root/radiance/ray/src/cv/lampcolor.c
Revision: 2.6
Committed: Sat Feb 22 02:07:23 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.5: +1 -4 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.6 static const char RCSid[] = "$Id$";
3 greg 1.1 #endif
4     /*
5 greg 1.2 * Program to convert lamp color from table and compute radiance.
6 greg 1.1 */
7
8     #include <stdio.h>
9
10 greg 2.4 #include <math.h>
11
12 greg 1.8 #include "color.h"
13
14 greg 1.2 #define PI 3.14159265358979323846
15
16     extern char *gets(), *strcpy();
17 greg 1.1 extern float *matchlamp();
18
19 greg 1.2 /* lamp parameters */
20     #define LTYPE 0
21     #define LUNIT 1
22     #define LGEOM 2
23     #define LOUTP 3
24     #define NPARAMS 4
25 greg 1.1
26 greg 1.2 int typecheck(), unitcheck(), geomcheck(), outpcheck();
27
28     float *lampcolor; /* the lamp color (RGB) */
29     double unit2meter; /* conversion from units to meters */
30 greg 1.7 double area; /* radiating area for this geometry */
31 greg 1.2 double lumens; /* total lamp lumens */
32
33     struct {
34     char *name;
35     char value[64];
36     int (*check)();
37     char *help;
38     } param[NPARAMS] = {
39 saba 2.5 { "lamp type", "WHITE", typecheck,
40 greg 1.2 "The lamp type is a string which corresponds to one of the types registered\n\
41 saba 2.5 in the lamp table file. A value of \"WHITE\" means an uncolored source,\n\
42 greg 1.2 which may be preferable because it results in a color balanced image." },
43     { "length unit", "meter", unitcheck,
44     "Unit must be one of: \"meter\", \"centimeter\", \"foot\", or \"inch\".\n\
45     These may be abbreviated as a single letter." },
46     { "lamp geometry", "polygon", geomcheck,
47     "The lamp geometry must be one of: \"polygon\", \"sphere\", \"cylinder\"\n\
48     or \"ring\". These may be abbreviated as a single letter." },
49     { "total lamp lumens", "0", outpcheck,
50     "This is the overall light output of the lamp and its fixture. If you do\n\
51     not know this value explicitly, you can compute the approximate lumens\n\
52 greg 1.3 by multiplying the input wattage by 14 for incandescent fixtures or 70\n\
53 greg 1.2 for fluorescent fixtures." },
54     };
55
56
57 greg 1.1 main(argc, argv)
58     int argc;
59     char *argv[];
60     {
61     char *lamptab = "lamp.tab";
62 greg 1.2 char buf[64];
63     int i;
64 greg 1.1
65     if (argc > 1) lamptab = argv[1];
66     if (loadlamps(lamptab) == 0) {
67 greg 1.2 fprintf(stderr, "%s: no such lamp table\n", lamptab);
68 greg 1.1 exit(1);
69     }
70 greg 1.2 printf("Program to compute lamp radiance. Enter '?' for help.\n");
71 greg 1.1 for ( ; ; ) {
72 greg 1.2 i = 0;
73     while (i < NPARAMS) {
74     printf("Enter %s [%s]: ", param[i].name,
75     param[i].value);
76     if (gets(buf) == NULL)
77     exit(0);
78     if (buf[0] == '?') {
79     puts(param[i].help);
80     continue;
81     }
82     if (buf[0])
83     strcpy(param[i].value, buf);
84     if (!(*param[i].check)(param[i].value)) {
85     fprintf(stderr, "%s: bad value for %s\n",
86     param[i].value, param[i].name);
87     continue;
88     }
89     i++;
90     }
91     compute();
92 greg 1.1 }
93 greg 1.2 }
94
95
96     typecheck(s) /* check lamp type */
97     char *s;
98     {
99     lampcolor = matchlamp(s);
100     return(lampcolor != NULL);
101     }
102
103
104     unitcheck(s) /* compute conversion to meters */
105     char *s;
106     {
107     int len = strlen(s);
108
109     switch (*s) {
110     case 'm':
111     if (strncmp(s, "meters", len))
112     return(0);
113     unit2meter = 1.0;
114     return(1);
115     case 'c':
116     if (strncmp(s, "centimeters", len) && strncmp(s, "cms", len))
117     return(0);
118     unit2meter = 0.01;
119     return(1);
120     case 'f':
121     if (strncmp(s, "foot", len) && strncmp(s, "feet", len))
122     return(0);
123     unit2meter = 0.3048;
124     return(1);
125     case 'i':
126     if (strncmp(s, "inches", len))
127     return(0);
128     unit2meter = 0.0254;
129     return(1);
130     }
131     return(0);
132     }
133
134
135     geomcheck(s) /* check/set lamp geometry */
136     char *s;
137     {
138     int len = strlen(s);
139
140     switch (*s) {
141     case 'p':
142     if (strncmp(s, "polygonal", len))
143     return(0);
144     return(getpolygon());
145     case 's':
146     if (strncmp(s, "sphere", len) && strncmp(s, "spherical", len))
147     return(0);
148     return(getsphere());
149     case 'c':
150     if (strncmp(s,"cylinder",len) && strncmp(s,"cylindrical",len))
151     return(0);
152     return(getcylinder());
153     case 'r':
154     if (strncmp(s, "ring", len) && strncmp(s, "disk", len))
155     return(0);
156     return(getring());
157     }
158     return(0);
159     }
160
161
162     outpcheck(s) /* check lumen output value */
163     register char *s;
164     {
165     if ((*s < '0' || *s > '9') && *s != '.')
166     return(0);
167     lumens = atof(s);
168     return(1);
169     }
170
171
172     compute() /* compute lamp radiance */
173     {
174     double whiteval;
175
176 greg 1.8 whiteval = lumens/area/(WHTEFFICACY*PI);
177 greg 1.2
178     printf("Lamp color (RGB) = %f %f %f\n",
179     lampcolor[0]*whiteval,
180     lampcolor[1]*whiteval,
181     lampcolor[2]*whiteval);
182     }
183
184
185 greg 1.6 getd(name, dp, help) /* get a positive double from stdin */
186     char *name;
187 greg 1.2 double *dp;
188 greg 1.6 char *help;
189 greg 1.2 {
190     char buf[32];
191 greg 1.6 again:
192     printf("%s [%g]: ", name, *dp);
193 greg 1.2 if (gets(buf) == NULL)
194     return(0);
195 greg 1.6 if (buf[0] == '?') {
196     puts(help);
197     goto again;
198     }
199 greg 1.2 if ((buf[0] < '0' || buf[0] > '9') && buf[0] != '.')
200     return(0);
201     *dp = atof(buf);
202     return(1);
203     }
204
205
206     getpolygon() /* get projected area for a polygon */
207     {
208 greg 1.9 static double parea = 1.0;
209 greg 1.5
210 greg 1.9 getd("Polygon area", &parea,
211 greg 1.6 "Enter the total radiating area of the polygon.");
212 greg 1.9 area = unit2meter*unit2meter * parea;
213 greg 1.2 return(1);
214     }
215
216
217     getsphere() /* get projected area for a sphere */
218     {
219 greg 1.5 static double radius = 1.0;
220 greg 1.2
221 greg 1.6 getd("Sphere radius", &radius,
222     "Enter the distance from the sphere's center to its surface.");
223 greg 1.7 area = 4.*PI*unit2meter*unit2meter * radius*radius;
224 greg 1.2 return(1);
225     }
226
227
228     getcylinder() /* get projected area for a cylinder */
229     {
230 greg 1.5 static double length = 1.0, radius = 0.1;
231 greg 1.2
232 greg 1.6 getd("Cylinder length", &length,
233     "Enter the length of the cylinder.");
234     getd("Cylinder radius", &radius,
235     "Enter the distance from the cylinder's axis to its surface.");
236 greg 1.7 area = 2.*PI*unit2meter*unit2meter * radius*length;
237 greg 1.2 return(1);
238     }
239
240
241     getring() /* get projected area for a ring */
242     {
243 greg 1.5 static double radius = 1.0;
244 greg 1.2
245 greg 1.6 getd("Disk radius", &radius,
246     "Enter the distance from the ring's center to its outer edge.\n\
247     The inner radius must be zero.");
248 greg 1.7 area = PI*unit2meter*unit2meter * radius*radius;
249 greg 1.2 return(1);
250 greg 1.1 }
