root/radiance/ray/src/cv/lampcolor.c
Revision: 2.10
Committed: Thu Mar 18 05:22:00 2004 UTC (19 years, 8 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
Fixed bug caused by substituting fgets() for gets() -- now calls fgetline()
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.10 static const char RCSid[] = "$Id: lampcolor.c,v 2.9 2003/11/15 17:54:06 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5 greg 1.2 * Program to convert lamp color from table and compute radiance.
6 greg 1.1 */
7
8     #include <stdio.h>
9 schorsch 2.7 #include <string.h>
10 greg 2.4 #include <math.h>
11
12 schorsch 2.9 #include "rtmath.h"
13     #include "rtio.h"
14 greg 1.8 #include "color.h"
15 greg 1.2
16     /* lamp parameters */
17     #define LTYPE 0
18     #define LUNIT 1
19     #define LGEOM 2
20     #define LOUTP 3
21     #define NPARAMS 4
22 greg 1.1
23 schorsch 2.7 static int typecheck(char *s);
24     static int unitcheck(char *s);
25     static int geomcheck(char *s);
26     static int outpcheck(char *s);
27     static void compute(void);
28     static int getpolygon(void), getsphere(void), getcylinder(void), getring(void);
29 schorsch 2.9 static int getd(char *name, double *dp, char *help);
30 schorsch 2.7
31 greg 1.2
32     float *lampcolor; /* the lamp color (RGB) */
33     double unit2meter; /* conversion from units to meters */
34 greg 1.7 double area; /* radiating area for this geometry */
35 greg 1.2 double lumens; /* total lamp lumens */
36
37     struct {
38     char *name;
39     char value[64];
40     int (*check)();
41     char *help;
42     } param[NPARAMS] = {
43 saba 2.5 { "lamp type", "WHITE", typecheck,
44 greg 1.2 "The lamp type is a string which corresponds to one of the types registered\n\
45 saba 2.5 in the lamp table file. A value of \"WHITE\" means an uncolored source,\n\
46 greg 1.2 which may be preferable because it results in a color balanced image." },
47     { "length unit", "meter", unitcheck,
48     "Unit must be one of: \"meter\", \"centimeter\", \"foot\", or \"inch\".\n\
49     These may be abbreviated as a single letter." },
50     { "lamp geometry", "polygon", geomcheck,
51     "The lamp geometry must be one of: \"polygon\", \"sphere\", \"cylinder\"\n\
52     or \"ring\". These may be abbreviated as a single letter." },
53     { "total lamp lumens", "0", outpcheck,
54     "This is the overall light output of the lamp and its fixture. If you do\n\
55     not know this value explicitly, you can compute the approximate lumens\n\
56 greg 1.3 by multiplying the input wattage by 14 for incandescent fixtures or 70\n\
57 greg 1.2 for fluorescent fixtures." },
58     };
59
60
61 schorsch 2.9 int
62     main(
63     int argc,
64     char *argv[]
65     )
66 greg 1.1 {
67     char *lamptab = "lamp.tab";
68 greg 1.2 char buf[64];
69     int i;
70 greg 1.1
71     if (argc > 1) lamptab = argv[1];
72     if (loadlamps(lamptab) == 0) {
73 greg 1.2 fprintf(stderr, "%s: no such lamp table\n", lamptab);
74 greg 1.1 exit(1);
75     }
76 greg 1.2 printf("Program to compute lamp radiance. Enter '?' for help.\n");
77 greg 1.1 for ( ; ; ) {
78 greg 1.2 i = 0;
79     while (i < NPARAMS) {
80     printf("Enter %s [%s]: ", param[i].name,
81     param[i].value);
82 greg 2.10 if (fgetline(buf, sizeof(buf), stdin) == NULL)
83 greg 1.2 exit(0);
84     if (buf[0] == '?') {
85     puts(param[i].help);
86     continue;
87     }
88     if (buf[0])
89     strcpy(param[i].value, buf);
90     if (!(*param[i].check)(param[i].value)) {
91     fprintf(stderr, "%s: bad value for %s\n",
92     param[i].value, param[i].name);
93     continue;
94     }
95     i++;
96     }
97     compute();
98 greg 1.1 }
99 greg 1.2 }
100
101
102 schorsch 2.7 static int
103     typecheck( /* check lamp type */
104 schorsch 2.9 char *s
105 schorsch 2.7 )
106 greg 1.2 {
107     lampcolor = matchlamp(s);
108     return(lampcolor != NULL);
109     }
110
111
112 schorsch 2.7 static int
113     unitcheck( /* compute conversion to meters */
114 schorsch 2.9 char *s
115 schorsch 2.7 )
116 greg 1.2 {
117     int len = strlen(s);
118
119     switch (*s) {
120     case 'm':
121     if (strncmp(s, "meters", len))
122     return(0);
123     unit2meter = 1.0;
124     return(1);
125     case 'c':
126     if (strncmp(s, "centimeters", len) && strncmp(s, "cms", len))
127     return(0);
128     unit2meter = 0.01;
129     return(1);
130     case 'f':
131     if (strncmp(s, "foot", len) && strncmp(s, "feet", len))
132     return(0);
133     unit2meter = 0.3048;
134     return(1);
135     case 'i':
136     if (strncmp(s, "inches", len))
137     return(0);
138     unit2meter = 0.0254;
139     return(1);
140     }
141     return(0);
142     }
143
144
145 schorsch 2.7 static int
146     geomcheck( /* check/set lamp geometry */
147 schorsch 2.9 char *s
148 schorsch 2.7 )
149 greg 1.2 {
150     int len = strlen(s);
151
152     switch (*s) {
153     case 'p':
154     if (strncmp(s, "polygonal", len))
155     return(0);
156     return(getpolygon());
157     case 's':
158     if (strncmp(s, "sphere", len) && strncmp(s, "spherical", len))
159     return(0);
160     return(getsphere());
161     case 'c':
162     if (strncmp(s,"cylinder",len) && strncmp(s,"cylindrical",len))
163     return(0);
164     return(getcylinder());
165     case 'r':
166     if (strncmp(s, "ring", len) && strncmp(s, "disk", len))
167     return(0);
168     return(getring());
169     }
170     return(0);
171     }
172
173
174 schorsch 2.7 static int
175     outpcheck( /* check lumen output value */
176 schorsch 2.9 register char *s
177 schorsch 2.7 )
178 greg 1.2 {
179     if ((*s < '0' || *s > '9') && *s != '.')
180     return(0);
181     lumens = atof(s);
182     return(1);
183     }
184
185
186 schorsch 2.7 static void
187     compute(void) /* compute lamp radiance */
188 greg 1.2 {
189     double whiteval;
190
191 greg 1.8 whiteval = lumens/area/(WHTEFFICACY*PI);
192 greg 1.2
193     printf("Lamp color (RGB) = %f %f %f\n",
194     lampcolor[0]*whiteval,
195     lampcolor[1]*whiteval,
196     lampcolor[2]*whiteval);
197     }
198
199
200 schorsch 2.9 static int
201     getd( /* get a positive double from stdin */
202     char *name,
203     double *dp,
204     char *help
205     )
206 greg 1.2 {
207     char buf[32];
208 greg 1.6 again:
209     printf("%s [%g]: ", name, *dp);
210 schorsch 2.9 if (fgets(buf, sizeof(buf), stdin) == NULL)
211 greg 1.2 return(0);
212 greg 1.6 if (buf[0] == '?') {
213     puts(help);
214     goto again;
215     }
216 greg 1.2 if ((buf[0] < '0' || buf[0] > '9') && buf[0] != '.')
217     return(0);
218     *dp = atof(buf);
219     return(1);
220     }
221
222
223 schorsch 2.7 static int
224     getpolygon(void) /* get projected area for a polygon */
225 greg 1.2 {
226 greg 1.9 static double parea = 1.0;
227 greg 1.5
228 greg 1.9 getd("Polygon area", &parea,
229 greg 1.6 "Enter the total radiating area of the polygon.");
230 greg 1.9 area = unit2meter*unit2meter * parea;
231 greg 1.2 return(1);
232     }
233
234
235 schorsch 2.7 static int
236     getsphere(void) /* get projected area for a sphere */
237 greg 1.2 {
238 greg 1.5 static double radius = 1.0;
239 greg 1.2
240 greg 1.6 getd("Sphere radius", &radius,
241     "Enter the distance from the sphere's center to its surface.");
242 greg 1.7 area = 4.*PI*unit2meter*unit2meter * radius*radius;
243 greg 1.2 return(1);
244     }
245
246
247 schorsch 2.7 static int
248     getcylinder(void) /* get projected area for a cylinder */
249 greg 1.2 {
250 greg 1.5 static double length = 1.0, radius = 0.1;
251 greg 1.2
252 greg 1.6 getd("Cylinder length", &length,
253     "Enter the length of the cylinder.");
254     getd("Cylinder radius", &radius,
255     "Enter the distance from the cylinder's axis to its surface.");
256 greg 1.7 area = 2.*PI*unit2meter*unit2meter * radius*length;
257 greg 1.2 return(1);
258     }
259
260
261 schorsch 2.7 static int
262     getring(void) /* get projected area for a ring */
263 greg 1.2 {
264 greg 1.5 static double radius = 1.0;
265 greg 1.2
266 greg 1.6 getd("Disk radius", &radius,
267     "Enter the distance from the ring's center to its outer edge.\n\
268     The inner radius must be zero.");
269 greg 1.7 area = PI*unit2meter*unit2meter * radius*radius;
270 greg 1.2 return(1);
271 greg 1.1 }
