root/radiance/ray/src/cv/mgflib/3ds2mgf.c
Revision 1.11
Tue Feb 22 15:58:41 2011 UTC (13 years, 3 months ago) by greg
FILE REMOVED
Finish of code reorg, moving MGF library into src/cv and src/common
Mon Nov 10 19:08:18 2008 UTC (15 years, 6 months ago) by greg
Changes since 1.9: +15 -2 lines
Diff to previous 1.9 , to selected 1.7
Wed Sep 5 02:41:19 2007 UTC (16 years, 9 months ago) by greg
Changes since 1.8: +2 -5 lines
Diff to previous 1.8 , to selected 1.7
More copyright fixes
Wed Sep 5 01:36:37 2007 UTC (16 years, 9 months ago) by greg
Diff to previous 1.7
Copyright fixes
Revision 1.7 - (view) (download) (annotate) - [selected]
Sat Nov 15 17:54:06 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 1.6: +4 -2 lines
Diff to previous 1.6
Fri Feb 28 20:11:29 2003 UTC (21 years, 3 months ago) by greg
Changes since 1.5: +3 -4 lines
Updates for 3.5 release
Fri Jan 16 10:47:27 1998 UTC (26 years, 4 months ago) by gregl
changed M_PI definition to ward off long double problems
Thu May 30 11:56:43 1996 UTC (28 years ago) by greg
Changes since 1.3: +6 -2 lines
added test for premature EOF
Fri Feb 9 11:02:29 1996 UTC (28 years, 4 months ago) by greg
Changes since 1.2: +4 -4 lines
changed help message and default format
Thu Feb 8 13:29:33 1996 UTC (28 years, 4 months ago) by greg
Changes since 1.1: +47 -3 lines
added better MGF output for smoothing turned off
Thu Feb 8 11:08:03 1996 UTC (28 years, 4 months ago) by greg
Diff to selected 1.7
