--- ray/src/cv/mgf2rad.c 2014/01/25 18:02:06 2.30 +++ ray/src/cv/mgf2rad.c 2024/01/17 00:43:45 2.35 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mgf2rad.c,v 2.30 2014/01/25 18:02:06 greg Exp $"; +static const char RCSid[] = "$Id: mgf2rad.c,v 2.35 2024/01/17 00:43:45 greg Exp $"; #endif /* * Convert MGF (Materials and Geometry Format) to Radiance @@ -14,6 +14,7 @@ static const char RCSid[] = "$Id: mgf2rad.c,v 2.30 201 #include "mgf_parser.h" #include "color.h" #include "tmesh.h" +#include "lookup.h" #define putv(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2]) @@ -25,8 +26,11 @@ double emult = 1.; /* emitter multiplier */ FILE *matfp; /* material output file */ +int dospectra = 0; /* output spectral colors? */ + extern int r_comment(int ac, char **av); +extern int r_color(int ac, char **av); extern int r_cone(int ac, char **av); extern int r_cyl(int ac, char **av); extern int r_sph(int ac, char **av); @@ -38,7 +42,8 @@ extern char * material(void); extern char * object(void); extern char * addarg(char *op, char *arg); extern void do_tri(char *mat, C_VERTEX *cv1, C_VERTEX *cv2, C_VERTEX *cv3, int iv); -extern void cvtcolor(COLOR radrgb, register C_COLOR *ciec, double intensity); +extern void cvtcolor(COLOR radrgb, C_COLOR *ciec, double intensity); +extern char * specolor(COLOR radrgb, C_COLOR *ciec, double intensity); int @@ -57,9 +62,9 @@ main( mg_ehand[MG_E_COLOR] = c_hcolor; /* they get color */ mg_ehand[MG_E_CONE] = r_cone; /* we do cones */ mg_ehand[MG_E_CMIX] = c_hcolor; /* they mix colors */ - mg_ehand[MG_E_CSPEC] = c_hcolor; /* they get spectra */ mg_ehand[MG_E_CXY] = c_hcolor; /* they get chromaticities */ - mg_ehand[MG_E_CCT] = c_hcolor; /* they get color temp's */ + mg_ehand[MG_E_CSPEC] = r_color; /* we get spectra */ + mg_ehand[MG_E_CCT] = r_color; /* we get color temp's */ mg_ehand[MG_E_CYL] = r_cyl; /* we do cylinders */ mg_ehand[MG_E_ED] = c_hmaterial; /* they get emission */ mg_ehand[MG_E_FACE] = r_face; /* we do faces */ @@ -104,6 +109,9 @@ main( } printf(" %s", argv[i]); break; + case 's': /* spectral color output? */ + dospectra = !dospectra; + break; default: goto userr; } @@ -129,7 +137,7 @@ main( } exit(0); userr: - fprintf(stderr, "Usage: %s [-g dist][-e mult][-m matf] [file.mgf] ..\n", + fprintf(stderr, "Usage: %s [-s][-g dist][-e mult][-m matf] [file.mgf] ..\n", argv[0]); exit(1); } @@ -137,8 +145,8 @@ userr: int r_comment( /* repeat a comment verbatim */ - register int ac, - register char **av + int ac, + char **av ) { putchar('#'); /* use Radiance comment character */ @@ -152,6 +160,21 @@ r_comment( /* repeat a comment verbatim */ int +r_color( /* call color handler & remember name */ + int ac, + char **av +) +{ + int rval = c_hcolor(ac, av); + + if (rval == MG_OK) + c_ccolor->client_data = c_ccname; + + return(rval); +} + + +int r_cone( /* put out a cone */ int ac, char **av @@ -320,8 +343,8 @@ r_face( /* convert a face */ static int nfaces; int myi = invert; char *mat; - register int i; - register C_VERTEX *cv; + int i; + C_VERTEX *cv; FVECT v; /* check argument count and type */ @@ -381,8 +404,8 @@ r_ies( /* convert an IES luminaire file */ char combuf[128]; char fname[48]; char *oname; - register char *op; - register int i; + char *op; + int i; /* check argument count */ if (ac < 2) return(MG_EARGC); @@ -452,7 +475,7 @@ do_tri( /* put out smoothed triangle */ C_VERTEX *cvt; FVECT v1, v2, v3; FVECT n1, n2, n3; - register int i; + int i; if (iv) { /* swap vertex order if inverted */ cvt = cv1; @@ -475,7 +498,7 @@ do_tri( /* put out smoothed triangle */ bcoor[i][1] = n2[i]; bcoor[i][2] = n3[i]; } - put_baryc(&bvecs, bcoor, 3); + fput_baryc(&bvecs, bcoor, 3, stdout); /* put out triangle */ printf("\nT-nor polygon %st%d\n", object(), ++ntris); printf("0\n0\n9\n"); @@ -497,6 +520,7 @@ char * material(void) /* get (and print) current material */ { char *mname = "mat"; + char *pname; COLOR radrgb, c2; double d; @@ -507,15 +531,15 @@ material(void) /* get (and print) current material * /* else update output */ c_cmaterial->clock = 0; if (c_cmaterial->ed > .1) { /* emitter */ - cvtcolor(radrgb, &c_cmaterial->ed_c, + pname = specolor(radrgb, &c_cmaterial->ed_c, emult*c_cmaterial->ed/(PI*WHTEFFICACY)); if (glowdist < FHUGE) { /* do a glow */ - fprintf(matfp, "\nvoid glow %s\n0\n0\n", mname); + fprintf(matfp, "\n%s glow %s\n0\n0\n", pname, mname); fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU), glowdist); } else { - fprintf(matfp, "\nvoid light %s\n0\n0\n", mname); + fprintf(matfp, "\n%s light %s\n0\n0\n", pname, mname); fprintf(matfp, "3 %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU)); @@ -552,7 +576,7 @@ material(void) /* get (and print) current material * colval(radrgb,GRN), colval(radrgb,BLU), c_cmaterial->nr); return(mname); - } + } /* check for trans */ if (c_cmaterial->td > .01 || c_cmaterial->ts > .01) { double a5, a6; @@ -584,10 +608,11 @@ material(void) /* get (and print) current material * return(mname); } /* check for plastic */ - if (c_cmaterial->rs < .1) { - cvtcolor(radrgb, &c_cmaterial->rd_c, + if (c_cmaterial->rs < .1 && (c_cmaterial->rs < .1*c_cmaterial->rd || + c_isgrey(&c_cmaterial->rs_c))) { + pname = specolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/(1.-c_cmaterial->rs)); - fprintf(matfp, "\nvoid plastic %s\n0\n0\n", mname); + fprintf(matfp, "\n%s plastic %s\n0\n0\n", pname, mname); fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU), c_cmaterial->rs, c_cmaterial->rs_a); @@ -596,11 +621,20 @@ material(void) /* get (and print) current material * return(mname); } /* else it's metal */ - /* average colors */ - cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd); - cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs); - addcolor(radrgb, c2); - fprintf(matfp, "\nvoid metal %s\n0\n0\n", mname); + /* compute color */ + if (c_equiv(&c_cmaterial->rd_c, &c_cmaterial->rs_c)) { + pname = specolor(radrgb, &c_cmaterial->rs_c, c_cmaterial->rs+c_cmaterial->rd); + } else if (c_cmaterial->rd <= .05f) { + pname = specolor(radrgb, &c_cmaterial->rs_c, c_cmaterial->rs); + cvtcolor(c2, &c_cmaterial->rd_c, c_cmaterial->rd); + addcolor(radrgb, c2); + } else { + pname = "void"; + cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd); + cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs); + addcolor(radrgb, c2); + } + fprintf(matfp, "\n%s metal %s\n0\n0\n", pname, mname); fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU), c_cmaterial->rs/(c_cmaterial->rd + c_cmaterial->rs), @@ -614,11 +648,11 @@ material(void) /* get (and print) current material * void cvtcolor( /* convert a CIE XYZ color to RGB */ COLOR radrgb, - register C_COLOR *ciec, + C_COLOR *ciec, double intensity ) { - static COLOR ciexyz; + COLOR ciexyz; c_ccvt(ciec, C_CSXY); /* get xy representation */ ciexyz[1] = intensity; @@ -628,12 +662,76 @@ cvtcolor( /* convert a CIE XYZ color to RGB */ } +static int /* new spectrum definition? */ +newspecdef(C_COLOR *spc) +{ + static LUTAB spc_tab = LU_SINIT(NULL,free); + LUENT *lp = lu_find(&spc_tab, (const char *)spc->client_data); + + if (lp == NULL) /* should never happen */ + return(1); + if (lp->data == NULL) { /* new entry */ + lp->key = (char *)spc->client_data; + lp->data = (char *)malloc(sizeof(C_COLOR)); + } else if (c_equiv(spc, (C_COLOR *)lp->data)) + return(0); /* unchanged */ + + if (lp->data != NULL) /* else remember if we can */ + *(C_COLOR *)lp->data = *spc; + return(1); /* good as new */ +} + + char * +specolor( /* check if color has spectra and output accordingly */ + COLOR radrgb, + C_COLOR *clr, + double intensity +) +{ + static char spname[128]; + double mult; + int cbeg, cend, i; + + if (!dospectra | !(clr->flags & C_CDSPEC)) { + cvtcolor(radrgb, clr, intensity); + return("void"); /* just use RGB */ + } + setcolor(radrgb, intensity, intensity, intensity); + for (cbeg = 0; cbeg < C_CNSS; cbeg++) /* trim zeros off beginning */ + if (clr->ssamp[cbeg]) + break; + if (cbeg >= C_CNSS) /* should never happen! */ + return("void"); + if (clr->client_data != NULL) { /* get name if available */ + strcpy(spname, (char *)clr->client_data); + strcat(spname, "*"); /* make sure it's special */ + if (!newspecdef(clr)) /* output already? */ + return(spname); + } else + strcpy(spname, "spec*"); + c_ccvt(clr, C_CSEFF); /* else output spectrum prim */ + for (cend = 0; !clr->ssamp[C_CNSS-1-cend]; cend++) + ; /* trim zeros off end */ + fprintf(matfp, "\nvoid spectrum %s\n0\n0\n", spname); + fprintf(matfp, "%d %d %d", C_CNSS+2-cbeg-cend, + C_CMINWL+cbeg*C_CWLI, C_CMAXWL-cend*C_CWLI); + mult = (C_CNSS*c_dfcolor.eff)/(clr->ssum*clr->eff); + for (i = cbeg; i < C_CNSS-cend; i++) { + if (!((i-cbeg+1)%6)) fputc('\n', matfp); + fprintf(matfp, "\t%.5f", clr->ssamp[i]*mult); + } + fputc('\n', matfp); + return(spname); +} + + +char * object(void) /* return current object name */ { static char objbuf[64]; - register int i; - register char *cp; + int i; + char *cp; int len; /* tracked by obj_handler */ i = obj_nnames - sizeof(objbuf)/16; @@ -652,8 +750,8 @@ object(void) /* return current object name */ char * addarg( /* add argument and advance pointer */ - register char *op, - register char *arg + char *op, + char *arg ) { *op = ' ';
