root/radiance/ray/src/cv/mgf2rad.c
Sat Nov 15 17:54:06 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 2.27: +70 -41 lines
Diff to previous 2.27 , to selected 2.25
Changes since 2.26: +5 -5 lines
Diff to previous 2.26 , to selected 2.25
Diff to previous 2.25
Revision 2.25 - (view) (download) (annotate) - [selected]
Changes since 2.24: +21 -13 lines
Diff to previous 2.24
Wed Jun 9 14:06:00 1999 UTC (24 years, 11 months ago) by gwlarson
Changes since 2.23: +3 -1 lines
Diff to previous 2.23 , to selected 2.25
moved output file initialization into main for Linux non-constant stdout
Wed Jul 24 13:07:48 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.22: +21 -16 lines
Diff to previous 2.22 , to selected 2.25
added check for flat triangles with normals
Thu Jun 6 11:49:53 1996 UTC (27 years, 11 months ago) by greg
Changes since 2.21: +3 -1 lines
Diff to previous 2.21 , to selected 2.25
bug fix in r_ies() associated with IES file pathnames
Tue Feb 27 20:11:27 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.20: +2 -3 lines
Diff to previous 2.20 , to selected 2.25
made choice of plastic more typical
Wed Nov 22 15:38:04 1995 UTC (28 years, 6 months ago) by greg
Diff to previous 2.19 , to selected 2.25
minor change removing unneeded variable
Thu May 11 21:49:05 1995 UTC (29 years ago) by greg
Changes since 2.18: +2 -0 lines
Diff to previous 2.18 , to selected 2.25
added MGF version tracking
Thu May 11 20:17:56 1995 UTC (29 years ago) by greg
Changes since 2.17: +9 -1 lines
Diff to previous 2.17 , to selected 2.25
added default handling of undefined entities
Mon May 1 17:05:22 1995 UTC (29 years ago) by greg
Diff to previous 2.16 , to selected 2.25
bug fix in r_ies
Fri Apr 14 19:03:20 1995 UTC (29 years, 1 month ago) by greg
Changes since 2.15: +94 -83 lines
Diff to previous 2.15 , to selected 2.25
added lots of comments and added file precheck to r_ies()
Fri Apr 14 10:47:50 1995 UTC (29 years, 1 month ago) by greg
Changes since 2.14: +12 -5 lines
Diff to previous 2.14 , to selected 2.25
fixed bug in ies conversion routine for getting file context
Thu Apr 13 14:43:33 1995 UTC (29 years, 1 month ago) by greg
Changes since 2.13: +28 -0 lines
Diff to previous 2.13 , to selected 2.25
added MGF index of refraction (ir) and dielectric support
Tue Mar 7 12:18:15 1995 UTC (29 years, 2 months ago) by greg
Changes since 2.12: +1 -0 lines
Diff to previous 2.12 , to selected 2.25
added cct entity
Wed Dec 7 12:40:37 1994 UTC (29 years, 5 months ago) by greg
Diff to previous 2.11 , to selected 2.25
fixed conversion of emittance
Fri Aug 26 12:54:24 1994 UTC (29 years, 9 months ago) by greg
Changes since 2.10: +22 -12 lines
Diff to previous 2.10 , to selected 2.25
added -m option for separate materials file
Thu Jul 21 17:23:43 1994 UTC (29 years, 10 months ago) by greg
Diff to previous 2.9 , to selected 2.25
fixed bad argument parsing
Thu Jul 21 15:04:23 1994 UTC (29 years, 10 months ago) by greg
Changes since 2.8: +10 -3 lines
Diff to previous 2.8 , to selected 2.25
added vertex reversal
Tue Jul 19 15:54:44 1994 UTC (29 years, 10 months ago) by greg
Diff to previous 2.7 , to selected 2.25
spelling correction in comment (really!)
Fri Jul 8 16:10:09 1994 UTC (29 years, 10 months ago) by greg
Changes since 2.6: +17 -19 lines
Diff to previous 2.6 , to selected 2.25
numerous bug fixes and enhancements
Fri Jul 1 18:06:36 1994 UTC (29 years, 10 months ago) by greg
Changes since 2.5: +7 -2 lines
Diff to previous 2.5 , to selected 2.25
added "sides" entity for one- vs. two-sided surfaces
Fri Jul 1 10:20:19 1994 UTC (29 years, 10 months ago) by greg
Diff to previous 2.4 , to selected 2.25
changed context names from struct members to extern variables
Sat Jun 25 09:45:22 1994 UTC (29 years, 11 months ago) by greg
Changes since 2.3: +8 -2 lines
Diff to previous 2.3 , to selected 2.25
added further color support
Fri Jun 24 17:16:51 1994 UTC (29 years, 11 months ago) by greg
Changes since 2.2: +4 -2 lines
Diff to previous 2.2 , to selected 2.25
slight modification to color handling
Wed Jun 22 17:16:03 1994 UTC (29 years, 11 months ago) by greg
Changes since 2.1: +16 -25 lines
Diff to previous 2.1 , to selected 2.25
bug fixes
Wed Jun 22 15:33:03 1994 UTC (29 years, 11 months ago) by greg
Diff to selected 2.25
