root/radiance/ray/src/cv/mgf2rad.c
Revision: 2.3
Committed: Fri Jun 24 17:16:51 1994 UTC (31 years, 1 month ago) by greg
Changes since 2.2: +4 -2 lines
slight modification to color handling
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert MGF (Materials and Geometry Format) to Radiance
9 */
10
11 #include <stdio.h>
12 #include <math.h>
13 #include <string.h>
14 #include "mgflib/parser.h"
15 #include "color.h"
16 #include "tmesh.h"
17
18 #define putv(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2])
19
20 double glowdist = FHUGE; /* glow test distance */
21
22 double emult = 1.; /* emmitter multiplier */
23
24 int r_comment(), r_cone(), r_cyl(), r_face(), r_ies(), r_ring(), r_sph();
25 char *material(), *object(), *addarg();
26
27
28 main(argc, argv) /* convert files to stdout */
29 int argc;
30 char *argv[];
31 {
32 int i, rv;
33 /* initialize dispatch table */
34 mg_ehand[MG_E_COMMENT] = r_comment;
35 mg_ehand[MG_E_COLOR] = c_hcolor;
36 mg_ehand[MG_E_CONE] = r_cone;
37 mg_ehand[MG_E_CXY] = c_hcolor;
38 mg_ehand[MG_E_CYL] = r_cyl;
39 mg_ehand[MG_E_ED] = c_hmaterial;
40 mg_ehand[MG_E_FACE] = r_face;
41 mg_ehand[MG_E_IES] = r_ies;
42 mg_ehand[MG_E_MATERIAL] = c_hmaterial;
43 mg_ehand[MG_E_NORMAL] = c_hvertex;
44 mg_ehand[MG_E_OBJECT] = obj_handler;
45 mg_ehand[MG_E_POINT] = c_hvertex;
46 mg_ehand[MG_E_RD] = c_hmaterial;
47 mg_ehand[MG_E_RING] = r_ring;
48 mg_ehand[MG_E_RS] = c_hmaterial;
49 mg_ehand[MG_E_SPH] = r_sph;
50 mg_ehand[MG_E_TD] = c_hmaterial;
51 mg_ehand[MG_E_TS] = c_hmaterial;
52 mg_ehand[MG_E_VERTEX] = c_hvertex;
53 mg_ehand[MG_E_XF] = xf_handler;
54 mg_init(); /* initialize the parser */
55 /* get options & print header */
56 printf("## %s", argv[0]);
57 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
58 printf(" %s", argv[i]);
59 switch (argv[i][1]) {
60 case 'g': /* glow distance (meters) */
61 if (argv[i][2] || badarg(argc-i, argv+i, "f"))
62 goto userr;
63 glowdist = atof(argv[++i]);
64 printf(" %s", argv[i]);
65 break;
66 case 'e': /* emitter multiplier */
67 if (argv[i][2] || badarg(argc-i, argv+i, "f"))
68 goto userr;
69 emult = atof(argv[++i]);
70 printf(" %s", argv[i]);
71 break;
72 default:
73 goto userr;
74 }
75 }
76 putchar('\n');
77 if (i == argc) { /* convert stdin */
78 if ((rv = mg_load(NULL)) != MG_OK)
79 exit(1);
80 } else /* convert each file */
81 for ( ; i < argc; i++) {
82 printf("## %s %s ##############################\n",
83 argv[0], argv[i]);
84 if ((rv = mg_load(argv[i])) != MG_OK)
85 exit(1);
86 }
87 exit(0);
88 userr:
89 fprintf(stderr, "Usage: %s [-g dist][-m mult] [file.mgf] ..\n",
90 argv[0]);
91 exit(1);
92 }
93
94
95 int
96 r_comment(ac, av) /* repeat a comment verbatim */
97 register int ac;
98 register char **av;
99 {
100 fputs("\n#", stdout); /* use Radiance comment character */
101 while (--ac) {
102 putchar(' ');
103 fputs(*++av, stdout);
104 }
105 putchar('\n');
106 return(MG_OK);
107 }
108
109
110 int
111 r_cone(ac, av) /* put out a cone */
112 int ac;
113 char **av;
114 {
115 static int ncones;
116 char *mat;
117 double r1, r2;
118 C_VERTEX *cv1, *cv2;
119 FVECT p1, p2;
120 int inv;
121
122 if (ac != 5)
123 return(MG_EARGC);
124 if (!isflt(av[2]) || !isflt(av[4]))
125 return(MG_ETYPE);
126 if ((cv1 = c_getvert(av[1])) == NULL ||
127 (cv2 = c_getvert(av[3])) == NULL)
128 return(MG_EUNDEF);
129 xf_xfmpoint(p1, cv1->p);
130 xf_xfmpoint(p2, cv2->p);
131 r1 = xf_scale(atof(av[2]));
132 r2 = xf_scale(atof(av[4]));
133 inv = r1 < 0.;
134 if (r1 == 0.) {
135 if (r2 == 0.)
136 return(MG_EILL);
137 inv = r2 < 0.;
138 } else if (r2 != 0. && inv ^ r2 < 0.)
139 return(MG_EILL);
140 if (inv) {
141 r1 = -r1;
142 r2 = -r2;
143 }
144 if ((mat = material()) == NULL)
145 return(MG_EBADMAT);
146 printf("\n%s %s %sc%d\n", mat, inv ? "cup" : "cone",
147 object(), ++ncones);
148 printf("0\n0\n8\n");
149 putv(p1);
150 putv(p2);
151 printf("%18.12g %18.12g\n", r1, r2);
152 return(MG_OK);
153 }
154
155
156 int
157 r_cyl(ac, av) /* put out a cylinder */
158 int ac;
159 char **av;
160 {
161 static int ncyls;
162 char *mat;
163 double rad;
164 C_VERTEX *cv1, *cv2;
165 FVECT p1, p2;
166 int inv;
167
168 if (ac != 4)
169 return(MG_EARGC);
170 if (!isflt(av[2]))
171 return(MG_ETYPE);
172 if ((cv1 = c_getvert(av[1])) == NULL ||
173 (cv2 = c_getvert(av[3])) == NULL)
174 return(MG_EUNDEF);
175 xf_xfmpoint(p1, cv1->p);
176 xf_xfmpoint(p2, cv2->p);
177 rad = xf_scale(atof(av[2]));
178 if ((inv = rad < 0.))
179 rad = -rad;
180 if ((mat = material()) == NULL)
181 return(MG_EBADMAT);
182 printf("\n%s %s %scy%d\n", mat, inv ? "tube" : "cylinder",
183 object(), ++ncyls);
184 printf("0\n0\n7\n");
185 putv(p1);
186 putv(p2);
187 printf("%18.12g\n", rad);
188 return(MG_OK);
189 }
190
191
192 int
193 r_sph(ac, av) /* put out a sphere */
194 int ac;
195 char **av;
196 {
197 static int nsphs;
198 char *mat;
199 double rad;
200 C_VERTEX *cv;
201 FVECT cent;
202 int inv;
203
204 if (ac != 3)
205 return(MG_EARGC);
206 if (!isflt(av[2]))
207 return(MG_ETYPE);
208 if ((cv = c_getvert(av[1])) == NULL)
209 return(MG_EUNDEF);
210 xf_xfmpoint(cent, cv->p);
211 rad = xf_scale(atof(av[2]));
212 if ((inv = rad < 0.))
213 rad = -rad;
214 if ((mat = material()) == NULL)
215 return(MG_EBADMAT);
216 printf("\n%s %s %ss%d\n", mat, inv ? "bubble" : "sphere",
217 object(), ++nsphs);
218 printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n",
219 cent[0], cent[1], cent[2], rad);
220 return(MG_OK);
221 }
222
223
224 int
225 r_ring(ac, av) /* put out a ring */
226 int ac;
227 char **av;
228 {
229 static int nrings;
230 char *mat;
231 double r1, r2;
232 C_VERTEX *cv;
233 FVECT cent, norm;
234
235 if (ac != 4)
236 return(MG_EARGC);
237 if (!isflt(av[2]) || !isflt(av[3]))
238 return(MG_ETYPE);
239 if ((cv = c_getvert(av[1])) == NULL)
240 return(MG_EUNDEF);
241 if (is0vect(cv->n))
242 return(MG_EILL);
243 xf_xfmpoint(cent, cv->p);
244 xf_rotvect(norm, cv->n);
245 r1 = xf_scale(atof(av[2]));
246 r2 = xf_scale(atof(av[3]));
247 if (r1 < 0. | r2 <= r1)
248 return(MG_EILL);
249 if ((mat = material()) == NULL)
250 return(MG_EBADMAT);
251 printf("\n%s ring %sr%d\n", mat, object(), ++nrings);
252 printf("0\n0\n8\n");
253 putv(cent);
254 putv(norm);
255 printf("%18.12g %18.12g\n", r1, r2);
256 return(MG_OK);
257 }
258
259
260 int
261 r_face(ac, av) /* convert a face */
262 int ac;
263 char **av;
264 {
265 static int nfaces;
266 char *mat;
267 register int i;
268 register C_VERTEX *cv;
269 FVECT v;
270 int rv;
271
272 if (ac < 4)
273 return(MG_EARGC);
274 if ((mat = material()) == NULL)
275 return(MG_EBADMAT);
276 if (ac <= 5) { /* check for surface normals */
277 for (i = 1; i < ac; i++) {
278 if ((cv = c_getvert(av[i])) == NULL)
279 return(MG_EUNDEF);
280 if (is0vect(cv->n))
281 break;
282 }
283 if (i == ac) { /* break into triangles */
284 do_tri(mat, av[1], av[2], av[3]);
285 if (ac == 5)
286 do_tri(mat, av[3], av[4], av[1]);
287 return(MG_OK);
288 }
289 }
290 printf("\n%s polygon %sf%d\n", mat, object(), ++nfaces);
291 printf("0\n0\n%d\n", 3*(ac-1));
292 for (i = 1; i < ac; i++) {
293 if ((cv = c_getvert(av[i])) == NULL)
294 return(MG_EUNDEF);
295 xf_xfmpoint(v, cv->p);
296 putv(v);
297 }
298 return(MG_OK);
299 }
300
301
302 r_ies(ac, av) /* convert an IES luminaire file */
303 int ac;
304 char **av;
305 {
306 int xa0 = 2;
307 char combuf[72];
308 char fname[48];
309 char *oname;
310 register char *op;
311 register int i;
312
313 if (ac < 2)
314 return(MG_EARGC);
315 (void)strcpy(combuf, "ies2rad");
316 op = combuf + 7;
317 if (ac-xa0 >= 2 && !strcmp(av[xa0], "-m")) {
318 if (!isflt(av[xa0+1]))
319 return(MG_ETYPE);
320 op = addarg(addarg(op, "-m"), av[xa0+1]);
321 xa0 += 2;
322 }
323 if (access(av[1], 0) == -1)
324 return(MG_ENOFILE);
325 *op++ = ' '; /* IES filename goes last */
326 (void)strcpy(op, av[1]);
327 system(combuf); /* run ies2rad */
328 /* now let's find the output file */
329 if ((op = strrchr(av[1], '/')) == NULL)
330 op = av[1];
331 (void)strcpy(fname, op);
332 if ((op = strrchr(fname, '.')) == NULL)
333 op = fname + strlen(fname);
334 (void)strcpy(op, ".rad");
335 if (access(fname, 0) == -1)
336 return(MG_EINCL);
337 /* put out xform command */
338 printf("\n!xform");
339 oname = object();
340 if (*oname)
341 printf(" -n %s", oname);
342 for (i = xa0; i < ac; i++)
343 printf(" %s", av[i]);
344 if (ac > xa0 && xf_argc > 0)
345 printf(" -i 1");
346 for (i = 0; i < xf_argc; i++)
347 printf(" %s", xf_argv[i]);
348 printf(" %s\n", fname);
349 return(MG_OK);
350 }
351
352
353 do_tri(mat, vn1, vn2, vn3) /* put out smoothed triangle */
354 char *mat, *vn1, *vn2, *vn3;
355 {
356 static int ntris;
357 BARYCCM bvecs;
358 FLOAT bcoor[3][3];
359 C_VERTEX *cv1, *cv2, *cv3;
360 FVECT v1, v2, v3;
361 FVECT n1, n2, n3;
362 register int i;
363 /* the following is repeat code, so assume it's OK */
364 cv1 = c_getvert(vn1);
365 cv2 = c_getvert(vn2);
366 cv3 = c_getvert(vn3);
367 xf_xfmpoint(v1, cv1->p);
368 xf_xfmpoint(v2, cv2->p);
369 xf_xfmpoint(v3, cv3->p);
370 if (comp_baryc(&bvecs, v1, v2, v3) < 0)
371 return; /* degenerate triangle! */
372 printf("\n%s texfunc T-nor\n", mat);
373 printf("4 dx dy dz %s\n0\n", TCALNAME);
374 xf_rotvect(n1, cv1->n);
375 xf_rotvect(n2, cv2->n);
376 xf_rotvect(n3, cv3->n);
377 for (i = 0; i < 3; i++) {
378 bcoor[i][0] = n1[i];
379 bcoor[i][1] = n2[i];
380 bcoor[i][2] = n3[i];
381 }
382 put_baryc(&bvecs, bcoor, 3);
383 printf("\nT-nor polygon %st%d\n", object(), ++ntris);
384 printf("0\n0\n9\n");
385 putv(v1);
386 putv(v2);
387 putv(v3);
388 }
389
390
391 char *
392 material() /* get (and print) current material */
393 {
394 char *mname = "mat";
395 COLOR radrgb, c2;
396 double d;
397 register int i;
398
399 if (c_cmaterial->name != NULL)
400 mname = c_cmaterial->name;
401 if (!c_cmaterial->clock)
402 return(mname); /* already current */
403 /* else update output */
404 c_cmaterial->clock = 0;
405 if (c_cmaterial->ed > .1) { /* emitter */
406 cvtcolor(radrgb, &c_cmaterial->ed_c,
407 emult*c_cmaterial->ed/WHTEFFICACY);
408 if (glowdist < FHUGE) { /* do a glow */
409 printf("\nvoid glow %s\n0\n0\n", mname);
410 printf("4 %f %f %f %f\n", colval(radrgb,RED),
411 colval(radrgb,GRN),
412 colval(radrgb,BLU), glowdist);
413 } else {
414 printf("\nvoid light %s\n0\n0\n", mname);
415 printf("3 %f %f %f\n", colval(radrgb,RED),
416 colval(radrgb,GRN),
417 colval(radrgb,BLU));
418 }
419 return(mname);
420 }
421 d = c_cmaterial->rd + c_cmaterial->td +
422 c_cmaterial->rs + c_cmaterial->ts;
423 if (d <= 0. | d >= 1.)
424 return(NULL);
425 /* check for trans */
426 if (c_cmaterial->td > .01 || c_cmaterial->ts > .01) {
427 double ts, a5, a6;
428
429 ts = sqrt(c_cmaterial->ts); /* because we use 2 sides */
430 /* average colors */
431 d = c_cmaterial->rd + c_cmaterial->td + ts;
432 cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d);
433 cvtcolor(c2, &c_cmaterial->td_c, c_cmaterial->td/d);
434 addcolor(radrgb, c2);
435 cvtcolor(c2, &c_cmaterial->ts_c, ts/d);
436 addcolor(radrgb, c2);
437 if (c_cmaterial->rs + ts > .0001)
438 a5 = (c_cmaterial->rs*c_cmaterial->rs_a +
439 ts*.5*c_cmaterial->ts_a) /
440 (c_cmaterial->rs + ts);
441 a6 = (c_cmaterial->td + ts) /
442 (c_cmaterial->rd + c_cmaterial->td + ts);
443 if (a6 < .999) {
444 d = c_cmaterial->rd/(1. - c_cmaterial->rs)/(1. - a6);
445 scalecolor(radrgb, d);
446 }
447 printf("\nvoid trans %s\n0\n0\n", mname);
448 printf("7 %f %f %f\n", colval(radrgb,RED),
449 colval(radrgb,GRN), colval(radrgb,BLU));
450 printf("\t%f %f %f %f\n", c_cmaterial->rs, a5, a6,
451 ts/(ts + c_cmaterial->td));
452 return(mname);
453 }
454 /* check for plastic */
455 if (c_cmaterial->rs < .01 || c_isgrey(&c_cmaterial->rs_c)) {
456 if (c_cmaterial->rs > .999)
457 cvtcolor(radrgb, &c_cmaterial->rd_c, 1.);
458 else
459 cvtcolor(radrgb, &c_cmaterial->rd_c,
460 c_cmaterial->rd/(1.-c_cmaterial->rs));
461 printf("\nvoid plastic %s\n0\n0\n", mname);
462 printf("5 %f %f %f %f %f\n", colval(radrgb,RED),
463 colval(radrgb,GRN), colval(radrgb,BLU),
464 c_cmaterial->rs, c_cmaterial->rs_a);
465 return(mname);
466 }
467 /* else it's metal */
468 d = c_cmaterial->rd + c_cmaterial->rs; /* average colors */
469 cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d);
470 cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs/d);
471 addcolor(radrgb, c2);
472 if (c_cmaterial->rs < .999) {
473 d = c_cmaterial->rd/(1. - c_cmaterial->rs);
474 scalecolor(radrgb, d);
475 }
476 printf("\nvoid metal %s\n0\n0\n", mname);
477 printf("5 %f %f %f %f %f\n", colval(radrgb,RED),
478 colval(radrgb,GRN), colval(radrgb,BLU),
479 c_cmaterial->rs, c_cmaterial->rs_a);
480 return(mname);
481 }
482
483
484 cvtcolor(radrgb, ciec, intensity) /* convert a CIE color to Radiance */
485 COLOR radrgb;
486 register C_COLOR *ciec;
487 double intensity;
488 {
489 static COLOR ciexyz;
490
491 ciexyz[1] = intensity;
492 ciexyz[0] = ciec->cx/ciec->cy*ciexyz[1];
493 ciexyz[2] = ciexyz[1]*(1./ciec->cy - 1.) - ciexyz[0];
494 cie_rgb(radrgb, ciexyz);
495 }
496
497
498 char *
499 object() /* return current object name */
500 {
501 static char objbuf[64];
502 register int i;
503 register char *cp;
504 int len;
505
506 i = obj_nnames - sizeof(objbuf)/16;
507 if (i < 0)
508 i = 0;
509 for (cp = objbuf; i < obj_nnames &&
510 cp + (len=strlen(obj_name[i])) < objbuf+sizeof(objbuf)-1;
511 i++, *cp++ = '.') {
512 strcpy(cp, obj_name[i]);
513 cp += len;
514 }
515 *cp = '\0';
516 return(objbuf);
517 }
518
519
520 char *
521 addarg(op, arg) /* add argument and advance pointer */
522 register char *op, *arg;
523 {
524 *op = ' ';
525 while (*++op = *arg++)
526 ;
527 return(op);
528 }
