--- ray/src/cv/mgf2rad.c 2011/02/22 16:45:12 2.29 +++ ray/src/cv/mgf2rad.c 2024/01/04 01:55:42 2.33 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mgf2rad.c,v 2.29 2011/02/22 16:45:12 greg Exp $"; +static const char RCSid[] = "$Id: mgf2rad.c,v 2.33 2024/01/04 01:55:42 greg Exp $"; #endif /* * Convert MGF (Materials and Geometry Format) to Radiance @@ -14,6 +14,7 @@ static const char RCSid[] = "$Id: mgf2rad.c,v 2.29 201 #include "mgf_parser.h" #include "color.h" #include "tmesh.h" +#include "lookup.h" #define putv(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2]) @@ -26,18 +27,21 @@ double emult = 1.; /* emitter multiplier */ FILE *matfp; /* material output file */ -int r_comment(int ac, char **av); -int r_cone(int ac, char **av); -int r_cyl(int ac, char **av); -int r_sph(int ac, char **av); -int r_ring(int ac, char **av); -int r_face(int ac, char **av); -int r_ies(int ac, char **av); -char * material(void); -char * object(void); -char * addarg(char *op, char *arg); -void do_tri(char *mat, C_VERTEX *cv1, C_VERTEX *cv2, C_VERTEX *cv3, int iv); -void cvtcolor(COLOR radrgb, register C_COLOR *ciec, double intensity); +extern int r_comment(int ac, char **av); +extern int r_color(int ac, char **av); +extern int r_cone(int ac, char **av); +extern int r_cyl(int ac, char **av); +extern int r_sph(int ac, char **av); +extern int r_ring(int ac, char **av); +extern int r_face(int ac, char **av); +extern int r_ies(int ac, char **av); +extern void putsided(char *mname); +extern char * material(void); +extern char * object(void); +extern char * addarg(char *op, char *arg); +extern void do_tri(char *mat, C_VERTEX *cv1, C_VERTEX *cv2, C_VERTEX *cv3, int iv); +extern void cvtcolor(COLOR radrgb, C_COLOR *ciec, double intensity); +extern char * specolor(COLOR radrgb, C_COLOR *ciec, double intensity); int @@ -56,9 +60,9 @@ main( mg_ehand[MG_E_COLOR] = c_hcolor; /* they get color */ mg_ehand[MG_E_CONE] = r_cone; /* we do cones */ mg_ehand[MG_E_CMIX] = c_hcolor; /* they mix colors */ - mg_ehand[MG_E_CSPEC] = c_hcolor; /* they get spectra */ mg_ehand[MG_E_CXY] = c_hcolor; /* they get chromaticities */ - mg_ehand[MG_E_CCT] = c_hcolor; /* they get color temp's */ + mg_ehand[MG_E_CSPEC] = r_color; /* we get spectra */ + mg_ehand[MG_E_CCT] = r_color; /* we get color temp's */ mg_ehand[MG_E_CYL] = r_cyl; /* we do cylinders */ mg_ehand[MG_E_ED] = c_hmaterial; /* they get emission */ mg_ehand[MG_E_FACE] = r_face; /* we do faces */ @@ -136,8 +140,8 @@ userr: int r_comment( /* repeat a comment verbatim */ - register int ac, - register char **av + int ac, + char **av ) { putchar('#'); /* use Radiance comment character */ @@ -151,6 +155,21 @@ r_comment( /* repeat a comment verbatim */ int +r_color( /* call color handler & remember name */ + int ac, + char **av +) +{ + int rval = c_hcolor(ac, av); + + if (rval == MG_OK) + c_ccolor->client_data = c_ccname; + + return(rval); +} + + +int r_cone( /* put out a cone */ int ac, char **av @@ -319,8 +338,8 @@ r_face( /* convert a face */ static int nfaces; int myi = invert; char *mat; - register int i; - register C_VERTEX *cv; + int i; + C_VERTEX *cv; FVECT v; /* check argument count and type */ @@ -380,8 +399,8 @@ r_ies( /* convert an IES luminaire file */ char combuf[128]; char fname[48]; char *oname; - register char *op; - register int i; + char *op; + int i; /* check argument count */ if (ac < 2) return(MG_EARGC); @@ -451,7 +470,7 @@ do_tri( /* put out smoothed triangle */ C_VERTEX *cvt; FVECT v1, v2, v3; FVECT n1, n2, n3; - register int i; + int i; if (iv) { /* swap vertex order if inverted */ cvt = cv1; @@ -474,7 +493,7 @@ do_tri( /* put out smoothed triangle */ bcoor[i][1] = n2[i]; bcoor[i][2] = n3[i]; } - put_baryc(&bvecs, bcoor, 3); + fput_baryc(&bvecs, bcoor, 3, stdout); /* put out triangle */ printf("\nT-nor polygon %st%d\n", object(), ++ntris); printf("0\n0\n9\n"); @@ -484,10 +503,19 @@ do_tri( /* put out smoothed triangle */ } +void +putsided(char *mname) /* print out mixfunc for sided material */ +{ + fprintf(matfp, "\nvoid mixfunc %s\n", mname); + fprintf(matfp, "4 %s void if(Rdot,1,0) .\n0\n0\n", mname); +} + + char * material(void) /* get (and print) current material */ { char *mname = "mat"; + char *pname; COLOR radrgb, c2; double d; @@ -498,15 +526,15 @@ material(void) /* get (and print) current material * /* else update output */ c_cmaterial->clock = 0; if (c_cmaterial->ed > .1) { /* emitter */ - cvtcolor(radrgb, &c_cmaterial->ed_c, + pname = specolor(radrgb, &c_cmaterial->ed_c, emult*c_cmaterial->ed/(PI*WHTEFFICACY)); if (glowdist < FHUGE) { /* do a glow */ - fprintf(matfp, "\nvoid glow %s\n0\n0\n", mname); + fprintf(matfp, "\n%s glow %s\n0\n0\n", pname, mname); fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU), glowdist); } else { - fprintf(matfp, "\nvoid light %s\n0\n0\n", mname); + fprintf(matfp, "\n%s light %s\n0\n0\n", pname, mname); fprintf(matfp, "3 %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU)); @@ -543,63 +571,71 @@ material(void) /* get (and print) current material * colval(radrgb,GRN), colval(radrgb,BLU), c_cmaterial->nr); return(mname); - } + } /* check for trans */ if (c_cmaterial->td > .01 || c_cmaterial->ts > .01) { - double ts, a5, a6; - - if (c_cmaterial->sided) { - ts = sqrt(c_cmaterial->ts); /* approximate */ - a5 = .5; - } else { - ts = c_cmaterial->ts; - a5 = 1.; - } + double a5, a6; /* average colors */ - d = c_cmaterial->rd + c_cmaterial->td + ts; + d = c_cmaterial->rd + c_cmaterial->td + c_cmaterial->ts; cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d); cvtcolor(c2, &c_cmaterial->td_c, c_cmaterial->td/d); addcolor(radrgb, c2); - cvtcolor(c2, &c_cmaterial->ts_c, ts/d); + cvtcolor(c2, &c_cmaterial->ts_c, c_cmaterial->ts/d); addcolor(radrgb, c2); - if (c_cmaterial->rs + ts > .0001) + if (c_cmaterial->rs + c_cmaterial->ts > .0001) a5 = (c_cmaterial->rs*c_cmaterial->rs_a + - ts*a5*c_cmaterial->ts_a) / - (c_cmaterial->rs + ts); - a6 = (c_cmaterial->td + ts) / - (c_cmaterial->rd + c_cmaterial->td + ts); + c_cmaterial->ts*c_cmaterial->ts_a) / + (c_cmaterial->rs + c_cmaterial->ts); + a6 = (c_cmaterial->td + c_cmaterial->ts) / + (c_cmaterial->rd + c_cmaterial->td + c_cmaterial->ts); if (a6 < .999) d = c_cmaterial->rd/(1. - c_cmaterial->rs)/(1. - a6); else - d = c_cmaterial->td + ts; + d = c_cmaterial->td + c_cmaterial->ts; scalecolor(radrgb, d); fprintf(matfp, "\nvoid trans %s\n0\n0\n", mname); fprintf(matfp, "7 %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU)); fprintf(matfp, "\t%f %f %f %f\n", c_cmaterial->rs, a5, a6, - ts/(ts + c_cmaterial->td)); + c_cmaterial->ts/(c_cmaterial->ts + c_cmaterial->td)); + if (c_cmaterial->sided) + putsided(mname); return(mname); } /* check for plastic */ - if (c_cmaterial->rs < .1) { - cvtcolor(radrgb, &c_cmaterial->rd_c, + if (c_cmaterial->rs < .1 && (c_cmaterial->rs < .1*c_cmaterial->rd || + c_isgrey(&c_cmaterial->rs_c))) { + pname = specolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/(1.-c_cmaterial->rs)); - fprintf(matfp, "\nvoid plastic %s\n0\n0\n", mname); + fprintf(matfp, "\n%s plastic %s\n0\n0\n", pname, mname); fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU), c_cmaterial->rs, c_cmaterial->rs_a); + if (c_cmaterial->sided) + putsided(mname); return(mname); } /* else it's metal */ - /* average colors */ - cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd); - cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs); - addcolor(radrgb, c2); - fprintf(matfp, "\nvoid metal %s\n0\n0\n", mname); + /* compute color */ + if (c_equiv(&c_cmaterial->rd_c, &c_cmaterial->rs_c)) { + pname = specolor(radrgb, &c_cmaterial->rs_c, c_cmaterial->rs+c_cmaterial->rd); + } else if (c_cmaterial->rd <= .05f) { + pname = specolor(radrgb, &c_cmaterial->rs_c, c_cmaterial->rs); + cvtcolor(c2, &c_cmaterial->rd_c, c_cmaterial->rd); + addcolor(radrgb, c2); + } else { + pname = "void"; + cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd); + cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs); + addcolor(radrgb, c2); + } + fprintf(matfp, "\n%s metal %s\n0\n0\n", pname, mname); fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU), c_cmaterial->rs/(c_cmaterial->rd + c_cmaterial->rs), c_cmaterial->rs_a); + if (c_cmaterial->sided) + putsided(mname); return(mname); } @@ -607,11 +643,11 @@ material(void) /* get (and print) current material * void cvtcolor( /* convert a CIE XYZ color to RGB */ COLOR radrgb, - register C_COLOR *ciec, + C_COLOR *ciec, double intensity ) { - static COLOR ciexyz; + COLOR ciexyz; c_ccvt(ciec, C_CSXY); /* get xy representation */ ciexyz[1] = intensity; @@ -621,12 +657,68 @@ cvtcolor( /* convert a CIE XYZ color to RGB */ } +static int /* new spectrum definition? */ +newspecdef(C_COLOR *spc) +{ + static LUTAB spc_tab = LU_SINIT(NULL,free); + LUENT *lp = lu_find(&spc_tab, (const char *)spc->client_data); + + if (lp == NULL) /* should never happen */ + return(1); + if (lp->data == NULL) { /* new entry */ + lp->key = (char *)spc->client_data; + lp->data = (char *)malloc(sizeof(C_COLOR)); + } else if (c_equiv(spc, (C_COLOR *)lp->data)) + return(0); /* unchanged */ + + if (lp->data != NULL) /* else remember if we can */ + *(C_COLOR *)lp->data = *spc; + return(1); /* good as new */ +} + + char * +specolor( /* check if color has spectra and output accordingly */ + COLOR radrgb, + C_COLOR *clr, + double intensity +) +{ + static char spname[128]; + double mult; + int i; + + if (!(clr->flags & C_CDSPEC)) { /* not defined spectrally? */ + cvtcolor(radrgb, clr, intensity); + return("void"); + } + setcolor(radrgb, intensity, intensity, intensity); + if (clr->client_data != NULL) { /* get name if available */ + strcpy(spname, (char *)clr->client_data); + strcat(spname, "*"); /* make sure it's special */ + if (!newspecdef(clr)) /* output already? */ + return(spname); + } else + strcpy(spname, "spec*"); + c_ccvt(clr, C_CSEFF); /* else output spectrum prim */ + fprintf(matfp, "\nvoid spectrum %s\n0\n0\n", spname); + fprintf(matfp, "%d %d %d", C_CNSS+2, C_CMINWL, C_CMAXWL); + mult = (C_CNSS*c_dfcolor.eff)/(clr->ssum*clr->eff); + for (i = 0; i < C_CNSS; i++) { + if (!((i+1)%6)) fputc('\n', matfp); + fprintf(matfp, "\t%.5f", clr->ssamp[i]*mult); + } + fputc('\n', matfp); + return(spname); +} + + +char * object(void) /* return current object name */ { static char objbuf[64]; - register int i; - register char *cp; + int i; + char *cp; int len; /* tracked by obj_handler */ i = obj_nnames - sizeof(objbuf)/16; @@ -645,8 +737,8 @@ object(void) /* return current object name */ char * addarg( /* add argument and advance pointer */ - register char *op, - register char *arg + char *op, + char *arg ) { *op = ' ';
