root/radiance/ray/src/cv/lampcolor.c
Revision: 2.6
Committed: Sat Feb 22 02:07:23 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.5: +1 -4 lines
5 * Program to convert lamp color from table and compute radiance.
6 */
7
8 #include <stdio.h>
9
10 #include <math.h>
11
12 #include "color.h"
13
14 #define PI 3.14159265358979323846
15
16 extern char *gets(), *strcpy();
17 extern float *matchlamp();
18
19 /* lamp parameters */
20 #define LTYPE 0
21 #define LUNIT 1
22 #define LGEOM 2
23 #define LOUTP 3
24 #define NPARAMS 4
25
26 int typecheck(), unitcheck(), geomcheck(), outpcheck();
27
28 float *lampcolor; /* the lamp color (RGB) */
29 double unit2meter; /* conversion from units to meters */
30 double area; /* radiating area for this geometry */
31 double lumens; /* total lamp lumens */
32
33 struct {
34 char *name;
35 char value[64];
36 int (*check)();
37 char *help;
38 } param[NPARAMS] = {
39 { "lamp type", "WHITE", typecheck,
40 "The lamp type is a string which corresponds to one of the types registered\n\
41 in the lamp table file. A value of \"WHITE\" means an uncolored source,\n\
42 which may be preferable because it results in a color balanced image." },
43 { "length unit", "meter", unitcheck,
44 "Unit must be one of: \"meter\", \"centimeter\", \"foot\", or \"inch\".\n\
45 These may be abbreviated as a single letter." },
46 { "lamp geometry", "polygon", geomcheck,
47 "The lamp geometry must be one of: \"polygon\", \"sphere\", \"cylinder\"\n\
48 or \"ring\". These may be abbreviated as a single letter." },
49 { "total lamp lumens", "0", outpcheck,
50 "This is the overall light output of the lamp and its fixture. If you do\n\
51 not know this value explicitly, you can compute the approximate lumens\n\
52 by multiplying the input wattage by 14 for incandescent fixtures or 70\n\
53 for fluorescent fixtures." },
54 };
55
56
57 main(argc, argv)
58 int argc;
59 char *argv[];
60 {
61 char *lamptab = "lamp.tab";
62 char buf[64];
63 int i;
64
65 if (argc > 1) lamptab = argv[1];
66 if (loadlamps(lamptab) == 0) {
67 fprintf(stderr, "%s: no such lamp table\n", lamptab);
68 exit(1);
69 }
70 printf("Program to compute lamp radiance. Enter '?' for help.\n");
71 for ( ; ; ) {
72 i = 0;
73 while (i < NPARAMS) {
74 printf("Enter %s [%s]: ", param[i].name,
75 param[i].value);
76 if (gets(buf) == NULL)
77 exit(0);
78 if (buf[0] == '?') {
79 puts(param[i].help);
80 continue;
81 }
82 if (buf[0])
83 strcpy(param[i].value, buf);
84 if (!(*param[i].check)(param[i].value)) {
85 fprintf(stderr, "%s: bad value for %s\n",
86 param[i].value, param[i].name);
87 continue;
88 }
89 i++;
90 }
91 compute();
92 }
93 }
94
95
96 typecheck(s) /* check lamp type */
97 char *s;
98 {
99 lampcolor = matchlamp(s);
100 return(lampcolor != NULL);
101 }
102
103
104 unitcheck(s) /* compute conversion to meters */
105 char *s;
106 {
107 int len = strlen(s);
108
109 switch (*s) {
110 case 'm':
111 if (strncmp(s, "meters", len))
112 return(0);
113 unit2meter = 1.0;
114 return(1);
115 case 'c':
116 if (strncmp(s, "centimeters", len) && strncmp(s, "cms", len))
117 return(0);
118 unit2meter = 0.01;
119 return(1);
120 case 'f':
121 if (strncmp(s, "foot", len) && strncmp(s, "feet", len))
122 return(0);
123 unit2meter = 0.3048;
124 return(1);
125 case 'i':
126 if (strncmp(s, "inches", len))
127 return(0);
128 unit2meter = 0.0254;
129 return(1);
130 }
131 return(0);
132 }
133
134
135 geomcheck(s) /* check/set lamp geometry */
136 char *s;
137 {
138 int len = strlen(s);
139
140 switch (*s) {
141 case 'p':
142 if (strncmp(s, "polygonal", len))
143 return(0);
144 return(getpolygon());
145 case 's':
146 if (strncmp(s, "sphere", len) && strncmp(s, "spherical", len))
147 return(0);
148 return(getsphere());
149 case 'c':
150 if (strncmp(s,"cylinder",len) && strncmp(s,"cylindrical",len))
151 return(0);
152 return(getcylinder());
153 case 'r':
154 if (strncmp(s, "ring", len) && strncmp(s, "disk", len))
155 return(0);
156 return(getring());
157 }
158 return(0);
159 }
160
161
162 outpcheck(s) /* check lumen output value */
163 register char *s;
164 {
165 if ((*s < '0' || *s > '9') && *s != '.')
166 return(0);
167 lumens = atof(s);
168 return(1);
169 }
170
171
172 compute() /* compute lamp radiance */
173 {
174 double whiteval;
175
176 whiteval = lumens/area/(WHTEFFICACY*PI);
177
178 printf("Lamp color (RGB) = %f %f %f\n",
179 lampcolor[0]*whiteval,
180 lampcolor[1]*whiteval,
181 lampcolor[2]*whiteval);
182 }
183
184
185 getd(name, dp, help) /* get a positive double from stdin */
186 char *name;
187 double *dp;
188 char *help;
189 {
190 char buf[32];
191 again:
192 printf("%s [%g]: ", name, *dp);
193 if (gets(buf) == NULL)
194 return(0);
195 if (buf[0] == '?') {
196 puts(help);
197 goto again;
198 }
199 if ((buf[0] < '0' || buf[0] > '9') && buf[0] != '.')
200 return(0);
201 *dp = atof(buf);
202 return(1);
203 }
204
205
206 getpolygon() /* get projected area for a polygon */
207 {
208 static double parea = 1.0;
209
210 getd("Polygon area", &parea,
211 "Enter the total radiating area of the polygon.");
212 area = unit2meter*unit2meter * parea;
213 return(1);
214 }
215
216
217 getsphere() /* get projected area for a sphere */
218 {
219 static double radius = 1.0;
220
221 getd("Sphere radius", &radius,
222 "Enter the distance from the sphere's center to its surface.");
223 area = 4.*PI*unit2meter*unit2meter * radius*radius;
224 return(1);
225 }
226
227
228 getcylinder() /* get projected area for a cylinder */
229 {
230 static double length = 1.0, radius = 0.1;
231
232 getd("Cylinder length", &length,
233 "Enter the length of the cylinder.");
234 getd("Cylinder radius", &radius,
235 "Enter the distance from the cylinder's axis to its surface.");
236 area = 2.*PI*unit2meter*unit2meter * radius*length;
237 return(1);
238 }
239
240
241 getring() /* get projected area for a ring */
242 {
243 static double radius = 1.0;
244
245 getd("Disk radius", &radius,
246 "Enter the distance from the ring's center to its outer edge.\n\
247 The inner radius must be zero.");
248 area = PI*unit2meter*unit2meter * radius*radius;
249 return(1);
250 }
