--- ray/src/cv/mgf2rad.c 1994/06/25 09:45:22 2.4 +++ ray/src/cv/mgf2rad.c 1995/04/13 14:43:33 2.14 @@ -17,10 +17,14 @@ static char SCCSid[] = "$SunId$ LBL"; #define putv(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2]) +#define invert (xf_context != NULL && xf_context->rev) + double glowdist = FHUGE; /* glow test distance */ -double emult = 1.; /* emmitter multiplier */ +double emult = 1.; /* emitter multiplier */ +FILE *matfp = stdout; /* material output file */ + int r_comment(), r_cone(), r_cyl(), r_face(), r_ies(), r_ring(), r_sph(); char *material(), *object(), *addarg(); @@ -37,10 +41,12 @@ char *argv[]; mg_ehand[MG_E_CMIX] = c_hcolor; mg_ehand[MG_E_CSPEC] = c_hcolor; mg_ehand[MG_E_CXY] = c_hcolor; + mg_ehand[MG_E_CCT] = c_hcolor; mg_ehand[MG_E_CYL] = r_cyl; mg_ehand[MG_E_ED] = c_hmaterial; mg_ehand[MG_E_FACE] = r_face; mg_ehand[MG_E_IES] = r_ies; + mg_ehand[MG_E_IR] = c_hmaterial; mg_ehand[MG_E_MATERIAL] = c_hmaterial; mg_ehand[MG_E_NORMAL] = c_hvertex; mg_ehand[MG_E_OBJECT] = obj_handler; @@ -48,6 +54,7 @@ char *argv[]; mg_ehand[MG_E_RD] = c_hmaterial; mg_ehand[MG_E_RING] = r_ring; mg_ehand[MG_E_RS] = c_hmaterial; + mg_ehand[MG_E_SIDES] = c_hmaterial; mg_ehand[MG_E_SPH] = r_sph; mg_ehand[MG_E_TD] = c_hmaterial; mg_ehand[MG_E_TS] = c_hmaterial; @@ -60,17 +67,25 @@ char *argv[]; printf(" %s", argv[i]); switch (argv[i][1]) { case 'g': /* glow distance (meters) */ - if (argv[i][2] || badarg(argc-i, argv+i, "f")) + if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f")) goto userr; glowdist = atof(argv[++i]); printf(" %s", argv[i]); break; case 'e': /* emitter multiplier */ - if (argv[i][2] || badarg(argc-i, argv+i, "f")) + if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f")) goto userr; emult = atof(argv[++i]); printf(" %s", argv[i]); break; + case 'm': /* materials file */ + matfp = fopen(argv[++i], "a"); + if (matfp == NULL) { + fprintf(stderr, "%s: cannot append\n", argv[i]); + exit(1); + } + printf(" %s", argv[i]); + break; default: goto userr; } @@ -88,7 +103,7 @@ char *argv[]; } exit(0); userr: - fprintf(stderr, "Usage: %s [-g dist][-m mult] [file.mgf] ..\n", + fprintf(stderr, "Usage: %s [-g dist][-e mult][-m matf] [file.mgf] ..\n", argv[0]); exit(1); } @@ -99,7 +114,7 @@ r_comment(ac, av) /* repeat a comment verbatim */ register int ac; register char **av; { - fputs("\n#", stdout); /* use Radiance comment character */ + putchar('#'); /* use Radiance comment character */ while (--ac) { putchar(' '); fputs(*++av, stdout); @@ -292,7 +307,7 @@ char **av; printf("\n%s polygon %sf%d\n", mat, object(), ++nfaces); printf("0\n0\n%d\n", 3*(ac-1)); for (i = 1; i < ac; i++) { - if ((cv = c_getvert(av[i])) == NULL) + if ((cv = c_getvert(av[invert ? ac-i : i])) == NULL) return(MG_EUNDEF); xf_xfmpoint(v, cv->p); putv(v); @@ -366,9 +381,14 @@ char *mat, *vn1, *vn2, *vn3; FVECT n1, n2, n3; register int i; /* the following is repeat code, so assume it's OK */ - cv1 = c_getvert(vn1); cv2 = c_getvert(vn2); - cv3 = c_getvert(vn3); + if (invert) { + cv3 = c_getvert(vn1); + cv1 = c_getvert(vn3); + } else { + cv1 = c_getvert(vn1); + cv3 = c_getvert(vn3); + } xf_xfmpoint(v1, cv1->p); xf_xfmpoint(v2, cv2->p); xf_xfmpoint(v3, cv3->p); @@ -401,23 +421,23 @@ material() /* get (and print) current material */ double d; register int i; - if (c_cmaterial->name != NULL) - mname = c_cmaterial->name; + if (c_cmname != NULL) + mname = c_cmname; if (!c_cmaterial->clock) return(mname); /* already current */ /* else update output */ c_cmaterial->clock = 0; if (c_cmaterial->ed > .1) { /* emitter */ cvtcolor(radrgb, &c_cmaterial->ed_c, - emult*c_cmaterial->ed/WHTEFFICACY); + emult*c_cmaterial->ed/(PI*WHTEFFICACY)); if (glowdist < FHUGE) { /* do a glow */ - printf("\nvoid glow %s\n0\n0\n", mname); - printf("4 %f %f %f %f\n", colval(radrgb,RED), + fprintf(matfp, "\nvoid glow %s\n0\n0\n", mname); + fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU), glowdist); } else { - printf("\nvoid light %s\n0\n0\n", mname); - printf("3 %f %f %f\n", colval(radrgb,RED), + fprintf(matfp, "\nvoid light %s\n0\n0\n", mname); + fprintf(matfp, "3 %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU)); } @@ -425,13 +445,46 @@ material() /* get (and print) current material */ } d = c_cmaterial->rd + c_cmaterial->td + c_cmaterial->rs + c_cmaterial->ts; - if (d <= 0. | d >= 1.) + if (d < 0. | d > 1.) return(NULL); + /* check for glass/dielectric */ + if (c_cmaterial->nr > 1.1 && + c_cmaterial->ts > .25 && c_cmaterial->rs <= .125 && + c_cmaterial->td <= .01 && c_cmaterial->rd <= .01 && + c_cmaterial->rs_a <= .01 && c_cmaterial->ts_a <= .01) { + cvtcolor(radrgb, &c_cmaterial->ts_c, + c_cmaterial->ts + c_cmaterial->rs); + if (c_cmaterial->sided) { /* dielectric */ + colval(radrgb,RED) = pow(colval(radrgb,RED), + 1./C_1SIDEDTHICK); + colval(radrgb,GRN) = pow(colval(radrgb,GRN), + 1./C_1SIDEDTHICK); + colval(radrgb,BLU) = pow(colval(radrgb,BLU), + 1./C_1SIDEDTHICK); + fprintf(matfp, "\nvoid dielectric %s\n0\n0\n", mname); + fprintf(matfp, "5 %g %g %g %f 0\n", colval(radrgb,RED), + colval(radrgb,GRN), colval(radrgb,BLU), + c_cmaterial->nr); + return(mname); + } + /* glass */ + fprintf(matfp, "\nvoid glass %s\n0\n0\n", mname); + fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED), + colval(radrgb,GRN), colval(radrgb,BLU), + c_cmaterial->nr); + return(mname); + } /* check for trans */ if (c_cmaterial->td > .01 || c_cmaterial->ts > .01) { double ts, a5, a6; - ts = sqrt(c_cmaterial->ts); /* because we use 2 sides */ + if (c_cmaterial->sided) { + ts = sqrt(c_cmaterial->ts); /* approximate */ + a5 = .5; + } else { + ts = c_cmaterial->ts; + a5 = 1.; + } /* average colors */ d = c_cmaterial->rd + c_cmaterial->td + ts; cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d); @@ -441,47 +494,43 @@ material() /* get (and print) current material */ addcolor(radrgb, c2); if (c_cmaterial->rs + ts > .0001) a5 = (c_cmaterial->rs*c_cmaterial->rs_a + - ts*.5*c_cmaterial->ts_a) / + ts*a5*c_cmaterial->ts_a) / (c_cmaterial->rs + ts); a6 = (c_cmaterial->td + ts) / (c_cmaterial->rd + c_cmaterial->td + ts); - if (a6 < .999) { + if (a6 < .999) d = c_cmaterial->rd/(1. - c_cmaterial->rs)/(1. - a6); - scalecolor(radrgb, d); - } - printf("\nvoid trans %s\n0\n0\n", mname); - printf("7 %f %f %f\n", colval(radrgb,RED), + else + d = c_cmaterial->td + ts; + scalecolor(radrgb, d); + fprintf(matfp, "\nvoid trans %s\n0\n0\n", mname); + fprintf(matfp, "7 %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU)); - printf("\t%f %f %f %f\n", c_cmaterial->rs, a5, a6, + fprintf(matfp, "\t%f %f %f %f\n", c_cmaterial->rs, a5, a6, ts/(ts + c_cmaterial->td)); return(mname); } /* check for plastic */ - if (c_cmaterial->rs < .01 || c_isgrey(&c_cmaterial->rs_c)) { - if (c_cmaterial->rs > .999) - cvtcolor(radrgb, &c_cmaterial->rd_c, 1.); - else - cvtcolor(radrgb, &c_cmaterial->rd_c, + if (c_cmaterial->rs < .1 && (c_cmaterial->rs < .01 || + c_isgrey(&c_cmaterial->rs_c))) { + cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/(1.-c_cmaterial->rs)); - printf("\nvoid plastic %s\n0\n0\n", mname); - printf("5 %f %f %f %f %f\n", colval(radrgb,RED), + fprintf(matfp, "\nvoid plastic %s\n0\n0\n", mname); + fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU), c_cmaterial->rs, c_cmaterial->rs_a); return(mname); } /* else it's metal */ - d = c_cmaterial->rd + c_cmaterial->rs; /* average colors */ - cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d); - cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs/d); + /* average colors */ + cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd); + cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs); addcolor(radrgb, c2); - if (c_cmaterial->rs < .999) { - d = c_cmaterial->rd/(1. - c_cmaterial->rs); - scalecolor(radrgb, d); - } - printf("\nvoid metal %s\n0\n0\n", mname); - printf("5 %f %f %f %f %f\n", colval(radrgb,RED), + fprintf(matfp, "\nvoid metal %s\n0\n0\n", mname); + fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU), - c_cmaterial->rs, c_cmaterial->rs_a); + c_cmaterial->rs/(c_cmaterial->rd + c_cmaterial->rs), + c_cmaterial->rs_a); return(mname); }
