--- ray/src/cv/mgf2rad.c 1995/04/14 10:47:50 2.15 +++ ray/src/cv/mgf2rad.c 2011/02/22 16:45:12 2.29 @@ -1,17 +1,17 @@ -/* Copyright (c) 1994 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: mgf2rad.c,v 2.29 2011/02/22 16:45:12 greg Exp $"; #endif - /* * Convert MGF (Materials and Geometry Format) to Radiance */ #include +#include #include #include -#include "mgflib/parser.h" + +#include "platform.h" +#include "mgf_parser.h" #include "color.h" #include "tmesh.h" @@ -23,45 +23,62 @@ double glowdist = FHUGE; /* glow test distance */ double emult = 1.; /* emitter multiplier */ -FILE *matfp = stdout; /* material output file */ +FILE *matfp; /* material output file */ -int r_comment(), r_cone(), r_cyl(), r_face(), r_ies(), r_ring(), r_sph(); -char *material(), *object(), *addarg(); +int r_comment(int ac, char **av); +int r_cone(int ac, char **av); +int r_cyl(int ac, char **av); +int r_sph(int ac, char **av); +int r_ring(int ac, char **av); +int r_face(int ac, char **av); +int r_ies(int ac, char **av); +char * material(void); +char * object(void); +char * addarg(char *op, char *arg); +void do_tri(char *mat, C_VERTEX *cv1, C_VERTEX *cv2, C_VERTEX *cv3, int iv); +void cvtcolor(COLOR radrgb, register C_COLOR *ciec, double intensity); -main(argc, argv) /* convert files to stdout */ -int argc; -char *argv[]; + +int +main( + int argc, + char *argv[] +) { - int i, rv; + int i; + + matfp = stdout; + /* print out parser version */ + printf("## Translated from MGF Version %d.%d\n", MG_VMAJOR, MG_VMINOR); /* initialize dispatch table */ - mg_ehand[MG_E_COMMENT] = r_comment; - mg_ehand[MG_E_COLOR] = c_hcolor; - mg_ehand[MG_E_CONE] = r_cone; - mg_ehand[MG_E_CMIX] = c_hcolor; - mg_ehand[MG_E_CSPEC] = c_hcolor; - mg_ehand[MG_E_CXY] = c_hcolor; - mg_ehand[MG_E_CCT] = c_hcolor; - mg_ehand[MG_E_CYL] = r_cyl; - mg_ehand[MG_E_ED] = c_hmaterial; - mg_ehand[MG_E_FACE] = r_face; - mg_ehand[MG_E_IES] = r_ies; - mg_ehand[MG_E_IR] = c_hmaterial; - mg_ehand[MG_E_MATERIAL] = c_hmaterial; - mg_ehand[MG_E_NORMAL] = c_hvertex; - mg_ehand[MG_E_OBJECT] = obj_handler; - mg_ehand[MG_E_POINT] = c_hvertex; - mg_ehand[MG_E_RD] = c_hmaterial; - mg_ehand[MG_E_RING] = r_ring; - mg_ehand[MG_E_RS] = c_hmaterial; - mg_ehand[MG_E_SIDES] = c_hmaterial; - mg_ehand[MG_E_SPH] = r_sph; - mg_ehand[MG_E_TD] = c_hmaterial; - mg_ehand[MG_E_TS] = c_hmaterial; - mg_ehand[MG_E_VERTEX] = c_hvertex; - mg_ehand[MG_E_XF] = xf_handler; + mg_ehand[MG_E_COMMENT] = r_comment; /* we pass comments */ + mg_ehand[MG_E_COLOR] = c_hcolor; /* they get color */ + mg_ehand[MG_E_CONE] = r_cone; /* we do cones */ + mg_ehand[MG_E_CMIX] = c_hcolor; /* they mix colors */ + mg_ehand[MG_E_CSPEC] = c_hcolor; /* they get spectra */ + mg_ehand[MG_E_CXY] = c_hcolor; /* they get chromaticities */ + mg_ehand[MG_E_CCT] = c_hcolor; /* they get color temp's */ + mg_ehand[MG_E_CYL] = r_cyl; /* we do cylinders */ + mg_ehand[MG_E_ED] = c_hmaterial; /* they get emission */ + mg_ehand[MG_E_FACE] = r_face; /* we do faces */ + mg_ehand[MG_E_IES] = r_ies; /* we do IES files */ + mg_ehand[MG_E_IR] = c_hmaterial; /* they get refractive index */ + mg_ehand[MG_E_MATERIAL] = c_hmaterial; /* they get materials */ + mg_ehand[MG_E_NORMAL] = c_hvertex; /* they get normals */ + mg_ehand[MG_E_OBJECT] = obj_handler; /* they track object names */ + mg_ehand[MG_E_POINT] = c_hvertex; /* they get points */ + mg_ehand[MG_E_RD] = c_hmaterial; /* they get diffuse refl. */ + mg_ehand[MG_E_RING] = r_ring; /* we do rings */ + mg_ehand[MG_E_RS] = c_hmaterial; /* they get specular refl. */ + mg_ehand[MG_E_SIDES] = c_hmaterial; /* they get # sides */ + mg_ehand[MG_E_SPH] = r_sph; /* we do spheres */ + mg_ehand[MG_E_TD] = c_hmaterial; /* they get diffuse trans. */ + mg_ehand[MG_E_TS] = c_hmaterial; /* they get specular trans. */ + mg_ehand[MG_E_VERTEX] = c_hvertex; /* they get vertices */ + mg_ehand[MG_E_XF] = xf_handler; /* they track transforms */ mg_init(); /* initialize the parser */ - /* get options & print header */ + /* get our options & print header */ printf("## %s", argv[0]); for (i = 1; i < argc && argv[i][0] == '-'; i++) { printf(" %s", argv[i]); @@ -92,14 +109,22 @@ char *argv[]; } putchar('\n'); if (i == argc) { /* convert stdin */ - if ((rv = mg_load(NULL)) != MG_OK) + if (mg_load(NULL) != MG_OK) exit(1); + if (mg_nunknown) + printf("## %s: %u unknown entities\n", + argv[0], mg_nunknown); } else /* convert each file */ for ( ; i < argc; i++) { printf("## %s %s ##############################\n", argv[0], argv[i]); - if ((rv = mg_load(argv[i])) != MG_OK) + if (mg_load(argv[i]) != MG_OK) exit(1); + if (mg_nunknown) { + printf("## %s %s: %u unknown entities\n", + argv[0], argv[i], mg_nunknown); + mg_nunknown = 0; + } } exit(0); userr: @@ -110,12 +135,13 @@ userr: int -r_comment(ac, av) /* repeat a comment verbatim */ -register int ac; -register char **av; +r_comment( /* repeat a comment verbatim */ + register int ac, + register char **av +) { putchar('#'); /* use Radiance comment character */ - while (--ac) { + while (--ac) { /* pass through verbatim */ putchar(' '); fputs(*++av, stdout); } @@ -125,9 +151,10 @@ register char **av; int -r_cone(ac, av) /* put out a cone */ -int ac; -char **av; +r_cone( /* put out a cone */ + int ac, + char **av +) { static int ncones; char *mat; @@ -135,31 +162,33 @@ char **av; C_VERTEX *cv1, *cv2; FVECT p1, p2; int inv; - + /* check argument count and type */ if (ac != 5) return(MG_EARGC); if (!isflt(av[2]) || !isflt(av[4])) return(MG_ETYPE); + /* get the endpoint vertices */ if ((cv1 = c_getvert(av[1])) == NULL || (cv2 = c_getvert(av[3])) == NULL) return(MG_EUNDEF); - xf_xfmpoint(p1, cv1->p); + xf_xfmpoint(p1, cv1->p); /* transform endpoints */ xf_xfmpoint(p2, cv2->p); - r1 = xf_scale(atof(av[2])); + r1 = xf_scale(atof(av[2])); /* scale radii */ r2 = xf_scale(atof(av[4])); - inv = r1 < 0.; - if (r1 == 0.) { + inv = r1 < 0.; /* check for inverted cone */ + if (r1 == 0.) { /* check for illegal radii */ if (r2 == 0.) return(MG_EILL); inv = r2 < 0.; - } else if (r2 != 0. && inv ^ r2 < 0.) + } else if (r2 != 0. && inv ^ (r2 < 0.)) return(MG_EILL); if (inv) { r1 = -r1; r2 = -r2; } - if ((mat = material()) == NULL) + if ((mat = material()) == NULL) /* get material */ return(MG_EBADMAT); + /* spit the sucker out */ printf("\n%s %s %sc%d\n", mat, inv ? "cup" : "cone", object(), ++ncones); printf("0\n0\n8\n"); @@ -171,9 +200,10 @@ char **av; int -r_cyl(ac, av) /* put out a cylinder */ -int ac; -char **av; +r_cyl( /* put out a cylinder */ + int ac, + char **av +) { static int ncyls; char *mat; @@ -181,21 +211,23 @@ char **av; C_VERTEX *cv1, *cv2; FVECT p1, p2; int inv; - + /* check argument count and type */ if (ac != 4) return(MG_EARGC); if (!isflt(av[2])) return(MG_ETYPE); + /* get the endpoint vertices */ if ((cv1 = c_getvert(av[1])) == NULL || (cv2 = c_getvert(av[3])) == NULL) return(MG_EUNDEF); - xf_xfmpoint(p1, cv1->p); + xf_xfmpoint(p1, cv1->p); /* transform endpoints */ xf_xfmpoint(p2, cv2->p); - rad = xf_scale(atof(av[2])); - if ((inv = rad < 0.)) + rad = xf_scale(atof(av[2])); /* scale radius */ + if ((inv = rad < 0.)) /* check for inverted cylinder */ rad = -rad; - if ((mat = material()) == NULL) + if ((mat = material()) == NULL) /* get material */ return(MG_EBADMAT); + /* spit out the primitive */ printf("\n%s %s %scy%d\n", mat, inv ? "tube" : "cylinder", object(), ++ncyls); printf("0\n0\n7\n"); @@ -207,9 +239,10 @@ char **av; int -r_sph(ac, av) /* put out a sphere */ -int ac; -char **av; +r_sph( /* put out a sphere */ + int ac, + char **av +) { static int nsphs; char *mat; @@ -217,19 +250,20 @@ char **av; C_VERTEX *cv; FVECT cent; int inv; - + /* check argument count and type */ if (ac != 3) return(MG_EARGC); if (!isflt(av[2])) return(MG_ETYPE); - if ((cv = c_getvert(av[1])) == NULL) + if ((cv = c_getvert(av[1])) == NULL) /* get center vertex */ return(MG_EUNDEF); - xf_xfmpoint(cent, cv->p); - rad = xf_scale(atof(av[2])); - if ((inv = rad < 0.)) + xf_xfmpoint(cent, cv->p); /* transform center */ + rad = xf_scale(atof(av[2])); /* scale radius */ + if ((inv = rad < 0.)) /* check for inversion */ rad = -rad; - if ((mat = material()) == NULL) + if ((mat = material()) == NULL) /* get material */ return(MG_EBADMAT); + /* spit out primitive */ printf("\n%s %s %ss%d\n", mat, inv ? "bubble" : "sphere", object(), ++nsphs); printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n", @@ -239,32 +273,34 @@ char **av; int -r_ring(ac, av) /* put out a ring */ -int ac; -char **av; +r_ring( /* put out a ring */ + int ac, + char **av +) { static int nrings; char *mat; double r1, r2; C_VERTEX *cv; FVECT cent, norm; - + /* check argument count and type */ if (ac != 4) return(MG_EARGC); if (!isflt(av[2]) || !isflt(av[3])) return(MG_ETYPE); - if ((cv = c_getvert(av[1])) == NULL) + if ((cv = c_getvert(av[1])) == NULL) /* get center vertex */ return(MG_EUNDEF); - if (is0vect(cv->n)) + if (is0vect(cv->n)) /* make sure we have normal */ return(MG_EILL); - xf_xfmpoint(cent, cv->p); - xf_rotvect(norm, cv->n); - r1 = xf_scale(atof(av[2])); + xf_xfmpoint(cent, cv->p); /* transform center */ + xf_rotvect(norm, cv->n); /* rotate normal */ + r1 = xf_scale(atof(av[2])); /* scale radii */ r2 = xf_scale(atof(av[3])); - if (r1 < 0. | r2 <= r1) + if ((r1 < 0.) | (r2 <= r1)) return(MG_EILL); - if ((mat = material()) == NULL) + if ((mat = material()) == NULL) /* get material */ return(MG_EBADMAT); + /* spit out primitive */ printf("\n%s ring %sr%d\n", mat, object(), ++nrings); printf("0\n0\n8\n"); putv(cent); @@ -275,39 +311,57 @@ char **av; int -r_face(ac, av) /* convert a face */ -int ac; -char **av; +r_face( /* convert a face */ + int ac, + char **av +) { static int nfaces; + int myi = invert; char *mat; register int i; register C_VERTEX *cv; FVECT v; - int rv; + /* check argument count and type */ if (ac < 4) return(MG_EARGC); - if ((mat = material()) == NULL) + if ((mat = material()) == NULL) /* get material */ return(MG_EBADMAT); - if (ac <= 5) { /* check for surface normals */ + if (ac <= 5) { /* check for smoothing */ + C_VERTEX *cva[5]; for (i = 1; i < ac; i++) { - if ((cv = c_getvert(av[i])) == NULL) + if ((cva[i-1] = c_getvert(av[i])) == NULL) return(MG_EUNDEF); - if (is0vect(cv->n)) + if (is0vect(cva[i-1]->n)) break; } - if (i == ac) { /* break into triangles */ - do_tri(mat, av[1], av[2], av[3]); + if (i < ac) + i = ISFLAT; + else + i = flat_tri(cva[0]->p, cva[1]->p, cva[2]->p, + cva[0]->n, cva[1]->n, cva[2]->n); + if (i == DEGEN) + return(MG_OK); /* degenerate (error?) */ + if (i == RVBENT) { + myi = !myi; + i = ISBENT; + } else if (i == RVFLAT) { + myi = !myi; + i = ISFLAT; + } + if (i == ISBENT) { /* smoothed triangles */ + do_tri(mat, cva[0], cva[1], cva[2], myi); if (ac == 5) - do_tri(mat, av[3], av[4], av[1]); + do_tri(mat, cva[2], cva[3], cva[0], myi); return(MG_OK); } } + /* spit out unsmoothed primitive */ printf("\n%s polygon %sf%d\n", mat, object(), ++nfaces); printf("0\n0\n%d\n", 3*(ac-1)); - for (i = 1; i < ac; i++) { - if ((cv = c_getvert(av[invert ? ac-i : i])) == NULL) + for (i = 1; i < ac; i++) { /* get, transform, print each vertex */ + if ((cv = c_getvert(av[myi ? ac-i : i])) == NULL) return(MG_EUNDEF); xf_xfmpoint(v, cv->p); putv(v); @@ -317,9 +371,10 @@ char **av; int -r_ies(ac, av) /* convert an IES luminaire file */ -int ac; -char **av; +r_ies( /* convert an IES luminaire file */ + int ac, + char **av +) { int xa0 = 2; char combuf[128]; @@ -327,39 +382,43 @@ char **av; char *oname; register char *op; register int i; - + /* check argument count */ if (ac < 2) return(MG_EARGC); - (void)strcpy(combuf, "ies2rad"); - op = combuf + 7; /* get -m option (must be first) */ - if (ac-xa0 >= 2 && !strcmp(av[xa0], "-m")) { - if (!isflt(av[xa0+1])) - return(MG_ETYPE); - op = addarg(addarg(op, "-m"), av[xa0+1]); - xa0 += 2; - } - *op++ = ' '; /* build IES filename */ - i = 0; - if (mg_file != NULL && - (oname = strrchr(mg_file->fname, '/')) != NULL) { - i = oname - mg_file->fname + 1; - (void)strcpy(op, mg_file->fname); - } - (void)strcpy(op+i, av[1]); - if (access(op, 0) == -1) - return(MG_ENOFILE); - system(combuf); /* run ies2rad */ - /* now let's find the output file */ - if ((op = strrchr(av[1], '/')) == NULL) + /* construct output file name */ + if ((op = strrchr(av[1], '/')) != NULL) + op++; + else op = av[1]; (void)strcpy(fname, op); if ((op = strrchr(fname, '.')) == NULL) op = fname + strlen(fname); (void)strcpy(op, ".rad"); - if (access(fname, 0) == -1) - return(MG_EINCL); - /* put out xform command */ - printf("\n!xform"); + /* see if we need to run ies2rad */ + if (access(fname, 0) == -1) { + (void)strcpy(combuf, "ies2rad");/* build ies2rad command */ + op = combuf + 7; /* get -m option (first) */ + if (ac-xa0 >= 2 && !strcmp(av[xa0], "-m")) { + if (!isflt(av[xa0+1])) + return(MG_ETYPE); + op = addarg(addarg(op, "-m"), av[xa0+1]); + xa0 += 2; + } + *op++ = ' '; /* build IES filename */ + i = 0; + if (mg_file != NULL && + (oname = strrchr(mg_file->fname,'/')) != NULL) { + i = oname - mg_file->fname + 1; + (void)strcpy(op, mg_file->fname); + } + (void)strcpy(op+i, av[1]); + if (access(op, 0) == -1) /* check for file existence */ + return(MG_ENOFILE); + system(combuf); /* run ies2rad */ + if (access(fname, 0) == -1) /* check success */ + return(MG_EINCL); + } + printf("\n!xform"); /* put out xform command */ oname = object(); if (*oname) { printf(" -n "); @@ -377,31 +436,35 @@ char **av; } -do_tri(mat, vn1, vn2, vn3) /* put out smoothed triangle */ -char *mat, *vn1, *vn2, *vn3; +void +do_tri( /* put out smoothed triangle */ + char *mat, + C_VERTEX *cv1, + C_VERTEX *cv2, + C_VERTEX *cv3, + int iv +) { static int ntris; BARYCCM bvecs; - FLOAT bcoor[3][3]; - C_VERTEX *cv1, *cv2, *cv3; + RREAL bcoor[3][3]; + C_VERTEX *cvt; FVECT v1, v2, v3; FVECT n1, n2, n3; register int i; - /* the following is repeat code, so assume it's OK */ - cv2 = c_getvert(vn2); - if (invert) { - cv3 = c_getvert(vn1); - cv1 = c_getvert(vn3); - } else { - cv1 = c_getvert(vn1); - cv3 = c_getvert(vn3); + + if (iv) { /* swap vertex order if inverted */ + cvt = cv1; + cv1 = cv3; + cv3 = cvt; } xf_xfmpoint(v1, cv1->p); xf_xfmpoint(v2, cv2->p); xf_xfmpoint(v3, cv3->p); + /* compute barycentric coords. */ if (comp_baryc(&bvecs, v1, v2, v3) < 0) return; /* degenerate triangle! */ - printf("\n%s texfunc T-nor\n", mat); + printf("\n%s texfunc T-nor\n", mat); /* put out texture */ printf("4 dx dy dz %s\n0\n", TCALNAME); xf_rotvect(n1, cv1->n); xf_rotvect(n2, cv2->n); @@ -412,6 +475,7 @@ char *mat, *vn1, *vn2, *vn3; bcoor[i][2] = n3[i]; } put_baryc(&bvecs, bcoor, 3); + /* put out triangle */ printf("\nT-nor polygon %st%d\n", object(), ++ntris); printf("0\n0\n9\n"); putv(v1); @@ -421,12 +485,11 @@ char *mat, *vn1, *vn2, *vn3; char * -material() /* get (and print) current material */ +material(void) /* get (and print) current material */ { char *mname = "mat"; COLOR radrgb, c2; double d; - register int i; if (c_cmname != NULL) mname = c_cmname; @@ -452,7 +515,7 @@ material() /* get (and print) current material */ } d = c_cmaterial->rd + c_cmaterial->td + c_cmaterial->rs + c_cmaterial->ts; - if (d < 0. | d > 1.) + if ((d < 0.) | (d > 1.)) return(NULL); /* check for glass/dielectric */ if (c_cmaterial->nr > 1.1 && @@ -518,8 +581,7 @@ material() /* get (and print) current material */ return(mname); } /* check for plastic */ - if (c_cmaterial->rs < .1 && (c_cmaterial->rs < .01 || - c_isgrey(&c_cmaterial->rs_c))) { + if (c_cmaterial->rs < .1) { cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/(1.-c_cmaterial->rs)); fprintf(matfp, "\nvoid plastic %s\n0\n0\n", mname); @@ -542,10 +604,12 @@ material() /* get (and print) current material */ } -cvtcolor(radrgb, ciec, intensity) /* convert a CIE color to Radiance */ -COLOR radrgb; -register C_COLOR *ciec; -double intensity; +void +cvtcolor( /* convert a CIE XYZ color to RGB */ + COLOR radrgb, + register C_COLOR *ciec, + double intensity +) { static COLOR ciexyz; @@ -558,13 +622,13 @@ double intensity; char * -object() /* return current object name */ +object(void) /* return current object name */ { static char objbuf[64]; register int i; register char *cp; int len; - + /* tracked by obj_handler */ i = obj_nnames - sizeof(objbuf)/16; if (i < 0) i = 0; @@ -580,11 +644,13 @@ object() /* return current object name */ char * -addarg(op, arg) /* add argument and advance pointer */ -register char *op, *arg; +addarg( /* add argument and advance pointer */ + register char *op, + register char *arg +) { *op = ' '; - while (*++op = *arg++) + while ( (*++op = *arg++) ) ; return(op); }
