Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
moved output file initialization into main for Linux non-constant stdout
added check for flat triangles with normals
bug fix in r_ies() associated with IES file pathnames
made choice of plastic more typical
minor change removing unneeded variable
added MGF version tracking
added default handling of undefined entities
bug fix in r_ies
added lots of comments and added file precheck to r_ies()
fixed bug in ies conversion routine for getting file context
added MGF index of refraction (ir) and dielectric support
added cct entity
fixed conversion of emittance
added -m option for separate materials file
fixed bad argument parsing
added vertex reversal
spelling correction in comment (really!)
numerous bug fixes and enhancements
added "sides" entity for one- vs. two-sided surfaces
changed context names from struct members to extern variables
added further color support
slight modification to color handling
bug fixes
