--- ray/src/cv/mgf2rad.c 1994/06/22 15:33:03 2.1 +++ ray/src/cv/mgf2rad.c 1994/06/25 09:45:22 2.4 @@ -17,15 +17,8 @@ static char SCCSid[] = "$SunId$ LBL"; #define putv(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2]) -#define isgrey(cxy) ((cxy)->cx > .31 && (cxy)->cx < .35 && \ - (cxy)->cy > .31 && (cxy)->cy < .35) +double glowdist = FHUGE; /* glow test distance */ -#define is0vect(v) ((v)[0] == 0. && (v)[1] == 0. && (v)[2] == 0.) - -#define BIGFLT 1e8 - -double glowdist = 1.5*BIGFLT; /* glow test distance */ - double emult = 1.; /* emmitter multiplier */ int r_comment(), r_cone(), r_cyl(), r_face(), r_ies(), r_ring(), r_sph(); @@ -41,6 +34,8 @@ char *argv[]; mg_ehand[MG_E_COMMENT] = r_comment; mg_ehand[MG_E_COLOR] = c_hcolor; mg_ehand[MG_E_CONE] = r_cone; + mg_ehand[MG_E_CMIX] = c_hcolor; + mg_ehand[MG_E_CSPEC] = c_hcolor; mg_ehand[MG_E_CXY] = c_hcolor; mg_ehand[MG_E_CYL] = r_cyl; mg_ehand[MG_E_ED] = c_hmaterial; @@ -280,7 +275,7 @@ char **av; return(MG_EARGC); if ((mat = material()) == NULL) return(MG_EBADMAT); - if (ac < 5) { /* check for surface normals */ + if (ac <= 5) { /* check for surface normals */ for (i = 1; i < ac; i++) { if ((cv = c_getvert(av[i])) == NULL) return(MG_EUNDEF); @@ -344,8 +339,11 @@ char **av; /* put out xform command */ printf("\n!xform"); oname = object(); - if (*oname) - printf(" -n %s", oname); + if (*oname) { + printf(" -n "); + for (op = oname; op[1]; op++) /* remove trailing separator */ + putchar(*op); + } for (i = xa0; i < ac; i++) printf(" %s", av[i]); if (ac > xa0 && xf_argc > 0) @@ -361,7 +359,6 @@ do_tri(mat, vn1, vn2, vn3) /* put out smoothed triang char *mat, *vn1, *vn2, *vn3; { static int ntris; - char *mod = mat; BARYCCM bvecs; FLOAT bcoor[3][3]; C_VERTEX *cv1, *cv2, *cv3; @@ -375,21 +372,20 @@ char *mat, *vn1, *vn2, *vn3; xf_xfmpoint(v1, cv1->p); xf_xfmpoint(v2, cv2->p); xf_xfmpoint(v3, cv3->p); - if (comp_baryc(&bvecs, v1, v2, v3) == 0) { - printf("\n%s texfunc T-nor\n", mod); - mod = "T-nor"; - printf("4 dx dy dz %s\n0\n", TCALNAME); - xf_rotvect(n1, cv1->n); - xf_rotvect(n2, cv2->n); - xf_rotvect(n3, cv3->n); - for (i = 0; i < 3; i++) { - bcoor[i][0] = n1[i]; - bcoor[i][1] = n2[i]; - bcoor[i][2] = n3[i]; - } - put_baryc(&bvecs, bcoor, 3); + if (comp_baryc(&bvecs, v1, v2, v3) < 0) + return; /* degenerate triangle! */ + printf("\n%s texfunc T-nor\n", mat); + printf("4 dx dy dz %s\n0\n", TCALNAME); + xf_rotvect(n1, cv1->n); + xf_rotvect(n2, cv2->n); + xf_rotvect(n3, cv3->n); + for (i = 0; i < 3; i++) { + bcoor[i][0] = n1[i]; + bcoor[i][1] = n2[i]; + bcoor[i][2] = n3[i]; } - printf("\n%s polygon %st%d\n", mod, object(), ++ntris); + put_baryc(&bvecs, bcoor, 3); + printf("\nT-nor polygon %st%d\n", object(), ++ntris); printf("0\n0\n9\n"); putv(v1); putv(v2); @@ -414,7 +410,7 @@ material() /* get (and print) current material */ if (c_cmaterial->ed > .1) { /* emitter */ cvtcolor(radrgb, &c_cmaterial->ed_c, emult*c_cmaterial->ed/WHTEFFICACY); - if (glowdist < BIGFLT) { /* do a glow */ + if (glowdist < FHUGE) { /* do a glow */ printf("\nvoid glow %s\n0\n0\n", mname); printf("4 %f %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), @@ -431,7 +427,8 @@ material() /* get (and print) current material */ c_cmaterial->rs + c_cmaterial->ts; if (d <= 0. | d >= 1.) return(NULL); - if (c_cmaterial->td > .01 || c_cmaterial->ts > .01) { /* trans */ + /* check for trans */ + if (c_cmaterial->td > .01 || c_cmaterial->ts > .01) { double ts, a5, a6; ts = sqrt(c_cmaterial->ts); /* because we use 2 sides */ @@ -459,7 +456,8 @@ material() /* get (and print) current material */ ts/(ts + c_cmaterial->td)); return(mname); } - if (c_cmaterial->rs < .01 || isgrey(&c_cmaterial->rs_c)) { /* plastic */ + /* check for plastic */ + if (c_cmaterial->rs < .01 || c_isgrey(&c_cmaterial->rs_c)) { if (c_cmaterial->rs > .999) cvtcolor(radrgb, &c_cmaterial->rd_c, 1.); else @@ -495,6 +493,7 @@ double intensity; { static COLOR ciexyz; + c_ccvt(ciec, C_CSXY); /* get xy representation */ ciexyz[1] = intensity; ciexyz[0] = ciec->cx/ciec->cy*ciexyz[1]; ciexyz[2] = ciexyz[1]*(1./ciec->cy - 1.) - ciexyz[0];
