--- ray/src/cv/mgf2rad.c 2003/11/15 17:54:06 2.28 +++ ray/src/cv/mgf2rad.c 2014/01/25 18:02:06 2.30 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mgf2rad.c,v 2.28 2003/11/15 17:54:06 schorsch Exp $"; +static const char RCSid[] = "$Id: mgf2rad.c,v 2.30 2014/01/25 18:02:06 greg Exp $"; #endif /* * Convert MGF (Materials and Geometry Format) to Radiance @@ -11,7 +11,7 @@ static const char RCSid[] = "$Id: mgf2rad.c,v 2.28 200 #include #include "platform.h" -#include "mgflib/parser.h" +#include "mgf_parser.h" #include "color.h" #include "tmesh.h" @@ -26,18 +26,19 @@ double emult = 1.; /* emitter multiplier */ FILE *matfp; /* material output file */ -int r_comment(int ac, char **av); -int r_cone(int ac, char **av); -int r_cyl(int ac, char **av); -int r_sph(int ac, char **av); -int r_ring(int ac, char **av); -int r_face(int ac, char **av); -int r_ies(int ac, char **av); -char * material(void); -char * object(void); -char * addarg(char *op, char *arg); -void do_tri(char *mat, C_VERTEX *cv1, C_VERTEX *cv2, C_VERTEX *cv3, int iv); -void cvtcolor(COLOR radrgb, register C_COLOR *ciec, double intensity); +extern int r_comment(int ac, char **av); +extern int r_cone(int ac, char **av); +extern int r_cyl(int ac, char **av); +extern int r_sph(int ac, char **av); +extern int r_ring(int ac, char **av); +extern int r_face(int ac, char **av); +extern int r_ies(int ac, char **av); +extern void putsided(char *mname); +extern char * material(void); +extern char * object(void); +extern char * addarg(char *op, char *arg); +extern void do_tri(char *mat, C_VERTEX *cv1, C_VERTEX *cv2, C_VERTEX *cv3, int iv); +extern void cvtcolor(COLOR radrgb, register C_COLOR *ciec, double intensity); int @@ -484,6 +485,14 @@ do_tri( /* put out smoothed triangle */ } +void +putsided(char *mname) /* print out mixfunc for sided material */ +{ + fprintf(matfp, "\nvoid mixfunc %s\n", mname); + fprintf(matfp, "4 %s void if(Rdot,1,0) .\n0\n0\n", mname); +} + + char * material(void) /* get (and print) current material */ { @@ -546,38 +555,32 @@ material(void) /* get (and print) current material * } /* check for trans */ if (c_cmaterial->td > .01 || c_cmaterial->ts > .01) { - double ts, a5, a6; - - if (c_cmaterial->sided) { - ts = sqrt(c_cmaterial->ts); /* approximate */ - a5 = .5; - } else { - ts = c_cmaterial->ts; - a5 = 1.; - } + double a5, a6; /* average colors */ - d = c_cmaterial->rd + c_cmaterial->td + ts; + d = c_cmaterial->rd + c_cmaterial->td + c_cmaterial->ts; cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d); cvtcolor(c2, &c_cmaterial->td_c, c_cmaterial->td/d); addcolor(radrgb, c2); - cvtcolor(c2, &c_cmaterial->ts_c, ts/d); + cvtcolor(c2, &c_cmaterial->ts_c, c_cmaterial->ts/d); addcolor(radrgb, c2); - if (c_cmaterial->rs + ts > .0001) + if (c_cmaterial->rs + c_cmaterial->ts > .0001) a5 = (c_cmaterial->rs*c_cmaterial->rs_a + - ts*a5*c_cmaterial->ts_a) / - (c_cmaterial->rs + ts); - a6 = (c_cmaterial->td + ts) / - (c_cmaterial->rd + c_cmaterial->td + ts); + c_cmaterial->ts*c_cmaterial->ts_a) / + (c_cmaterial->rs + c_cmaterial->ts); + a6 = (c_cmaterial->td + c_cmaterial->ts) / + (c_cmaterial->rd + c_cmaterial->td + c_cmaterial->ts); if (a6 < .999) d = c_cmaterial->rd/(1. - c_cmaterial->rs)/(1. - a6); else - d = c_cmaterial->td + ts; + d = c_cmaterial->td + c_cmaterial->ts; scalecolor(radrgb, d); fprintf(matfp, "\nvoid trans %s\n0\n0\n", mname); fprintf(matfp, "7 %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU)); fprintf(matfp, "\t%f %f %f %f\n", c_cmaterial->rs, a5, a6, - ts/(ts + c_cmaterial->td)); + c_cmaterial->ts/(c_cmaterial->ts + c_cmaterial->td)); + if (c_cmaterial->sided) + putsided(mname); return(mname); } /* check for plastic */ @@ -588,6 +591,8 @@ material(void) /* get (and print) current material * fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED), colval(radrgb,GRN), colval(radrgb,BLU), c_cmaterial->rs, c_cmaterial->rs_a); + if (c_cmaterial->sided) + putsided(mname); return(mname); } /* else it's metal */ @@ -600,6 +605,8 @@ material(void) /* get (and print) current material * colval(radrgb,GRN), colval(radrgb,BLU), c_cmaterial->rs/(c_cmaterial->rd + c_cmaterial->rs), c_cmaterial->rs_a); + if (c_cmaterial->sided) + putsided(mname); return(mname); }
