root/Development/ray/src/cv/mgf2rad.c
Revision: 2.36
Committed: Fri May 23 17:02:07 2025 UTC (5 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.35: +141 -6 lines
feat(mgf2rad): Added support of WGMDfunc material for different spectral components
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.36 static const char RCSid[] = "$Id: mgf2rad.c,v 2.35 2024/01/17 00:43:45 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Convert MGF (Materials and Geometry Format) to Radiance
6     */
7
8     #include <stdio.h>
9 greg 2.25 #include <stdlib.h>
10 greg 2.1 #include <math.h>
11     #include <string.h>
12 schorsch 2.28
13     #include "platform.h"
14 greg 2.29 #include "mgf_parser.h"
15 greg 2.1 #include "color.h"
16     #include "tmesh.h"
17 greg 2.33 #include "lookup.h"
18 greg 2.1
19     #define putv(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2])
20
21 greg 2.9 #define invert (xf_context != NULL && xf_context->rev)
22
23 greg 2.36 #define SGEN_DEF "spec*"
24     #define SGEN_RS "rs_spec*"
25     #define SGEN_TD "td_spec*"
26     #define SGEN_TS "ts_spec*"
27
28     char void_str[] = "void"; /* global VOIDID */
29     char sgen_str[16] = SGEN_DEF; /* generic specular */
30
31 greg 2.2 double glowdist = FHUGE; /* glow test distance */
32 greg 2.1
33 greg 2.8 double emult = 1.; /* emitter multiplier */
34 greg 2.1
35 gwlarson 2.24 FILE *matfp; /* material output file */
36 greg 2.11
37 greg 2.35 int dospectra = 0; /* output spectral colors? */
38
39 schorsch 2.28
40 greg 2.30 extern int r_comment(int ac, char **av);
41 greg 2.33 extern int r_color(int ac, char **av);
42 greg 2.30 extern int r_cone(int ac, char **av);
43     extern int r_cyl(int ac, char **av);
44     extern int r_sph(int ac, char **av);
45     extern int r_ring(int ac, char **av);
46     extern int r_face(int ac, char **av);
47     extern int r_ies(int ac, char **av);
48     extern void putsided(char *mname);
49     extern char * material(void);
50     extern char * object(void);
51     extern char * addarg(char *op, char *arg);
52     extern void do_tri(char *mat, C_VERTEX *cv1, C_VERTEX *cv2, C_VERTEX *cv3, int iv);
53 greg 2.33 extern void cvtcolor(COLOR radrgb, C_COLOR *ciec, double intensity);
54 greg 2.36 extern int color_clash(int e1, int e2);
55     extern int isgrey(COLOR rgb);
56     extern void putrgbpat(char *pnm, COLOR rgb);
57 greg 2.33 extern char * specolor(COLOR radrgb, C_COLOR *ciec, double intensity);
58 greg 2.1
59
60 schorsch 2.28 int
61     main(
62     int argc,
63     char *argv[]
64     )
65 greg 2.1 {
66 greg 2.20 int i;
67 gwlarson 2.24
68     matfp = stdout;
69 greg 2.19 /* print out parser version */
70     printf("## Translated from MGF Version %d.%d\n", MG_VMAJOR, MG_VMINOR);
71 greg 2.1 /* initialize dispatch table */
72 greg 2.16 mg_ehand[MG_E_COMMENT] = r_comment; /* we pass comments */
73     mg_ehand[MG_E_COLOR] = c_hcolor; /* they get color */
74     mg_ehand[MG_E_CONE] = r_cone; /* we do cones */
75     mg_ehand[MG_E_CMIX] = c_hcolor; /* they mix colors */
76     mg_ehand[MG_E_CXY] = c_hcolor; /* they get chromaticities */
77 greg 2.33 mg_ehand[MG_E_CSPEC] = r_color; /* we get spectra */
78     mg_ehand[MG_E_CCT] = r_color; /* we get color temp's */
79 greg 2.16 mg_ehand[MG_E_CYL] = r_cyl; /* we do cylinders */
80     mg_ehand[MG_E_ED] = c_hmaterial; /* they get emission */
81     mg_ehand[MG_E_FACE] = r_face; /* we do faces */
82     mg_ehand[MG_E_IES] = r_ies; /* we do IES files */
83     mg_ehand[MG_E_IR] = c_hmaterial; /* they get refractive index */
84     mg_ehand[MG_E_MATERIAL] = c_hmaterial; /* they get materials */
85     mg_ehand[MG_E_NORMAL] = c_hvertex; /* they get normals */
86     mg_ehand[MG_E_OBJECT] = obj_handler; /* they track object names */
87     mg_ehand[MG_E_POINT] = c_hvertex; /* they get points */
88     mg_ehand[MG_E_RD] = c_hmaterial; /* they get diffuse refl. */
89     mg_ehand[MG_E_RING] = r_ring; /* we do rings */
90     mg_ehand[MG_E_RS] = c_hmaterial; /* they get specular refl. */
91     mg_ehand[MG_E_SIDES] = c_hmaterial; /* they get # sides */
92     mg_ehand[MG_E_SPH] = r_sph; /* we do spheres */
93     mg_ehand[MG_E_TD] = c_hmaterial; /* they get diffuse trans. */
94     mg_ehand[MG_E_TS] = c_hmaterial; /* they get specular trans. */
95     mg_ehand[MG_E_VERTEX] = c_hvertex; /* they get vertices */
96     mg_ehand[MG_E_XF] = xf_handler; /* they track transforms */
97 greg 2.1 mg_init(); /* initialize the parser */
98 greg 2.16 /* get our options & print header */
99 greg 2.1 printf("## %s", argv[0]);
100     for (i = 1; i < argc && argv[i][0] == '-'; i++) {
101     printf(" %s", argv[i]);
102     switch (argv[i][1]) {
103     case 'g': /* glow distance (meters) */
104 greg 2.10 if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f"))
105 greg 2.1 goto userr;
106     glowdist = atof(argv[++i]);
107     printf(" %s", argv[i]);
108     break;
109     case 'e': /* emitter multiplier */
110 greg 2.10 if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f"))
111 greg 2.1 goto userr;
112     emult = atof(argv[++i]);
113     printf(" %s", argv[i]);
114     break;
115 greg 2.11 case 'm': /* materials file */
116     matfp = fopen(argv[++i], "a");
117     if (matfp == NULL) {
118     fprintf(stderr, "%s: cannot append\n", argv[i]);
119     exit(1);
120     }
121     printf(" %s", argv[i]);
122     break;
123 greg 2.35 case 's': /* spectral color output? */
124     dospectra = !dospectra;
125     break;
126 greg 2.1 default:
127     goto userr;
128     }
129     }
130     putchar('\n');
131     if (i == argc) { /* convert stdin */
132 greg 2.20 if (mg_load(NULL) != MG_OK)
133 greg 2.1 exit(1);
134 greg 2.18 if (mg_nunknown)
135     printf("## %s: %u unknown entities\n",
136     argv[0], mg_nunknown);
137 greg 2.1 } else /* convert each file */
138     for ( ; i < argc; i++) {
139     printf("## %s %s ##############################\n",
140     argv[0], argv[i]);
141 greg 2.20 if (mg_load(argv[i]) != MG_OK)
142 greg 2.1 exit(1);
143 greg 2.18 if (mg_nunknown) {
144     printf("## %s %s: %u unknown entities\n",
145     argv[0], argv[i], mg_nunknown);
146     mg_nunknown = 0;
147     }
148 greg 2.1 }
149     exit(0);
150     userr:
151 greg 2.35 fprintf(stderr, "Usage: %s [-s][-g dist][-e mult][-m matf] [file.mgf] ..\n",
152 greg 2.1 argv[0]);
153     exit(1);
154     }
155
156
157     int
158 schorsch 2.28 r_comment( /* repeat a comment verbatim */
159 greg 2.33 int ac,
160     char **av
161 schorsch 2.28 )
162 greg 2.1 {
163 greg 2.7 putchar('#'); /* use Radiance comment character */
164 greg 2.16 while (--ac) { /* pass through verbatim */
165 greg 2.1 putchar(' ');
166     fputs(*++av, stdout);
167     }
168     putchar('\n');
169     return(MG_OK);
170     }
171
172
173     int
174 greg 2.33 r_color( /* call color handler & remember name */
175     int ac,
176     char **av
177     )
178     {
179     int rval = c_hcolor(ac, av);
180
181     if (rval == MG_OK)
182     c_ccolor->client_data = c_ccname;
183
184     return(rval);
185     }
186
187
188     int
189 schorsch 2.28 r_cone( /* put out a cone */
190     int ac,
191     char **av
192     )
193 greg 2.1 {
194     static int ncones;
195     char *mat;
196     double r1, r2;
197     C_VERTEX *cv1, *cv2;
198     FVECT p1, p2;
199     int inv;
200 greg 2.16 /* check argument count and type */
201 greg 2.1 if (ac != 5)
202     return(MG_EARGC);
203     if (!isflt(av[2]) || !isflt(av[4]))
204     return(MG_ETYPE);
205 greg 2.16 /* get the endpoint vertices */
206 greg 2.1 if ((cv1 = c_getvert(av[1])) == NULL ||
207     (cv2 = c_getvert(av[3])) == NULL)
208     return(MG_EUNDEF);
209 greg 2.16 xf_xfmpoint(p1, cv1->p); /* transform endpoints */
210 greg 2.1 xf_xfmpoint(p2, cv2->p);
211 greg 2.16 r1 = xf_scale(atof(av[2])); /* scale radii */
212 greg 2.1 r2 = xf_scale(atof(av[4]));
213 greg 2.16 inv = r1 < 0.; /* check for inverted cone */
214     if (r1 == 0.) { /* check for illegal radii */
215 greg 2.1 if (r2 == 0.)
216     return(MG_EILL);
217     inv = r2 < 0.;
218 schorsch 2.27 } else if (r2 != 0. && inv ^ (r2 < 0.))
219 greg 2.1 return(MG_EILL);
220     if (inv) {
221     r1 = -r1;
222     r2 = -r2;
223     }
224 greg 2.16 if ((mat = material()) == NULL) /* get material */
225 greg 2.1 return(MG_EBADMAT);
226 greg 2.16 /* spit the sucker out */
227 greg 2.1 printf("\n%s %s %sc%d\n", mat, inv ? "cup" : "cone",
228     object(), ++ncones);
229     printf("0\n0\n8\n");
230     putv(p1);
231     putv(p2);
232     printf("%18.12g %18.12g\n", r1, r2);
233     return(MG_OK);
234     }
235
236
237     int
238 schorsch 2.28 r_cyl( /* put out a cylinder */
239     int ac,
240     char **av
241     )
242 greg 2.1 {
243     static int ncyls;
244     char *mat;
245     double rad;
246     C_VERTEX *cv1, *cv2;
247     FVECT p1, p2;
248     int inv;
249 greg 2.16 /* check argument count and type */
250 greg 2.1 if (ac != 4)
251     return(MG_EARGC);
252     if (!isflt(av[2]))
253     return(MG_ETYPE);
254 greg 2.16 /* get the endpoint vertices */
255 greg 2.1 if ((cv1 = c_getvert(av[1])) == NULL ||
256     (cv2 = c_getvert(av[3])) == NULL)
257     return(MG_EUNDEF);
258 greg 2.16 xf_xfmpoint(p1, cv1->p); /* transform endpoints */
259 greg 2.1 xf_xfmpoint(p2, cv2->p);
260 greg 2.16 rad = xf_scale(atof(av[2])); /* scale radius */
261     if ((inv = rad < 0.)) /* check for inverted cylinder */
262 greg 2.1 rad = -rad;
263 greg 2.16 if ((mat = material()) == NULL) /* get material */
264 greg 2.1 return(MG_EBADMAT);
265 greg 2.16 /* spit out the primitive */
266 greg 2.1 printf("\n%s %s %scy%d\n", mat, inv ? "tube" : "cylinder",
267     object(), ++ncyls);
268     printf("0\n0\n7\n");
269     putv(p1);
270     putv(p2);
271     printf("%18.12g\n", rad);
272     return(MG_OK);
273     }
274
275
276     int
277 schorsch 2.28 r_sph( /* put out a sphere */
278     int ac,
279     char **av
280     )
281 greg 2.1 {
282     static int nsphs;
283     char *mat;
284     double rad;
285     C_VERTEX *cv;
286     FVECT cent;
287     int inv;
288 greg 2.16 /* check argument count and type */
289 greg 2.1 if (ac != 3)
290     return(MG_EARGC);
291     if (!isflt(av[2]))
292     return(MG_ETYPE);
293 greg 2.16 if ((cv = c_getvert(av[1])) == NULL) /* get center vertex */
294 greg 2.1 return(MG_EUNDEF);
295 greg 2.16 xf_xfmpoint(cent, cv->p); /* transform center */
296     rad = xf_scale(atof(av[2])); /* scale radius */
297     if ((inv = rad < 0.)) /* check for inversion */
298 greg 2.1 rad = -rad;
299 greg 2.16 if ((mat = material()) == NULL) /* get material */
300 greg 2.1 return(MG_EBADMAT);
301 greg 2.16 /* spit out primitive */
302 greg 2.1 printf("\n%s %s %ss%d\n", mat, inv ? "bubble" : "sphere",
303     object(), ++nsphs);
304     printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n",
305     cent[0], cent[1], cent[2], rad);
306     return(MG_OK);
307     }
308
309
310     int
311 schorsch 2.28 r_ring( /* put out a ring */
312     int ac,
313     char **av
314     )
315 greg 2.1 {
316     static int nrings;
317     char *mat;
318     double r1, r2;
319     C_VERTEX *cv;
320     FVECT cent, norm;
321 greg 2.16 /* check argument count and type */
322 greg 2.1 if (ac != 4)
323     return(MG_EARGC);
324     if (!isflt(av[2]) || !isflt(av[3]))
325     return(MG_ETYPE);
326 greg 2.16 if ((cv = c_getvert(av[1])) == NULL) /* get center vertex */
327 greg 2.1 return(MG_EUNDEF);
328 greg 2.16 if (is0vect(cv->n)) /* make sure we have normal */
329 greg 2.1 return(MG_EILL);
330 greg 2.16 xf_xfmpoint(cent, cv->p); /* transform center */
331     xf_rotvect(norm, cv->n); /* rotate normal */
332     r1 = xf_scale(atof(av[2])); /* scale radii */
333 greg 2.1 r2 = xf_scale(atof(av[3]));
334 schorsch 2.27 if ((r1 < 0.) | (r2 <= r1))
335 greg 2.1 return(MG_EILL);
336 greg 2.16 if ((mat = material()) == NULL) /* get material */
337 greg 2.1 return(MG_EBADMAT);
338 greg 2.16 /* spit out primitive */
339 greg 2.1 printf("\n%s ring %sr%d\n", mat, object(), ++nrings);
340     printf("0\n0\n8\n");
341     putv(cent);
342     putv(norm);
343     printf("%18.12g %18.12g\n", r1, r2);
344     return(MG_OK);
345     }
346
347
348     int
349 schorsch 2.28 r_face( /* convert a face */
350     int ac,
351     char **av
352     )
353 greg 2.1 {
354     static int nfaces;
355 greg 2.25 int myi = invert;
356 greg 2.1 char *mat;
357 greg 2.33 int i;
358     C_VERTEX *cv;
359 greg 2.1 FVECT v;
360 schorsch 2.28
361 greg 2.16 /* check argument count and type */
362 greg 2.1 if (ac < 4)
363     return(MG_EARGC);
364 greg 2.16 if ((mat = material()) == NULL) /* get material */
365 greg 2.1 return(MG_EBADMAT);
366 greg 2.16 if (ac <= 5) { /* check for smoothing */
367 greg 2.23 C_VERTEX *cva[5];
368 greg 2.1 for (i = 1; i < ac; i++) {
369 greg 2.23 if ((cva[i-1] = c_getvert(av[i])) == NULL)
370 greg 2.1 return(MG_EUNDEF);
371 greg 2.23 if (is0vect(cva[i-1]->n))
372 greg 2.1 break;
373     }
374 greg 2.25 if (i < ac)
375     i = ISFLAT;
376     else
377 greg 2.23 i = flat_tri(cva[0]->p, cva[1]->p, cva[2]->p,
378     cva[0]->n, cva[1]->n, cva[2]->n);
379 greg 2.25 if (i == DEGEN)
380     return(MG_OK); /* degenerate (error?) */
381     if (i == RVBENT) {
382     myi = !myi;
383     i = ISBENT;
384     } else if (i == RVFLAT) {
385     myi = !myi;
386     i = ISFLAT;
387 greg 2.23 }
388 greg 2.25 if (i == ISBENT) { /* smoothed triangles */
389     do_tri(mat, cva[0], cva[1], cva[2], myi);
390 greg 2.1 if (ac == 5)
391 greg 2.25 do_tri(mat, cva[2], cva[3], cva[0], myi);
392 greg 2.1 return(MG_OK);
393     }
394     }
395 greg 2.16 /* spit out unsmoothed primitive */
396 greg 2.1 printf("\n%s polygon %sf%d\n", mat, object(), ++nfaces);
397     printf("0\n0\n%d\n", 3*(ac-1));
398 greg 2.16 for (i = 1; i < ac; i++) { /* get, transform, print each vertex */
399 greg 2.25 if ((cv = c_getvert(av[myi ? ac-i : i])) == NULL)
400 greg 2.1 return(MG_EUNDEF);
401     xf_xfmpoint(v, cv->p);
402     putv(v);
403     }
404     return(MG_OK);
405     }
406
407
408 greg 2.15 int
409 schorsch 2.28 r_ies( /* convert an IES luminaire file */
410     int ac,
411     char **av
412     )
413 greg 2.1 {
414     int xa0 = 2;
415 greg 2.15 char combuf[128];
416 greg 2.1 char fname[48];
417     char *oname;
418 greg 2.33 char *op;
419     int i;
420 greg 2.16 /* check argument count */
421 greg 2.1 if (ac < 2)
422     return(MG_EARGC);
423 greg 2.16 /* construct output file name */
424 greg 2.22 if ((op = strrchr(av[1], '/')) != NULL)
425     op++;
426     else
427 greg 2.1 op = av[1];
428     (void)strcpy(fname, op);
429     if ((op = strrchr(fname, '.')) == NULL)
430     op = fname + strlen(fname);
431     (void)strcpy(op, ".rad");
432 greg 2.16 /* see if we need to run ies2rad */
433 greg 2.17 if (access(fname, 0) == -1) {
434 greg 2.16 (void)strcpy(combuf, "ies2rad");/* build ies2rad command */
435     op = combuf + 7; /* get -m option (first) */
436     if (ac-xa0 >= 2 && !strcmp(av[xa0], "-m")) {
437     if (!isflt(av[xa0+1]))
438     return(MG_ETYPE);
439     op = addarg(addarg(op, "-m"), av[xa0+1]);
440     xa0 += 2;
441     }
442     *op++ = ' '; /* build IES filename */
443     i = 0;
444     if (mg_file != NULL &&
445     (oname = strrchr(mg_file->fname,'/')) != NULL) {
446     i = oname - mg_file->fname + 1;
447     (void)strcpy(op, mg_file->fname);
448     }
449     (void)strcpy(op+i, av[1]);
450     if (access(op, 0) == -1) /* check for file existence */
451     return(MG_ENOFILE);
452     system(combuf); /* run ies2rad */
453     if (access(fname, 0) == -1) /* check success */
454     return(MG_EINCL);
455     }
456     printf("\n!xform"); /* put out xform command */
457 greg 2.1 oname = object();
458 greg 2.4 if (*oname) {
459     printf(" -n ");
460     for (op = oname; op[1]; op++) /* remove trailing separator */
461     putchar(*op);
462     }
463 greg 2.1 for (i = xa0; i < ac; i++)
464     printf(" %s", av[i]);
465     if (ac > xa0 && xf_argc > 0)
466     printf(" -i 1");
467     for (i = 0; i < xf_argc; i++)
468     printf(" %s", xf_argv[i]);
469     printf(" %s\n", fname);
470     return(MG_OK);
471     }
472
473
474 schorsch 2.28 void
475     do_tri( /* put out smoothed triangle */
476     char *mat,
477     C_VERTEX *cv1,
478     C_VERTEX *cv2,
479     C_VERTEX *cv3,
480     int iv
481     )
482 greg 2.1 {
483     static int ntris;
484     BARYCCM bvecs;
485 schorsch 2.26 RREAL bcoor[3][3];
486 greg 2.23 C_VERTEX *cvt;
487 greg 2.1 FVECT v1, v2, v3;
488     FVECT n1, n2, n3;
489 greg 2.33 int i;
490 greg 2.23
491 greg 2.25 if (iv) { /* swap vertex order if inverted */
492 greg 2.23 cvt = cv1;
493     cv1 = cv3;
494     cv3 = cvt;
495 greg 2.9 }
496 greg 2.1 xf_xfmpoint(v1, cv1->p);
497     xf_xfmpoint(v2, cv2->p);
498     xf_xfmpoint(v3, cv3->p);
499 greg 2.16 /* compute barycentric coords. */
500 greg 2.2 if (comp_baryc(&bvecs, v1, v2, v3) < 0)
501     return; /* degenerate triangle! */
502 greg 2.16 printf("\n%s texfunc T-nor\n", mat); /* put out texture */
503 greg 2.2 printf("4 dx dy dz %s\n0\n", TCALNAME);
504     xf_rotvect(n1, cv1->n);
505     xf_rotvect(n2, cv2->n);
506     xf_rotvect(n3, cv3->n);
507     for (i = 0; i < 3; i++) {
508     bcoor[i][0] = n1[i];
509     bcoor[i][1] = n2[i];
510     bcoor[i][2] = n3[i];
511 greg 2.1 }
512 greg 2.32 fput_baryc(&bvecs, bcoor, 3, stdout);
513 greg 2.16 /* put out triangle */
514 greg 2.2 printf("\nT-nor polygon %st%d\n", object(), ++ntris);
515 greg 2.1 printf("0\n0\n9\n");
516     putv(v1);
517     putv(v2);
518     putv(v3);
519     }
520
521
522 greg 2.30 void
523     putsided(char *mname) /* print out mixfunc for sided material */
524     {
525     fprintf(matfp, "\nvoid mixfunc %s\n", mname);
526     fprintf(matfp, "4 %s void if(Rdot,1,0) .\n0\n0\n", mname);
527     }
528
529
530 greg 2.1 char *
531 schorsch 2.28 material(void) /* get (and print) current material */
532 greg 2.1 {
533     char *mname = "mat";
534 greg 2.36 C_COLOR *refclr = NULL;
535 greg 2.33 char *pname;
536 greg 2.1 COLOR radrgb, c2;
537     double d;
538
539 greg 2.5 if (c_cmname != NULL)
540     mname = c_cmname;
541 greg 2.1 if (!c_cmaterial->clock)
542     return(mname); /* already current */
543     /* else update output */
544     c_cmaterial->clock = 0;
545     if (c_cmaterial->ed > .1) { /* emitter */
546 greg 2.33 pname = specolor(radrgb, &c_cmaterial->ed_c,
547 greg 2.12 emult*c_cmaterial->ed/(PI*WHTEFFICACY));
548 greg 2.2 if (glowdist < FHUGE) { /* do a glow */
549 greg 2.33 fprintf(matfp, "\n%s glow %s\n0\n0\n", pname, mname);
550 greg 2.11 fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED),
551 greg 2.1 colval(radrgb,GRN),
552     colval(radrgb,BLU), glowdist);
553     } else {
554 greg 2.33 fprintf(matfp, "\n%s light %s\n0\n0\n", pname, mname);
555 greg 2.11 fprintf(matfp, "3 %f %f %f\n", colval(radrgb,RED),
556 greg 2.1 colval(radrgb,GRN),
557     colval(radrgb,BLU));
558     }
559     return(mname);
560     }
561     d = c_cmaterial->rd + c_cmaterial->td +
562     c_cmaterial->rs + c_cmaterial->ts;
563 schorsch 2.27 if ((d < 0.) | (d > 1.))
564 greg 2.1 return(NULL);
565 greg 2.14 /* check for glass/dielectric */
566     if (c_cmaterial->nr > 1.1 &&
567     c_cmaterial->ts > .25 && c_cmaterial->rs <= .125 &&
568     c_cmaterial->td <= .01 && c_cmaterial->rd <= .01 &&
569     c_cmaterial->rs_a <= .01 && c_cmaterial->ts_a <= .01) {
570     cvtcolor(radrgb, &c_cmaterial->ts_c,
571     c_cmaterial->ts + c_cmaterial->rs);
572     if (c_cmaterial->sided) { /* dielectric */
573     colval(radrgb,RED) = pow(colval(radrgb,RED),
574     1./C_1SIDEDTHICK);
575     colval(radrgb,GRN) = pow(colval(radrgb,GRN),
576     1./C_1SIDEDTHICK);
577     colval(radrgb,BLU) = pow(colval(radrgb,BLU),
578     1./C_1SIDEDTHICK);
579     fprintf(matfp, "\nvoid dielectric %s\n0\n0\n", mname);
580     fprintf(matfp, "5 %g %g %g %f 0\n", colval(radrgb,RED),
581     colval(radrgb,GRN), colval(radrgb,BLU),
582     c_cmaterial->nr);
583     return(mname);
584     }
585     /* glass */
586     fprintf(matfp, "\nvoid glass %s\n0\n0\n", mname);
587     fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED),
588     colval(radrgb,GRN), colval(radrgb,BLU),
589     c_cmaterial->nr);
590     return(mname);
591 greg 2.33 }
592 greg 2.36 /* check for WGMDfunc */
593     if (((c_cmaterial->rs > .02) & (c_cmaterial->ts > .02) &&
594     fabs(c_cmaterial->rs_a - c_cmaterial->ts_a) > .02) ||
595     ((c_cmaterial->rs > .05) & (c_cmaterial->rd > .05) &&
596     !c_isgrey(&c_cmaterial->rs_c) &&
597     !c_equiv(&c_cmaterial->rd_c, &c_cmaterial->rs_c)) ||
598     color_clash(MG_E_TS, MG_E_TD) ||
599     color_clash(MG_E_TD, MG_E_RD) ||
600     color_clash(MG_E_RD, MG_E_TS)) {
601     COLOR rs_rgb, ts_rgb, td_rgb; /* separate modifier paths */
602     char rs_pname[128], ts_pname[128], td_pname[128];
603     strcpy(sgen_str, SGEN_RS);
604     strcpy(rs_pname, specolor(rs_rgb, &c_cmaterial->rs_c, c_cmaterial->rs));
605     strcpy(sgen_str, SGEN_TS);
606     strcpy(ts_pname, specolor(ts_rgb, &c_cmaterial->ts_c, c_cmaterial->ts));
607     strcpy(sgen_str, SGEN_TD);
608     strcpy(td_pname, specolor(td_rgb, &c_cmaterial->td_c, c_cmaterial->td));
609     strcpy(sgen_str, SGEN_DEF);
610     pname = specolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd);
611     if (!strcmp(rs_pname, void_str) && !isgrey(rs_rgb)) {
612     putrgbpat(strcpy(rs_pname,"rs_rgb*"), rs_rgb);
613     colval(rs_rgb,GRN) = 1;
614     }
615     if (!strcmp(ts_pname, void_str) && !isgrey(ts_rgb)) {
616     putrgbpat(strcpy(ts_pname,"ts_rgb*"), ts_rgb);
617     colval(ts_rgb,GRN) = 1;
618     }
619     fprintf(matfp, "\n%s WGMDfunc %s\n", pname, mname);
620     fprintf(matfp, "13\t%s %f %f %f\n", rs_pname, colval(rs_rgb,GRN),
621     c_cmaterial->rs_a, c_cmaterial->rs_a);
622     fprintf(matfp, "\t%s %f %f %f\n", ts_pname, colval(ts_rgb,GRN),
623     c_cmaterial->ts_a, c_cmaterial->ts_a);
624     fprintf(matfp, "\t%s\n\t0 0 1 .\n0\n", td_pname);
625     fprintf(matfp, "9\t%f %f %f\n", colval(radrgb,RED),
626     colval(radrgb,GRN), colval(radrgb,BLU));
627     fprintf(matfp, "\t%f %f %f\n", colval(radrgb,RED),
628     colval(radrgb,GRN), colval(radrgb,BLU));
629     fprintf(matfp, "\t%f %f %f\n", colval(td_rgb,RED),
630     colval(td_rgb,GRN), colval(td_rgb,BLU));
631     if (c_cmaterial->sided)
632     putsided(mname);
633     return(mname);
634     }
635 greg 2.3 /* check for trans */
636 greg 2.36 if (c_cmaterial->td + c_cmaterial->ts > .01) {
637 greg 2.30 double a5, a6;
638 greg 2.1 /* average colors */
639 greg 2.30 d = c_cmaterial->rd + c_cmaterial->td + c_cmaterial->ts;
640 greg 2.1 cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d);
641     cvtcolor(c2, &c_cmaterial->td_c, c_cmaterial->td/d);
642     addcolor(radrgb, c2);
643 greg 2.30 cvtcolor(c2, &c_cmaterial->ts_c, c_cmaterial->ts/d);
644 greg 2.1 addcolor(radrgb, c2);
645 greg 2.30 if (c_cmaterial->rs + c_cmaterial->ts > .0001)
646 greg 2.1 a5 = (c_cmaterial->rs*c_cmaterial->rs_a +
647 greg 2.30 c_cmaterial->ts*c_cmaterial->ts_a) /
648     (c_cmaterial->rs + c_cmaterial->ts);
649     a6 = (c_cmaterial->td + c_cmaterial->ts) /
650     (c_cmaterial->rd + c_cmaterial->td + c_cmaterial->ts);
651 greg 2.7 if (a6 < .999)
652 greg 2.1 d = c_cmaterial->rd/(1. - c_cmaterial->rs)/(1. - a6);
653 greg 2.7 else
654 greg 2.30 d = c_cmaterial->td + c_cmaterial->ts;
655 greg 2.7 scalecolor(radrgb, d);
656 greg 2.11 fprintf(matfp, "\nvoid trans %s\n0\n0\n", mname);
657     fprintf(matfp, "7 %f %f %f\n", colval(radrgb,RED),
658 greg 2.1 colval(radrgb,GRN), colval(radrgb,BLU));
659 greg 2.11 fprintf(matfp, "\t%f %f %f %f\n", c_cmaterial->rs, a5, a6,
660 greg 2.30 c_cmaterial->ts/(c_cmaterial->ts + c_cmaterial->td));
661     if (c_cmaterial->sided)
662     putsided(mname);
663 greg 2.1 return(mname);
664     }
665 greg 2.3 /* check for plastic */
666 greg 2.33 if (c_cmaterial->rs < .1 && (c_cmaterial->rs < .1*c_cmaterial->rd ||
667 greg 2.31 c_isgrey(&c_cmaterial->rs_c))) {
668 greg 2.33 pname = specolor(radrgb, &c_cmaterial->rd_c,
669 greg 2.1 c_cmaterial->rd/(1.-c_cmaterial->rs));
670 greg 2.33 fprintf(matfp, "\n%s plastic %s\n0\n0\n", pname, mname);
671 greg 2.11 fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED),
672 greg 2.1 colval(radrgb,GRN), colval(radrgb,BLU),
673     c_cmaterial->rs, c_cmaterial->rs_a);
674 greg 2.30 if (c_cmaterial->sided)
675     putsided(mname);
676 greg 2.1 return(mname);
677     }
678     /* else it's metal */
679 greg 2.33 /* compute color */
680     if (c_equiv(&c_cmaterial->rd_c, &c_cmaterial->rs_c)) {
681     pname = specolor(radrgb, &c_cmaterial->rs_c, c_cmaterial->rs+c_cmaterial->rd);
682     } else if (c_cmaterial->rd <= .05f) {
683     pname = specolor(radrgb, &c_cmaterial->rs_c, c_cmaterial->rs);
684     cvtcolor(c2, &c_cmaterial->rd_c, c_cmaterial->rd);
685     addcolor(radrgb, c2);
686     } else {
687     pname = "void";
688     cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd);
689     cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs);
690     addcolor(radrgb, c2);
691     }
692     fprintf(matfp, "\n%s metal %s\n0\n0\n", pname, mname);
693 greg 2.11 fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED),
694 greg 2.1 colval(radrgb,GRN), colval(radrgb,BLU),
695 greg 2.7 c_cmaterial->rs/(c_cmaterial->rd + c_cmaterial->rs),
696     c_cmaterial->rs_a);
697 greg 2.30 if (c_cmaterial->sided)
698     putsided(mname);
699 greg 2.1 return(mname);
700     }
701
702
703 schorsch 2.28 void
704     cvtcolor( /* convert a CIE XYZ color to RGB */
705     COLOR radrgb,
706 greg 2.33 C_COLOR *ciec,
707 schorsch 2.28 double intensity
708     )
709 greg 2.1 {
710 greg 2.33 COLOR ciexyz;
711 greg 2.1
712 greg 2.36 if (intensity <= 0) {
713     setcolor(radrgb, 0, 0, 0);
714     return;
715     }
716 greg 2.4 c_ccvt(ciec, C_CSXY); /* get xy representation */
717 greg 2.1 ciexyz[1] = intensity;
718     ciexyz[0] = ciec->cx/ciec->cy*ciexyz[1];
719     ciexyz[2] = ciexyz[1]*(1./ciec->cy - 1.) - ciexyz[0];
720     cie_rgb(radrgb, ciexyz);
721     }
722
723
724 greg 2.36 int color_clash( /* do non-zero material components clash? */
725     int e1,
726     int e2
727     )
728     {
729     C_COLOR *c1;
730
731     if (e1 == e2)
732     return(0);
733     switch (e1) {
734     case MG_E_RD:
735     if (c_cmaterial->rd <= .01) return(0);
736     c1 = &c_cmaterial->rd_c;
737     break;
738     case MG_E_RS:
739     if (c_cmaterial->rs <= .01) return(0);
740     c1 = &c_cmaterial->rs_c;
741     break;
742     case MG_E_TD:
743     if (c_cmaterial->td <= .01) return(0);
744     c1 = &c_cmaterial->td_c;
745     break;
746     case MG_E_TS:
747     if (c_cmaterial->ts <= .01) return(0);
748     c1 = &c_cmaterial->ts_c;
749     break;
750     default:
751     return(0);
752     }
753     switch (e2) {
754     case MG_E_RD:
755     if (c_cmaterial->rd <= .01) return(0);
756     return(!c_equiv(c1, &c_cmaterial->rd_c));
757     case MG_E_RS:
758     if (c_cmaterial->rs <= .01) return(0);
759     return(!c_equiv(c1, &c_cmaterial->rs_c));
760     case MG_E_TD:
761     if (c_cmaterial->td <= .01) return(0);
762     return(!c_equiv(c1, &c_cmaterial->td_c));
763     case MG_E_TS:
764     if (c_cmaterial->ts <= .01) return(0);
765     return(!c_equiv(c1, &c_cmaterial->ts_c));
766     }
767     return(0);
768     }
769
770
771 greg 2.33 static int /* new spectrum definition? */
772     newspecdef(C_COLOR *spc)
773     {
774     static LUTAB spc_tab = LU_SINIT(NULL,free);
775     LUENT *lp = lu_find(&spc_tab, (const char *)spc->client_data);
776
777     if (lp == NULL) /* should never happen */
778     return(1);
779     if (lp->data == NULL) { /* new entry */
780     lp->key = (char *)spc->client_data;
781     lp->data = (char *)malloc(sizeof(C_COLOR));
782     } else if (c_equiv(spc, (C_COLOR *)lp->data))
783     return(0); /* unchanged */
784
785     if (lp->data != NULL) /* else remember if we can */
786     *(C_COLOR *)lp->data = *spc;
787     return(1); /* good as new */
788     }
789
790
791     char *
792     specolor( /* check if color has spectra and output accordingly */
793     COLOR radrgb,
794     C_COLOR *clr,
795     double intensity
796     )
797     {
798     static char spname[128];
799     double mult;
800 greg 2.34 int cbeg, cend, i;
801 greg 2.33
802 greg 2.36 if (!dospectra | !(clr->flags & C_CDSPEC) | (intensity <= FTINY)) {
803 greg 2.33 cvtcolor(radrgb, clr, intensity);
804 greg 2.36 return(void_str); /* just use RGB */
805 greg 2.33 }
806     setcolor(radrgb, intensity, intensity, intensity);
807 greg 2.34 for (cbeg = 0; cbeg < C_CNSS; cbeg++) /* trim zeros off beginning */
808     if (clr->ssamp[cbeg])
809     break;
810     if (cbeg >= C_CNSS) /* should never happen! */
811 greg 2.36 return(void_str);
812 greg 2.33 if (clr->client_data != NULL) { /* get name if available */
813     strcpy(spname, (char *)clr->client_data);
814     strcat(spname, "*"); /* make sure it's special */
815     if (!newspecdef(clr)) /* output already? */
816     return(spname);
817     } else
818 greg 2.36 strcpy(spname, sgen_str);
819 greg 2.33 c_ccvt(clr, C_CSEFF); /* else output spectrum prim */
820 greg 2.34 for (cend = 0; !clr->ssamp[C_CNSS-1-cend]; cend++)
821     ; /* trim zeros off end */
822 greg 2.33 fprintf(matfp, "\nvoid spectrum %s\n0\n0\n", spname);
823 greg 2.34 fprintf(matfp, "%d %d %d", C_CNSS+2-cbeg-cend,
824     C_CMINWL+cbeg*C_CWLI, C_CMAXWL-cend*C_CWLI);
825 greg 2.33 mult = (C_CNSS*c_dfcolor.eff)/(clr->ssum*clr->eff);
826 greg 2.34 for (i = cbeg; i < C_CNSS-cend; i++) {
827     if (!((i-cbeg+1)%6)) fputc('\n', matfp);
828 greg 2.33 fprintf(matfp, "\t%.5f", clr->ssamp[i]*mult);
829     }
830     fputc('\n', matfp);
831     return(spname);
832     }
833
834
835 greg 2.36 int
836     isgrey( /* is RGB close match to grey? */
837     COLOR rgb
838     )
839     {
840     const double yv = bright(rgb);
841     double diff2 = 0;
842     int i;
843
844     for (i = 3; i--; ) {
845     double d = yv - colval(rgb,i);
846     diff2 += d*d;
847     }
848     return(diff2 <= yv*yv*0.0025);
849     }
850
851
852     void
853     putrgbpat( /* put out RGB pattern with given name */
854     char *pnm,
855     COLOR rgb
856     )
857     {
858     fprintf(matfp, "\nvoid colorfunc %s\n", pnm);
859     fprintf(matfp, "4 %f %f %f .\n0\n0\n", colval(rgb,RED),
860     colval(rgb,GRN), colval(rgb,BLU));
861     }
862
863
864 greg 2.1 char *
865 schorsch 2.28 object(void) /* return current object name */
866 greg 2.1 {
867     static char objbuf[64];
868 greg 2.33 int i;
869     char *cp;
870 greg 2.1 int len;
871 greg 2.16 /* tracked by obj_handler */
872 greg 2.1 i = obj_nnames - sizeof(objbuf)/16;
873     if (i < 0)
874     i = 0;
875     for (cp = objbuf; i < obj_nnames &&
876     cp + (len=strlen(obj_name[i])) < objbuf+sizeof(objbuf)-1;
877     i++, *cp++ = '.') {
878     strcpy(cp, obj_name[i]);
879     cp += len;
880     }
881     *cp = '\0';
882     return(objbuf);
883     }
884
885
886     char *
887 schorsch 2.28 addarg( /* add argument and advance pointer */
888 greg 2.33 char *op,
889     char *arg
890 schorsch 2.28 )
891 greg 2.1 {
892     *op = ' ';
893 schorsch 2.27 while ( (*++op = *arg++) )
894 greg 2.1 ;
895     return(op);
896     }
