--- ray/src/cv/mgf2rad.c 1995/11/22 15:38:04 2.20 +++ ray/src/cv/mgf2rad.c 2003/06/26 00:58:09 2.26 @@ -1,14 +1,12 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: mgf2rad.c,v 2.26 2003/06/26 00:58:09 schorsch Exp $"; #endif - /* * Convert MGF (Materials and Geometry Format) to Radiance */ #include +#include #include #include #include "mgflib/parser.h" @@ -23,7 +21,7 @@ double glowdist = FHUGE; /* glow test distance */ double emult = 1.; /* emitter multiplier */ -FILE *matfp = stdout; /* material output file */ +FILE *matfp; /* material output file */ int r_comment(), r_cone(), r_cyl(), r_face(), r_ies(), r_ring(), r_sph(); char *material(), *object(), *addarg(); @@ -34,6 +32,8 @@ int argc; char *argv[]; { int i; + + matfp = stdout; /* print out parser version */ printf("## Translated from MGF Version %d.%d\n", MG_VMAJOR, MG_VMINOR); /* initialize dispatch table */ @@ -296,6 +296,7 @@ int ac; char **av; { static int nfaces; + int myi = invert; char *mat; register int i; register C_VERTEX *cv; @@ -307,16 +308,31 @@ char **av; if ((mat = material()) == NULL) /* get material */ return(MG_EBADMAT); if (ac <= 5) { /* check for smoothing */ + C_VERTEX *cva[5]; for (i = 1; i < ac; i++) { - if ((cv = c_getvert(av[i])) == NULL) + if ((cva[i-1] = c_getvert(av[i])) == NULL) return(MG_EUNDEF); - if (is0vect(cv->n)) + if (is0vect(cva[i-1]->n)) break; } - if (i == ac) { /* break into triangles */ - do_tri(mat, av[1], av[2], av[3]); + if (i < ac) + i = ISFLAT; + else + i = flat_tri(cva[0]->p, cva[1]->p, cva[2]->p, + cva[0]->n, cva[1]->n, cva[2]->n); + if (i == DEGEN) + return(MG_OK); /* degenerate (error?) */ + if (i == RVBENT) { + myi = !myi; + i = ISBENT; + } else if (i == RVFLAT) { + myi = !myi; + i = ISFLAT; + } + if (i == ISBENT) { /* smoothed triangles */ + do_tri(mat, cva[0], cva[1], cva[2], myi); if (ac == 5) - do_tri(mat, av[3], av[4], av[1]); + do_tri(mat, cva[2], cva[3], cva[0], myi); return(MG_OK); } } @@ -324,7 +340,7 @@ char **av; printf("\n%s polygon %sf%d\n", mat, object(), ++nfaces); printf("0\n0\n%d\n", 3*(ac-1)); for (i = 1; i < ac; i++) { /* get, transform, print each vertex */ - if ((cv = c_getvert(av[invert ? ac-i : i])) == NULL) + if ((cv = c_getvert(av[myi ? ac-i : i])) == NULL) return(MG_EUNDEF); xf_xfmpoint(v, cv->p); putv(v); @@ -348,7 +364,9 @@ char **av; if (ac < 2) return(MG_EARGC); /* construct output file name */ - if ((op = strrchr(av[1], '/')) == NULL) + if ((op = strrchr(av[1], '/')) != NULL) + op++; + else op = av[1]; (void)strcpy(fname, op); if ((op = strrchr(fname, '.')) == NULL) @@ -396,24 +414,23 @@ char **av; } -do_tri(mat, vn1, vn2, vn3) /* put out smoothed triangle */ -char *mat, *vn1, *vn2, *vn3; +do_tri(mat, cv1, cv2, cv3, iv) /* put out smoothed triangle */ +char *mat; +C_VERTEX *cv1, *cv2, *cv3; +int iv; { static int ntris; BARYCCM bvecs; - FLOAT bcoor[3][3]; - C_VERTEX *cv1, *cv2, *cv3; + RREAL bcoor[3][3]; + C_VERTEX *cvt; FVECT v1, v2, v3; FVECT n1, n2, n3; register int i; - /* the following is repeat code, so assume it's OK */ - cv2 = c_getvert(vn2); - if (invert) { - cv3 = c_getvert(vn1); - cv1 = c_getvert(vn3); - } else { - cv1 = c_getvert(vn1); - cv3 = c_getvert(vn3); + + if (iv) { /* swap vertex order if inverted */ + cvt = cv1; + cv1 = cv3; + cv3 = cvt; } xf_xfmpoint(v1, cv1->p); xf_xfmpoint(v2, cv2->p); @@ -539,8 +556,7 @@ material() /* get (and print) current material */ return(mname); } /* check for plastic */ - if (c_cmaterial->rs < .1 && (c_cmaterial->rs < .01 || - c_isgrey(&c_cmaterial->rs_c))) { + if (c_cmaterial->rs < .1) { cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/(1.-c_cmaterial->rs)); fprintf(matfp, "\nvoid plastic %s\n0\n0\n", mname);
