1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: mgf2inv.c,v 2.3 2012/05/15 15:36:33 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Convert MGF to Inventor file. |
6 |
7 |
* December 1995 Greg Ward |
8 |
9 |
10 |
#include <stdio.h> |
11 |
12 |
#include <stdlib.h> |
13 |
14 |
#include <math.h> |
15 |
16 |
#include <ctype.h> |
17 |
18 |
#include <string.h> |
19 |
20 |
#include "mgf_parser.h" |
21 |
22 |
#include "lookup.h" |
23 |
24 |
#define O_INV1 1 /* Inventor 1.0 output */ |
25 |
#define O_INV2 2 /* Inventor 2.0 output */ |
26 |
#define O_VRML1 3 /* VRML 1.0 output */ |
27 |
28 |
#define MAXID 48 /* maximum identifier length */ |
29 |
30 |
#define VERTFMT "%+16.9e %+16.9e %+16.9e\n%+6.3f %+6.3f %+6.3f" |
31 |
#define VZVECT "+0.000 +0.000 +0.000" |
32 |
#define VFLEN 92 /* total vertex string length */ |
33 |
#define MAXVERT 10240 /* maximum cached vertices */ |
34 |
35 |
#define setvkey(k,v) sprintf(k,VERTFMT,(v)->p[0],(v)->p[1],(v)->p[2],\ |
36 |
(v)->n[0],(v)->n[1],(v)->n[2]); |
37 |
38 |
char vlist[MAXVERT][VFLEN]; /* our vertex cache */ |
39 |
int nverts; /* current cache size */ |
40 |
41 |
LUTAB vert_tab = LU_SINIT(NULL,NULL); |
42 |
43 |
struct face { |
44 |
struct face *next; /* next face in list */ |
45 |
short nv; /* number of vertices */ |
46 |
short vl[3]; /* vertex index list (variable) */ |
47 |
} *flist, *flast; /* our face cache */ |
48 |
49 |
#define newface(n) (struct face *)malloc(sizeof(struct face) + \ |
50 |
((n) > 3 ? (n)-3 : 0)*sizeof(short)) |
51 |
#define freeface(f) free(f) |
52 |
53 |
#define TABSTOP 8 /* assumed number of characters per tab */ |
54 |
#define SHIFTW 2 /* nesting shift width */ |
55 |
#define MAXIND 15 /* maximum indent level */ |
56 |
57 |
char tabs[MAXIND*SHIFTW+1]; /* current tab-in string */ |
58 |
59 |
#define curmatname (c_cmname == NULL ? "mat" : to_id(c_cmname)) |
60 |
61 |
int outtype = O_INV2; /* output format */ |
62 |
63 |
int i_comment(int ac, char **av); |
64 |
int i_object(int ac, char **av); |
65 |
int i_xf(int ac, char **av); |
66 |
int put_xform(register XF_SPEC *spec); |
67 |
int put_material(void); |
68 |
int i_face(int ac, char **av); |
69 |
int i_sph(int ac, char **av); |
70 |
int i_cyl(int ac, char **av); |
71 |
char * to_id(register char *name); |
72 |
73 |
void flush_cache(void); |
74 |
75 |
76 |
int |
77 |
main( |
78 |
int argc, |
79 |
char *argv[] |
80 |
81 |
82 |
int i; |
83 |
/* initialize dispatch table */ |
84 |
mg_ehand[MG_E_COMMENT] = i_comment; /* we pass comments */ |
85 |
mg_ehand[MG_E_COLOR] = c_hcolor; /* they get color */ |
86 |
mg_ehand[MG_E_CMIX] = c_hcolor; /* they mix colors */ |
87 |
mg_ehand[MG_E_CSPEC] = c_hcolor; /* they get spectra */ |
88 |
mg_ehand[MG_E_CXY] = c_hcolor; /* they get chromaticities */ |
89 |
mg_ehand[MG_E_CCT] = c_hcolor; /* they get color temp's */ |
90 |
mg_ehand[MG_E_CYL] = i_cyl; /* we do cylinders */ |
91 |
mg_ehand[MG_E_ED] = c_hmaterial; /* they get emission */ |
92 |
mg_ehand[MG_E_FACE] = i_face; /* we do faces */ |
93 |
mg_ehand[MG_E_MATERIAL] = c_hmaterial; /* they get materials */ |
94 |
mg_ehand[MG_E_NORMAL] = c_hvertex; /* they get normals */ |
95 |
mg_ehand[MG_E_OBJECT] = i_object; /* we track object names */ |
96 |
mg_ehand[MG_E_POINT] = c_hvertex; /* they get points */ |
97 |
mg_ehand[MG_E_RD] = c_hmaterial; /* they get diffuse refl. */ |
98 |
mg_ehand[MG_E_RS] = c_hmaterial; /* they get specular refl. */ |
99 |
mg_ehand[MG_E_SIDES] = c_hmaterial; /* they get # sides */ |
100 |
mg_ehand[MG_E_SPH] = i_sph; /* we do spheres */ |
101 |
mg_ehand[MG_E_TD] = c_hmaterial; /* they get diffuse trans. */ |
102 |
mg_ehand[MG_E_TS] = c_hmaterial; /* they get specular trans. */ |
103 |
mg_ehand[MG_E_VERTEX] = c_hvertex; /* they get vertices */ |
104 |
mg_ehand[MG_E_XF] = i_xf; /* we track transforms */ |
105 |
mg_init(); /* initialize the parser */ |
106 |
/* get options and print format line */ |
107 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
108 |
if (!strcmp(argv[i], "-vrml")) |
109 |
outtype = O_VRML1; |
110 |
else if (!strcmp(argv[i], "-1")) |
111 |
outtype = O_INV1; |
112 |
else if (!strcmp(argv[i], "-2")) |
113 |
outtype = O_INV2; |
114 |
else |
115 |
goto userr; |
116 |
switch (outtype) { |
117 |
case O_INV1: |
118 |
printf("#Inventor V1.0 ascii\n"); |
119 |
break; |
120 |
case O_INV2: |
121 |
printf("#Inventor V2.0 ascii\n"); |
122 |
break; |
123 |
case O_VRML1: |
124 |
printf("#VRML V1.0 ascii\n"); |
125 |
break; |
126 |
127 |
printf("## Translated from MGF Version %d.%d\n", MG_VMAJOR, MG_VMINOR); |
128 |
printf("Separator {\n"); /* begin root node */ |
129 |
/* general properties */ |
130 |
printf("MaterialBinding { value OVERALL }\n"); |
131 |
printf("NormalBinding { value PER_VERTEX_INDEXED }\n"); |
132 |
if (outtype != O_INV1) { |
133 |
printf("ShapeHints {\n"); |
134 |
printf("\tvertexOrdering CLOCKWISE\n"); |
135 |
printf("\tfaceType UNKNOWN_FACE_TYPE\n"); |
136 |
printf("}\n"); |
137 |
138 |
if (i == argc) { /* load standard input */ |
139 |
if (mg_load(NULL) != MG_OK) |
140 |
exit(1); |
141 |
if (mg_nunknown) |
142 |
printf("## %s: %u unknown entities\n", |
143 |
argv[0], mg_nunknown); |
144 |
145 |
/* load MGF files */ |
146 |
for ( ; i < argc; i++) { |
147 |
printf("## %s %s ##############################\n", |
148 |
argv[0], argv[i]); |
149 |
mg_nunknown = 0; |
150 |
if (mg_load(argv[i]) != MG_OK) |
151 |
exit(1); |
152 |
if (mg_nunknown) |
153 |
printf("## %s %s: %u unknown entities\n", |
154 |
argv[0], argv[i], mg_nunknown); |
155 |
156 |
flush_cache(); /* flush face cache, just in case */ |
157 |
printf("}\n"); /* close root node */ |
158 |
exit(0); |
159 |
userr: |
160 |
fprintf(stderr, "%s: [-1|-2|-vrml] [file] ..\n", argv[0]); |
161 |
exit(1); |
162 |
163 |
164 |
165 |
void |
166 |
indent( /* indent in or out */ |
167 |
int deeper |
168 |
169 |
170 |
static int level; /* current nesting level */ |
171 |
register int i; |
172 |
register char *cp; |
173 |
174 |
if (deeper) level++; /* in or out? */ |
175 |
else if (level > 0) level--; |
176 |
/* compute actual shift */ |
177 |
if ((i = level) > MAXIND) i = MAXIND; |
178 |
cp = tabs; |
179 |
for (i *= SHIFTW; i >= TABSTOP; i -= TABSTOP) |
180 |
*cp++ = '\t'; |
181 |
while (i--) |
182 |
*cp++ = ' '; |
183 |
*cp = '\0'; |
184 |
185 |
186 |
187 |
int |
188 |
i_comment( /* transfer comment as is */ |
189 |
int ac, |
190 |
char **av |
191 |
192 |
193 |
fputs(tabs, stdout); |
194 |
putchar('#'); /* Inventor comment character */ |
195 |
while (--ac > 0) { |
196 |
putchar(' '); |
197 |
fputs(*++av, stdout); |
198 |
199 |
putchar('\n'); |
200 |
return(MG_OK); |
201 |
202 |
203 |
204 |
int |
205 |
i_object( /* group object name */ |
206 |
int ac, |
207 |
char **av |
208 |
209 |
210 |
static int objnest; |
211 |
212 |
flush_cache(); /* flush cached objects */ |
213 |
if (ac == 2) { /* start group */ |
214 |
printf("%sDEF %s Group {\n", tabs, to_id(av[1])); |
215 |
indent(1); |
216 |
objnest++; |
217 |
return(MG_OK); |
218 |
219 |
if (ac == 1) { /* end group */ |
220 |
if (--objnest < 0) |
221 |
return(MG_ECNTXT); |
222 |
indent(0); |
223 |
224 |
fputs("}\n", stdout); |
225 |
return(MG_OK); |
226 |
227 |
return(MG_EARGC); |
228 |
229 |
230 |
231 |
int |
232 |
i_xf( /* transform object(s) */ |
233 |
int ac, |
234 |
char **av |
235 |
236 |
237 |
static long xfid; |
238 |
register XF_SPEC *spec; |
239 |
240 |
241 |
if (ac == 1) { /* end of transform */ |
242 |
if ((spec = xf_context) == NULL) |
243 |
244 |
indent(0); /* close original segment */ |
245 |
printf("%s}\n", tabs); |
246 |
indent(0); |
247 |
248 |
if (spec->xarr != NULL) { /* check for iteration */ |
249 |
register struct xf_array *ap = spec->xarr; |
250 |
register int n; |
251 |
252 |
ap->aarg[ap->ndim-1].i = 1; /* iterate array */ |
253 |
for ( ; ; ) { |
254 |
n = ap->ndim-1; |
255 |
while (ap->aarg[n].i < ap->aarg[n].n) { |
256 |
sprintf(ap->aarg[n].arg, "%d", |
257 |
ap->aarg[n].i); |
258 |
printf("%sSeparator {\n", tabs); |
259 |
indent(1); |
260 |
(void)put_xform(spec); |
261 |
printf("%sUSE _xf%ld\n", tabs, |
262 |
spec->xid); |
263 |
indent(0); |
264 |
265 |
++ap->aarg[n].i; |
266 |
267 |
ap->aarg[n].i = 0; |
268 |
(void)strcpy(ap->aarg[n].arg, "0"); |
269 |
while (n-- && ++ap->aarg[n].i >= ap->aarg[n].n) { |
270 |
271 |
272 |
273 |
if (n < 0) |
274 |
break; |
275 |
sprintf(ap->aarg[n].arg, "%d", ap->aarg[n].i); |
276 |
277 |
278 |
/* pop transform */ |
279 |
xf_context = spec->prev; |
280 |
free_xf(spec); |
281 |
return(MG_OK); |
282 |
283 |
/* else allocate new transform */ |
284 |
if ((spec = new_xf(ac-1, av+1)) == NULL) |
285 |
return(MG_EMEM); |
286 |
spec->xid = ++xfid; /* assign unique ID */ |
287 |
spec->prev = xf_context; /* push onto stack */ |
288 |
xf_context = spec; |
289 |
/* translate xf specification */ |
290 |
291 |
indent(1); |
292 |
if (put_xform(spec) < 0) |
293 |
return(MG_ETYPE); |
294 |
printf("%sDEF _xf%ld Group {\n", tabs, spec->xid); /* begin */ |
295 |
indent(1); |
296 |
return(MG_OK); |
297 |
298 |
299 |
300 |
int |
301 |
put_xform( /* translate and print transform */ |
302 |
register XF_SPEC *spec |
303 |
304 |
305 |
register char **av; |
306 |
register int n; |
307 |
308 |
n = xf_ac(spec) - xf_ac(spec->prev); |
309 |
if (xf(&spec->xf, n, av=xf_av(spec)) != n) |
310 |
return(-1); |
311 |
printf("%sMatrixTransform {\n", tabs); |
312 |
indent(1); |
313 |
printf("%s# xf", tabs); /* put out original as comment */ |
314 |
while (n--) { |
315 |
putchar(' '); |
316 |
fputs(*av++, stdout); |
317 |
318 |
putchar('\n'); /* put out computed matrix */ |
319 |
printf("%smatrix %13.9g %13.9g %13.9g %13.9g\n", tabs, |
320 |
spec->xf.xfm[0][0], spec->xf.xfm[0][1], |
321 |
spec->xf.xfm[0][2], spec->xf.xfm[0][3]); |
322 |
for (n = 1; n < 4; n++) |
323 |
printf("%s %13.9g %13.9g %13.9g %13.9g\n", tabs, |
324 |
spec->xf.xfm[n][0], spec->xf.xfm[n][1], |
325 |
spec->xf.xfm[n][2], spec->xf.xfm[n][3]); |
326 |
indent(0); |
327 |
328 |
return(0); |
329 |
330 |
331 |
332 |
int |
333 |
put_material(void) /* put out current material */ |
334 |
335 |
char *mname = curmatname; |
336 |
float rgbval[3]; |
337 |
338 |
if (!c_cmaterial->clock) { /* current, just use it */ |
339 |
printf("%sUSE %s\n", tabs, mname); |
340 |
return(0); |
341 |
342 |
/* else update definition */ |
343 |
printf("%sDEF %s Group {\n", tabs, mname); |
344 |
indent(1); |
345 |
printf("%sMaterial {\n", tabs); |
346 |
indent(1); |
347 |
ccy2rgb(&c_cmaterial->rd_c, c_cmaterial->rd, rgbval); |
348 |
printf("%sambientColor %.4f %.4f %.4f\n", tabs, |
349 |
rgbval[0], rgbval[1], rgbval[2]); |
350 |
printf("%sdiffuseColor %.4f %.4f %.4f\n", tabs, |
351 |
352 |
if (c_cmaterial->rs > FTINY) { |
353 |
ccy2rgb(&c_cmaterial->rs_c, c_cmaterial->rs, rgbval); |
354 |
printf("%sspecularColor %.4f %.4f %.4f\n", tabs, |
355 |
356 |
printf("%sshininess %.3f\n", tabs, 1.-sqrt(c_cmaterial->rs_a)); |
357 |
358 |
if (c_cmaterial->ed > FTINY) { |
359 |
ccy2rgb(&c_cmaterial->ed_c, 1.0, rgbval); |
360 |
printf("%semissiveColor %.4f %.4f %.4f\n", tabs, |
361 |
362 |
363 |
if (c_cmaterial->ts > FTINY) |
364 |
printf("%stransparency %.4f\n", tabs, |
365 |
c_cmaterial->ts + c_cmaterial->td); |
366 |
indent(0); |
367 |
368 |
if (outtype != O_INV1) |
369 |
printf("%sShapeHints { shapeType %s faceType UNKNOWN_FACE_TYPE }\n", |
370 |
tabs, |
371 |
c_cmaterial->sided ? "SOLID" : "UNKNOWN_SHAPE_TYPE"); |
372 |
indent(0); |
373 |
374 |
c_cmaterial->clock = 0; |
375 |
return(0); |
376 |
377 |
378 |
379 |
int |
380 |
i_face( /* translate an N-sided face */ |
381 |
int ac, |
382 |
char **av |
383 |
384 |
385 |
static char lastmat[MAXID]; |
386 |
struct face *newf; |
387 |
register C_VERTEX *vp; |
388 |
register LUENT *lp; |
389 |
register int i; |
390 |
391 |
if (ac < 4) |
392 |
return(MG_EARGC); |
393 |
if ( strcmp(lastmat, curmatname) || c_cmaterial->clock || |
394 |
nverts == 0 || nverts+ac-1 >= MAXVERT) { |
395 |
flush_cache(); /* new cache */ |
396 |
lu_init(&vert_tab, MAXVERT); |
397 |
398 |
indent(1); |
399 |
if (put_material() < 0) /* put out material */ |
400 |
return(MG_EBADMAT); |
401 |
(void)strcpy(lastmat, curmatname); |
402 |
403 |
/* allocate new face */ |
404 |
if ((newf = newface(ac-1)) == NULL) |
405 |
return(MG_EMEM); |
406 |
newf->nv = ac-1; |
407 |
/* get vertex references */ |
408 |
for (i = 0; i < newf->nv; i++) { |
409 |
if ((vp = c_getvert(av[i+1])) == NULL) |
410 |
return(MG_EUNDEF); |
411 |
setvkey(vlist[nverts], vp); |
412 |
lp = lu_find(&vert_tab, vlist[nverts]); |
413 |
if (lp == NULL) |
414 |
return(MG_EMEM); |
415 |
if (lp->key == NULL) |
416 |
lp->key = (char *)vlist[nverts++]; |
417 |
newf->vl[i] = ((char (*)[VFLEN])lp->key - vlist); |
418 |
419 |
/* add to face list */ |
420 |
newf->next = NULL; |
421 |
if (flist == NULL) |
422 |
flist = newf; |
423 |
else |
424 |
flast->next = newf; |
425 |
flast = newf; |
426 |
return(MG_OK); /* we'll actually put it out later */ |
427 |
428 |
429 |
430 |
int |
431 |
i_sph( /* translate sphere description */ |
432 |
int ac, |
433 |
char **av |
434 |
435 |
436 |
register C_VERTEX *cent; |
437 |
438 |
if (ac != 3) |
439 |
return(MG_EARGC); |
440 |
flush_cache(); /* flush vertex cache */ |
441 |
442 |
indent(1); |
443 |
444 |
if (put_material() < 0) |
445 |
446 |
/* get center */ |
447 |
if ((cent = c_getvert(av[1])) == NULL) |
448 |
449 |
/* get radius */ |
450 |
if (!isflt(av[2])) |
451 |
return(MG_ETYPE); |
452 |
printf("%sTranslation { translation %13.9g %13.9g %13.9g }\n", tabs, |
453 |
cent->p[0], cent->p[1], cent->p[2]); |
454 |
printf("%sSphere { radius %s }\n", tabs, av[2]); |
455 |
indent(0); |
456 |
457 |
return(MG_OK); |
458 |
459 |
460 |
461 |
int |
462 |
i_cyl( /* translate a cylinder description */ |
463 |
int ac, |
464 |
char **av |
465 |
466 |
467 |
register C_VERTEX *v1, *v2; |
468 |
FVECT va; |
469 |
double length, angle; |
470 |
471 |
if (ac != 4) |
472 |
return(MG_EARGC); |
473 |
474 |
475 |
indent(1); |
476 |
477 |
478 |
479 |
/* get endpoints */ |
480 |
if (((v1 = c_getvert(av[1])) == NULL) | ((v2 = c_getvert(av[3])) == NULL)) |
481 |
482 |
/* get radius */ |
483 |
484 |
return(MG_ETYPE); |
485 |
/* compute transform */ |
486 |
va[0] = v2->p[0] - v1->p[0]; |
487 |
va[1] = v2->p[1] - v1->p[1]; |
488 |
va[2] = v2->p[2] - v1->p[2]; |
489 |
length = VLEN(va); |
490 |
angle = Acos(va[1]/length); |
491 |
492 |
.5*(v1->p[0]+v2->p[0]), .5*(v1->p[1]+v2->p[1]), |
493 |
.5*(v1->p[2]+v2->p[2])); |
494 |
printf("%sRotation { rotation %.9g %.9g %.9g %.9g }\n", tabs, |
495 |
va[2], 0., -va[0], angle); |
496 |
/* open-ended */ |
497 |
printf("%sCylinder { parts SIDES height %13.9g radius %s }\n", tabs, |
498 |
length, av[2]); |
499 |
indent(0); |
500 |
501 |
return(MG_OK); |
502 |
503 |
504 |
505 |
char * |
506 |
to_id( /* make sure a name is a valid Inventor ID */ |
507 |
register char *name |
508 |
509 |
510 |
static char id[MAXID]; |
511 |
512 |
513 |
for (cp = id; *name && cp < MAXID-1+id; name++) |
514 |
if (isalnum(*name) || *name == '_') |
515 |
*cp++ = *name; |
516 |
else |
517 |
*cp++ = '_'; |
518 |
*cp = '\0'; |
519 |
return(id); |
520 |
521 |
522 |
523 |
void |
524 |
flush_cache(void) /* put out cached faces */ |
525 |
526 |
int VFSEPPOS = strchr(vlist[0],'\n') - vlist[0]; |
527 |
int donorms = 0; |
528 |
register struct face *f; |
529 |
register int i; |
530 |
531 |
if (nverts == 0) |
532 |
return; |
533 |
/* put out coordinates */ |
534 |
printf("%sCoordinate3 {\n", tabs); |
535 |
indent(1); |
536 |
vlist[0][VFSEPPOS] = '\0'; |
537 |
printf("%spoint [ %s", tabs, vlist[0]); |
538 |
for (i = 1; i < nverts; i++) { |
539 |
vlist[i][VFSEPPOS] = '\0'; |
540 |
printf(",\n%s %s", tabs, vlist[i]); |
541 |
if (strcmp(VFSEPPOS+1+vlist[i], VZVECT)) |
542 |
donorms++; |
543 |
544 |
indent(0); |
545 |
printf(" ]\n%s}\n", tabs); |
546 |
if (donorms) { /* put out normals */ |
547 |
printf("%sNormal {\n", tabs); |
548 |
indent(1); |
549 |
printf("%svector [ %s", tabs, VFSEPPOS+1+vlist[0]); |
550 |
for (i = 1; i < nverts; i++) |
551 |
printf(",\n%s %s", tabs, VFSEPPOS+1+vlist[i]); |
552 |
indent(0); |
553 |
554 |
555 |
/* put out faces */ |
556 |
printf("%sIndexedFaceSet {\n", tabs); |
557 |
indent(1); |
558 |
f = flist; /* coordinate indices */ |
559 |
printf("%scoordIndex [ %d", tabs, f->vl[0]); |
560 |
for (i = 1; i < f->nv; i++) |
561 |
printf(", %d", f->vl[i]); |
562 |
for (f = f->next; f != NULL; f = f->next) { |
563 |
printf(", -1,\n%s %d", tabs, f->vl[0]); |
564 |
565 |
566 |
567 |
printf(" ]\n"); |
568 |
if (donorms) { |
569 |
f = flist; /* normal indices */ |
570 |
printf("%snormalIndex [ %d", tabs, f->vl[0]); |
571 |
572 |
573 |
574 |
575 |
576 |
577 |
578 |
printf(" ]\n"); |
579 |
580 |
indent(0); /* close IndexedFaceSet */ |
581 |
582 |
indent(0); /* close face group */ |
583 |
584 |
while ((f = flist) != NULL) { /* free face list */ |
585 |
flist = f->next; |
586 |
freeface(f); |
587 |
588 |
lu_done(&vert_tab); /* clear lookup table */ |
589 |
nverts = 0; |
590 |
