--- ray/src/cv/mgf2meta.c 1995/04/11 13:32:47 2.3 +++ ray/src/cv/mgf2meta.c 1995/05/04 14:25:15 2.5 @@ -10,15 +10,22 @@ static char SCCSid[] = "$SunId$ LBL"; #include #include +#include "random.h" #include "mgflib/parser.h" -#define MX(v) (int)(((1<<14)-1)*(v)[(proj_axis+1)%3]) -#define MY(v) (int)(((1<<14)-1)*(v)[(proj_axis+2)%3]) +#define MSIZE ((1<<14)-1) +#define MX(v) (int)(MSIZE*(v)[(proj_axis+1)%3]) +#define MY(v) (int)(MSIZE*(v)[(proj_axis+2)%3]) +#ifdef DCL_ATOF +extern double atof(); +#endif + int r_face(); int proj_axis; double limit[3][2]; int layer; +long rthresh = 1; extern int mg_nqcdivs; @@ -36,6 +43,12 @@ char *argv[]; mg_nqcdivs = 3; /* reduce object subdivision */ mg_init(); /* initialize the parser */ /* get arguments */ + if (argc > 9 && !strcmp(argv[1], "-t")) { + rthresh = atof(argv[2])*MSIZE + 0.5; + rthresh *= rthresh; + argv += 2; + argc -= 2; + } if (argc < 8 || (proj_axis = argv[1][0]-'x') < 0 || proj_axis > 2) goto userr; limit[0][0] = atof(argv[2]); limit[0][1] = atof(argv[3]); @@ -49,17 +62,14 @@ char *argv[]; for (i = 8; i < argc; i++) { if (mg_load(argv[i]) != MG_OK) exit(1); - if (++layer >= 16) { - mendpage(); - layer = 0; - } + newlayer(); } mendpage(); /* print page */ mdone(); /* close output */ exit(0); userr: - fprintf(stderr, "Usage: %s {x|y|z} xmin xmax ymin ymax zmin zmax [file.mgf] ..\n", - argv[0]); + fputs("Usage: mgf2meta [-t thresh] {x|y|z} xmin xmax ymin ymax zmin zmax [file.mgf] ..\n", + stderr); exit(1); } @@ -73,7 +83,6 @@ char **av; register int i, j; register C_VERTEX *cv; FVECT v1, v2, vo; - int newline = 1; if (ac < 4) return(MG_EARGC); @@ -91,10 +100,55 @@ char **av; v2[j] = (v2[j] - limit[j][0])/(limit[j][1]-limit[j][0]); VCOPY(v1, vo); VCOPY(vo, v2); - if (clip(v1, v2, bbmin, bbmax)) { - mline(MX(v1), MY(v1), layer/4, 0, layer%4); - mdraw(MX(v2), MY(v2)); - } + if (clip(v1, v2, bbmin, bbmax)) + doline(MX(v1), MY(v1), MX(v2), MY(v2)); } return(MG_OK); +} + + +#define HTBLSIZ 16381 /* prime hash table size */ + +short hshtab[HTBLSIZ][4]; /* done line segments */ + +#define hash(mx1,my1,mx2,my2) ((long)(mx1)<<15 ^ (long)(my1)<<10 ^ \ + (long)(mx2)<<5 ^ (long)(my2)) + + +newlayer() /* start a new layer */ +{ +#ifdef BSD + bzero((char *)hshtab, sizeof(hshtab)); +#else + (void)memset((char *)hshtab, 0, sizeof(hshtab)); +#endif + if (++layer >= 16) { + mendpage(); + layer = 0; + } +} + + +int +doline(v1x, v1y, v2x, v2y) /* draw line conditionally */ +int v1x, v1y, v2x, v2y; +{ + register int h; + + if (v1x > v2x || (v1x == v2x && v1y > v2y)) { /* sort endpoints */ + h=v1x; v1x=v2x; v2x=h; + h=v1y; v1y=v2y; v2y=h; + } + h = hash(v1x, v1y, v2x, v2y) % HTBLSIZ; + if (hshtab[h][0] == v1x && hshtab[h][1] == v1y && + hshtab[h][2] == v2x && hshtab[h][3] == v2y) + return(0); + hshtab[h][0] = v1x; hshtab[h][1] = v1y; + hshtab[h][2] = v2x; hshtab[h][3] = v2y; + if ((long)(v2x-v1x)*(v2x-v1x) + (long)(v2y-v1y)*(v2y-v1y) + <= random() % rthresh) + return(0); + mline(v1x, v1y, layer/4, 0, layer%4); + mdraw(v2x, v2y); + return(1); }
