| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: mgf2rad.c,v 2.35 2024/01/17 00:43:45 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Convert MGF (Materials and Geometry Format) to Radiance
| 6 |
| 7 |
| 8 |
#include <stdio.h>
| 9 |
#include <stdlib.h>
| 10 |
#include <math.h>
| 11 |
#include <string.h>
| 12 |
| 13 |
#include "platform.h"
| 14 |
#include "mgf_parser.h"
| 15 |
#include "color.h"
| 16 |
#include "tmesh.h"
| 17 |
#include "lookup.h"
| 18 |
| 19 |
#define putv(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2])
| 20 |
| 21 |
#define invert (xf_context != NULL && xf_context->rev)
| 22 |
| 23 |
#define SGEN_DEF "spec*"
| 24 |
#define SGEN_RS "rs_spec*"
| 25 |
#define SGEN_TD "td_spec*"
| 26 |
#define SGEN_TS "ts_spec*"
| 27 |
| 28 |
char void_str[] = "void"; /* global VOIDID */
| 29 |
char sgen_str[16] = SGEN_DEF; /* generic specular */
| 30 |
| 31 |
double glowdist = FHUGE; /* glow test distance */
| 32 |
| 33 |
double emult = 1.; /* emitter multiplier */
| 34 |
| 35 |
FILE *matfp; /* material output file */
| 36 |
| 37 |
int dospectra = 0; /* output spectral colors? */
| 38 |
| 39 |
| 40 |
extern int r_comment(int ac, char **av);
| 41 |
extern int r_color(int ac, char **av);
| 42 |
extern int r_cone(int ac, char **av);
| 43 |
extern int r_cyl(int ac, char **av);
| 44 |
extern int r_sph(int ac, char **av);
| 45 |
extern int r_ring(int ac, char **av);
| 46 |
extern int r_face(int ac, char **av);
| 47 |
extern int r_ies(int ac, char **av);
| 48 |
extern void putsided(char *mname);
| 49 |
extern char * material(void);
| 50 |
extern char * object(void);
| 51 |
extern char * addarg(char *op, char *arg);
| 52 |
extern void do_tri(char *mat, C_VERTEX *cv1, C_VERTEX *cv2, C_VERTEX *cv3, int iv);
| 53 |
extern void cvtcolor(COLOR radrgb, C_COLOR *ciec, double intensity);
| 54 |
extern int color_clash(int e1, int e2);
| 55 |
extern int isgrey(COLOR rgb);
| 56 |
extern void putrgbpat(char *pnm, COLOR rgb);
| 57 |
extern char * specolor(COLOR radrgb, C_COLOR *ciec, double intensity);
| 58 |
| 59 |
| 60 |
int
| 61 |
main(
| 62 |
int argc,
| 63 |
char *argv[]
| 64 |
| 65 |
| 66 |
int i;
| 67 |
| 68 |
matfp = stdout;
| 69 |
/* print out parser version */
| 70 |
printf("## Translated from MGF Version %d.%d\n", MG_VMAJOR, MG_VMINOR);
| 71 |
/* initialize dispatch table */
| 72 |
mg_ehand[MG_E_COMMENT] = r_comment; /* we pass comments */
| 73 |
mg_ehand[MG_E_COLOR] = c_hcolor; /* they get color */
| 74 |
mg_ehand[MG_E_CONE] = r_cone; /* we do cones */
| 75 |
mg_ehand[MG_E_CMIX] = c_hcolor; /* they mix colors */
| 76 |
mg_ehand[MG_E_CXY] = c_hcolor; /* they get chromaticities */
| 77 |
mg_ehand[MG_E_CSPEC] = r_color; /* we get spectra */
| 78 |
mg_ehand[MG_E_CCT] = r_color; /* we get color temp's */
| 79 |
mg_ehand[MG_E_CYL] = r_cyl; /* we do cylinders */
| 80 |
mg_ehand[MG_E_ED] = c_hmaterial; /* they get emission */
| 81 |
mg_ehand[MG_E_FACE] = r_face; /* we do faces */
| 82 |
mg_ehand[MG_E_IES] = r_ies; /* we do IES files */
| 83 |
mg_ehand[MG_E_IR] = c_hmaterial; /* they get refractive index */
| 84 |
mg_ehand[MG_E_MATERIAL] = c_hmaterial; /* they get materials */
| 85 |
mg_ehand[MG_E_NORMAL] = c_hvertex; /* they get normals */
| 86 |
mg_ehand[MG_E_OBJECT] = obj_handler; /* they track object names */
| 87 |
mg_ehand[MG_E_POINT] = c_hvertex; /* they get points */
| 88 |
mg_ehand[MG_E_RD] = c_hmaterial; /* they get diffuse refl. */
| 89 |
mg_ehand[MG_E_RING] = r_ring; /* we do rings */
| 90 |
mg_ehand[MG_E_RS] = c_hmaterial; /* they get specular refl. */
| 91 |
mg_ehand[MG_E_SIDES] = c_hmaterial; /* they get # sides */
| 92 |
mg_ehand[MG_E_SPH] = r_sph; /* we do spheres */
| 93 |
mg_ehand[MG_E_TD] = c_hmaterial; /* they get diffuse trans. */
| 94 |
mg_ehand[MG_E_TS] = c_hmaterial; /* they get specular trans. */
| 95 |
mg_ehand[MG_E_VERTEX] = c_hvertex; /* they get vertices */
| 96 |
mg_ehand[MG_E_XF] = xf_handler; /* they track transforms */
| 97 |
mg_init(); /* initialize the parser */
| 98 |
/* get our options & print header */
| 99 |
printf("## %s", argv[0]);
| 100 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) {
| 101 |
printf(" %s", argv[i]);
| 102 |
switch (argv[i][1]) {
| 103 |
case 'g': /* glow distance (meters) */
| 104 |
if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f"))
| 105 |
goto userr;
| 106 |
glowdist = atof(argv[++i]);
| 107 |
| 108 |
break;
| 109 |
case 'e': /* emitter multiplier */
| 110 |
| 111 |
goto userr;
| 112 |
emult = atof(argv[++i]);
| 113 |
| 114 |
break;
| 115 |
case 'm': /* materials file */
| 116 |
matfp = fopen(argv[++i], "a");
| 117 |
if (matfp == NULL) {
| 118 |
fprintf(stderr, "%s: cannot append\n", argv[i]);
| 119 |
exit(1);
| 120 |
| 121 |
| 122 |
break;
| 123 |
case 's': /* spectral color output? */
| 124 |
dospectra = !dospectra;
| 125 |
break;
| 126 |
default:
| 127 |
goto userr;
| 128 |
| 129 |
| 130 |
putchar('\n');
| 131 |
if (i == argc) { /* convert stdin */
| 132 |
if (mg_load(NULL) != MG_OK)
| 133 |
exit(1);
| 134 |
if (mg_nunknown)
| 135 |
printf("## %s: %u unknown entities\n",
| 136 |
argv[0], mg_nunknown);
| 137 |
} else /* convert each file */
| 138 |
for ( ; i < argc; i++) {
| 139 |
printf("## %s %s ##############################\n",
| 140 |
argv[0], argv[i]);
| 141 |
if (mg_load(argv[i]) != MG_OK)
| 142 |
exit(1);
| 143 |
if (mg_nunknown) {
| 144 |
printf("## %s %s: %u unknown entities\n",
| 145 |
argv[0], argv[i], mg_nunknown);
| 146 |
mg_nunknown = 0;
| 147 |
| 148 |
| 149 |
exit(0);
| 150 |
userr:
| 151 |
fprintf(stderr, "Usage: %s [-s][-g dist][-e mult][-m matf] [file.mgf] ..\n",
| 152 |
argv[0]);
| 153 |
exit(1);
| 154 |
| 155 |
| 156 |
| 157 |
int
| 158 |
r_comment( /* repeat a comment verbatim */
| 159 |
int ac,
| 160 |
char **av
| 161 |
| 162 |
| 163 |
putchar('#'); /* use Radiance comment character */
| 164 |
while (--ac) { /* pass through verbatim */
| 165 |
putchar(' ');
| 166 |
fputs(*++av, stdout);
| 167 |
| 168 |
putchar('\n');
| 169 |
return(MG_OK);
| 170 |
| 171 |
| 172 |
| 173 |
int
| 174 |
r_color( /* call color handler & remember name */
| 175 |
int ac,
| 176 |
char **av
| 177 |
| 178 |
| 179 |
int rval = c_hcolor(ac, av);
| 180 |
| 181 |
if (rval == MG_OK)
| 182 |
c_ccolor->client_data = c_ccname;
| 183 |
| 184 |
return(rval);
| 185 |
| 186 |
| 187 |
| 188 |
int
| 189 |
r_cone( /* put out a cone */
| 190 |
int ac,
| 191 |
char **av
| 192 |
| 193 |
| 194 |
static int ncones;
| 195 |
char *mat;
| 196 |
double r1, r2;
| 197 |
C_VERTEX *cv1, *cv2;
| 198 |
FVECT p1, p2;
| 199 |
int inv;
| 200 |
/* check argument count and type */
| 201 |
if (ac != 5)
| 202 |
return(MG_EARGC);
| 203 |
if (!isflt(av[2]) || !isflt(av[4]))
| 204 |
return(MG_ETYPE);
| 205 |
/* get the endpoint vertices */
| 206 |
if ((cv1 = c_getvert(av[1])) == NULL ||
| 207 |
(cv2 = c_getvert(av[3])) == NULL)
| 208 |
return(MG_EUNDEF);
| 209 |
xf_xfmpoint(p1, cv1->p); /* transform endpoints */
| 210 |
xf_xfmpoint(p2, cv2->p);
| 211 |
r1 = xf_scale(atof(av[2])); /* scale radii */
| 212 |
r2 = xf_scale(atof(av[4]));
| 213 |
inv = r1 < 0.; /* check for inverted cone */
| 214 |
if (r1 == 0.) { /* check for illegal radii */
| 215 |
if (r2 == 0.)
| 216 |
return(MG_EILL);
| 217 |
inv = r2 < 0.;
| 218 |
} else if (r2 != 0. && inv ^ (r2 < 0.))
| 219 |
return(MG_EILL);
| 220 |
if (inv) {
| 221 |
r1 = -r1;
| 222 |
r2 = -r2;
| 223 |
| 224 |
if ((mat = material()) == NULL) /* get material */
| 225 |
return(MG_EBADMAT);
| 226 |
/* spit the sucker out */
| 227 |
printf("\n%s %s %sc%d\n", mat, inv ? "cup" : "cone",
| 228 |
object(), ++ncones);
| 229 |
printf("0\n0\n8\n");
| 230 |
putv(p1);
| 231 |
putv(p2);
| 232 |
printf("%18.12g %18.12g\n", r1, r2);
| 233 |
return(MG_OK);
| 234 |
| 235 |
| 236 |
| 237 |
int
| 238 |
r_cyl( /* put out a cylinder */
| 239 |
int ac,
| 240 |
char **av
| 241 |
| 242 |
| 243 |
static int ncyls;
| 244 |
char *mat;
| 245 |
double rad;
| 246 |
| 247 |
FVECT p1, p2;
| 248 |
int inv;
| 249 |
| 250 |
if (ac != 4)
| 251 |
return(MG_EARGC);
| 252 |
if (!isflt(av[2]))
| 253 |
return(MG_ETYPE);
| 254 |
| 255 |
| 256 |
| 257 |
return(MG_EUNDEF);
| 258 |
| 259 |
| 260 |
rad = xf_scale(atof(av[2])); /* scale radius */
| 261 |
if ((inv = rad < 0.)) /* check for inverted cylinder */
| 262 |
rad = -rad;
| 263 |
| 264 |
return(MG_EBADMAT);
| 265 |
/* spit out the primitive */
| 266 |
printf("\n%s %s %scy%d\n", mat, inv ? "tube" : "cylinder",
| 267 |
object(), ++ncyls);
| 268 |
printf("0\n0\n7\n");
| 269 |
putv(p1);
| 270 |
putv(p2);
| 271 |
printf("%18.12g\n", rad);
| 272 |
return(MG_OK);
| 273 |
| 274 |
| 275 |
| 276 |
int
| 277 |
r_sph( /* put out a sphere */
| 278 |
int ac,
| 279 |
char **av
| 280 |
| 281 |
| 282 |
static int nsphs;
| 283 |
char *mat;
| 284 |
double rad;
| 285 |
C_VERTEX *cv;
| 286 |
FVECT cent;
| 287 |
int inv;
| 288 |
| 289 |
if (ac != 3)
| 290 |
return(MG_EARGC);
| 291 |
if (!isflt(av[2]))
| 292 |
return(MG_ETYPE);
| 293 |
if ((cv = c_getvert(av[1])) == NULL) /* get center vertex */
| 294 |
return(MG_EUNDEF);
| 295 |
xf_xfmpoint(cent, cv->p); /* transform center */
| 296 |
| 297 |
if ((inv = rad < 0.)) /* check for inversion */
| 298 |
rad = -rad;
| 299 |
| 300 |
return(MG_EBADMAT);
| 301 |
/* spit out primitive */
| 302 |
printf("\n%s %s %ss%d\n", mat, inv ? "bubble" : "sphere",
| 303 |
object(), ++nsphs);
| 304 |
printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n",
| 305 |
cent[0], cent[1], cent[2], rad);
| 306 |
return(MG_OK);
| 307 |
| 308 |
| 309 |
| 310 |
int
| 311 |
r_ring( /* put out a ring */
| 312 |
int ac,
| 313 |
char **av
| 314 |
| 315 |
| 316 |
static int nrings;
| 317 |
char *mat;
| 318 |
double r1, r2;
| 319 |
C_VERTEX *cv;
| 320 |
FVECT cent, norm;
| 321 |
| 322 |
if (ac != 4)
| 323 |
return(MG_EARGC);
| 324 |
if (!isflt(av[2]) || !isflt(av[3]))
| 325 |
return(MG_ETYPE);
| 326 |
| 327 |
return(MG_EUNDEF);
| 328 |
if (is0vect(cv->n)) /* make sure we have normal */
| 329 |
return(MG_EILL);
| 330 |
| 331 |
xf_rotvect(norm, cv->n); /* rotate normal */
| 332 |
| 333 |
r2 = xf_scale(atof(av[3]));
| 334 |
if ((r1 < 0.) | (r2 <= r1))
| 335 |
return(MG_EILL);
| 336 |
| 337 |
return(MG_EBADMAT);
| 338 |
| 339 |
printf("\n%s ring %sr%d\n", mat, object(), ++nrings);
| 340 |
| 341 |
putv(cent);
| 342 |
putv(norm);
| 343 |
| 344 |
return(MG_OK);
| 345 |
| 346 |
| 347 |
| 348 |
int
| 349 |
r_face( /* convert a face */
| 350 |
int ac,
| 351 |
char **av
| 352 |
| 353 |
| 354 |
static int nfaces;
| 355 |
int myi = invert;
| 356 |
char *mat;
| 357 |
int i;
| 358 |
C_VERTEX *cv;
| 359 |
FVECT v;
| 360 |
| 361 |
| 362 |
if (ac < 4)
| 363 |
return(MG_EARGC);
| 364 |
| 365 |
return(MG_EBADMAT);
| 366 |
if (ac <= 5) { /* check for smoothing */
| 367 |
C_VERTEX *cva[5];
| 368 |
for (i = 1; i < ac; i++) {
| 369 |
if ((cva[i-1] = c_getvert(av[i])) == NULL)
| 370 |
return(MG_EUNDEF);
| 371 |
if (is0vect(cva[i-1]->n))
| 372 |
break;
| 373 |
| 374 |
if (i < ac)
| 375 |
i = ISFLAT;
| 376 |
else
| 377 |
i = flat_tri(cva[0]->p, cva[1]->p, cva[2]->p,
| 378 |
cva[0]->n, cva[1]->n, cva[2]->n);
| 379 |
if (i == DEGEN)
| 380 |
return(MG_OK); /* degenerate (error?) */
| 381 |
if (i == RVBENT) {
| 382 |
myi = !myi;
| 383 |
i = ISBENT;
| 384 |
} else if (i == RVFLAT) {
| 385 |
myi = !myi;
| 386 |
i = ISFLAT;
| 387 |
| 388 |
if (i == ISBENT) { /* smoothed triangles */
| 389 |
do_tri(mat, cva[0], cva[1], cva[2], myi);
| 390 |
if (ac == 5)
| 391 |
do_tri(mat, cva[2], cva[3], cva[0], myi);
| 392 |
return(MG_OK);
| 393 |
| 394 |
| 395 |
/* spit out unsmoothed primitive */
| 396 |
printf("\n%s polygon %sf%d\n", mat, object(), ++nfaces);
| 397 |
printf("0\n0\n%d\n", 3*(ac-1));
| 398 |
for (i = 1; i < ac; i++) { /* get, transform, print each vertex */
| 399 |
if ((cv = c_getvert(av[myi ? ac-i : i])) == NULL)
| 400 |
return(MG_EUNDEF);
| 401 |
xf_xfmpoint(v, cv->p);
| 402 |
putv(v);
| 403 |
| 404 |
return(MG_OK);
| 405 |
| 406 |
| 407 |
| 408 |
int
| 409 |
r_ies( /* convert an IES luminaire file */
| 410 |
int ac,
| 411 |
char **av
| 412 |
| 413 |
| 414 |
int xa0 = 2;
| 415 |
char combuf[128];
| 416 |
char fname[48];
| 417 |
char *oname;
| 418 |
char *op;
| 419 |
int i;
| 420 |
/* check argument count */
| 421 |
if (ac < 2)
| 422 |
return(MG_EARGC);
| 423 |
/* construct output file name */
| 424 |
if ((op = strrchr(av[1], '/')) != NULL)
| 425 |
op++;
| 426 |
else
| 427 |
op = av[1];
| 428 |
(void)strcpy(fname, op);
| 429 |
if ((op = strrchr(fname, '.')) == NULL)
| 430 |
op = fname + strlen(fname);
| 431 |
(void)strcpy(op, ".rad");
| 432 |
/* see if we need to run ies2rad */
| 433 |
if (access(fname, 0) == -1) {
| 434 |
(void)strcpy(combuf, "ies2rad");/* build ies2rad command */
| 435 |
op = combuf + 7; /* get -m option (first) */
| 436 |
if (ac-xa0 >= 2 && !strcmp(av[xa0], "-m")) {
| 437 |
if (!isflt(av[xa0+1]))
| 438 |
return(MG_ETYPE);
| 439 |
op = addarg(addarg(op, "-m"), av[xa0+1]);
| 440 |
xa0 += 2;
| 441 |
| 442 |
*op++ = ' '; /* build IES filename */
| 443 |
i = 0;
| 444 |
if (mg_file != NULL &&
| 445 |
(oname = strrchr(mg_file->fname,'/')) != NULL) {
| 446 |
i = oname - mg_file->fname + 1;
| 447 |
(void)strcpy(op, mg_file->fname);
| 448 |
| 449 |
(void)strcpy(op+i, av[1]);
| 450 |
if (access(op, 0) == -1) /* check for file existence */
| 451 |
return(MG_ENOFILE);
| 452 |
system(combuf); /* run ies2rad */
| 453 |
if (access(fname, 0) == -1) /* check success */
| 454 |
return(MG_EINCL);
| 455 |
| 456 |
printf("\n!xform"); /* put out xform command */
| 457 |
oname = object();
| 458 |
if (*oname) {
| 459 |
printf(" -n ");
| 460 |
for (op = oname; op[1]; op++) /* remove trailing separator */
| 461 |
putchar(*op);
| 462 |
| 463 |
for (i = xa0; i < ac; i++)
| 464 |
printf(" %s", av[i]);
| 465 |
if (ac > xa0 && xf_argc > 0)
| 466 |
printf(" -i 1");
| 467 |
for (i = 0; i < xf_argc; i++)
| 468 |
printf(" %s", xf_argv[i]);
| 469 |
printf(" %s\n", fname);
| 470 |
return(MG_OK);
| 471 |
| 472 |
| 473 |
| 474 |
void
| 475 |
do_tri( /* put out smoothed triangle */
| 476 |
char *mat,
| 477 |
C_VERTEX *cv1,
| 478 |
C_VERTEX *cv2,
| 479 |
C_VERTEX *cv3,
| 480 |
int iv
| 481 |
| 482 |
| 483 |
static int ntris;
| 484 |
BARYCCM bvecs;
| 485 |
RREAL bcoor[3][3];
| 486 |
C_VERTEX *cvt;
| 487 |
FVECT v1, v2, v3;
| 488 |
FVECT n1, n2, n3;
| 489 |
int i;
| 490 |
| 491 |
if (iv) { /* swap vertex order if inverted */
| 492 |
cvt = cv1;
| 493 |
cv1 = cv3;
| 494 |
cv3 = cvt;
| 495 |
| 496 |
xf_xfmpoint(v1, cv1->p);
| 497 |
xf_xfmpoint(v2, cv2->p);
| 498 |
xf_xfmpoint(v3, cv3->p);
| 499 |
/* compute barycentric coords. */
| 500 |
if (comp_baryc(&bvecs, v1, v2, v3) < 0)
| 501 |
return; /* degenerate triangle! */
| 502 |
printf("\n%s texfunc T-nor\n", mat); /* put out texture */
| 503 |
printf("4 dx dy dz %s\n0\n", TCALNAME);
| 504 |
xf_rotvect(n1, cv1->n);
| 505 |
xf_rotvect(n2, cv2->n);
| 506 |
xf_rotvect(n3, cv3->n);
| 507 |
for (i = 0; i < 3; i++) {
| 508 |
bcoor[i][0] = n1[i];
| 509 |
bcoor[i][1] = n2[i];
| 510 |
bcoor[i][2] = n3[i];
| 511 |
| 512 |
fput_baryc(&bvecs, bcoor, 3, stdout);
| 513 |
/* put out triangle */
| 514 |
printf("\nT-nor polygon %st%d\n", object(), ++ntris);
| 515 |
printf("0\n0\n9\n");
| 516 |
putv(v1);
| 517 |
putv(v2);
| 518 |
putv(v3);
| 519 |
| 520 |
| 521 |
| 522 |
void
| 523 |
putsided(char *mname) /* print out mixfunc for sided material */
| 524 |
| 525 |
fprintf(matfp, "\nvoid mixfunc %s\n", mname);
| 526 |
fprintf(matfp, "4 %s void if(Rdot,1,0) .\n0\n0\n", mname);
| 527 |
| 528 |
| 529 |
| 530 |
char *
| 531 |
material(void) /* get (and print) current material */
| 532 |
| 533 |
char *mname = "mat";
| 534 |
C_COLOR *refclr = NULL;
| 535 |
char *pname;
| 536 |
COLOR radrgb, c2;
| 537 |
double d;
| 538 |
| 539 |
if (c_cmname != NULL)
| 540 |
mname = c_cmname;
| 541 |
if (!c_cmaterial->clock)
| 542 |
return(mname); /* already current */
| 543 |
/* else update output */
| 544 |
c_cmaterial->clock = 0;
| 545 |
if (c_cmaterial->ed > .1) { /* emitter */
| 546 |
pname = specolor(radrgb, &c_cmaterial->ed_c,
| 547 |
emult*c_cmaterial->ed/(PI*WHTEFFICACY));
| 548 |
if (glowdist < FHUGE) { /* do a glow */
| 549 |
fprintf(matfp, "\n%s glow %s\n0\n0\n", pname, mname);
| 550 |
fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED),
| 551 |
colval(radrgb,GRN),
| 552 |
colval(radrgb,BLU), glowdist);
| 553 |
} else {
| 554 |
fprintf(matfp, "\n%s light %s\n0\n0\n", pname, mname);
| 555 |
fprintf(matfp, "3 %f %f %f\n", colval(radrgb,RED),
| 556 |
colval(radrgb,GRN),
| 557 |
colval(radrgb,BLU));
| 558 |
| 559 |
return(mname);
| 560 |
| 561 |
d = c_cmaterial->rd + c_cmaterial->td +
| 562 |
c_cmaterial->rs + c_cmaterial->ts;
| 563 |
if ((d < 0.) | (d > 1.))
| 564 |
return(NULL);
| 565 |
/* check for glass/dielectric */
| 566 |
if (c_cmaterial->nr > 1.1 &&
| 567 |
c_cmaterial->ts > .25 && c_cmaterial->rs <= .125 &&
| 568 |
c_cmaterial->td <= .01 && c_cmaterial->rd <= .01 &&
| 569 |
c_cmaterial->rs_a <= .01 && c_cmaterial->ts_a <= .01) {
| 570 |
cvtcolor(radrgb, &c_cmaterial->ts_c,
| 571 |
c_cmaterial->ts + c_cmaterial->rs);
| 572 |
if (c_cmaterial->sided) { /* dielectric */
| 573 |
colval(radrgb,RED) = pow(colval(radrgb,RED),
| 574 |
1./C_1SIDEDTHICK);
| 575 |
colval(radrgb,GRN) = pow(colval(radrgb,GRN),
| 576 |
1./C_1SIDEDTHICK);
| 577 |
colval(radrgb,BLU) = pow(colval(radrgb,BLU),
| 578 |
1./C_1SIDEDTHICK);
| 579 |
fprintf(matfp, "\nvoid dielectric %s\n0\n0\n", mname);
| 580 |
fprintf(matfp, "5 %g %g %g %f 0\n", colval(radrgb,RED),
| 581 |
colval(radrgb,GRN), colval(radrgb,BLU),
| 582 |
c_cmaterial->nr);
| 583 |
return(mname);
| 584 |
| 585 |
/* glass */
| 586 |
fprintf(matfp, "\nvoid glass %s\n0\n0\n", mname);
| 587 |
| 588 |
| 589 |
c_cmaterial->nr);
| 590 |
return(mname);
| 591 |
| 592 |
/* check for WGMDfunc */
| 593 |
if (((c_cmaterial->rs > .02) & (c_cmaterial->ts > .02) &&
| 594 |
fabs(c_cmaterial->rs_a - c_cmaterial->ts_a) > .02) ||
| 595 |
((c_cmaterial->rs > .05) & (c_cmaterial->rd > .05) &&
| 596 |
!c_isgrey(&c_cmaterial->rs_c) &&
| 597 |
!c_equiv(&c_cmaterial->rd_c, &c_cmaterial->rs_c)) ||
| 598 |
color_clash(MG_E_TS, MG_E_TD) ||
| 599 |
color_clash(MG_E_TD, MG_E_RD) ||
| 600 |
color_clash(MG_E_RD, MG_E_TS)) {
| 601 |
COLOR rs_rgb, ts_rgb, td_rgb; /* separate modifier paths */
| 602 |
char rs_pname[128], ts_pname[128], td_pname[128];
| 603 |
strcpy(sgen_str, SGEN_RS);
| 604 |
strcpy(rs_pname, specolor(rs_rgb, &c_cmaterial->rs_c, c_cmaterial->rs));
| 605 |
strcpy(sgen_str, SGEN_TS);
| 606 |
strcpy(ts_pname, specolor(ts_rgb, &c_cmaterial->ts_c, c_cmaterial->ts));
| 607 |
strcpy(sgen_str, SGEN_TD);
| 608 |
strcpy(td_pname, specolor(td_rgb, &c_cmaterial->td_c, c_cmaterial->td));
| 609 |
strcpy(sgen_str, SGEN_DEF);
| 610 |
pname = specolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd);
| 611 |
if (!strcmp(rs_pname, void_str) && !isgrey(rs_rgb)) {
| 612 |
putrgbpat(strcpy(rs_pname,"rs_rgb*"), rs_rgb);
| 613 |
colval(rs_rgb,GRN) = 1;
| 614 |
| 615 |
if (!strcmp(ts_pname, void_str) && !isgrey(ts_rgb)) {
| 616 |
putrgbpat(strcpy(ts_pname,"ts_rgb*"), ts_rgb);
| 617 |
colval(ts_rgb,GRN) = 1;
| 618 |
| 619 |
fprintf(matfp, "\n%s WGMDfunc %s\n", pname, mname);
| 620 |
fprintf(matfp, "13\t%s %f %f %f\n", rs_pname, colval(rs_rgb,GRN),
| 621 |
c_cmaterial->rs_a, c_cmaterial->rs_a);
| 622 |
fprintf(matfp, "\t%s %f %f %f\n", ts_pname, colval(ts_rgb,GRN),
| 623 |
c_cmaterial->ts_a, c_cmaterial->ts_a);
| 624 |
fprintf(matfp, "\t%s\n\t0 0 1 .\n0\n", td_pname);
| 625 |
fprintf(matfp, "9\t%f %f %f\n", colval(radrgb,RED),
| 626 |
colval(radrgb,GRN), colval(radrgb,BLU));
| 627 |
fprintf(matfp, "\t%f %f %f\n", colval(radrgb,RED),
| 628 |
| 629 |
fprintf(matfp, "\t%f %f %f\n", colval(td_rgb,RED),
| 630 |
colval(td_rgb,GRN), colval(td_rgb,BLU));
| 631 |
| 632 |
putsided(mname);
| 633 |
return(mname);
| 634 |
| 635 |
/* check for trans */
| 636 |
if (c_cmaterial->td + c_cmaterial->ts > .01) {
| 637 |
double a5, a6;
| 638 |
/* average colors */
| 639 |
d = c_cmaterial->rd + c_cmaterial->td + c_cmaterial->ts;
| 640 |
cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d);
| 641 |
cvtcolor(c2, &c_cmaterial->td_c, c_cmaterial->td/d);
| 642 |
addcolor(radrgb, c2);
| 643 |
cvtcolor(c2, &c_cmaterial->ts_c, c_cmaterial->ts/d);
| 644 |
| 645 |
if (c_cmaterial->rs + c_cmaterial->ts > .0001)
| 646 |
a5 = (c_cmaterial->rs*c_cmaterial->rs_a +
| 647 |
c_cmaterial->ts*c_cmaterial->ts_a) /
| 648 |
(c_cmaterial->rs + c_cmaterial->ts);
| 649 |
a6 = (c_cmaterial->td + c_cmaterial->ts) /
| 650 |
(c_cmaterial->rd + c_cmaterial->td + c_cmaterial->ts);
| 651 |
if (a6 < .999)
| 652 |
d = c_cmaterial->rd/(1. - c_cmaterial->rs)/(1. - a6);
| 653 |
else
| 654 |
d = c_cmaterial->td + c_cmaterial->ts;
| 655 |
scalecolor(radrgb, d);
| 656 |
fprintf(matfp, "\nvoid trans %s\n0\n0\n", mname);
| 657 |
fprintf(matfp, "7 %f %f %f\n", colval(radrgb,RED),
| 658 |
| 659 |
fprintf(matfp, "\t%f %f %f %f\n", c_cmaterial->rs, a5, a6,
| 660 |
c_cmaterial->ts/(c_cmaterial->ts + c_cmaterial->td));
| 661 |
| 662 |
putsided(mname);
| 663 |
return(mname);
| 664 |
| 665 |
/* check for plastic */
| 666 |
if (c_cmaterial->rs < .1 && (c_cmaterial->rs < .1*c_cmaterial->rd ||
| 667 |
c_isgrey(&c_cmaterial->rs_c))) {
| 668 |
| 669 |
c_cmaterial->rd/(1.-c_cmaterial->rs));
| 670 |
fprintf(matfp, "\n%s plastic %s\n0\n0\n", pname, mname);
| 671 |
fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED),
| 672 |
| 673 |
c_cmaterial->rs, c_cmaterial->rs_a);
| 674 |
| 675 |
putsided(mname);
| 676 |
return(mname);
| 677 |
| 678 |
/* else it's metal */
| 679 |
/* compute color */
| 680 |
if (c_equiv(&c_cmaterial->rd_c, &c_cmaterial->rs_c)) {
| 681 |
pname = specolor(radrgb, &c_cmaterial->rs_c, c_cmaterial->rs+c_cmaterial->rd);
| 682 |
} else if (c_cmaterial->rd <= .05f) {
| 683 |
pname = specolor(radrgb, &c_cmaterial->rs_c, c_cmaterial->rs);
| 684 |
cvtcolor(c2, &c_cmaterial->rd_c, c_cmaterial->rd);
| 685 |
| 686 |
} else {
| 687 |
pname = "void";
| 688 |
cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd);
| 689 |
cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs);
| 690 |
| 691 |
| 692 |
fprintf(matfp, "\n%s metal %s\n0\n0\n", pname, mname);
| 693 |
| 694 |
| 695 |
c_cmaterial->rs/(c_cmaterial->rd + c_cmaterial->rs),
| 696 |
c_cmaterial->rs_a);
| 697 |
| 698 |
putsided(mname);
| 699 |
return(mname);
| 700 |
| 701 |
| 702 |
| 703 |
void
| 704 |
cvtcolor( /* convert a CIE XYZ color to RGB */
| 705 |
COLOR radrgb,
| 706 |
C_COLOR *ciec,
| 707 |
double intensity
| 708 |
| 709 |
| 710 |
COLOR ciexyz;
| 711 |
| 712 |
if (intensity <= 0) {
| 713 |
setcolor(radrgb, 0, 0, 0);
| 714 |
return;
| 715 |
| 716 |
c_ccvt(ciec, C_CSXY); /* get xy representation */
| 717 |
ciexyz[1] = intensity;
| 718 |
ciexyz[0] = ciec->cx/ciec->cy*ciexyz[1];
| 719 |
ciexyz[2] = ciexyz[1]*(1./ciec->cy - 1.) - ciexyz[0];
| 720 |
cie_rgb(radrgb, ciexyz);
| 721 |
| 722 |
| 723 |
| 724 |
int color_clash( /* do non-zero material components clash? */
| 725 |
int e1,
| 726 |
int e2
| 727 |
| 728 |
| 729 |
C_COLOR *c1;
| 730 |
| 731 |
if (e1 == e2)
| 732 |
return(0);
| 733 |
switch (e1) {
| 734 |
case MG_E_RD:
| 735 |
if (c_cmaterial->rd <= .01) return(0);
| 736 |
c1 = &c_cmaterial->rd_c;
| 737 |
break;
| 738 |
case MG_E_RS:
| 739 |
if (c_cmaterial->rs <= .01) return(0);
| 740 |
c1 = &c_cmaterial->rs_c;
| 741 |
break;
| 742 |
case MG_E_TD:
| 743 |
if (c_cmaterial->td <= .01) return(0);
| 744 |
c1 = &c_cmaterial->td_c;
| 745 |
break;
| 746 |
case MG_E_TS:
| 747 |
if (c_cmaterial->ts <= .01) return(0);
| 748 |
c1 = &c_cmaterial->ts_c;
| 749 |
break;
| 750 |
default:
| 751 |
return(0);
| 752 |
| 753 |
switch (e2) {
| 754 |
case MG_E_RD:
| 755 |
| 756 |
return(!c_equiv(c1, &c_cmaterial->rd_c));
| 757 |
case MG_E_RS:
| 758 |
| 759 |
return(!c_equiv(c1, &c_cmaterial->rs_c));
| 760 |
case MG_E_TD:
| 761 |
| 762 |
return(!c_equiv(c1, &c_cmaterial->td_c));
| 763 |
case MG_E_TS:
| 764 |
| 765 |
return(!c_equiv(c1, &c_cmaterial->ts_c));
| 766 |
| 767 |
return(0);
| 768 |
| 769 |
| 770 |
| 771 |
static int /* new spectrum definition? */
| 772 |
newspecdef(C_COLOR *spc)
| 773 |
| 774 |
static LUTAB spc_tab = LU_SINIT(NULL,free);
| 775 |
LUENT *lp = lu_find(&spc_tab, (const char *)spc->client_data);
| 776 |
| 777 |
if (lp == NULL) /* should never happen */
| 778 |
return(1);
| 779 |
if (lp->data == NULL) { /* new entry */
| 780 |
lp->key = (char *)spc->client_data;
| 781 |
lp->data = (char *)malloc(sizeof(C_COLOR));
| 782 |
} else if (c_equiv(spc, (C_COLOR *)lp->data))
| 783 |
return(0); /* unchanged */
| 784 |
| 785 |
if (lp->data != NULL) /* else remember if we can */
| 786 |
*(C_COLOR *)lp->data = *spc;
| 787 |
return(1); /* good as new */
| 788 |
| 789 |
| 790 |
| 791 |
char *
| 792 |
specolor( /* check if color has spectra and output accordingly */
| 793 |
COLOR radrgb,
| 794 |
C_COLOR *clr,
| 795 |
double intensity
| 796 |
| 797 |
| 798 |
static char spname[128];
| 799 |
double mult;
| 800 |
int cbeg, cend, i;
| 801 |
| 802 |
if (!dospectra | !(clr->flags & C_CDSPEC) | (intensity <= FTINY)) {
| 803 |
cvtcolor(radrgb, clr, intensity);
| 804 |
return(void_str); /* just use RGB */
| 805 |
| 806 |
setcolor(radrgb, intensity, intensity, intensity);
| 807 |
for (cbeg = 0; cbeg < C_CNSS; cbeg++) /* trim zeros off beginning */
| 808 |
if (clr->ssamp[cbeg])
| 809 |
break;
| 810 |
if (cbeg >= C_CNSS) /* should never happen! */
| 811 |
return(void_str);
| 812 |
if (clr->client_data != NULL) { /* get name if available */
| 813 |
strcpy(spname, (char *)clr->client_data);
| 814 |
strcat(spname, "*"); /* make sure it's special */
| 815 |
if (!newspecdef(clr)) /* output already? */
| 816 |
return(spname);
| 817 |
} else
| 818 |
strcpy(spname, sgen_str);
| 819 |
c_ccvt(clr, C_CSEFF); /* else output spectrum prim */
| 820 |
for (cend = 0; !clr->ssamp[C_CNSS-1-cend]; cend++)
| 821 |
; /* trim zeros off end */
| 822 |
fprintf(matfp, "\nvoid spectrum %s\n0\n0\n", spname);
| 823 |
fprintf(matfp, "%d %d %d", C_CNSS+2-cbeg-cend,
| 824 |
C_CMINWL+cbeg*C_CWLI, C_CMAXWL-cend*C_CWLI);
| 825 |
mult = (C_CNSS*c_dfcolor.eff)/(clr->ssum*clr->eff);
| 826 |
for (i = cbeg; i < C_CNSS-cend; i++) {
| 827 |
if (!((i-cbeg+1)%6)) fputc('\n', matfp);
| 828 |
fprintf(matfp, "\t%.5f", clr->ssamp[i]*mult);
| 829 |
| 830 |
fputc('\n', matfp);
| 831 |
return(spname);
| 832 |
| 833 |
| 834 |
| 835 |
int
| 836 |
isgrey( /* is RGB close match to grey? */
| 837 |
COLOR rgb
| 838 |
| 839 |
| 840 |
const double yv = bright(rgb);
| 841 |
double diff2 = 0;
| 842 |
int i;
| 843 |
| 844 |
for (i = 3; i--; ) {
| 845 |
double d = yv - colval(rgb,i);
| 846 |
diff2 += d*d;
| 847 |
| 848 |
return(diff2 <= yv*yv*0.0025);
| 849 |
| 850 |
| 851 |
| 852 |
void
| 853 |
putrgbpat( /* put out RGB pattern with given name */
| 854 |
char *pnm,
| 855 |
COLOR rgb
| 856 |
| 857 |
| 858 |
fprintf(matfp, "\nvoid colorfunc %s\n", pnm);
| 859 |
fprintf(matfp, "4 %f %f %f .\n0\n0\n", colval(rgb,RED),
| 860 |
colval(rgb,GRN), colval(rgb,BLU));
| 861 |
| 862 |
| 863 |
| 864 |
char *
| 865 |
object(void) /* return current object name */
| 866 |
| 867 |
static char objbuf[64];
| 868 |
int i;
| 869 |
char *cp;
| 870 |
int len;
| 871 |
/* tracked by obj_handler */
| 872 |
i = obj_nnames - sizeof(objbuf)/16;
| 873 |
if (i < 0)
| 874 |
i = 0;
| 875 |
for (cp = objbuf; i < obj_nnames &&
| 876 |
cp + (len=strlen(obj_name[i])) < objbuf+sizeof(objbuf)-1;
| 877 |
i++, *cp++ = '.') {
| 878 |
strcpy(cp, obj_name[i]);
| 879 |
cp += len;
| 880 |
| 881 |
*cp = '\0';
| 882 |
return(objbuf);
| 883 |
| 884 |
| 885 |
| 886 |
char *
| 887 |
addarg( /* add argument and advance pointer */
| 888 |
char *op,
| 889 |
char *arg
| 890 |
| 891 |
| 892 |
*op = ' ';
| 893 |
while ( (*++op = *arg++) )
| 894 |
| 895 |
return(op);
| 896 |
