996 UTC (29 years, 4 months ago) by greg
Diff to selected 1.2
