root/radiance/ray/src/cv/mgf2rad.c
Fri May 23 17:02:07 2025 UTC (2 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.35: +141 -6 lines
Diff to previous 2.35 , to selected 2.32
feat(mgf2rad): Added support of WGMDfunc material for different spectral components
Wed Jan 17 00:43:45 2024 UTC (18 months, 2 weeks ago) by greg
Changes since 2.34: +9 -4 lines
Diff to previous 2.34 , to selected 2.32
feat(mgf2rad): Made spectra conversion optional with -s command-line flag
Fri Jan 5 16:33:36 2024 UTC (18 months, 3 weeks ago) by greg
Changes since 2.33: +13 -5 lines
Diff to previous 2.33 , to selected 2.32
perf(mgf2rad): Trim zero spectral values at ends
Thu Jan 4 01:55:42 2024 UTC (18 months, 4 weeks ago) by greg
Changes since 2.32: +113 -29 lines
Diff to previous 2.32
feat(mgf2rad): Now handles spectral color translation
Revision 2.32 - (view) (download) (annotate) - [selected]
Thu Apr 15 23:51:04 2021 UTC (4 years, 3 months ago) by greg
Diff to previous 2.31
Mon Oct 3 18:16:45 2016 UTC (8 years, 9 months ago) by greg
Changes since 2.30: +3 -2 lines
Diff to previous 2.30 , to selected 2.32
Fixed issue pointed out by David G-M with metal material translation
Sat Jan 25 18:02:06 2014 UTC (11 years, 6 months ago) by greg
Changes since 2.29: +38 -31 lines
Diff to previous 2.29 , to selected 2.32
Made one-sided materials really work using mixfunc
Tue Feb 22 16:45:12 2011 UTC (14 years, 5 months ago) by greg
Diff to previous 2.28 , to selected 2.32
Fixed a few compile errors due to code reorg
Sat Nov 15 17:54:06 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 2.27: +70 -41 lines
Diff to previous 2.27 , to selected 2.32
Sun Jul 27 22:12:01 2003 UTC (22 years ago) by schorsch
Changes since 2.26: +5 -5 lines
Diff to previous 2.26 , to selected 2.32
Thu Jun 26 00:58:09 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.25 , to selected 2.32
Sat Feb 22 02:07:23 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.24: +21 -13 lines
Diff to previous 2.24 , to selected 2.32
Wed Jun 9 14:06:00 1999 UTC (26 years, 1 month ago) by gwlarson
Changes since 2.23: +3 -1 lines
Diff to previous 2.23 , to selected 2.32
moved output file initialization into main for Linux non-constant stdout
Wed Jul 24 13:07:48 1996 UTC (29 years ago) by greg
Changes since 2.22: +21 -16 lines
Diff to previous 2.22 , to selected 2.32
added check for flat triangles with normals
Thu Jun 6 11:49:53 1996 UTC (29 years, 2 months ago) by greg
Changes since 2.21: +3 -1 lines
Diff to previous 2.21 , to selected 2.32
bug fix in r_ies() associated with IES file pathnames
Tue Feb 27 20:11:27 1996 UTC (29 years, 5 months ago) by greg
Changes since 2.20: +2 -3 lines
Diff to previous 2.20 , to selected 2.32
made choice of plastic more typical
Wed Nov 22 15:38:04 1995 UTC (29 years, 8 months ago) by greg
Diff to previous 2.19 , to selected 2.32
minor change removing unneeded variable
Thu May 11 21:49:05 1995 UTC (30 years, 2 months ago) by greg
Changes since 2.18: +2 -0 lines
Diff to previous 2.18 , to selected 2.32
added MGF version tracking
Thu May 11 20:17:56 1995 UTC (30 years, 2 months ago) by greg
Changes since 2.17: +9 -1 lines
Diff to previous 2.17 , to selected 2.32
added default handling of undefined entities
Mon May 1 17:05:22 1995 UTC (30 years, 3 months ago) by greg
Diff to previous 2.16 , to selected 2.32
bug fix in r_ies
Fri Apr 14 19:03:20 1995 UTC (30 years, 3 months ago) by greg
Changes since 2.15: +94 -83 lines
Diff to previous 2.15 , to selected 2.32
added lots of comments and added file precheck to r_ies()
Fri Apr 14 10:47:50 1995 UTC (30 years, 3 months ago) by greg
Changes since 2.14: +12 -5 lines
Diff to previous 2.14 , to selected 2.32
fixed bug in ies conversion routine for getting file context
Thu Apr 13 14:43:33 1995 UTC (30 years, 3 months ago) by greg
Changes since 2.13: +28 -0 lines
Diff to previous 2.13 , to selected 2.32
added MGF index of refraction (ir) and dielectric support
Tue Mar 7 12:18:15 1995 UTC (30 years, 5 months ago) by greg
Changes since 2.12: +1 -0 lines
Diff to previous 2.12 , to selected 2.32
added cct entity
Wed Dec 7 12:40:37 1994 UTC (30 years, 8 months ago) by greg
Diff to previous 2.11 , to selected 2.32
fixed conversion of emittance
Fri Aug 26 12:54:24 1994 UTC (30 years, 11 months ago) by greg
Changes since 2.10: +22 -12 lines
Diff to previous 2.10 , to selected 2.32
added -m option for separate materials file
Thu Jul 21 17:23:43 1994 UTC (31 years ago) by greg
Diff to previous 2.9 , to selected 2.32
fixed bad argument parsing
Thu Jul 21 15:04:23 1994 UTC (31 years ago) by greg
Changes since 2.8: +10 -3 lines
Diff to previous 2.8 , to selected 2.32
added vertex reversal
Tue Jul 19 15:54:44 1994 UTC (31 years ago) by greg
Diff to previous 2.7 , to selected 2.32
spelling correction in comment (really!)
Fri Jul 8 16:10:09 1994 UTC (31 years, 1 month ago) by greg
Changes since 2.6: +17 -19 lines
Diff to previous 2.6 , to selected 2.32
numerous bug fixes and enhancements
Fri Jul 1 18:06:36 1994 UTC (31 years, 1 month ago) by greg
Changes since 2.5: +7 -2 lines
Diff to previous 2.5 , to selected 2.32
added "sides" entity for one- vs. two-sided surfaces
Fri Jul 1 10:20:19 1994 UTC (31 years, 1 month ago) by greg
Diff to previous 2.4 , to selected 2.32
changed context names from struct members to extern variables
Sat Jun 25 09:45:22 1994 UTC (31 years, 1 month ago) by greg
Changes since 2.3: +8 -2 lines
Diff to previous 2.3 , to selected 2.32
added further color support
Fri Jun 24 17:16:51 1994 UTC (31 years, 1 month ago) by greg
Changes since 2.2: +4 -2 lines
Diff to previous 2.2 , to selected 2.32
slight modification to color handling
Wed Jun 22 17:16:03 1994 UTC (31 years, 1 month ago) by greg
Changes since 2.1: +16 -25 lines
Diff to previous 2.1 , to selected 2.32
bug fixes
Wed Jun 22 15:33:03 1994 UTC (31 years, 1 month ago) by greg
Diff to selected 2.32
