root/radiance/ray/src/cv/mgf2rad.c
Revision: 2.25
Committed: Sat Feb 22 02:07:23 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.24: +21 -13 lines
5 * Convert MGF (Materials and Geometry Format) to Radiance
6 */
7
8 #include <stdio.h>
9 #include <stdlib.h>
10 #include <math.h>
11 #include <string.h>
12 #include "mgflib/parser.h"
13 #include "color.h"
14 #include "tmesh.h"
15
16 #define putv(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2])
17
18 #define invert (xf_context != NULL && xf_context->rev)
19
20 double glowdist = FHUGE; /* glow test distance */
21
22 double emult = 1.; /* emitter multiplier */
23
24 FILE *matfp; /* material output file */
25
26 int r_comment(), r_cone(), r_cyl(), r_face(), r_ies(), r_ring(), r_sph();
27 char *material(), *object(), *addarg();
28
29
30 main(argc, argv) /* convert files to stdout */
31 int argc;
32 char *argv[];
33 {
34 int i;
35
36 matfp = stdout;
37 /* print out parser version */
38 printf("## Translated from MGF Version %d.%d\n", MG_VMAJOR, MG_VMINOR);
39 /* initialize dispatch table */
40 mg_ehand[MG_E_COMMENT] = r_comment; /* we pass comments */
41 mg_ehand[MG_E_COLOR] = c_hcolor; /* they get color */
42 mg_ehand[MG_E_CONE] = r_cone; /* we do cones */
43 mg_ehand[MG_E_CMIX] = c_hcolor; /* they mix colors */
44 mg_ehand[MG_E_CSPEC] = c_hcolor; /* they get spectra */
45 mg_ehand[MG_E_CXY] = c_hcolor; /* they get chromaticities */
46 mg_ehand[MG_E_CCT] = c_hcolor; /* they get color temp's */
47 mg_ehand[MG_E_CYL] = r_cyl; /* we do cylinders */
48 mg_ehand[MG_E_ED] = c_hmaterial; /* they get emission */
49 mg_ehand[MG_E_FACE] = r_face; /* we do faces */
50 mg_ehand[MG_E_IES] = r_ies; /* we do IES files */
51 mg_ehand[MG_E_IR] = c_hmaterial; /* they get refractive index */
52 mg_ehand[MG_E_MATERIAL] = c_hmaterial; /* they get materials */
53 mg_ehand[MG_E_NORMAL] = c_hvertex; /* they get normals */
54 mg_ehand[MG_E_OBJECT] = obj_handler; /* they track object names */
55 mg_ehand[MG_E_POINT] = c_hvertex; /* they get points */
56 mg_ehand[MG_E_RD] = c_hmaterial; /* they get diffuse refl. */
57 mg_ehand[MG_E_RING] = r_ring; /* we do rings */
58 mg_ehand[MG_E_RS] = c_hmaterial; /* they get specular refl. */
59 mg_ehand[MG_E_SIDES] = c_hmaterial; /* they get # sides */
60 mg_ehand[MG_E_SPH] = r_sph; /* we do spheres */
61 mg_ehand[MG_E_TD] = c_hmaterial; /* they get diffuse trans. */
62 mg_ehand[MG_E_TS] = c_hmaterial; /* they get specular trans. */
63 mg_ehand[MG_E_VERTEX] = c_hvertex; /* they get vertices */
64 mg_ehand[MG_E_XF] = xf_handler; /* they track transforms */
65 mg_init(); /* initialize the parser */
66 /* get our options & print header */
67 printf("## %s", argv[0]);
68 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
69 printf(" %s", argv[i]);
70 switch (argv[i][1]) {
71 case 'g': /* glow distance (meters) */
72 if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f"))
73 goto userr;
74 glowdist = atof(argv[++i]);
75 printf(" %s", argv[i]);
76 break;
77 case 'e': /* emitter multiplier */
78 if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f"))
79 goto userr;
80 emult = atof(argv[++i]);
81 printf(" %s", argv[i]);
82 break;
83 case 'm': /* materials file */
84 matfp = fopen(argv[++i], "a");
85 if (matfp == NULL) {
86 fprintf(stderr, "%s: cannot append\n", argv[i]);
87 exit(1);
88 }
89 printf(" %s", argv[i]);
90 break;
91 default:
92 goto userr;
93 }
94 }
95 putchar('\n');
96 if (i == argc) { /* convert stdin */
97 if (mg_load(NULL) != MG_OK)
98 exit(1);
99 if (mg_nunknown)
100 printf("## %s: %u unknown entities\n",
101 argv[0], mg_nunknown);
102 } else /* convert each file */
103 for ( ; i < argc; i++) {
104 printf("## %s %s ##############################\n",
105 argv[0], argv[i]);
106 if (mg_load(argv[i]) != MG_OK)
107 exit(1);
108 if (mg_nunknown) {
109 printf("## %s %s: %u unknown entities\n",
110 argv[0], argv[i], mg_nunknown);
111 mg_nunknown = 0;
112 }
113 }
114 exit(0);
115 userr:
116 fprintf(stderr, "Usage: %s [-g dist][-e mult][-m matf] [file.mgf] ..\n",
117 argv[0]);
118 exit(1);
119 }
120
121
122 int
123 r_comment(ac, av) /* repeat a comment verbatim */
124 register int ac;
125 register char **av;
126 {
127 putchar('#'); /* use Radiance comment character */
128 while (--ac) { /* pass through verbatim */
129 putchar(' ');
130 fputs(*++av, stdout);
131 }
132 putchar('\n');
133 return(MG_OK);
134 }
135
136
137 int
138 r_cone(ac, av) /* put out a cone */
139 int ac;
140 char **av;
141 {
142 static int ncones;
143 char *mat;
144 double r1, r2;
145 C_VERTEX *cv1, *cv2;
146 FVECT p1, p2;
147 int inv;
148 /* check argument count and type */
149 if (ac != 5)
150 return(MG_EARGC);
151 if (!isflt(av[2]) || !isflt(av[4]))
152 return(MG_ETYPE);
153 /* get the endpoint vertices */
154 if ((cv1 = c_getvert(av[1])) == NULL ||
155 (cv2 = c_getvert(av[3])) == NULL)
156 return(MG_EUNDEF);
157 xf_xfmpoint(p1, cv1->p); /* transform endpoints */
158 xf_xfmpoint(p2, cv2->p);
159 r1 = xf_scale(atof(av[2])); /* scale radii */
160 r2 = xf_scale(atof(av[4]));
161 inv = r1 < 0.; /* check for inverted cone */
162 if (r1 == 0.) { /* check for illegal radii */
163 if (r2 == 0.)
164 return(MG_EILL);
165 inv = r2 < 0.;
166 } else if (r2 != 0. && inv ^ r2 < 0.)
167 return(MG_EILL);
168 if (inv) {
169 r1 = -r1;
170 r2 = -r2;
171 }
172 if ((mat = material()) == NULL) /* get material */
173 return(MG_EBADMAT);
174 /* spit the sucker out */
175 printf("\n%s %s %sc%d\n", mat, inv ? "cup" : "cone",
176 object(), ++ncones);
177 printf("0\n0\n8\n");
178 putv(p1);
179 putv(p2);
180 printf("%18.12g %18.12g\n", r1, r2);
181 return(MG_OK);
182 }
183
184
185 int
186 r_cyl(ac, av) /* put out a cylinder */
187 int ac;
188 char **av;
189 {
190 static int ncyls;
191 char *mat;
192 double rad;
193 C_VERTEX *cv1, *cv2;
194 FVECT p1, p2;
195 int inv;
196 /* check argument count and type */
197 if (ac != 4)
198 return(MG_EARGC);
199 if (!isflt(av[2]))
200 return(MG_ETYPE);
201 /* get the endpoint vertices */
202 if ((cv1 = c_getvert(av[1])) == NULL ||
203 (cv2 = c_getvert(av[3])) == NULL)
204 return(MG_EUNDEF);
205 xf_xfmpoint(p1, cv1->p); /* transform endpoints */
206 xf_xfmpoint(p2, cv2->p);
207 rad = xf_scale(atof(av[2])); /* scale radius */
208 if ((inv = rad < 0.)) /* check for inverted cylinder */
209 rad = -rad;
210 if ((mat = material()) == NULL) /* get material */
211 return(MG_EBADMAT);
212 /* spit out the primitive */
213 printf("\n%s %s %scy%d\n", mat, inv ? "tube" : "cylinder",
214 object(), ++ncyls);
215 printf("0\n0\n7\n");
216 putv(p1);
217 putv(p2);
218 printf("%18.12g\n", rad);
219 return(MG_OK);
220 }
221
222
223 int
224 r_sph(ac, av) /* put out a sphere */
225 int ac;
226 char **av;
227 {
228 static int nsphs;
229 char *mat;
230 double rad;
231 C_VERTEX *cv;
232 FVECT cent;
233 int inv;
234 /* check argument count and type */
235 if (ac != 3)
236 return(MG_EARGC);
237 if (!isflt(av[2]))
238 return(MG_ETYPE);
239 if ((cv = c_getvert(av[1])) == NULL) /* get center vertex */
240 return(MG_EUNDEF);
241 xf_xfmpoint(cent, cv->p); /* transform center */
242 rad = xf_scale(atof(av[2])); /* scale radius */
243 if ((inv = rad < 0.)) /* check for inversion */
244 rad = -rad;
245 if ((mat = material()) == NULL) /* get material */
246 return(MG_EBADMAT);
247 /* spit out primitive */
248 printf("\n%s %s %ss%d\n", mat, inv ? "bubble" : "sphere",
249 object(), ++nsphs);
250 printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n",
251 cent[0], cent[1], cent[2], rad);
252 return(MG_OK);
253 }
254
255
256 int
257 r_ring(ac, av) /* put out a ring */
258 int ac;
259 char **av;
260 {
261 static int nrings;
262 char *mat;
263 double r1, r2;
264 C_VERTEX *cv;
265 FVECT cent, norm;
266 /* check argument count and type */
267 if (ac != 4)
268 return(MG_EARGC);
269 if (!isflt(av[2]) || !isflt(av[3]))
270 return(MG_ETYPE);
271 if ((cv = c_getvert(av[1])) == NULL) /* get center vertex */
272 return(MG_EUNDEF);
273 if (is0vect(cv->n)) /* make sure we have normal */
274 return(MG_EILL);
275 xf_xfmpoint(cent, cv->p); /* transform center */
276 xf_rotvect(norm, cv->n); /* rotate normal */
277 r1 = xf_scale(atof(av[2])); /* scale radii */
278 r2 = xf_scale(atof(av[3]));
279 if (r1 < 0. | r2 <= r1)
280 return(MG_EILL);
281 if ((mat = material()) == NULL) /* get material */
282 return(MG_EBADMAT);
283 /* spit out primitive */
284 printf("\n%s ring %sr%d\n", mat, object(), ++nrings);
285 printf("0\n0\n8\n");
286 putv(cent);
287 putv(norm);
288 printf("%18.12g %18.12g\n", r1, r2);
289 return(MG_OK);
290 }
291
292
293 int
294 r_face(ac, av) /* convert a face */
295 int ac;
296 char **av;
297 {
298 static int nfaces;
299 int myi = invert;
300 char *mat;
301 register int i;
302 register C_VERTEX *cv;
303 FVECT v;
304 int rv;
305 /* check argument count and type */
306 if (ac < 4)
307 return(MG_EARGC);
308 if ((mat = material()) == NULL) /* get material */
309 return(MG_EBADMAT);
310 if (ac <= 5) { /* check for smoothing */
311 C_VERTEX *cva[5];
312 for (i = 1; i < ac; i++) {
313 if ((cva[i-1] = c_getvert(av[i])) == NULL)
314 return(MG_EUNDEF);
315 if (is0vect(cva[i-1]->n))
316 break;
317 }
318 if (i < ac)
319 i = ISFLAT;
320 else
321 i = flat_tri(cva[0]->p, cva[1]->p, cva[2]->p,
322 cva[0]->n, cva[1]->n, cva[2]->n);
323 if (i == DEGEN)
324 return(MG_OK); /* degenerate (error?) */
325 if (i == RVBENT) {
326 myi = !myi;
327 i = ISBENT;
328 } else if (i == RVFLAT) {
329 myi = !myi;
330 i = ISFLAT;
331 }
332 if (i == ISBENT) { /* smoothed triangles */
333 do_tri(mat, cva[0], cva[1], cva[2], myi);
334 if (ac == 5)
335 do_tri(mat, cva[2], cva[3], cva[0], myi);
336 return(MG_OK);
337 }
338 }
339 /* spit out unsmoothed primitive */
340 printf("\n%s polygon %sf%d\n", mat, object(), ++nfaces);
341 printf("0\n0\n%d\n", 3*(ac-1));
342 for (i = 1; i < ac; i++) { /* get, transform, print each vertex */
343 if ((cv = c_getvert(av[myi ? ac-i : i])) == NULL)
344 return(MG_EUNDEF);
345 xf_xfmpoint(v, cv->p);
346 putv(v);
347 }
348 return(MG_OK);
349 }
350
351
352 int
353 r_ies(ac, av) /* convert an IES luminaire file */
354 int ac;
355 char **av;
356 {
357 int xa0 = 2;
358 char combuf[128];
359 char fname[48];
360 char *oname;
361 register char *op;
362 register int i;
363 /* check argument count */
364 if (ac < 2)
365 return(MG_EARGC);
366 /* construct output file name */
367 if ((op = strrchr(av[1], '/')) != NULL)
368 op++;
369 else
370 op = av[1];
371 (void)strcpy(fname, op);
372 if ((op = strrchr(fname, '.')) == NULL)
373 op = fname + strlen(fname);
374 (void)strcpy(op, ".rad");
375 /* see if we need to run ies2rad */
376 if (access(fname, 0) == -1) {
377 (void)strcpy(combuf, "ies2rad");/* build ies2rad command */
378 op = combuf + 7; /* get -m option (first) */
379 if (ac-xa0 >= 2 && !strcmp(av[xa0], "-m")) {
380 if (!isflt(av[xa0+1]))
381 return(MG_ETYPE);
382 op = addarg(addarg(op, "-m"), av[xa0+1]);
383 xa0 += 2;
384 }
385 *op++ = ' '; /* build IES filename */
386 i = 0;
387 if (mg_file != NULL &&
388 (oname = strrchr(mg_file->fname,'/')) != NULL) {
389 i = oname - mg_file->fname + 1;
390 (void)strcpy(op, mg_file->fname);
391 }
392 (void)strcpy(op+i, av[1]);
393 if (access(op, 0) == -1) /* check for file existence */
394 return(MG_ENOFILE);
395 system(combuf); /* run ies2rad */
396 if (access(fname, 0) == -1) /* check success */
397 return(MG_EINCL);
398 }
399 printf("\n!xform"); /* put out xform command */
400 oname = object();
401 if (*oname) {
402 printf(" -n ");
403 for (op = oname; op[1]; op++) /* remove trailing separator */
404 putchar(*op);
405 }
406 for (i = xa0; i < ac; i++)
407 printf(" %s", av[i]);
408 if (ac > xa0 && xf_argc > 0)
409 printf(" -i 1");
410 for (i = 0; i < xf_argc; i++)
411 printf(" %s", xf_argv[i]);
412 printf(" %s\n", fname);
413 return(MG_OK);
414 }
415
416
417 do_tri(mat, cv1, cv2, cv3, iv) /* put out smoothed triangle */
418 char *mat;
419 C_VERTEX *cv1, *cv2, *cv3;
420 int iv;
421 {
422 static int ntris;
423 BARYCCM bvecs;
424 FLOAT bcoor[3][3];
425 C_VERTEX *cvt;
426 FVECT v1, v2, v3;
427 FVECT n1, n2, n3;
428 register int i;
429
430 if (iv) { /* swap vertex order if inverted */
431 cvt = cv1;
432 cv1 = cv3;
433 cv3 = cvt;
434 }
435 xf_xfmpoint(v1, cv1->p);
436 xf_xfmpoint(v2, cv2->p);
437 xf_xfmpoint(v3, cv3->p);
438 /* compute barycentric coords. */
439 if (comp_baryc(&bvecs, v1, v2, v3) < 0)
440 return; /* degenerate triangle! */
441 printf("\n%s texfunc T-nor\n", mat); /* put out texture */
442 printf("4 dx dy dz %s\n0\n", TCALNAME);
443 xf_rotvect(n1, cv1->n);
444 xf_rotvect(n2, cv2->n);
445 xf_rotvect(n3, cv3->n);
446 for (i = 0; i < 3; i++) {
447 bcoor[i][0] = n1[i];
448 bcoor[i][1] = n2[i];
449 bcoor[i][2] = n3[i];
450 }
451 put_baryc(&bvecs, bcoor, 3);
452 /* put out triangle */
453 printf("\nT-nor polygon %st%d\n", object(), ++ntris);
454 printf("0\n0\n9\n");
455 putv(v1);
456 putv(v2);
457 putv(v3);
458 }
459
460
461 char *
462 material() /* get (and print) current material */
463 {
464 char *mname = "mat";
465 COLOR radrgb, c2;
466 double d;
467 register int i;
468
469 if (c_cmname != NULL)
470 mname = c_cmname;
471 if (!c_cmaterial->clock)
472 return(mname); /* already current */
473 /* else update output */
474 c_cmaterial->clock = 0;
475 if (c_cmaterial->ed > .1) { /* emitter */
476 cvtcolor(radrgb, &c_cmaterial->ed_c,
477 emult*c_cmaterial->ed/(PI*WHTEFFICACY));
478 if (glowdist < FHUGE) { /* do a glow */
479 fprintf(matfp, "\nvoid glow %s\n0\n0\n", mname);
480 fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED),
481 colval(radrgb,GRN),
482 colval(radrgb,BLU), glowdist);
483 } else {
484 fprintf(matfp, "\nvoid light %s\n0\n0\n", mname);
485 fprintf(matfp, "3 %f %f %f\n", colval(radrgb,RED),
486 colval(radrgb,GRN),
487 colval(radrgb,BLU));
488 }
489 return(mname);
490 }
491 d = c_cmaterial->rd + c_cmaterial->td +
492 c_cmaterial->rs + c_cmaterial->ts;
493 if (d < 0. | d > 1.)
494 return(NULL);
495 /* check for glass/dielectric */
496 if (c_cmaterial->nr > 1.1 &&
497 c_cmaterial->ts > .25 && c_cmaterial->rs <= .125 &&
498 c_cmaterial->td <= .01 && c_cmaterial->rd <= .01 &&
499 c_cmaterial->rs_a <= .01 && c_cmaterial->ts_a <= .01) {
500 cvtcolor(radrgb, &c_cmaterial->ts_c,
501 c_cmaterial->ts + c_cmaterial->rs);
502 if (c_cmaterial->sided) { /* dielectric */
503 colval(radrgb,RED) = pow(colval(radrgb,RED),
504 1./C_1SIDEDTHICK);
505 colval(radrgb,GRN) = pow(colval(radrgb,GRN),
506 1./C_1SIDEDTHICK);
507 colval(radrgb,BLU) = pow(colval(radrgb,BLU),
508 1./C_1SIDEDTHICK);
509 fprintf(matfp, "\nvoid dielectric %s\n0\n0\n", mname);
510 fprintf(matfp, "5 %g %g %g %f 0\n", colval(radrgb,RED),
511 colval(radrgb,GRN), colval(radrgb,BLU),
512 c_cmaterial->nr);
513 return(mname);
514 }
515 /* glass */
516 fprintf(matfp, "\nvoid glass %s\n0\n0\n", mname);
517 fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED),
518 colval(radrgb,GRN), colval(radrgb,BLU),
519 c_cmaterial->nr);
520 return(mname);
521 }
522 /* check for trans */
523 if (c_cmaterial->td > .01 || c_cmaterial->ts > .01) {
524 double ts, a5, a6;
525
526 if (c_cmaterial->sided) {
527 ts = sqrt(c_cmaterial->ts); /* approximate */
528 a5 = .5;
529 } else {
530 ts = c_cmaterial->ts;
531 a5 = 1.;
532 }
533 /* average colors */
534 d = c_cmaterial->rd + c_cmaterial->td + ts;
535 cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d);
536 cvtcolor(c2, &c_cmaterial->td_c, c_cmaterial->td/d);
537 addcolor(radrgb, c2);
538 cvtcolor(c2, &c_cmaterial->ts_c, ts/d);
539 addcolor(radrgb, c2);
540 if (c_cmaterial->rs + ts > .0001)
541 a5 = (c_cmaterial->rs*c_cmaterial->rs_a +
542 ts*a5*c_cmaterial->ts_a) /
543 (c_cmaterial->rs + ts);
544 a6 = (c_cmaterial->td + ts) /
545 (c_cmaterial->rd + c_cmaterial->td + ts);
546 if (a6 < .999)
547 d = c_cmaterial->rd/(1. - c_cmaterial->rs)/(1. - a6);
548 else
549 d = c_cmaterial->td + ts;
550 scalecolor(radrgb, d);
551 fprintf(matfp, "\nvoid trans %s\n0\n0\n", mname);
552 fprintf(matfp, "7 %f %f %f\n", colval(radrgb,RED),
553 colval(radrgb,GRN), colval(radrgb,BLU));
554 fprintf(matfp, "\t%f %f %f %f\n", c_cmaterial->rs, a5, a6,
555 ts/(ts + c_cmaterial->td));
556 return(mname);
557 }
558 /* check for plastic */
559 if (c_cmaterial->rs < .1) {
560 cvtcolor(radrgb, &c_cmaterial->rd_c,
561 c_cmaterial->rd/(1.-c_cmaterial->rs));
562 fprintf(matfp, "\nvoid plastic %s\n0\n0\n", mname);
563 fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED),
564 colval(radrgb,GRN), colval(radrgb,BLU),
565 c_cmaterial->rs, c_cmaterial->rs_a);
566 return(mname);
567 }
568 /* else it's metal */
569 /* average colors */
570 cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd);
571 cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs);
572 addcolor(radrgb, c2);
573 fprintf(matfp, "\nvoid metal %s\n0\n0\n", mname);
574 fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED),
575 colval(radrgb,GRN), colval(radrgb,BLU),
576 c_cmaterial->rs/(c_cmaterial->rd + c_cmaterial->rs),
577 c_cmaterial->rs_a);
578 return(mname);
579 }
580
581
582 cvtcolor(radrgb, ciec, intensity) /* convert a CIE XYZ color to RGB */
583 COLOR radrgb;
584 register C_COLOR *ciec;
585 double intensity;
586 {
587 static COLOR ciexyz;
588
589 c_ccvt(ciec, C_CSXY); /* get xy representation */
590 ciexyz[1] = intensity;
591 ciexyz[0] = ciec->cx/ciec->cy*ciexyz[1];
592 ciexyz[2] = ciexyz[1]*(1./ciec->cy - 1.) - ciexyz[0];
593 cie_rgb(radrgb, ciexyz);
594 }
595
596
597 char *
598 object() /* return current object name */
599 {
600 static char objbuf[64];
601 register int i;
602 register char *cp;
603 int len;
604 /* tracked by obj_handler */
605 i = obj_nnames - sizeof(objbuf)/16;
606 if (i < 0)
607 i = 0;
608 for (cp = objbuf; i < obj_nnames &&
609 cp + (len=strlen(obj_name[i])) < objbuf+sizeof(objbuf)-1;
610 i++, *cp++ = '.') {
611 strcpy(cp, obj_name[i]);
612 cp += len;
613 }
614 *cp = '\0';
615 return(objbuf);
616 }
617
618
619 char *
620 addarg(op, arg) /* add argument and advance pointer */
621 register char *op, *arg;
622 {
623 *op = ' ';
624 while (*++op = *arg++)
625 ;
626 return(op);
627 }
