1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: 3ds2mgf.c,v 1.10 2008/11/10 19:08:18 greg Exp $"; |
3 |
#endif |
4 |
5 |
3DS2POV.C by Steve Anger and Jeff Bowermaster |
6 |
MGF output added by Greg Ward |
7 |
8 |
Reads a 3D Studio .3DS file and writes a POV-Ray, Vivid, |
9 |
Polyray, MGF or raw scene file. |
10 |
11 |
Version 2.0 Written Feb/96 |
12 |
13 |
Compiled with MSDOS GNU C++ 2.4.1 or generic ANSI-C compiler |
14 |
15 |
16 |
#include <stdio.h> |
17 |
#include <stdlib.h> |
18 |
#include <math.h> |
19 |
#include <string.h> |
20 |
#include <ctype.h> |
21 |
#include "vect.h" |
22 |
#include "rayopt.h" |
23 |
24 |
#ifdef __TURBOC__ |
25 |
#include <alloc.h> |
26 |
extern unsigned _stklen = 16384; |
27 |
#endif |
28 |
29 |
30 |
#define FALSE 0 |
31 |
#define TRUE 1 |
32 |
33 |
/* Internal bounding modes */ |
34 |
#define OFF 0 |
35 |
#define ON 1 |
36 |
#define AUTO 2 |
37 |
38 |
#define MAX_LIB 10 |
39 |
#define ASPECT 1.333 |
40 |
41 |
/* Output formats */ |
42 |
#define POV10 0 |
43 |
#define POV20 1 |
44 |
#define VIVID 2 |
45 |
#define POLYRAY 3 |
46 |
#define MGF 4 |
47 |
#define RAW 99 |
48 |
49 |
#define DEG(x) ((double)(180.0/M_PI)*(x)) |
50 |
#define RAD(x) ((double)(M_PI/180.0)*(x)) |
51 |
52 |
#ifndef M_PI |
53 |
#define M_PI (3.14159265358979323846) |
54 |
#endif |
55 |
56 |
#ifndef MAXFLOAT |
57 |
#define MAXFLOAT (1e37) |
58 |
#endif |
59 |
/* RGB chromaticity definitions for MGF */ |
60 |
#define CIE_x_r 0.640 |
61 |
#define CIE_y_r 0.330 |
62 |
#define CIE_x_g 0.290 |
63 |
#define CIE_y_g 0.600 |
64 |
#define CIE_x_b 0.150 |
65 |
#define CIE_y_b 0.060 |
66 |
/* computed luminances from above */ |
67 |
#define CIE_Y_r 0.265 |
68 |
#define CIE_Y_g 0.670 |
69 |
#define CIE_Y_b 0.065 |
70 |
71 |
/* A generic list type */ |
72 |
#define LIST_INSERT(root, node) list_insert ((List **)&root, (List *)node) |
73 |
#define LIST_FIND(root, name) list_find ((List **)&root, name) |
74 |
#define LIST_DELETE(root, node) list_delete ((List **)&root, (List *)node) |
75 |
#define LIST_KILL(root) list_kill ((List **)&root) |
76 |
77 |
#define LIST_FIELDS \ |
78 |
char name[80]; \ |
79 |
void *next; |
80 |
81 |
82 |
typedef unsigned char byte; |
83 |
typedef unsigned short word; |
84 |
typedef unsigned long dword; |
85 |
86 |
typedef struct { |
87 |
LIST_FIELDS |
88 |
} List; |
89 |
90 |
91 |
typedef struct { |
92 |
int a, b, c; |
93 |
} Face; |
94 |
95 |
96 |
typedef struct { |
97 |
float red, green, blue; |
98 |
} Colour; |
99 |
100 |
101 |
/* Transformation command */ |
102 |
typedef struct { |
103 |
LIST_FIELDS |
104 |
105 |
Matrix matrix; |
106 |
} Transform; |
107 |
108 |
109 |
/* Morph command */ |
110 |
typedef struct { |
111 |
LIST_FIELDS |
112 |
113 |
int count; /* Number of objects in morph */ |
114 |
char names[4][80]; /* Name of n'th object in average */ |
115 |
float weight[4]; /* Weight applied to n'th object */ |
116 |
117 |
Matrix matrix; |
118 |
} Morph; |
119 |
120 |
121 |
/* Omni light command */ |
122 |
typedef struct { |
123 |
LIST_FIELDS |
124 |
125 |
Vector pos; /* Light position */ |
126 |
Colour col; /* Light colour */ |
127 |
} OmniLight; |
128 |
129 |
130 |
/* Spotlight command */ |
131 |
typedef struct { |
132 |
LIST_FIELDS |
133 |
134 |
Vector pos; /* Spotlight position */ |
135 |
Vector target; /* Spotlight target location */ |
136 |
Colour col; /* Spotlight colour */ |
137 |
float hotspot; /* Hotspot angle (degrees) */ |
138 |
float falloff; /* Falloff angle (degrees) */ |
139 |
int shadow_flag; /* Shadow flag (not used) */ |
140 |
} Spotlight; |
141 |
142 |
143 |
/* Camera command */ |
144 |
typedef struct { |
145 |
LIST_FIELDS |
146 |
147 |
Vector pos; /* Camera location */ |
148 |
Vector target; /* Camera target */ |
149 |
float bank; /* Banking angle (degrees) */ |
150 |
float lens; /* Camera lens size (mm) */ |
151 |
} Camera; |
152 |
153 |
154 |
/* Material list */ |
155 |
typedef struct { |
156 |
LIST_FIELDS |
157 |
158 |
int external; /* Externally defined material? */ |
159 |
} Material; |
160 |
161 |
162 |
/* Object summary */ |
163 |
typedef struct { |
164 |
LIST_FIELDS |
165 |
166 |
Vector center; /* Min value of object extents */ |
167 |
Vector lengths; /* Max value of object extents */ |
168 |
} Summary; |
169 |
170 |
171 |
/* Material property */ |
172 |
typedef struct { |
173 |
LIST_FIELDS |
174 |
175 |
Colour ambient; |
176 |
Colour diffuse; |
177 |
Colour specular; |
178 |
float shininess; |
179 |
float transparency; |
180 |
float reflection; |
181 |
int self_illum; |
182 |
int two_side; |
183 |
char tex_map[40]; |
184 |
float tex_strength; |
185 |
char bump_map[40]; |
186 |
float bump_strength; |
187 |
} MatProp; |
188 |
189 |
190 |
/* Default material property */ |
191 |
MatProp DefaultMaterial = { "Default", NULL, {1.0, 1.0, 1.0}, {1.0, 1.0, 1.0}, |
192 |
{1.0, 1.0, 1.0}, 70.0, 0.0, 0.0, FALSE, FALSE }; |
193 |
194 |
/* A mesh object */ |
195 |
typedef struct { |
196 |
LIST_FIELDS |
197 |
198 |
int vertices; /* Number of vertices */ |
199 |
Vector *vertex; /* List of object vertices */ |
200 |
201 |
int faces; /* Number of faces */ |
202 |
Face *face; /* List of object faces */ |
203 |
Material **mtl; /* Materials for each face */ |
204 |
205 |
Matrix matrix; /* Local mesh matrix */ |
206 |
Matrix invmatrix; |
207 |
Vector center; /* Center of object */ |
208 |
Vector lengths; /* Dimensions of object */ |
209 |
210 |
int hidden; /* Hidden flag */ |
211 |
int shadow; /* Shadow flag */ |
212 |
} Mesh; |
213 |
214 |
215 |
typedef struct { |
216 |
dword start; |
217 |
dword end; |
218 |
dword length; |
219 |
word tag; |
220 |
} Chunk; |
221 |
222 |
223 |
typedef struct { |
224 |
byte red; |
225 |
byte green; |
226 |
byte blue; |
227 |
} Colour_24; |
228 |
229 |
230 |
Colour Black = {0.0, 0.0, 0.0}; |
231 |
232 |
OmniLight *omni_list = NULL; |
233 |
Spotlight *spot_list = NULL; |
234 |
Camera *cam_list = NULL; |
235 |
Mesh *mesh_list = NULL; |
236 |
Transform *trans_list = NULL; |
237 |
Morph *morph_list = NULL; |
238 |
Material *mtl_list = NULL; |
239 |
List *excl_list = NULL; |
240 |
List *box_list = NULL; |
241 |
MatProp *mprop_list = NULL; |
242 |
Summary *summary = NULL; |
243 |
244 |
245 |
FILE *in; |
246 |
FILE *out; |
247 |
char inname[80]; |
248 |
char outname[80]; |
249 |
char vuename[80]; |
250 |
char obj_name[80] = ""; |
251 |
Colour fog_colour = {0.0, 0.0, 0.0}; |
252 |
Colour col = {0.0, 0.0, 0.0}; |
253 |
Colour global_amb = {0.1, 0.1, 0.1}; |
254 |
Vector pos = {0.0, 0.0, 0.0}; |
255 |
Vector target = {0.0, 0.0, 0.0}; |
256 |
float fog_distance = 0.0; |
257 |
float hotspot = -1; |
258 |
float falloff = -1; |
259 |
Mesh *mesh = NULL; |
260 |
int frame = -1; |
261 |
char libname[MAX_LIB][80]; |
262 |
float smooth = 60.0; |
263 |
int bound = 0; |
264 |
int verbose = 0; |
265 |
int format = POV20; |
266 |
int internal_bounding = AUTO; |
267 |
int box_all = FALSE; |
268 |
int cameras = 0; |
269 |
int libs = 0; |
270 |
float vue_version = 1.0; |
271 |
Matrix *ani_matrix = NULL; |
272 |
int no_opt = FALSE; |
273 |
FILE *meshf = NULL; |
274 |
275 |
276 |
void process_args (int argc, char *argv[]); |
277 |
void parse_option (char *option); |
278 |
void list_insert (List **root, List *new_node); |
279 |
void *list_find (List **root, char *name); |
280 |
void list_delete (List **root, List *node); |
281 |
void list_kill (List **root); |
282 |
Material *update_materials (char *new_material, int ext); |
283 |
MatProp *create_mprop (void); |
284 |
void read_library (char *fname); |
285 |
void write_intro (FILE *f); |
286 |
void write_summary (FILE *f); |
287 |
void write_bgsolid (FILE *f, Colour col); |
288 |
void write_light (FILE *f, char *name, Vector pos, Colour col); |
289 |
void write_spot (FILE *f, char *name, Vector pos, Vector target, Colour col, |
290 |
float hotspot, float falloff); |
291 |
void write_fog (FILE *f, Colour col, float dist); |
292 |
void write_camera (FILE *f, char *name, Vector pos, Vector target, float lens, |
293 |
float bank); |
294 |
void write_material (FILE *f, char *mat); |
295 |
void write_pov10_material (FILE *f, MatProp *m); |
296 |
void write_pov20_material (FILE *f, MatProp *m); |
297 |
void write_vivid_material (FILE *f, MatProp *m); |
298 |
void write_polyray_material (FILE *f, MatProp *m); |
299 |
void write_mgf_material (FILE *f, MatProp *m); |
300 |
void write_mesh (FILE *f, Mesh *mesh); |
301 |
Transform *parse_transform (char *string); |
302 |
Morph *parse_morph (char *string); |
303 |
OmniLight *parse_omnilight (char *string); |
304 |
Spotlight *parse_spotlight (char *string); |
305 |
Camera *parse_camera (char *string); |
306 |
void read_frame (char *filename, int frame_no); |
307 |
void find_frame (FILE *f, int frame_no); |
308 |
void save_animation (void); |
309 |
Mesh *create_mesh (char *name, int vertices, int faces); |
310 |
Mesh *copy_mesh (Mesh *mesh); |
311 |
void free_mesh_data (Mesh *mesh); |
312 |
void update_limits (Mesh *mesh); |
313 |
char *before (char *str, char *target); |
314 |
char *after (char *str, char *target); |
315 |
char *between (char *str, char *target1, char *target2); |
316 |
char *parse_string (char *str); |
317 |
char upcase (char c); |
318 |
float colour_intens (Colour *colour); |
319 |
void parse_file (void); |
320 |
void parse_3ds (Chunk *mainchunk); |
321 |
void parse_mdata (Chunk *mainchunk); |
322 |
void parse_fog (Chunk *mainchunk); |
323 |
void parse_fog_bgnd (void); |
324 |
void parse_mat_entry (Chunk *mainchunk); |
325 |
char *parse_mapname (Chunk *mainchunk); |
326 |
void parse_named_object (Chunk *mainchunk); |
327 |
void parse_n_tri_object (Chunk *mainchunk); |
328 |
void parse_point_array (void); |
329 |
void parse_face_array (Chunk *mainchunk); |
330 |
void parse_msh_mat_group (void); |
331 |
void parse_smooth_group (void); |
332 |
void parse_mesh_matrix (void); |
333 |
void parse_n_direct_light (Chunk *mainchunk); |
334 |
void parse_dl_spotlight (void); |
335 |
void parse_n_camera (void); |
336 |
void parse_colour (Colour *colour); |
337 |
void parse_colour_f (Colour *colour); |
338 |
void parse_colour_24 (Colour_24 *colour); |
339 |
float parse_percentage (void); |
340 |
short parse_int_percentage (void); |
341 |
float parse_float_percentage (void); |
342 |
void start_chunk (Chunk *chunk); |
343 |
void end_chunk (Chunk *chunk); |
344 |
byte read_byte (void); |
345 |
word read_word (void); |
346 |
dword read_dword (void); |
347 |
float read_float (void); |
348 |
void read_point (Vector v); |
349 |
char *read_string (void); |
350 |
float findfov (float lens); |
351 |
int read_mgfmatname (char *s, int n, FILE *f); |
352 |
353 |
char *progname; |
354 |
355 |
356 |
int main (int argc, char *argv[]) |
357 |
358 |
char meshfname[128]; |
359 |
Material *m; |
360 |
int i; |
361 |
362 |
process_args (argc, argv); |
363 |
364 |
if (!no_opt) { |
365 |
opt_set_format (format); |
366 |
opt_set_dec (4); |
367 |
opt_set_bound (bound); |
368 |
opt_set_smooth (smooth); |
369 |
opt_set_quiet (!verbose); |
370 |
opt_set_fname (outname, ""); |
371 |
} else if (format == MGF) { |
372 |
strcpy(meshfname, outname); |
373 |
add_ext(meshfname, "inc", 1); |
374 |
if (!strcmp(meshfname, outname)) { |
375 |
printf ("Output and mesh file names are identical!\n"); |
376 |
exit (1); |
377 |
378 |
if ((meshf = fopen (meshfname, "w")) == NULL) { |
379 |
printf ("Cannot open mesh output file %s!\n", meshfname); |
380 |
exit (1); |
381 |
382 |
383 |
384 |
if ((in = fopen (inname, "rb")) == NULL) { |
385 |
printf ("Cannot open input file %s!\n", inname); |
386 |
exit (1); |
387 |
388 |
389 |
if ((out = fopen (outname, "w")) == NULL) { |
390 |
printf ("Cannot open output file %s!\n", outname); |
391 |
exit (1); |
392 |
393 |
394 |
/* Load the names of pre-defined materials */ |
395 |
for (i = 0; i < MAX_LIB; i++) { |
396 |
if (strlen(libname[i]) > 0) |
397 |
read_library (libname[i]); |
398 |
399 |
400 |
/* Load the instructions for the current frame */ |
401 |
if (strlen(vuename) > 0) |
402 |
read_frame (vuename, frame); |
403 |
404 |
printf("Output to: %s\n", outname); |
405 |
406 |
if (frame >= 0) |
407 |
printf ("Generating frame #%d\n", frame); |
408 |
409 |
printf("\nPlease wait; Processing...\n"); |
410 |
411 |
write_intro(out); |
412 |
413 |
parse_file(); |
414 |
415 |
fclose(in); |
416 |
417 |
for (m = mtl_list; m != NULL; m = m->next) { |
418 |
if (!m->external) |
419 |
write_material (out, m->name); |
420 |
421 |
422 |
if (frame >= 0) |
423 |
save_animation(); |
424 |
425 |
if (!no_opt) { |
426 |
write_summary (out); |
427 |
fflush (out); |
428 |
429 |
opt_finish(); |
430 |
} else if (meshf != NULL) { |
431 |
fclose(meshf); |
432 |
fprintf (out, "i %s\n", meshfname); |
433 |
434 |
435 |
fclose (out); |
436 |
437 |
LIST_KILL (omni_list); |
438 |
LIST_KILL (spot_list); |
439 |
LIST_KILL (cam_list); |
440 |
LIST_KILL (mesh_list); |
441 |
LIST_KILL (trans_list); |
442 |
LIST_KILL (morph_list); |
443 |
LIST_KILL (mtl_list); |
444 |
LIST_KILL (excl_list); |
445 |
LIST_KILL (box_list); |
446 |
LIST_KILL (mprop_list); |
447 |
LIST_KILL (summary); |
448 |
449 |
return 0; |
450 |
451 |
452 |
453 |
/* Handle the command line args */ |
454 |
void process_args (int argc, char *argv[]) |
455 |
456 |
int i; |
457 |
char *env_opt, *option; |
458 |
459 |
printf("\n\nAutodesk 3D Studio to Raytracer file Translator. Feb/96\n"); |
460 |
printf("Version 2.0 by Steve Anger and Jeff Bowermaster 1996\n"); |
461 |
printf ("\n"); |
462 |
463 |
if (argc < 2) { |
464 |
printf ("Usage: %s inputfile[.3ds] [outputfile] [options]\n\n", argv[0]); |
465 |
printf ("Options: -snnn - Smooth triangles with angles < nnn\n"); |
466 |
printf (" -l<filename> - Specifies native material library\n"); |
467 |
printf (" -a<filename> - Use animation information in specified file\n"); |
468 |
printf (" -fnnn - Generate frame nnn of animation\n"); |
469 |
printf (" -x<object> - Exclude this object from conversion\n"); |
470 |
printf (" -b<object> - Convert this object as a box\n"); |
471 |
printf (" +i, -i - Turn internal bounding on or off\n"); |
472 |
printf (" +v, -v - Turn verbose status messages on or off\n"); |
473 |
printf (" -op - Output to POV-Ray 2.0 format\n"); |
474 |
printf (" -op1 - Output to POV-Ray 1.0 format\n"); |
475 |
printf (" -ov - Output to Vivid format\n"); |
476 |
printf (" -ol - Output to poLyray format\n"); |
477 |
printf (" -om - Output to MGF\n"); |
478 |
printf (" -or - Output to RAW triangle format\n\n"); |
479 |
printf ("ex. %s birdshow +v -lmaterials.inc\n\n", argv[0]); |
480 |
exit(1); |
481 |
482 |
/* figure default format from name */ |
483 |
progname = strrchr(argv[0], '/'); |
484 |
if (progname == NULL) progname = argv[0]; |
485 |
else progname++; |
486 |
if (!strcmp(progname, "3ds2pov")) |
487 |
format = POV20; |
488 |
else if (!strcmp(progname, "3ds2viv")) |
489 |
format = VIVID; |
490 |
else if (!strcmp(progname, "3ds2pi")) |
491 |
format = POLYRAY; |
492 |
else if (!strcmp(progname, "3ds2mgf")) |
493 |
format = MGF; |
494 |
else if (!strcmp(progname, "3ds2raw")) |
495 |
format = RAW; |
496 |
else |
497 |
format = POV20; /* default if program name strange */ |
498 |
499 |
strcpy (inname, ""); |
500 |
strcpy (outname, ""); |
501 |
strcpy (vuename, ""); |
502 |
503 |
for (i = 0; i < MAX_LIB; i++) |
504 |
strcpy (libname[i], ""); |
505 |
506 |
frame = -1; |
507 |
smooth = 70.0; |
508 |
bound = 0; |
509 |
verbose = 0; |
510 |
511 |
box_all = FALSE; |
512 |
libs = 0; |
513 |
514 |
/* Parse the enviroment string options */ |
515 |
env_opt = getenv ("3DS2POV"); |
516 |
517 |
if (env_opt != NULL) { |
518 |
option = parse_string (env_opt); |
519 |
520 |
while (strlen(option) > 0) { |
521 |
parse_option (option); |
522 |
option = parse_string (NULL); |
523 |
524 |
525 |
526 |
/* Parse the command line options */ |
527 |
for (i = 1; i < argc; i++) |
528 |
parse_option (argv[i]); |
529 |
530 |
if (strlen(inname) == 0) |
531 |
abortmsg ("No input file specified", 1); |
532 |
533 |
if (strlen(outname) == 0) |
534 |
strcpy (outname, inname); |
535 |
536 |
switch (format) { |
537 |
case POV10: |
538 |
case POV20: add_ext (outname, "pov", 1); break; |
539 |
case VIVID: add_ext (outname, "v", 1); break; |
540 |
case POLYRAY: add_ext (outname, "pi", 1); break; |
541 |
case MGF: add_ext (outname, "mgf", 1); break; |
542 |
case RAW: add_ext (outname, "raw", 1); break; |
543 |
544 |
545 |
switch (internal_bounding) { |
546 |
case OFF: bound = 2; break; |
547 |
case ON: bound = 0; break; |
548 |
case AUTO: bound = (format == POV10) ? 0 : 2; break; |
549 |
550 |
551 |
if ((strlen(vuename) > 0) != (frame >= 0)) |
552 |
abortmsg ("The -a and -f parameters must be used together", 1); |
553 |
554 |
if (format == RAW || (format == MGF && smooth < 0.1)) |
555 |
no_opt = TRUE; |
556 |
557 |
558 |
559 |
void parse_option (char *option) |
560 |
561 |
List *excl, *box; |
562 |
char name[80]; |
563 |
564 |
if (option[0] == '-' || option[0] == '+') { |
565 |
switch (upcase(option[1])) { |
566 |
case 'A': strcpy (vuename, &option[2]); |
567 |
break; |
568 |
569 |
case 'B': strcpy (name, parse_string (&option[2])); |
570 |
if (strlen(name) == 0) |
571 |
box_all = TRUE; |
572 |
else { |
573 |
cleanup_name (name); |
574 |
575 |
box = malloc (sizeof (*box)); |
576 |
strcpy (box->name, name); |
577 |
578 |
LIST_INSERT (box_list, box); |
579 |
580 |
break; |
581 |
582 |
case 'F': if (option[2] != '\0') |
583 |
frame = atoi (&option[2]); |
584 |
break; |
585 |
586 |
case 'I': if (option[0] == '-') |
587 |
internal_bounding = OFF; |
588 |
else |
589 |
internal_bounding = ON; |
590 |
break; |
591 |
592 |
case 'L': if (libs == MAX_LIB) |
593 |
abortmsg ("Too many libraries specified", 1); |
594 |
595 |
strcpy (libname[libs++], &option[2]); |
596 |
break; |
597 |
598 |
case 'O': switch (upcase(option[2])) { |
599 |
case 'P': if (option[3] == '1') |
600 |
format = POV10; |
601 |
else |
602 |
format = POV20; |
603 |
break; |
604 |
605 |
case 'V': format = VIVID; |
606 |
break; |
607 |
608 |
case 'L': format = POLYRAY; |
609 |
break; |
610 |
611 |
case 'R': format = RAW; |
612 |
break; |
613 |
614 |
case 'M': format = MGF; |
615 |
break; |
616 |
617 |
default: printf ("Invalid output format %s specified\n", option); |
618 |
exit(1); |
619 |
620 |
break; |
621 |
622 |
case 'S': if (option[2] != '\0') |
623 |
smooth = atof (&option[2]); |
624 |
break; |
625 |
626 |
case 'U': printf ("Warning: -u parameter no long has any effect\n"); |
627 |
printf (" use +i or -i instead.\n"); |
628 |
break; |
629 |
630 |
case 'V': if (option[0] == '-') |
631 |
verbose = 0; |
632 |
else |
633 |
verbose = 1; |
634 |
break; |
635 |
636 |
case 'X': strcpy (name, parse_string (&option[2])); |
637 |
638 |
639 |
excl = malloc (sizeof (*excl)); |
640 |
strcpy (excl->name, name); |
641 |
642 |
LIST_INSERT (excl_list, excl); |
643 |
break; |
644 |
645 |
default : printf ("\nInvalid option %s specified\n", option); |
646 |
exit (1); |
647 |
648 |
649 |
else if (strlen (inname) == 0) { |
650 |
strcpy (inname, option); |
651 |
add_ext (inname, "3ds", 0); |
652 |
653 |
else if (strlen (outname) == 0) |
654 |
strcpy (outname, option); |
655 |
else |
656 |
abortmsg ("Too many file names specified.\n", 1); |
657 |
658 |
659 |
660 |
/* Insert a new node into the list */ |
661 |
void list_insert (List **root, List *new_node) |
662 |
663 |
new_node->next = *root; |
664 |
665 |
*root = new_node; |
666 |
667 |
668 |
669 |
/* Find the node with the specified name */ |
670 |
void *list_find (List **root, char *name) |
671 |
672 |
List *p; |
673 |
674 |
for (p = *root; p != NULL; p = p->next) { |
675 |
if (strcmp (p->name, name) == 0) |
676 |
break; |
677 |
678 |
679 |
return (void *)p; |
680 |
681 |
682 |
683 |
/* Delete the indicated node from the list */ |
684 |
void list_delete (List **root, List *node) |
685 |
686 |
List *prev; |
687 |
688 |
prev = *root; |
689 |
while (prev != NULL && prev->next != node) |
690 |
prev = prev->next; |
691 |
692 |
if (prev == NULL) |
693 |
*root = node->next; |
694 |
else |
695 |
prev->next = node->next; |
696 |
697 |
free (node); |
698 |
699 |
700 |
701 |
/* Delete the entire list */ |
702 |
void list_kill (List **root) |
703 |
704 |
List *temp; |
705 |
706 |
while (*root != NULL) { |
707 |
temp = *root; |
708 |
*root = (*root)->next; |
709 |
free (temp); |
710 |
711 |
712 |
713 |
714 |
/* Add a new material to the material list */ |
715 |
Material *update_materials (char *new_material, int ext) |
716 |
717 |
Material *p; |
718 |
719 |
p = LIST_FIND (mtl_list, new_material); |
720 |
721 |
if (p == NULL) { |
722 |
p = malloc (sizeof (*p)); |
723 |
724 |
if (p == NULL) |
725 |
abortmsg ("Out of memory adding material", 1); |
726 |
727 |
strcpy (p->name, new_material); |
728 |
p->external = ext; |
729 |
730 |
LIST_INSERT (mtl_list, p); |
731 |
732 |
733 |
return p; |
734 |
735 |
736 |
737 |
MatProp *create_mprop() |
738 |
739 |
MatProp *new_mprop; |
740 |
741 |
new_mprop = malloc (sizeof(*new_mprop)); |
742 |
if (new_mprop == NULL) |
743 |
744 |
745 |
strcpy (new_mprop->name, ""); |
746 |
new_mprop->ambient = Black; |
747 |
new_mprop->diffuse = Black; |
748 |
new_mprop->specular = Black; |
749 |
new_mprop->shininess = 0.0; |
750 |
new_mprop->transparency = 0.0; |
751 |
new_mprop->reflection = 0.0; |
752 |
new_mprop->self_illum = FALSE; |
753 |
new_mprop->two_side = FALSE; |
754 |
755 |
strcpy (new_mprop->tex_map, ""); |
756 |
new_mprop->tex_strength = 0.0; |
757 |
758 |
strcpy (new_mprop->bump_map, ""); |
759 |
new_mprop->bump_strength = 0.0; |
760 |
761 |
return new_mprop; |
762 |
763 |
764 |
765 |
/* Load in any predefined materials */ |
766 |
void read_library (char *fname) |
767 |
768 |
FILE *lib; |
769 |
char string[256], name[80]; |
770 |
771 |
if ((lib = fopen (fname, "r")) == NULL) { |
772 |
printf ("Cannot open texture library file %s!\n", fname); |
773 |
exit(1); |
774 |
775 |
776 |
switch (format) { |
777 |
case POV10: |
778 |
case POV20: |
779 |
while (fgets (string, 256, lib) != NULL) { |
780 |
if (strstr (string, "#declare")) { |
781 |
strcpy (name, between (string, "#declare", "=")); |
782 |
783 |
(void)update_materials (name, TRUE); |
784 |
785 |
786 |
break; |
787 |
788 |
case VIVID: |
789 |
790 |
if (strstr (string, "#define")) { |
791 |
(void)parse_string (string); |
792 |
strcpy (name, parse_string (NULL)); |
793 |
794 |
795 |
796 |
797 |
break; |
798 |
799 |
case POLYRAY: |
800 |
801 |
if (strstr (string, "define")) { |
802 |
803 |
804 |
805 |
806 |
807 |
808 |
break; |
809 |
810 |
case MGF: |
811 |
while (read_mgfmatname(name, 80, lib)) |
812 |
813 |
break; |
814 |
815 |
816 |
fclose (lib); |
817 |
818 |
819 |
820 |
/* parse the next MGF material name from f, return FALSE if EOF */ |
821 |
int read_mgfmatname (char *s, int n, FILE *f) |
822 |
823 |
char inpline[128]; |
824 |
register char *cp, *cp2; |
825 |
register int i; |
826 |
/* find material */ |
827 |
while (fgets(inpline, sizeof(inpline), f) != NULL) { |
828 |
for (cp = inpline; isspace(*cp); cp++) |
829 |
830 |
if (*cp++ != 'm' || !isspace(*cp++)) |
831 |
continue; |
832 |
while (isspace(*cp)) |
833 |
cp++; |
834 |
if (!*cp) |
835 |
continue; |
836 |
for (i=n, cp2=s; *cp && !isspace(*cp); cp++) /* get name */ |
837 |
if (--i > 0) |
838 |
*cp2++ = *cp; |
839 |
*cp2 = '\0'; |
840 |
841 |
cp++; |
842 |
if (*cp++ != '=' || !isspace(*cp)) /* not defined? */ |
843 |
continue; |
844 |
return TRUE; |
845 |
846 |
return FALSE; |
847 |
848 |
849 |
850 |
void write_intro (FILE *f) |
851 |
852 |
int i; |
853 |
854 |
switch (format) { |
855 |
case POV10: |
856 |
case POV20: |
857 |
fprintf (f, "#include \"colors.inc\"\n"); |
858 |
fprintf (f, "#include \"shapes.inc\"\n"); |
859 |
fprintf (f, "#include \"textures.inc\"\n"); |
860 |
861 |
862 |
863 |
fprintf (f, "#include \"%s\"\n", libname[i]); |
864 |
865 |
866 |
fprintf (f, "\n"); |
867 |
break; |
868 |
869 |
case VIVID: |
870 |
fprintf (f, "#include color.vc\n"); |
871 |
872 |
873 |
874 |
fprintf (f, "#include %s\n", libname[i]); |
875 |
876 |
877 |
878 |
break; |
879 |
880 |
case POLYRAY: |
881 |
fprintf (f, "include \"colors.inc\"\n"); |
882 |
883 |
884 |
885 |
fprintf (f, "include \"%s\"\n", libname[i]); |
886 |
887 |
888 |
889 |
break; |
890 |
891 |
case MGF: |
892 |
fprintf (f, "c R =\n\tcxy %.3f %.3f\n", CIE_x_r, CIE_y_r); |
893 |
fprintf (f, "c G =\n\tcxy %.3f %.3f\n", CIE_x_g, CIE_y_g); |
894 |
fprintf (f, "c B =\n\tcxy %.3f %.3f\n", CIE_x_b, CIE_y_b); |
895 |
896 |
897 |
898 |
fprintf (f, "i %s\n", libname[i]); |
899 |
900 |
901 |
902 |
break; |
903 |
904 |
905 |
906 |
907 |
/* Write the object summary */ |
908 |
void write_summary (FILE *f) |
909 |
910 |
char *comstr; |
911 |
Summary *s; |
912 |
913 |
if (summary == NULL) |
914 |
return; |
915 |
916 |
switch (format) { |
917 |
case POV10: |
918 |
case POV20: |
919 |
case VIVID: |
920 |
case POLYRAY: |
921 |
comstr = "//"; |
922 |
break; |
923 |
case MGF: |
924 |
comstr = "# "; |
925 |
break; |
926 |
default: |
927 |
printf ("Illegal format in write_summary() '%c'\n", format); |
928 |
exit(1); |
929 |
930 |
fprintf (f, "%s Object CenterX CenterY CenterZ LengthX LengthY LengthZ\n", comstr); |
931 |
fprintf (f, "%s ---------- ---------- ---------- ---------- ---------- ---------- ----------\n", comstr); |
932 |
933 |
for (s = summary; s != NULL; s = s->next) { |
934 |
fprintf (f, "%s %-10s%11.2f%11.2f%11.2f%11.2f%11.2f%11.2f\n", |
935 |
comstr, s->name, s->center[X], s->center[Y], s->center[Z], |
936 |
s->lengths[X], s->lengths[Y], s->lengths[Z]); |
937 |
938 |
939 |
940 |
941 |
942 |
943 |
/* Write background solid colour */ |
944 |
void write_bgsolid (FILE *f, Colour col) |
945 |
946 |
switch (format) { |
947 |
case POV10: |
948 |
fprintf (f, "/* Background colour */\n"); |
949 |
fprintf (f, "object {\n"); |
950 |
fprintf (f, " sphere { <0.0 0.0 0.0> 1e6 }\n"); |
951 |
fprintf (f, " texture {\n"); |
952 |
fprintf (f, " ambient 1.0\n"); |
953 |
fprintf (f, " diffuse 0.0\n"); |
954 |
fprintf (f, " color red %4.2f green %4.2f blue %4.2f\n", |
955 |
col.red, col.green, col.blue); |
956 |
fprintf (f, " }\n"); |
957 |
fprintf (f, "}\n\n"); |
958 |
break; |
959 |
960 |
case POV20: |
961 |
fprintf (f, "background { color red %4.2f green %4.2f blue %4.2f }\n\n", |
962 |
963 |
break; |
964 |
965 |
case POLYRAY: |
966 |
fprintf (f, "background <%4.2f, %4.2f, %4.2f>\n\n", |
967 |
968 |
break; |
969 |
970 |
971 |
972 |
973 |
void write_light (FILE *f, char *name, Vector pos, Colour col) |
974 |
975 |
switch (format) { |
976 |
case POV10: |
977 |
fprintf (f, "/* Light: %s */\n", name); |
978 |
979 |
fprintf (f, " light_source { <%.4f %.4f %.4f> color red %4.2f green %4.2f blue %4.2f }\n", |
980 |
pos[X], pos[Y], pos[Z], col.red, col.green, col.blue); |
981 |
982 |
break; |
983 |
984 |
case POV20: |
985 |
986 |
fprintf (f, "light_source {\n"); |
987 |
fprintf (f, " <%.4f, %.4f, %.4f> color rgb <%4.2f, %4.2f, %4.2f>\n", |
988 |
989 |
990 |
break; |
991 |
992 |
case VIVID: |
993 |
994 |
fprintf (f, "light {\n"); |
995 |
fprintf (f, " type point\n"); |
996 |
fprintf (f, " position %.4f %.4f %.4f\n", |
997 |
pos[X], pos[Y], pos[Z]); |
998 |
fprintf (f, " color %4.2f %4.2f %4.2f\n", |
999 |
1000 |
1001 |
break; |
1002 |
1003 |
case POLYRAY: |
1004 |
fprintf (f, "// Light: %s\n", name); |
1005 |
fprintf (f, "light <%4.2f, %4.2f, %4.2f>, <%.4f, %.4f, %.4f>\n\n", |
1006 |
col.red, col.green, col.blue, pos[X], pos[Y], pos[Z]); |
1007 |
break; |
1008 |
1009 |
case MGF: |
1010 |
fprintf (f, "\n# Light\n"); |
1011 |
if (name[0]) fprintf (f, "o %s\n", name); |
1012 |
fprintf (f, "m\n\tsides 1\n\tc\n\t\t\tcmix %.3f R %.3f G %.3f B\n\ted %e\n", |
1013 |
CIE_Y_r*col.red, CIE_Y_g*col.green, CIE_Y_b*col.blue, |
1014 |
100000.0*(CIE_Y_r*col.red + CIE_Y_g*col.green + CIE_Y_b*col.blue)); |
1015 |
fprintf (f, "v c =\n\tp %.4f %.4f %.4f\nsph c .01\n", |
1016 |
1017 |
if (name[0]) fprintf (f, "o\n"); |
1018 |
1019 |
break; |
1020 |
1021 |
1022 |
1023 |
1024 |
1025 |
float hotspot, float falloff) |
1026 |
1027 |
switch (format) { |
1028 |
case POV10: |
1029 |
fprintf (f, "/* Spotlight: %s */\n", name); |
1030 |
1031 |
fprintf (f, " light_source {\n"); |
1032 |
fprintf (f, " <%.4f %.4f %.4f> color red %4.2f green %4.2f blue %4.2f\n", |
1033 |
pos[X], pos[Y], pos[Z], |
1034 |
1035 |
fprintf (f, " spotlight\n"); |
1036 |
fprintf (f, " point_at <%.4f %.4f %.4f>\n", |
1037 |
target[X], target[Y], target[Z]); |
1038 |
fprintf (f, " tightness 0\n"); |
1039 |
fprintf (f, " radius %.2f\n", 0.5*hotspot); |
1040 |
fprintf (f, " falloff %.2f\n", 0.5*falloff); |
1041 |
1042 |
1043 |
break; |
1044 |
1045 |
case POV20: |
1046 |
1047 |
1048 |
1049 |
1050 |
1051 |
1052 |
fprintf (f, " point_at <%.4f, %.4f, %.4f>\n", |
1053 |
1054 |
1055 |
1056 |
1057 |
1058 |
break; |
1059 |
1060 |
case VIVID: |
1061 |
1062 |
1063 |
fprintf (f, " type spot\n"); |
1064 |
1065 |
1066 |
fprintf (f, " at %.4f %.4f %.4f\n", |
1067 |
1068 |
1069 |
1070 |
fprintf (f, " min_angle %.2f\n", hotspot); |
1071 |
fprintf (f, " max_angle %.2f\n", falloff); |
1072 |
1073 |
break; |
1074 |
1075 |
case POLYRAY: |
1076 |
fprintf (f, "// Spotlight: %s\n", name); |
1077 |
fprintf (f, "spot_light <%4.2f, %4.2f, %4.2f>, <%.4f, %.4f, %.4f>,\n", |
1078 |
1079 |
fprintf (f, " <%.4f, %.4f, %.4f>, 0.0, %.2f, %.2f\n\n", |
1080 |
target[X], target[Y], target[Z], hotspot/2.0, falloff/2.0); |
1081 |
break; |
1082 |
1083 |
case MGF: |
1084 |
fprintf (f, "\n# Spotlight\n"); |
1085 |
1086 |
fprintf (f, "# hotspot: %.2f\n# falloff: %.2f\n", hotspot, falloff); |
1087 |
1088 |
1089 |
1090 |
fprintf (f, "v c =\n\tp %.4f %.4f %.4f\n\tn %.4f %.4f %.4f\n", |
1091 |
1092 |
target[X]-pos[X], target[Y]-pos[Y], target[Z]-pos[Z]); |
1093 |
fprintf (f, "ring c 0 .01\n"); |
1094 |
1095 |
1096 |
break; |
1097 |
1098 |
1099 |
1100 |
1101 |
void write_fog (FILE *f, Colour col, float dist) |
1102 |
1103 |
if (dist <= 0.0) |
1104 |
return; |
1105 |
1106 |
switch (format) { |
1107 |
case POV10: |
1108 |
fprintf (f, "fog {\n"); |
1109 |
fprintf (f, " color red %4.2f green %4.2f blue %4.2f %.4f\n", |
1110 |
col.red, col.green, col.blue, dist/2.0); |
1111 |
1112 |
break; |
1113 |
1114 |
case POV20: |
1115 |
1116 |
fprintf (f, " color red %4.2f green %4.2f blue %4.2f distance %.4f\n", |
1117 |
1118 |
1119 |
break; |
1120 |
1121 |
1122 |
1123 |
1124 |
void write_camera (FILE *f, char *name, Vector pos, Vector target, |
1125 |
float lens, float bank) |
1126 |
1127 |
float fov; |
1128 |
1129 |
cameras++; |
1130 |
1131 |
fov = findfov (lens); |
1132 |
1133 |
switch (format) { |
1134 |
case POV10: |
1135 |
/* Comment out multiple cameras */ |
1136 |
if (cameras > 1) |
1137 |
fprintf (f, "/*\n"); |
1138 |
1139 |
fprintf (f, "/* Camera: %s */\n", name); |
1140 |
fprintf (f, "camera {\n"); |
1141 |
fprintf (f, " location <%.4f %.4f %.4f>\n", |
1142 |
1143 |
fprintf (f, " direction <0 %.3f 0>\n", 0.60/tan(0.5*RAD(fov)) ); |
1144 |
fprintf (f, " up <0 0 1>\n"); |
1145 |
fprintf (f, " sky <0 0 1>\n"); |
1146 |
fprintf (f, " right <%.3f 0 0>\n", ASPECT); |
1147 |
fprintf (f, " look_at <%.4f %.4f %.4f>\n", |
1148 |
1149 |
if (bank != 0.0) |
1150 |
fprintf (f, " /* Bank angle = %.2f */\n", bank); |
1151 |
1152 |
fprintf (f, "}\n"); |
1153 |
1154 |
if (cameras > 1) |
1155 |
fprintf (f, "*/\n"); |
1156 |
1157 |
1158 |
break; |
1159 |
1160 |
case POV20: |
1161 |
1162 |
if (cameras > 1) |
1163 |
1164 |
1165 |
1166 |
1167 |
fprintf (f, " location <%.4f, %.4f, %.4f>\n", |
1168 |
1169 |
fprintf (f, " direction <0, %.3f, 0>\n", 0.60/tan(0.5*RAD(fov)) ); |
1170 |
fprintf (f, " up <0, 0, 1>\n"); |
1171 |
fprintf (f, " sky <0, 0, 1>\n"); |
1172 |
fprintf (f, " right <%.3f, 0, 0>\n", ASPECT); |
1173 |
fprintf (f, " look_at <%.4f, %.4f, %.4f>\n", |
1174 |
1175 |
if (bank != 0.0) |
1176 |
1177 |
1178 |
1179 |
1180 |
if (cameras > 1) |
1181 |
1182 |
1183 |
1184 |
break; |
1185 |
1186 |
case VIVID: |
1187 |
1188 |
1189 |
if (cameras > 1) |
1190 |
1191 |
1192 |
fprintf (f, "studio {\n"); |
1193 |
fprintf (f, " from %.4f %.4f %.4f\n", |
1194 |
1195 |
1196 |
1197 |
fprintf (f, " up 0 0 1\n"); |
1198 |
fprintf (f, " angle %.2f\n", 1.1*fov); |
1199 |
fprintf (f, " aspect %.3f\n", ASPECT); |
1200 |
fprintf (f, " resolution 320 200\n"); |
1201 |
fprintf (f, " antialias none\n"); |
1202 |
1203 |
1204 |
if (cameras > 1) |
1205 |
1206 |
1207 |
1208 |
break; |
1209 |
1210 |
case POLYRAY: |
1211 |
if (cameras == 1) { |
1212 |
fprintf (f, "// Camera: %s\n", name); |
1213 |
fprintf (f, "viewpoint {\n"); |
1214 |
fprintf (f, " from <%.4f, %.4f, %.4f>\n", |
1215 |
1216 |
fprintf (f, " at <%.4f, %.4f, %.4f>\n", |
1217 |
1218 |
1219 |
fprintf (f, " angle %.2f\n", 0.85*fov); |
1220 |
fprintf (f, " aspect %.3f\n", -(ASPECT)); |
1221 |
fprintf (f, " resolution 320, 200\n"); |
1222 |
1223 |
1224 |
1225 |
1226 |
break; |
1227 |
1228 |
case MGF: |
1229 |
fprintf (f, "# Camera %s\n", name); |
1230 |
fprintf (f, "# from: %.4f %.4f %.4f\n", pos[X], pos[Y], pos[Z]); |
1231 |
fprintf (f, "# to: %.4f %.4f %.4f\n", target[X], target[Y], target[Z]); |
1232 |
fprintf (f, "# lens length: %.2f\n", lens); |
1233 |
fprintf (f, "# bank: %.2f\n", bank); |
1234 |
break; |
1235 |
1236 |
1237 |
1238 |
1239 |
void write_material (FILE *f, char *mat) |
1240 |
1241 |
MatProp *mprop = LIST_FIND (mprop_list, mat); |
1242 |
1243 |
if (mprop == NULL) { |
1244 |
mprop = &DefaultMaterial; |
1245 |
(void)strcpy(mprop->name, mat); |
1246 |
1247 |
1248 |
switch (format) { |
1249 |
case POV10: |
1250 |
write_pov10_material (f, mprop); |
1251 |
break; |
1252 |
1253 |
case POV20: |
1254 |
write_pov20_material (f, mprop); |
1255 |
break; |
1256 |
1257 |
case VIVID: |
1258 |
write_vivid_material (f, mprop); |
1259 |
break; |
1260 |
1261 |
case POLYRAY: |
1262 |
write_polyray_material (f, mprop); |
1263 |
break; |
1264 |
1265 |
case MGF: |
1266 |
write_mgf_material (f, mprop); |
1267 |
break; |
1268 |
1269 |
1270 |
1271 |
1272 |
void write_pov10_material (FILE *f, MatProp *m) |
1273 |
1274 |
float amb = 0.1, dif = 0.9, spec = 1.0; |
1275 |
float dist_white, dist_diff, phong, phong_size; |
1276 |
1277 |
1278 |
/* amb = get_ambient (m); */ |
1279 |
1280 |
if (m->self_illum) { |
1281 |
amb = 0.9; |
1282 |
dif = 0.1; |
1283 |
1284 |
1285 |
dist_white = fabs(1.0 - m->specular.red) + |
1286 |
fabs(1.0 - m->specular.green) + |
1287 |
fabs(1.0 - m->specular.blue); |
1288 |
1289 |
dist_diff = fabs(m->diffuse.red - m->specular.red) + |
1290 |
fabs(m->diffuse.green - m->specular.green) + |
1291 |
fabs(m->diffuse.blue - m->specular.blue); |
1292 |
1293 |
1294 |
phong_size = 0.7*m->shininess; |
1295 |
if (phong_size < 1.0) phong_size = 1.0; |
1296 |
1297 |
if (phong_size > 30.0) |
1298 |
phong = 1.0; |
1299 |
else |
1300 |
phong = phong_size/30.0; |
1301 |
1302 |
fprintf (f, "#declare %s = texture {\n", m->name); |
1303 |
fprintf (f, " ambient %.2f\n", amb); |
1304 |
fprintf (f, " diffuse %.2f\n", dif); |
1305 |
fprintf (f, " phong %.2f\n", phong); |
1306 |
fprintf (f, " phong_size %.1f\n", phong_size); |
1307 |
1308 |
if (dist_diff < dist_white) |
1309 |
fprintf (f, " metallic\n"); |
1310 |
1311 |
if (m->reflection > 0.0) { |
1312 |
spec = (m->specular.red + m->specular.green + m->specular.blue)/3.0; |
1313 |
fprintf (f, " reflection %.3f\n", spec * m->reflection); |
1314 |
1315 |
1316 |
if (m->transparency > 0.0) { |
1317 |
red = m->diffuse.red; |
1318 |
green = m->diffuse.green; |
1319 |
blue = m->diffuse.blue; |
1320 |
1321 |
/* Saturate the colour towards white as the transparency increases */ |
1322 |
red = ((1.0 - m->transparency) * red) + m->transparency; |
1323 |
green = ((1.0 - m->transparency) * green) + m->transparency; |
1324 |
blue = ((1.0 - m->transparency) * blue) + m->transparency; |
1325 |
1326 |
fprintf (f, " color red %.3f green %.3f blue %.3f alpha %.3f\n", |
1327 |
red, green, blue, m->transparency); |
1328 |
fprintf (f, " ior 1.1\n"); |
1329 |
fprintf (f, " refraction 1.0\n"); |
1330 |
1331 |
else |
1332 |
fprintf (f, " color red %.3f green %.3f blue %.3f\n", |
1333 |
m->diffuse.red, m->diffuse.green, m->diffuse.blue); |
1334 |
1335 |
if (strlen (m->tex_map) > 0) { |
1336 |
fprintf (f, " /* Image map: %s, Strength: %.2f */\n", |
1337 |
m->tex_map, m->tex_strength); |
1338 |
1339 |
1340 |
if (strlen (m->bump_map) > 0) { |
1341 |
fprintf (f, " /* Bump map: %s, Strength: %.2f */\n", |
1342 |
m->bump_map, m->bump_strength); |
1343 |
1344 |
1345 |
1346 |
1347 |
1348 |
1349 |
void write_pov20_material (FILE *f, MatProp *m) |
1350 |
1351 |
1352 |
1353 |
1354 |
1355 |
1356 |
1357 |
1358 |
amb = 0.9; |
1359 |
dif = 0.1; |
1360 |
1361 |
1362 |
1363 |
1364 |
1365 |
1366 |
1367 |
1368 |
1369 |
1370 |
1371 |
1372 |
1373 |
1374 |
phong = 1.0; |
1375 |
else |
1376 |
1377 |
1378 |
1379 |
fprintf (f, " finish {\n"); |
1380 |
1381 |
1382 |
1383 |
1384 |
1385 |
1386 |
1387 |
1388 |
1389 |
1390 |
1391 |
1392 |
1393 |
1394 |
1395 |
1396 |
1397 |
1398 |
1399 |
1400 |
1401 |
1402 |
1403 |
1404 |
1405 |
1406 |
1407 |
1408 |
1409 |
1410 |
fprintf (f, " pigment { rgbf <%.3f, %.3f, %.3f, %.3f> }\n", |
1411 |
1412 |
1413 |
else |
1414 |
fprintf (f, " pigment { rgb <%.3f, %.3f, %.3f> }\n", |
1415 |
1416 |
1417 |
1418 |
1419 |
1420 |
1421 |
1422 |
1423 |
1424 |
1425 |
1426 |
1427 |
1428 |
1429 |
1430 |
1431 |
void write_vivid_material (FILE *f, MatProp *m) |
1432 |
1433 |
float amb = 0.1, dif = 0.9; |
1434 |
1435 |
1436 |
1437 |
1438 |
amb = 0.9; |
1439 |
dif = 0.1; |
1440 |
1441 |
1442 |
1443 |
dif = dif - m->transparency; |
1444 |
if (dif < 0.0) dif = 0.0; |
1445 |
1446 |
1447 |
fprintf (f, "#define %s \\ \n", m->name); |
1448 |
fprintf (f, " surface { \\ \n"); |
1449 |
fprintf (f, " ambient %.3f %.3f %.3f \\ \n", |
1450 |
amb*m->ambient.red, amb*m->ambient.green, amb*m->ambient.blue); |
1451 |
1452 |
fprintf (f, " diffuse %.3f %.3f %.3f \\ \n", |
1453 |
dif*m->diffuse.red, dif*m->diffuse.green, dif*m->diffuse.blue); |
1454 |
1455 |
fprintf (f, " shine %.1f %.3f %.3f %.3f \\ \n", |
1456 |
0.7*m->shininess, m->specular.red, m->specular.green, m->specular.blue); |
1457 |
1458 |
1459 |
fprintf (f, " transparent %.3f*white \\ \n", 1.0 - (1.0 - m->transparency)/14.0); |
1460 |
fprintf (f, " ior 1.1 \\ \n"); |
1461 |
1462 |
1463 |
if (m->reflection > 0.0) |
1464 |
fprintf (f, " specular %.3f*white \\ \n", m->reflection); |
1465 |
1466 |
1467 |
fprintf (f, " /* Image map: %s, Strength: %.2f */ \\ \n", |
1468 |
1469 |
1470 |
1471 |
1472 |
fprintf (f, " /* Bump map: %s, Strength: %.2f */ \\ \n", |
1473 |
1474 |
1475 |
1476 |
fprintf (f, " }\n\n"); |
1477 |
1478 |
1479 |
1480 |
void write_polyray_material (FILE *f, MatProp *m) |
1481 |
1482 |
float amb = 0.1, dif = 0.9, spec; |
1483 |
1484 |
1485 |
1486 |
1487 |
amb = 0.9; |
1488 |
dif = 0.1; |
1489 |
1490 |
1491 |
1492 |
1493 |
1494 |
1495 |
1496 |
if (m->shininess == 0.0) |
1497 |
m->shininess = 0.1; |
1498 |
1499 |
if (m->shininess > 40.0) |
1500 |
spec = 1.0; |
1501 |
else |
1502 |
spec = m->shininess/40.0; |
1503 |
1504 |
fprintf (f, "define %s\n", m->name); |
1505 |
fprintf (f, "texture {\n"); |
1506 |
fprintf (f, " surface {\n"); |
1507 |
fprintf (f, " ambient <%.3f, %.3f, %.3f>, %.1f\n", |
1508 |
m->ambient.red, m->ambient.green, m->ambient.blue, amb); |
1509 |
1510 |
fprintf (f, " diffuse <%.3f, %.3f, %.3f>, %.1f\n", |
1511 |
m->diffuse.red, m->diffuse.green, m->diffuse.blue, dif); |
1512 |
1513 |
fprintf (f, " specular <%.3f, %.3f, %.3f>, %.2f\n", |
1514 |
m->specular.red, m->specular.green, m->specular.blue, spec); |
1515 |
1516 |
fprintf (f, " microfacet Reitz %.1f\n", 400.0/m->shininess); |
1517 |
1518 |
if (m->transparency > 0.0) |
1519 |
fprintf (f, " transmission %.3f, 1.1\n", m->transparency); |
1520 |
1521 |
1522 |
fprintf (f, " reflection %.3f\n", m->reflection); |
1523 |
1524 |
1525 |
fprintf (f, " // Image map: %s, Strength: %.2f\n", |
1526 |
1527 |
1528 |
1529 |
1530 |
fprintf (f, " // Bump map: %s, Strength: %.2f\n", |
1531 |
1532 |
1533 |
1534 |
1535 |
1536 |
1537 |
1538 |
1539 |
void write_mgf_material (FILE *f, MatProp *m) |
1540 |
1541 |
float dmag, smag, rdmag, rsmag, tdmag, tsmag, total; |
1542 |
1543 |
fprintf (f, "m %s =\n", m->name); |
1544 |
fprintf (f, "\tsides %d\n", m->two_side ? 2 : 1); |
1545 |
dmag = CIE_Y_r*m->diffuse.red + CIE_Y_g*m->diffuse.green |
1546 |
+ CIE_Y_b*m->diffuse.blue; |
1547 |
smag = CIE_Y_r*m->specular.red + CIE_Y_g*m->specular.green |
1548 |
+ CIE_Y_b*m->specular.blue; |
1549 |
rdmag = dmag; |
1550 |
rsmag = smag * m->reflection; |
1551 |
tdmag = 0.0; |
1552 |
tsmag = m->transparency; |
1553 |
total = rdmag + rsmag + tdmag + tsmag; |
1554 |
if (total > 0.99) { |
1555 |
total = 0.9/total; |
1556 |
dmag *= total; |
1557 |
smag *= total; |
1558 |
rdmag *= total; |
1559 |
rsmag *= total; |
1560 |
tdmag *= total; |
1561 |
tsmag *= total; |
1562 |
total = 0.9; |
1563 |
1564 |
if (dmag > 0.005) { |
1565 |
fprintf (f, "\tc\n\t\tcmix %.3f R %.3f G %.3f B\n", |
1566 |
CIE_Y_r*m->diffuse.red, |
1567 |
CIE_Y_g*m->diffuse.green, |
1568 |
CIE_Y_b*m->diffuse.blue); |
1569 |
if (rdmag > 0.005) |
1570 |
fprintf (f, "\trd %.4f\n", rdmag); |
1571 |
if (tdmag > 0.005) |
1572 |
fprintf (f, "\ttd %.4f\n", tdmag); |
1573 |
if (m->self_illum) |
1574 |
fprintf (f, "\ted %.4f\n", dmag); |
1575 |
1576 |
if (m->shininess > 1.1 && rsmag > 0.005) { |
1577 |
1578 |
CIE_Y_r*m->specular.red, |
1579 |
CIE_Y_g*m->specular.green, |
1580 |
CIE_Y_b*m->specular.blue); |
1581 |
fprintf (f, "\trs %.4f %.4f\n", rsmag, 0.6/sqrt(m->shininess)); |
1582 |
1583 |
if (tsmag > 0.005) |
1584 |
fprintf (f, "\tc\n\tts %.4f 0\n", tsmag); |
1585 |
1586 |
1587 |
fprintf (f, "# image map: %s, strength: %.2f\n", |
1588 |
1589 |
1590 |
1591 |
1592 |
fprintf (f, "# bump map: %s, strength: %.2f\n", |
1593 |
1594 |
1595 |
1596 |
1597 |
1598 |
1599 |
1600 |
/* Write a mesh file */ |
1601 |
void write_mesh (FILE *f, Mesh *mesh) |
1602 |
1603 |
int i; |
1604 |
char curmat[80]; |
1605 |
Vector va, vb, vc; |
1606 |
Summary *new_summary; |
1607 |
Matrix obj_matrix; |
1608 |
1609 |
if (mesh->hidden || LIST_FIND (excl_list, mesh->name)) |
1610 |
return; |
1611 |
1612 |
/* Add this object's stats to the summary */ |
1613 |
new_summary = malloc (sizeof(*new_summary)); |
1614 |
if (new_summary == NULL) |
1615 |
abortmsg ("Out of memory adding summary", 1); |
1616 |
1617 |
strcpy (new_summary->name, mesh->name); |
1618 |
vect_copy (new_summary->center, mesh->center); |
1619 |
vect_copy (new_summary->lengths, mesh->lengths); |
1620 |
1621 |
LIST_INSERT (summary, new_summary); |
1622 |
1623 |
/* Compute the object transformation matrix for animations */ |
1624 |
if (ani_matrix != NULL) { |
1625 |
mat_copy (obj_matrix, *ani_matrix); |
1626 |
if (vue_version > 2.0) |
1627 |
mat_mult (obj_matrix, mesh->invmatrix, obj_matrix); |
1628 |
1629 |
1630 |
switch (format) { |
1631 |
case MGF: |
1632 |
if (no_opt) { |
1633 |
if (mesh->name[0]) fprintf (meshf, "o %s\n", mesh->name); |
1634 |
for (i = 0; i < mesh->vertices; i++) { |
1635 |
vect_copy(va, mesh->vertex[i]); |
1636 |
if (ani_matrix != NULL) |
1637 |
vect_transform (va, va, obj_matrix); |
1638 |
fprintf (meshf, "v v%d =\n\tp %.5f %.5f %.5f\n", |
1639 |
i, va[X], va[Y], va[Z]); |
1640 |
1641 |
curmat[0] = '\0'; |
1642 |
for (i = 0; i < mesh->faces; i++) { |
1643 |
if (strcmp(mesh->mtl[i]->name, curmat)) { |
1644 |
strcpy(curmat, mesh->mtl[i]->name); |
1645 |
fprintf (meshf, "m %s\n", curmat); |
1646 |
1647 |
fprintf (meshf, "f v%d v%d v%d\n", mesh->face[i].a, |
1648 |
mesh->face[i].b, mesh->face[i].c); |
1649 |
1650 |
if (mesh->name[0]) fprintf (meshf, "o\n"); |
1651 |
break; |
1652 |
1653 |
/*FALL THROUGH*/ |
1654 |
case POV10: |
1655 |
case POV20: |
1656 |
case VIVID: |
1657 |
case POLYRAY: |
1658 |
opt_set_vert (mesh->vertices); |
1659 |
1660 |
1661 |
vect_copy (va, mesh->vertex[mesh->face[i].a]); |
1662 |
vect_copy (vb, mesh->vertex[mesh->face[i].b]); |
1663 |
vect_copy (vc, mesh->vertex[mesh->face[i].c]); |
1664 |
1665 |
opt_set_texture (mesh->mtl[i]->name); |
1666 |
1667 |
opt_add_tri (va[X], va[Y], va[Z], vc[X], vc[Y], vc[Z], |
1668 |
vb[X], vb[Y], vb[Z]); |
1669 |
1670 |
1671 |
fflush (f); |
1672 |
1673 |
1674 |
opt_set_transform (obj_matrix); |
1675 |
1676 |
if (box_all || LIST_FIND (box_list, mesh->name)) |
1677 |
opt_write_box (mesh->name); |
1678 |
else |
1679 |
opt_write_file (mesh->name); |
1680 |
1681 |
break; |
1682 |
1683 |
case RAW: |
1684 |
fprintf (f, "%s\n", mesh->name); |
1685 |
1686 |
1687 |
1688 |
1689 |
1690 |
1691 |
1692 |
1693 |
vect_transform (vb, vb, obj_matrix); |
1694 |
vect_transform (vc, vc, obj_matrix); |
1695 |
1696 |
1697 |
fprintf (f, "%f %f %f %f %f %f %f %f %f\n", |
1698 |
va[X], va[Y], va[Z], vb[X], vb[Y], vb[Z], |
1699 |
vc[X], vc[Y], vc[Z]); |
1700 |
1701 |
1702 |
break; |
1703 |
1704 |
1705 |
1706 |
1707 |
/* Parses an object transformation and returns a pointer to the |
1708 |
newly allocated transformation */ |
1709 |
Transform *parse_transform (char *string) |
1710 |
1711 |
Transform *t; |
1712 |
char *token; |
1713 |
int token_no; |
1714 |
1715 |
t = (Transform *)malloc (sizeof(*t)); |
1716 |
if (t == NULL) |
1717 |
abortmsg ("Out of memory allocating transform", 1); |
1718 |
1719 |
mat_identity (t->matrix); |
1720 |
1721 |
token = parse_string (string); |
1722 |
token_no = 0; |
1723 |
1724 |
while (strlen(token) > 0) { |
1725 |
switch (token_no) { |
1726 |
case 0: break; |
1727 |
case 1: strcpy (t->name, token); break; |
1728 |
case 2: t->matrix[0][0] = atof(token); break; |
1729 |
case 3: t->matrix[0][1] = atof(token); break; |
1730 |
case 4: t->matrix[0][2] = atof(token); break; |
1731 |
case 5: t->matrix[1][0] = atof(token); break; |
1732 |
case 6: t->matrix[1][1] = atof(token); break; |
1733 |
case 7: t->matrix[1][2] = atof(token); break; |
1734 |
case 8: t->matrix[2][0] = atof(token); break; |
1735 |
case 9: t->matrix[2][1] = atof(token); break; |
1736 |
case 10: t->matrix[2][2] = atof(token); break; |
1737 |
case 11: t->matrix[3][0] = atof(token); break; |
1738 |
case 12: t->matrix[3][1] = atof(token); break; |
1739 |
case 13: t->matrix[3][2] = atof(token); break; |
1740 |
1741 |
default: abortmsg ("Error parsing transform", 1); |
1742 |
1743 |
1744 |
token = parse_string (NULL); |
1745 |
token_no++; |
1746 |
1747 |
1748 |
t->matrix[0][3] = 0.0; |
1749 |
t->matrix[1][3] = 0.0; |
1750 |
t->matrix[2][3] = 0.0; |
1751 |
t->matrix[3][3] = 1.0; |
1752 |
1753 |
cleanup_name (t->name); |
1754 |
1755 |
return t; |
1756 |
1757 |
1758 |
1759 |
/* Parses a morph command and returns a pointer to the |
1760 |
newly allocated morph */ |
1761 |
Morph *parse_morph (char *string) |
1762 |
1763 |
Morph *m; |
1764 |
char *token; |
1765 |
int i, token_no; |
1766 |
1767 |
m = (Morph *)malloc (sizeof(*m)); |
1768 |
if (m == NULL) |
1769 |
abortmsg ("Out of memory allocating morph", 1); |
1770 |
1771 |
mat_identity (m->matrix); |
1772 |
1773 |
1774 |
1775 |
1776 |
strcpy (m->name, token); |
1777 |
1778 |
1779 |
m->count = atoi (token); |
1780 |
1781 |
if (strlen (m->name) == 0 || m->count < 1 || m->count > 4) |
1782 |
abortmsg ("Error parsing morph command", 1); |
1783 |
1784 |
cleanup_name (m->name); |
1785 |
1786 |
for (i = 0; i < m->count; i++) { |
1787 |
1788 |
strcpy (m->names[i], token); |
1789 |
1790 |
1791 |
m->weight[i] = atof (token); |
1792 |
1793 |
if (strlen (m->names[i]) == 0) |
1794 |
1795 |
1796 |
cleanup_name (m->names[i]); |
1797 |
1798 |
1799 |
1800 |
token_no = 0; |
1801 |
1802 |
1803 |
1804 |
case 0: m->matrix[0][0] = atof(token); break; |
1805 |
case 1: m->matrix[0][1] = atof(token); break; |
1806 |
case 2: m->matrix[0][2] = atof(token); break; |
1807 |
case 3: m->matrix[1][0] = atof(token); break; |
1808 |
case 4: m->matrix[1][1] = atof(token); break; |
1809 |
case 5: m->matrix[1][2] = atof(token); break; |
1810 |
case 6: m->matrix[2][0] = atof(token); break; |
1811 |
case 7: m->matrix[2][1] = atof(token); break; |
1812 |
case 8: m->matrix[2][2] = atof(token); break; |
1813 |
case 9: m->matrix[3][0] = atof(token); break; |
1814 |
case 10: m->matrix[3][1] = atof(token); break; |
1815 |
case 11: m->matrix[3][2] = atof(token); break; |
1816 |
1817 |
default: abortmsg ("Error parsing morph command", 1); |
1818 |
1819 |
1820 |
1821 |
token_no++; |
1822 |
1823 |
1824 |
m->matrix[0][3] = 0.0; |
1825 |
m->matrix[1][3] = 0.0; |
1826 |
m->matrix[2][3] = 0.0; |
1827 |
m->matrix[3][3] = 1.0; |
1828 |
1829 |
return m; |
1830 |
1831 |
1832 |
1833 |
/* Parses an omni light and returns a pointer to the |
1834 |
newly allocated light */ |
1835 |
OmniLight *parse_omnilight (char *string) |
1836 |
1837 |
OmniLight *o; |
1838 |
char *token; |
1839 |
int token_no; |
1840 |
1841 |
o = (OmniLight *)malloc (sizeof(*o)); |
1842 |
if (o == NULL) |
1843 |
abortmsg ("Out of memory allocating omnilight", 1); |
1844 |
1845 |
1846 |
token_no = 0; |
1847 |
1848 |
1849 |
1850 |
case 0: break; |
1851 |
case 1: strcpy (o->name, token); break; |
1852 |
case 2: o->pos[X] = atof (token); break; |
1853 |
case 3: o->pos[Y] = atof (token); break; |
1854 |
case 4: o->pos[Z] = atof (token); break; |
1855 |
case 5: o->col.red = atof (token); break; |
1856 |
case 6: o->col.green = atof (token); break; |
1857 |
case 7: o->col.blue = atof (token); break; |
1858 |
1859 |
default: abortmsg ("Error parsing omnilight", 1); |
1860 |
1861 |
1862 |
1863 |
token_no++; |
1864 |
1865 |
1866 |
cleanup_name (o->name); |
1867 |
1868 |
return o; |
1869 |
1870 |
1871 |
1872 |
/* Parses a spotlight and returns a pointer to the |
1873 |
newly allocated spotlight */ |
1874 |
Spotlight *parse_spotlight (char *string) |
1875 |
1876 |
Spotlight *s; |
1877 |
char *token; |
1878 |
int token_no; |
1879 |
1880 |
s = (Spotlight *)malloc (sizeof(*s)); |
1881 |
if (s == NULL) |
1882 |
abortmsg ("Out of memory allocating spotlight", 1); |
1883 |
1884 |
1885 |
token_no = 0; |
1886 |
1887 |
1888 |
1889 |
case 0: break; |
1890 |
case 1: strcpy (s->name, token); break; |
1891 |
case 2: s->pos[X] = atof (token); break; |
1892 |
case 3: s->pos[Y] = atof (token); break; |
1893 |
case 4: s->pos[Z] = atof (token); break; |
1894 |
case 5: s->target[X] = atof (token); break; |
1895 |
case 6: s->target[Y] = atof (token); break; |
1896 |
case 7: s->target[Z] = atof (token); break; |
1897 |
case 8: s->col.red = atof (token); break; |
1898 |
case 9: s->col.green = atof (token); break; |
1899 |
case 10: s->col.blue = atof (token); break; |
1900 |
case 11: s->hotspot = atof (token); break; |
1901 |
case 12: s->falloff = atof (token); break; |
1902 |
case 13: break; |
1903 |
1904 |
default: abortmsg ("Error parsing spotlight", 1); |
1905 |
1906 |
1907 |
1908 |
token_no++; |
1909 |
1910 |
1911 |
cleanup_name (s->name); |
1912 |
1913 |
return s; |
1914 |
1915 |
1916 |
1917 |
/* Parses a camera command and returns a pointer to the |
1918 |
newly allocated camera */ |
1919 |
Camera *parse_camera (char *string) |
1920 |
1921 |
Camera *c; |
1922 |
char *token; |
1923 |
int token_no; |
1924 |
1925 |
c = (Camera *)malloc (sizeof(*c)); |
1926 |
if (c == NULL) |
1927 |
abortmsg ("Out of memory allocating camera", 1); |
1928 |
1929 |
1930 |
token_no = 0; |
1931 |
1932 |
1933 |
1934 |
case 0: break; |
1935 |
case 1: c->pos[X] = atof (token); break; |
1936 |
case 2: c->pos[Y] = atof (token); break; |
1937 |
case 3: c->pos[Z] = atof (token); break; |
1938 |
case 4: c->target[X] = atof (token); break; |
1939 |
case 5: c->target[Y] = atof (token); break; |
1940 |
case 6: c->target[Z] = atof (token); break; |
1941 |
case 7: c->bank = atof (token); break; |
1942 |
case 8: c->lens = atof (token); break; |
1943 |
1944 |
default: abortmsg ("Error parsing camera", 1); |
1945 |
1946 |
1947 |
1948 |
token_no++; |
1949 |
1950 |
1951 |
return c; |
1952 |
1953 |
1954 |
1955 |
/* Load the transforms, camera movements, etc for the specified frame */ |
1956 |
void read_frame (char *filename, int frame_no) |
1957 |
1958 |
FILE *f; |
1959 |
char fname[80]; |
1960 |
char string[256]; |
1961 |
char *token; |
1962 |
1963 |
/* Open the .vue file */ |
1964 |
strcpy (fname, filename); /* Make a copy we can mess with */ |
1965 |
add_ext (fname, "vue", 0); |
1966 |
1967 |
f = fopen (fname, "r"); |
1968 |
if (f == NULL) { |
1969 |
printf ("Error opening file '%s'\n", fname); |
1970 |
exit(1); |
1971 |
1972 |
1973 |
/* Load the specified frame */ |
1974 |
find_frame (f, frame_no); |
1975 |
1976 |
while (fgets (string, 256, f) != NULL) { |
1977 |
1978 |
1979 |
if (strcmp (token, "frame") == 0) |
1980 |
break; |
1981 |
else if (strcmp (token, "transform") == 0) { |
1982 |
LIST_INSERT (trans_list, parse_transform (string)); |
1983 |
1984 |
else if (strcmp (token, "morph") == 0) { |
1985 |
LIST_INSERT (morph_list, parse_morph (string)); |
1986 |
1987 |
else if (strcmp (token, "light") == 0) { |
1988 |
LIST_INSERT (omni_list, parse_omnilight (string)); |
1989 |
1990 |
else if (strcmp (token, "spotlight") == 0) { |
1991 |
LIST_INSERT (spot_list, parse_spotlight (string)); |
1992 |
1993 |
else if (strcmp (token, "camera") == 0) { |
1994 |
if (cam_list != NULL) |
1995 |
abortmsg ("ERROR - Multiple cameras in .vue file", 1); |
1996 |
1997 |
LIST_INSERT (cam_list, parse_camera (string)); |
1998 |
1999 |
else if (strcmp (token, "top") == 0) |
2000 |
abortmsg ("ERROR - Orthogonal viewports are not supported", 1); |
2001 |
else if (strcmp (token, "bottom") == 0) |
2002 |
2003 |
else if (strcmp (token, "left") == 0) |
2004 |
2005 |
else if (strcmp (token, "right") == 0) |
2006 |
2007 |
else if (strcmp (token, "front") == 0) |
2008 |
2009 |
else if (strcmp (token, "back") == 0) |
2010 |
2011 |
else if (strcmp (token, "user") == 0) |
2012 |
abortmsg ("ERROR - User viewports are not supported", 1); |
2013 |
2014 |
2015 |
fclose(f); |
2016 |
2017 |
2018 |
2019 |
void find_frame (FILE *f, int frame_no) |
2020 |
2021 |
char string[256]; |
2022 |
char *token; |
2023 |
int frame = 0; |
2024 |
2025 |
/* Search the .vue file for the required frame */ |
2026 |
while (1) { |
2027 |
/* Read the next line in the file */ |
2028 |
if (fgets (string, 256, f) == NULL) { |
2029 |
printf ("Unable to locate frame #%d in .vue file\n", frame_no); |
2030 |
exit(1); |
2031 |
2032 |
2033 |
2034 |
2035 |
if (strcmp (token, "frame") == 0) { |
2036 |
2037 |
2038 |
if (strlen(token) == 0) { |
2039 |
2040 |
exit(1); |
2041 |
2042 |
2043 |
frame = atoi (token); |
2044 |
2045 |
if (frame == frame_no) |
2046 |
break; |
2047 |
2048 |
else if (strcmp (token, "VERSION") == 0) { |
2049 |
2050 |
2051 |
vue_version = atoi(token) / 100.0; |
2052 |
2053 |
2054 |
2055 |
2056 |
2057 |
void save_animation() |
2058 |
2059 |
Mesh *mesh, *master; |
2060 |
Transform *t; |
2061 |
Morph *m; |
2062 |
Vector temp; |
2063 |
int i, j; |
2064 |
2065 |
printf ("\n"); |
2066 |
2067 |
for (t = trans_list; t != NULL; t = t->next) { |
2068 |
printf ("Transforming object: %s\n", t->name); |
2069 |
2070 |
ani_matrix = &(t->matrix); |
2071 |
2072 |
mesh = LIST_FIND (mesh_list, t->name); |
2073 |
2074 |
if (mesh == NULL) { |
2075 |
printf ("Unable to locate mesh object %s\n", t->name); |
2076 |
exit(1); |
2077 |
2078 |
2079 |
write_mesh (out, mesh); |
2080 |
2081 |
2082 |
for (m = morph_list; m != NULL; m = m->next) { |
2083 |
printf ("Morphing object: %s\n", m->name); |
2084 |
2085 |
ani_matrix = &(m->matrix); |
2086 |
2087 |
mesh = LIST_FIND (mesh_list, m->name); |
2088 |
2089 |
printf ("Unable to locate mesh object %s\n", m->name); |
2090 |
exit(1); |
2091 |
2092 |
2093 |
/* Make a copy to mess with */ |
2094 |
master = copy_mesh (mesh); |
2095 |
master->hidden = FALSE; |
2096 |
2097 |
strcpy (master->name, m->name); |
2098 |
2099 |
for (i = 0; i < master->vertices; i++) |
2100 |
vect_init (master->vertex[i], 0.0, 0.0, 0.0); |
2101 |
2102 |
2103 |
mesh = LIST_FIND (mesh_list, m->names[i]); |
2104 |
2105 |
printf ("Unable to locate mesh object %s\n", m->names[0]); |
2106 |
exit(1); |
2107 |
2108 |
2109 |
if (mesh->vertices != master->vertices) |
2110 |
abortmsg ("Morphed objects do not contain the same number of vertices", 1); |
2111 |
2112 |
if (mesh->faces != master->faces) |
2113 |
abortmsg ("Morphed objects do not contain the same number of faces", 1); |
2114 |
2115 |
for (j = 0; j < master->vertices; j++) { |
2116 |
vect_transform (temp, mesh->vertex[j], mesh->invmatrix); |
2117 |
vect_scale (temp, temp, m->weight[i]); |
2118 |
vect_add (master->vertex[j], master->vertex[j], temp); |
2119 |
2120 |
2121 |
2122 |
2123 |
vect_transform (master->vertex[i], master->vertex[i], master->matrix); |
2124 |
2125 |
write_mesh (out, master); |
2126 |
2127 |
free_mesh_data (master); |
2128 |
free (master); |
2129 |
2130 |
2131 |
for (mesh = mesh_list; mesh != NULL; mesh = mesh->next) |
2132 |
free_mesh_data (mesh); |
2133 |
2134 |
2135 |
2136 |
/* Create a new mesh */ |
2137 |
Mesh *create_mesh (char *name, int vertices, int faces) |
2138 |
2139 |
Mesh *new_mesh; |
2140 |
2141 |
new_mesh = malloc (sizeof(*new_mesh)); |
2142 |
if (new_mesh == NULL) |
2143 |
abortmsg ("Out of memory allocating mesh", 1); |
2144 |
2145 |
strcpy (new_mesh->name, name); |
2146 |
2147 |
new_mesh->vertices = vertices; |
2148 |
2149 |
if (vertices <= 0) |
2150 |
new_mesh->vertex = NULL; |
2151 |
else { |
2152 |
new_mesh->vertex = malloc (vertices * sizeof(*new_mesh->vertex)); |
2153 |
if (new_mesh->vertex == NULL) |
2154 |
2155 |
2156 |
2157 |
new_mesh->faces = faces; |
2158 |
2159 |
if (faces <= 0) { |
2160 |
new_mesh->face = NULL; |
2161 |
new_mesh->mtl = NULL; |
2162 |
2163 |
else { |
2164 |
new_mesh->face = malloc (faces * sizeof(*new_mesh->face)); |
2165 |
if (new_mesh->face == NULL) |
2166 |
2167 |
2168 |
new_mesh->mtl = malloc (faces * sizeof(*new_mesh->mtl)); |
2169 |
if (new_mesh->mtl == NULL) |
2170 |
2171 |
2172 |
2173 |
vect_init (new_mesh->center, 0.0, 0.0, 0.0); |
2174 |
vect_init (new_mesh->lengths, 0.0, 0.0, 0.0); |
2175 |
2176 |
mat_identity (new_mesh->matrix); |
2177 |
mat_identity (new_mesh->invmatrix); |
2178 |
2179 |
new_mesh->hidden = FALSE; |
2180 |
new_mesh->shadow = TRUE; |
2181 |
2182 |
return new_mesh; |
2183 |
2184 |
2185 |
2186 |
/* Creates a duplicate copy of a mesh */ |
2187 |
Mesh *copy_mesh (Mesh *mesh) |
2188 |
2189 |
Mesh *new_mesh; |
2190 |
int i; |
2191 |
2192 |
new_mesh = create_mesh (mesh->name, mesh->vertices, mesh->faces); |
2193 |
2194 |
2195 |
2196 |
2197 |
for (i = 0; i < mesh->vertices; i++) |
2198 |
vect_copy (new_mesh->vertex[i], mesh->vertex[i]); |
2199 |
2200 |
2201 |
new_mesh->face[i] = mesh->face[i]; |
2202 |
new_mesh->mtl[i] = mesh->mtl[i]; |
2203 |
2204 |
2205 |
mat_copy (new_mesh->matrix, mesh->matrix); |
2206 |
mat_copy (new_mesh->invmatrix, mesh->invmatrix); |
2207 |
2208 |
vect_copy (new_mesh->center, mesh->center); |
2209 |
vect_copy (new_mesh->lengths, mesh->lengths); |
2210 |
2211 |
new_mesh->hidden = mesh->hidden; |
2212 |
new_mesh->shadow = mesh->shadow; |
2213 |
2214 |
return new_mesh; |
2215 |
2216 |
2217 |
2218 |
/* Free all data associated with mesh object */ |
2219 |
void free_mesh_data (Mesh *mesh) |
2220 |
2221 |
if (mesh->vertex != NULL) |
2222 |
free (mesh->vertex); |
2223 |
2224 |
if (mesh->face != NULL) |
2225 |
free (mesh->face); |
2226 |
2227 |
if (mesh->mtl != NULL) |
2228 |
free (mesh->mtl); |
2229 |
2230 |
2231 |
2232 |
/* Updates the center (pivot) point of the mesh */ |
2233 |
void update_limits (Mesh *mesh) |
2234 |
2235 |
Vector vmin = {+MAXFLOAT, +MAXFLOAT, +MAXFLOAT}; |
2236 |
Vector vmax = {-MAXFLOAT, -MAXFLOAT, -MAXFLOAT}; |
2237 |
int i; |
2238 |
2239 |
2240 |
vect_min (vmin, vmin, mesh->vertex[i]); |
2241 |
vect_max (vmax, vmax, mesh->vertex[i]); |
2242 |
2243 |
2244 |
vect_add (mesh->center, vmin, vmax); |
2245 |
vect_scale (mesh->center, mesh->center, 0.5); |
2246 |
2247 |
vect_sub (mesh->lengths, vmax, vmin); |
2248 |
2249 |
2250 |
2251 |
/* Return the sub-string of 'str' that is before 'target' */ |
2252 |
char *before (char *str, char *target) |
2253 |
2254 |
static char result[256]; |
2255 |
char *search; |
2256 |
2257 |
strncpy (result, str, 256); |
2258 |
result[255] = '\0'; |
2259 |
2260 |
search = strstr (result, target); |
2261 |
2262 |
if (search != NULL) |
2263 |
*search = '\0'; |
2264 |
2265 |
return result; |
2266 |
2267 |
2268 |
2269 |
/* Return the sub-string of 'str' that is after 'target' */ |
2270 |
char *after (char *str, char *target) |
2271 |
2272 |
2273 |
char *search; |
2274 |
2275 |
search = strstr (str, target); |
2276 |
2277 |
if (search == NULL) |
2278 |
strncpy (result, "", 256); |
2279 |
else |
2280 |
strncpy (result, search + strlen(target), 256); |
2281 |
2282 |
2283 |
2284 |
return result; |
2285 |
2286 |
2287 |
2288 |
/* Return the sub-string of 'str' that is between 'target1' and 'target2' */ |
2289 |
char *between (char *str, char *target1, char *target2) |
2290 |
2291 |
2292 |
2293 |
strcpy (result, after (str, target1)); |
2294 |
strcpy (result, before (result, target2)); |
2295 |
2296 |
return result; |
2297 |
2298 |
2299 |
2300 |
/* Works like the C strtok() function except that it can handle */ |
2301 |
/* tokens enclosed in double quotes */ |
2302 |
char *parse_string (char *str) |
2303 |
2304 |
2305 |
static char *p; |
2306 |
char QUOTE = '\"'; |
2307 |
int index; |
2308 |
2309 |
strcpy (result, ""); |
2310 |
index = 0; |
2311 |
2312 |
if (str != NULL) |
2313 |
p = str; |
2314 |
2315 |
/* Find the start of the next token */ |
2316 |
while (isspace (*p)) |
2317 |
p++; |
2318 |
2319 |
if (*p == QUOTE) { |
2320 |
p++; |
2321 |
2322 |
while (*p != '\0' && *p != QUOTE) |
2323 |
result[index++] = *p++; |
2324 |
2325 |
if (*p == QUOTE) |
2326 |
p++; |
2327 |
2328 |
else { |
2329 |
while (*p != '\0' && !isspace(*p)) |
2330 |
2331 |
2332 |
2333 |
result[index] = '\0'; |
2334 |
2335 |
return result; |
2336 |
2337 |
2338 |
2339 |
/* Convert character 'c' to upper case */ |
2340 |
char upcase (char c) |
2341 |
2342 |
if (c >= 'a' && c <= 'z') |
2343 |
c = c - 'a' + 'A'; |
2344 |
2345 |
return c; |
2346 |
2347 |
2348 |
2349 |
float colour_intens (Colour *colour) |
2350 |
2351 |
return sqrt (colour->red * colour->red + |
2352 |
colour->green * colour->green + |
2353 |
colour->blue * colour->blue); |
2354 |
2355 |
2356 |
2357 |
void parse_file() |
2358 |
2359 |
Chunk chunk; |
2360 |
2361 |
start_chunk(&chunk); |
2362 |
2363 |
if (chunk.tag == 0x4D4D) |
2364 |
parse_3ds (&chunk); |
2365 |
else |
2366 |
abortmsg ("Error: Input file is not .3DS format", 1); |
2367 |
2368 |
end_chunk (&chunk); |
2369 |
2370 |
2371 |
2372 |
void parse_3ds (Chunk *mainchunk) |
2373 |
2374 |
Chunk chunk; |
2375 |
2376 |
do { |
2377 |
start_chunk (&chunk); |
2378 |
if (feof(in)) { |
2379 |
fprintf(stderr, "%s: unexpected EOF\n", progname); |
2380 |
break; |
2381 |
2382 |
if (chunk.end <= mainchunk->end) { |
2383 |
switch (chunk.tag) { |
2384 |
case 0x3D3D: parse_mdata (&chunk); |
2385 |
break; |
2386 |
2387 |
2388 |
2389 |
2390 |
} while (chunk.end <= mainchunk->end); |
2391 |
2392 |
2393 |
2394 |
void parse_mdata (Chunk *mainchunk) |
2395 |
2396 |
Chunk chunk; |
2397 |
Colour bgnd_colour; |
2398 |
2399 |
do { |
2400 |
2401 |
2402 |
2403 |
2404 |
case 0x2100: parse_colour (&global_amb); |
2405 |
break; |
2406 |
case 0x1200: parse_colour (&bgnd_colour); |
2407 |
break; |
2408 |
case 0x1201: write_bgsolid (out, bgnd_colour); |
2409 |
break; |
2410 |
case 0x2200: parse_fog (&chunk); |
2411 |
break; |
2412 |
case 0x2210: parse_fog_bgnd(); |
2413 |
break; |
2414 |
case 0x2201: write_fog (out, fog_colour, fog_distance); |
2415 |
break; |
2416 |
case 0xAFFF: parse_mat_entry (&chunk); |
2417 |
break; |
2418 |
case 0x4000: parse_named_object (&chunk); |
2419 |
break; |
2420 |
2421 |
2422 |
2423 |
2424 |
2425 |
2426 |
2427 |
2428 |
void parse_fog (Chunk *mainchunk) |
2429 |
2430 |
Chunk chunk; |
2431 |
2432 |
(void)read_float(); |
2433 |
2434 |
fog_distance = read_float(); |
2435 |
2436 |
2437 |
parse_colour (&fog_colour); |
2438 |
2439 |
do { |
2440 |
2441 |
2442 |
2443 |
2444 |
2445 |
break; |
2446 |
2447 |
2448 |
2449 |
2450 |
2451 |
2452 |
2453 |
2454 |
void parse_fog_bgnd() |
2455 |
2456 |
2457 |
2458 |
2459 |
2460 |
void parse_mat_entry (Chunk *mainchunk) |
2461 |
2462 |
Chunk chunk; |
2463 |
MatProp *mprop; |
2464 |
2465 |
mprop = create_mprop(); |
2466 |
2467 |
do { |
2468 |
2469 |
2470 |
2471 |
2472 |
case 0xA000: strcpy (mprop->name, read_string()); |
2473 |
cleanup_name (mprop->name); |
2474 |
break; |
2475 |
2476 |
case 0xA010: parse_colour (&mprop->ambient); |
2477 |
break; |
2478 |
2479 |
case 0xA020: parse_colour (&mprop->diffuse); |
2480 |
break; |
2481 |
2482 |
case 0xA030: parse_colour (&mprop->specular); |
2483 |
break; |
2484 |
2485 |
case 0xA040: mprop->shininess = 100.0*parse_percentage(); |
2486 |
break; |
2487 |
2488 |
case 0xA050: mprop->transparency = parse_percentage(); |
2489 |
break; |
2490 |
2491 |
case 0xA080: mprop->self_illum = TRUE; |
2492 |
break; |
2493 |
2494 |
case 0xA081: mprop->two_side = TRUE; |
2495 |
break; |
2496 |
2497 |
case 0xA220: mprop->reflection = parse_percentage(); |
2498 |
(void)parse_mapname (&chunk); |
2499 |
break; |
2500 |
2501 |
case 0xA310: if (mprop->reflection == 0.0) |
2502 |
mprop->reflection = 1.0; |
2503 |
break; |
2504 |
2505 |
case 0xA200: mprop->tex_strength = parse_percentage(); |
2506 |
strcpy (mprop->tex_map, parse_mapname (&chunk)); |
2507 |
break; |
2508 |
2509 |
case 0xA230: mprop->bump_strength = parse_percentage(); |
2510 |
strcpy (mprop->bump_map, parse_mapname (&chunk)); |
2511 |
break; |
2512 |
2513 |
2514 |
2515 |
2516 |
2517 |
2518 |
LIST_INSERT (mprop_list, mprop); |
2519 |
2520 |
2521 |
2522 |
char *parse_mapname (Chunk *mainchunk) |
2523 |
2524 |
static char name[80] = ""; |
2525 |
Chunk chunk; |
2526 |
2527 |
do { |
2528 |
2529 |
2530 |
2531 |
2532 |
case 0xA300: strcpy (name, read_string()); |
2533 |
break; |
2534 |
2535 |
2536 |
2537 |
2538 |
2539 |
2540 |
return name; |
2541 |
2542 |
2543 |
2544 |
void parse_named_object (Chunk *mainchunk) |
2545 |
2546 |
Chunk chunk; |
2547 |
2548 |
strcpy (obj_name, read_string()); |
2549 |
cleanup_name (obj_name); |
2550 |
2551 |
printf ("Working on: %s\n", obj_name); |
2552 |
2553 |
mesh = NULL; |
2554 |
2555 |
do { |
2556 |
2557 |
2558 |
2559 |
2560 |
case 0x4100: parse_n_tri_object (&chunk); |
2561 |
break; |
2562 |
case 0x4600: parse_n_direct_light (&chunk); |
2563 |
break; |
2564 |
case 0x4700: parse_n_camera(); |
2565 |
break; |
2566 |
case 0x4010: if (mesh != NULL) mesh->hidden = TRUE; |
2567 |
break; |
2568 |
case 0x4012: if (mesh != NULL) mesh->shadow = FALSE; |
2569 |
break; |
2570 |
2571 |
2572 |
2573 |
2574 |
2575 |
2576 |
if (mesh != NULL) { |
2577 |
update_limits (mesh); |
2578 |
2579 |
if (frame >= 0) |
2580 |
LIST_INSERT (mesh_list, mesh); |
2581 |
else { |
2582 |
2583 |
2584 |
2585 |
free (mesh); |
2586 |
2587 |
2588 |
2589 |
2590 |
2591 |
void parse_n_tri_object (Chunk *mainchunk) |
2592 |
2593 |
Chunk chunk; |
2594 |
2595 |
mesh = create_mesh (obj_name, 0, 0); |
2596 |
2597 |
do { |
2598 |
2599 |
2600 |
2601 |
2602 |
case 0x4110: parse_point_array(); |
2603 |
break; |
2604 |
case 0x4120: parse_face_array (&chunk); |
2605 |
break; |
2606 |
case 0x4160: parse_mesh_matrix(); |
2607 |
break; |
2608 |
2609 |
2610 |
2611 |
2612 |
2613 |
2614 |
2615 |
2616 |
void parse_point_array() |
2617 |
2618 |
int i; |
2619 |
2620 |
mesh->vertices = read_word(); |
2621 |
mesh->vertex = malloc (mesh->vertices * sizeof(*(mesh->vertex))); |
2622 |
if (mesh->vertex == NULL) |
2623 |
2624 |
2625 |
2626 |
read_point (mesh->vertex[i]); |
2627 |
2628 |
2629 |
2630 |
void parse_face_array (Chunk *mainchunk) |
2631 |
2632 |
Chunk chunk; |
2633 |
int i; |
2634 |
2635 |
mesh->faces = read_word(); |
2636 |
mesh->face = malloc (mesh->faces * sizeof(*(mesh->face))); |
2637 |
if (mesh->face == NULL) |
2638 |
2639 |
2640 |
mesh->mtl = malloc (mesh->faces * sizeof(*(mesh->mtl))); |
2641 |
if (mesh->mtl == NULL) |
2642 |
2643 |
2644 |
2645 |
mesh->face[i].a = read_word(); |
2646 |
mesh->face[i].b = read_word(); |
2647 |
mesh->face[i].c = read_word(); |
2648 |
(void)read_word(); |
2649 |
2650 |
mesh->mtl[i] = NULL; |
2651 |
2652 |
2653 |
do { |
2654 |
2655 |
2656 |
2657 |
2658 |
case 0x4130: parse_msh_mat_group(); |
2659 |
break; |
2660 |
case 0x4150: parse_smooth_group(); |
2661 |
break; |
2662 |
2663 |
2664 |
2665 |
2666 |
2667 |
2668 |
2669 |
if (mesh->mtl[i] == NULL) |
2670 |
mesh->mtl[i] = update_materials ("Default", 0); |
2671 |
2672 |
2673 |
2674 |
2675 |
void parse_msh_mat_group() |
2676 |
2677 |
Material *new_mtl; |
2678 |
char mtlname[80]; |
2679 |
int mtlcnt; |
2680 |
int i, face; |
2681 |
2682 |
strcpy (mtlname, read_string()); |
2683 |
cleanup_name (mtlname); |
2684 |
2685 |
new_mtl = update_materials (mtlname, 0); |
2686 |
2687 |
mtlcnt = read_word(); |
2688 |
2689 |
for (i = 0; i < mtlcnt; i++) { |
2690 |
face = read_word(); |
2691 |
mesh->mtl[face] = new_mtl; |
2692 |
2693 |
2694 |
2695 |
2696 |
void parse_smooth_group() |
2697 |
2698 |
2699 |
2700 |
2701 |
2702 |
void parse_mesh_matrix() |
2703 |
2704 |
int i, j; |
2705 |
2706 |
2707 |
for (i = 0; i < 4; i++) { |
2708 |
for (j = 0; j < 3; j++) |
2709 |
mesh->matrix[i][j] = read_float(); |
2710 |
2711 |
2712 |
mat_inv (mesh->invmatrix, mesh->matrix); |
2713 |
2714 |
2715 |
2716 |
2717 |
void parse_n_direct_light (Chunk *mainchunk) |
2718 |
2719 |
Chunk chunk; |
2720 |
Spotlight *s; |
2721 |
OmniLight *o; |
2722 |
int light_off = FALSE; |
2723 |
int spot_flag = FALSE; |
2724 |
2725 |
read_point (pos); |
2726 |
parse_colour (&col); |
2727 |
2728 |
do { |
2729 |
2730 |
2731 |
2732 |
2733 |
case 0x4620: light_off = TRUE; |
2734 |
break; |
2735 |
case 0x4610: parse_dl_spotlight(); |
2736 |
spot_flag = TRUE; |
2737 |
break; |
2738 |
2739 |
2740 |
2741 |
2742 |
2743 |
2744 |
if (light_off) |
2745 |
return; |
2746 |
2747 |
if (!spot_flag) { |
2748 |
if (frame >= 0) { |
2749 |
o = LIST_FIND (omni_list, obj_name); |
2750 |
2751 |
if (o != NULL) { |
2752 |
pos[X] = o->pos[X]; |
2753 |
pos[Y] = o->pos[Y]; |
2754 |
pos[Z] = o->pos[Z]; |
2755 |
col = o->col; |
2756 |
2757 |
2758 |
2759 |
write_light (out, obj_name, pos, col); |
2760 |
2761 |
else { |
2762 |
if (frame >= 0) { |
2763 |
s = LIST_FIND (spot_list, obj_name); |
2764 |
2765 |
if (s != NULL) { |
2766 |
pos[X] = s->pos[X]; |
2767 |
pos[Y] = s->pos[Y]; |
2768 |
pos[Z] = s->pos[Z]; |
2769 |
target[X] = s->target[X]; |
2770 |
target[Y] = s->target[Y]; |
2771 |
target[Z] = s->target[Z]; |
2772 |
col = s->col; |
2773 |
hotspot = s->hotspot; |
2774 |
falloff = s->falloff; |
2775 |
2776 |
2777 |
2778 |
if (falloff <= 0.0) |
2779 |
falloff = 180.0; |
2780 |
2781 |
if (hotspot <= 0.0) |
2782 |
hotspot = 0.7*falloff; |
2783 |
2784 |
write_spot (out, obj_name, pos, target, col, hotspot, falloff); |
2785 |
2786 |
2787 |
2788 |
2789 |
void parse_dl_spotlight() |
2790 |
2791 |
read_point (target); |
2792 |
2793 |
hotspot = read_float(); |
2794 |
falloff = read_float(); |
2795 |
2796 |
2797 |
2798 |
void parse_n_camera() |
2799 |
2800 |
float bank; |
2801 |
float lens; |
2802 |
2803 |
read_point (pos); |
2804 |
2805 |
bank = read_float(); |
2806 |
lens = read_float(); |
2807 |
2808 |
if (frame >= 0 && cam_list != NULL) { |
2809 |
pos[X] = cam_list->pos[X]; |
2810 |
pos[Y] = cam_list->pos[Y]; |
2811 |
pos[Z] = cam_list->pos[Z]; |
2812 |
target[X] = cam_list->target[X]; |
2813 |
target[Y] = cam_list->target[Y]; |
2814 |
target[Z] = cam_list->target[Z]; |
2815 |
lens = cam_list->lens; |
2816 |
bank = cam_list->bank; |
2817 |
2818 |
2819 |
write_camera (out, obj_name, pos, target, lens, bank); |
2820 |
2821 |
2822 |
2823 |
void parse_colour (Colour *colour) |
2824 |
2825 |
Chunk chunk; |
2826 |
Colour_24 colour_24; |
2827 |
2828 |
2829 |
2830 |
2831 |
case 0x0010: parse_colour_f (colour); |
2832 |
break; |
2833 |
2834 |
case 0x0011: parse_colour_24 (&colour_24); |
2835 |
colour->red = colour_24.red/255.0; |
2836 |
colour->green = colour_24.green/255.0; |
2837 |
colour->blue = colour_24.blue/255.0; |
2838 |
break; |
2839 |
2840 |
default: abortmsg ("Error parsing colour", 1); |
2841 |
2842 |
2843 |
2844 |
2845 |
2846 |
2847 |
void parse_colour_f (Colour *colour) |
2848 |
2849 |
colour->red = read_float(); |
2850 |
colour->green = read_float(); |
2851 |
colour->blue = read_float(); |
2852 |
2853 |
2854 |
2855 |
void parse_colour_24 (Colour_24 *colour) |
2856 |
2857 |
colour->red = read_byte(); |
2858 |
colour->green = read_byte(); |
2859 |
colour->blue = read_byte(); |
2860 |
2861 |
2862 |
2863 |
float parse_percentage() |
2864 |
2865 |
Chunk chunk; |
2866 |
float percent = 0.0; |
2867 |
2868 |
2869 |
2870 |
2871 |
case 0x0030: percent = parse_int_percentage()/100.0; |
2872 |
break; |
2873 |
2874 |
case 0x0031: percent = parse_float_percentage(); |
2875 |
break; |
2876 |
2877 |
default: printf ("WARNING: Error parsing percentage"); |
2878 |
2879 |
2880 |
2881 |
2882 |
return percent; |
2883 |
2884 |
2885 |
2886 |
short parse_int_percentage() |
2887 |
2888 |
word percent = read_word(); |
2889 |
2890 |
return percent; |
2891 |
2892 |
2893 |
2894 |
float parse_float_percentage() |
2895 |
2896 |
float percent = read_float(); |
2897 |
2898 |
return percent; |
2899 |
2900 |
2901 |
2902 |
void start_chunk (Chunk *chunk) |
2903 |
2904 |
chunk->start = ftell(in); |
2905 |
chunk->tag = read_word(); |
2906 |
chunk->length = read_dword(); |
2907 |
if (chunk->length < sizeof(word)+sizeof(dword)) |
2908 |
chunk->length = sizeof(word) + sizeof(dword); |
2909 |
chunk->end = chunk->start + chunk->length; |
2910 |
2911 |
2912 |
2913 |
void end_chunk (Chunk *chunk) |
2914 |
2915 |
fseek (in, chunk->end, 0); |
2916 |
2917 |
2918 |
2919 |
byte read_byte() |
2920 |
2921 |
byte data; |
2922 |
2923 |
data = fgetc (in); |
2924 |
2925 |
return data; |
2926 |
2927 |
2928 |
2929 |
word read_word() |
2930 |
2931 |
word data; |
2932 |
2933 |
2934 |
data |= fgetc (in) << 8; |
2935 |
2936 |
return data; |
2937 |
2938 |
2939 |
2940 |
dword read_dword() |
2941 |
2942 |
dword data; |
2943 |
2944 |
data = read_word(); |
2945 |
data |= read_word() << 16; |
2946 |
2947 |
return data; |
2948 |
2949 |
2950 |
2951 |
float read_float() |
2952 |
2953 |
union { dword i; char c[8]; } u; |
2954 |
dword data; |
2955 |
2956 |
data = read_dword(); |
2957 |
2958 |
if (sizeof(dword) == sizeof(float)) |
2959 |
return *(float *)&data; |
2960 |
2961 |
u.i = 1; |
2962 |
if (u.c[0] == 0) |
2963 |
return *(float *)&data; /* assume big-endian */ |
2964 |
2965 |
if (sizeof(dword) != 2*sizeof(float)) { |
2966 |
fputs("Unsupported word length\n", stderr); |
2967 |
exit(1); |
2968 |
2969 |
u.i = data; |
2970 |
return *(float *)&u.c[4]; |
2971 |
2972 |
2973 |
2974 |
void read_point (Vector v) |
2975 |
2976 |
v[X] = read_float(); |
2977 |
v[Y] = read_float(); |
2978 |
v[Z] = read_float(); |
2979 |
2980 |
2981 |
2982 |
char *read_string() |
2983 |
2984 |
static char string[80]; |
2985 |
int i; |
2986 |
2987 |
for (i = 0; i < 80; i++) { |
2988 |
string[i] = read_byte(); |
2989 |
2990 |
if (string[i] == '\0') |
2991 |
break; |
2992 |
2993 |
2994 |
return string; |
2995 |
2996 |
2997 |
2998 |
float findfov (float lens) |
2999 |
3000 |
static float lens_table[13] = |
3001 |
{ 15.0, 17.0, 24.0, 35.0, 50.0, 85.0, 100.0, 135.0, 200.0, |
3002 |
500.0, 625.0, 800.0, 1000.0 }; |
3003 |
static float fov_table[13] = |
3004 |
{ 115.0, 102.0, 84.0, 63.0, 46.0, 28.0, 24.0, 18.0, |
3005 |
12.0, 5.0, 4.0, 3.125, 2.5 }; |
3006 |
3007 |
float fov, f1, f2, l1, l2; |
3008 |
int i; |
3009 |
3010 |
if (lens < 15.0) |
3011 |
lens = 15.0; |
3012 |
else if (lens > 1000.0) |
3013 |
lens = 1000.0; |
3014 |
3015 |
for (i = 0; i < 13; i++) |
3016 |
if (lens < lens_table[i]) |
3017 |
break; |
3018 |
3019 |
if (i == 13) |
3020 |
i = 12; |
3021 |
else if (i == 0) |
3022 |
i = 1; |
3023 |
3024 |
f1 = fov_table[i-1]; |
3025 |
f2 = fov_table[i]; |
3026 |
l1 = lens_table[i-1]; |
3027 |
l2 = lens_table[i]; |
3028 |
3029 |
fov = f1 + (lens - l1) * (f2 - f1) / (l2 - l1); |
3030 |
3031 |
return fov; |
3032 |
3033 |
3034 |
