root/radiance/ray/src/cv/mgf2meta.c
Tue Feb 22 16:45:12 2011 UTC (13 years, 2 months ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Diff to previous 2.11 , to selected 2.3
Fixed a few compile errors due to code reorg
Mon Nov 17 13:20:10 2003 UTC (20 years, 5 months ago) by schorsch
Diff to previous 2.10 , to selected 2.3
Mon Nov 17 02:21:53 2003 UTC (20 years, 5 months ago) by greg
Diff to previous 2.9 , to selected 2.3
Unix compile fixes for previous change
Sat Nov 15 17:54:06 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 2.8: +25 -11 lines
Tue Oct 21 19:19:28 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 2.6: +3 -6 lines
Changes since 2.5: +2 -8 lines
Thu May 4 14:25:15 1995 UTC (29 years ago) by greg
Changes since 2.4: +17 -7 lines
made random tossing of lines optional with -t
Thu May 4 13:55:30 1995 UTC (29 years ago) by greg
Changes since 2.3: +53 -9 lines
decreased number of lines by checking for overdraw and
throwing out small segments on a random basis
Tue Apr 11 13:32:47 1995 UTC (29 years, 1 month ago) by greg
Changes since 2.2: +7 -3 lines
added colors to layers
Tue Apr 4 11:06:53 1995 UTC (29 years, 1 month ago) by greg
Changes since 2.1: +8 -6 lines
bug fix
Tue Apr 4 10:20:21 1995 UTC (29 years, 1 month ago) by greg
Diff to selected 2.3
